RTEMS 6.1-rc1
Test context for spec:/dev/grlib/req/apbuart-inbyte-nonblocking test case. More...
apbuart regs
 This member provides the APBUART register block.
int result
 This member contains the return value of the apbuart_inbyte_nonblocking() call.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   DevGrlibReqApbuartInbyteNonblocking_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
