RTEMS 6.1-rc1
Data Fields | |
volatile ALT_I2C_CON_t | ic_con |
volatile ALT_I2C_TAR_t | ic_tar |
volatile ALT_I2C_SAR_t | ic_sar |
volatile uint32_t | _pad_0xc_0xf |
volatile ALT_I2C_DATA_CMD_t | ic_data_cmd |
volatile ALT_I2C_SS_SCL_HCNT_t | ic_ss_scl_hcnt |
volatile ALT_I2C_SS_SCL_LCNT_t | ic_ss_scl_lcnt |
volatile ALT_I2C_FS_SCL_HCNT_t | ic_fs_scl_hcnt |
volatile ALT_I2C_FS_SCL_LCNT_t | ic_fs_scl_lcnt |
volatile uint32_t | _pad_0x24_0x2b [2] |
volatile ALT_I2C_INTR_STAT_t | ic_intr_stat |
volatile ALT_I2C_INTR_MSK_t | ic_intr_mask |
volatile ALT_I2C_RAW_INTR_STAT_t | ic_raw_intr_stat |
volatile ALT_I2C_RX_TL_t | ic_rx_tl |
volatile ALT_I2C_TX_TL_t | ic_tx_tl |
volatile ALT_I2C_CLR_INTR_t | ic_clr_intr |
volatile ALT_I2C_CLR_RX_UNDER_t | ic_clr_rx_under |
volatile ALT_I2C_CLR_RX_OVER_t | ic_clr_rx_over |
volatile ALT_I2C_CLR_TX_OVER_t | ic_clr_tx_over |
volatile ALT_I2C_CLR_RD_REQ_t | ic_clr_rd_req |
volatile ALT_I2C_CLR_TX_ABRT_t | ic_clr_tx_abrt |
volatile ALT_I2C_CLR_RX_DONE_t | ic_clr_rx_done |
volatile ALT_I2C_CLR_ACTIVITY_t | ic_clr_activity |
volatile ALT_I2C_CLR_STOP_DET_t | ic_clr_stop_det |
volatile ALT_I2C_CLR_START_DET_t | ic_clr_start_det |
volatile ALT_I2C_CLR_GEN_CALL_t | ic_clr_gen_call |
volatile ALT_I2C_EN_t | ic_enable |
volatile ALT_I2C_STAT_t | ic_status |
volatile ALT_I2C_TXFLR_t | ic_txflr |
volatile ALT_I2C_RXFLR_t | ic_rxflr |
volatile ALT_I2C_SDA_HOLD_t | ic_sda_hold |
volatile ALT_I2C_TX_ABRT_SRC_t | ic_tx_abrt_source |
volatile ALT_I2C_SLV_DATA_NACK_ONLY_t | ic_slv_data_nack_only |
volatile ALT_I2C_DMA_CR_t | ic_dma_cr |
volatile ALT_I2C_DMA_TDLR_t | ic_dma_tdlr |
volatile ALT_I2C_DMA_RDLR_t | ic_dma_rdlr |
volatile ALT_I2C_SDA_SETUP_t | ic_sda_setup |
volatile ALT_I2C_ACK_GENERAL_CALL_t | ic_ack_general_call |
volatile ALT_I2C_EN_STAT_t | ic_enable_status |
volatile ALT_I2C_FS_SPKLEN_t | ic_fs_spklen |
volatile uint32_t | _pad_0xa4_0xf3 [20] |
volatile ALT_I2C_COMP_PARAM_1_t | ic_comp_param_1 |
volatile ALT_I2C_COMP_VER_t | ic_comp_version |
volatile ALT_I2C_COMP_TYPE_t | ic_comp_type |
