RTEMS 6.1-rc1
Test context for spec:/acfg/val/fatal-init-task-construct-failed test case. More...
Data Fields | |
rtems_fatal_source | source |
This member contains a copy of the corresponding AcfgValFatalInitTaskConstructFailed_Run() parameter. | |
rtems_fatal_code | code |
