RTEMS 6.1-rc1
Test context for spec:/rtems/clock/req/get-uptime test case. More...
rtems_status_code status
struct timespec * uptime
struct timespec uptime_value
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsClockReqGetUptime_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
