39#ifndef __ALTERA_ALT_I2C_H__
40#define __ALTERA_ALT_I2C_H__
97#define ALT_I2C_CON_MST_MOD_E_DIS 0x0
103#define ALT_I2C_CON_MST_MOD_E_EN 0x1
106#define ALT_I2C_CON_MST_MOD_LSB 0
108#define ALT_I2C_CON_MST_MOD_MSB 0
110#define ALT_I2C_CON_MST_MOD_WIDTH 1
112#define ALT_I2C_CON_MST_MOD_SET_MSK 0x00000001
114#define ALT_I2C_CON_MST_MOD_CLR_MSK 0xfffffffe
116#define ALT_I2C_CON_MST_MOD_RESET 0x1
118#define ALT_I2C_CON_MST_MOD_GET(value) (((value) & 0x00000001) >> 0)
120#define ALT_I2C_CON_MST_MOD_SET(value) (((value) << 0) & 0x00000001)
145#define ALT_I2C_CON_SPEED_E_STANDARD 0x1
151#define ALT_I2C_CON_SPEED_E_FAST 0x2
154#define ALT_I2C_CON_SPEED_LSB 1
156#define ALT_I2C_CON_SPEED_MSB 2
158#define ALT_I2C_CON_SPEED_WIDTH 2
160#define ALT_I2C_CON_SPEED_SET_MSK 0x00000006
162#define ALT_I2C_CON_SPEED_CLR_MSK 0xfffffff9
164#define ALT_I2C_CON_SPEED_RESET 0x2
166#define ALT_I2C_CON_SPEED_GET(value) (((value) & 0x00000006) >> 1)
168#define ALT_I2C_CON_SPEED_SET(value) (((value) << 1) & 0x00000006)
193#define ALT_I2C_CON_IC_10BITADDR_SLV_E_SLVADDR7BIT 0x0
199#define ALT_I2C_CON_IC_10BITADDR_SLV_E_SLVADDR10BIT 0x1
202#define ALT_I2C_CON_IC_10BITADDR_SLV_LSB 3
204#define ALT_I2C_CON_IC_10BITADDR_SLV_MSB 3
206#define ALT_I2C_CON_IC_10BITADDR_SLV_WIDTH 1
208#define ALT_I2C_CON_IC_10BITADDR_SLV_SET_MSK 0x00000008
210#define ALT_I2C_CON_IC_10BITADDR_SLV_CLR_MSK 0xfffffff7
212#define ALT_I2C_CON_IC_10BITADDR_SLV_RESET 0x1
214#define ALT_I2C_CON_IC_10BITADDR_SLV_GET(value) (((value) & 0x00000008) >> 3)
216#define ALT_I2C_CON_IC_10BITADDR_SLV_SET(value) (((value) << 3) & 0x00000008)
239#define ALT_I2C_CON_IC_10BITADDR_MST_E_MSTADDR7BIT 0x0
245#define ALT_I2C_CON_IC_10BITADDR_MST_E_MSTADDR10BIT 0x1
248#define ALT_I2C_CON_IC_10BITADDR_MST_LSB 4
250#define ALT_I2C_CON_IC_10BITADDR_MST_MSB 4
252#define ALT_I2C_CON_IC_10BITADDR_MST_WIDTH 1
254#define ALT_I2C_CON_IC_10BITADDR_MST_SET_MSK 0x00000010
256#define ALT_I2C_CON_IC_10BITADDR_MST_CLR_MSK 0xffffffef
258#define ALT_I2C_CON_IC_10BITADDR_MST_RESET 0x1
260#define ALT_I2C_CON_IC_10BITADDR_MST_GET(value) (((value) & 0x00000010) >> 4)
262#define ALT_I2C_CON_IC_10BITADDR_MST_SET(value) (((value) << 4) & 0x00000010)
304#define ALT_I2C_CON_IC_RESTART_EN_E_DIS 0x0
310#define ALT_I2C_CON_IC_RESTART_EN_E_EN 0x1
313#define ALT_I2C_CON_IC_RESTART_EN_LSB 5
315#define ALT_I2C_CON_IC_RESTART_EN_MSB 5
317#define ALT_I2C_CON_IC_RESTART_EN_WIDTH 1
319#define ALT_I2C_CON_IC_RESTART_EN_SET_MSK 0x00000020
321#define ALT_I2C_CON_IC_RESTART_EN_CLR_MSK 0xffffffdf
323#define ALT_I2C_CON_IC_RESTART_EN_RESET 0x1
325#define ALT_I2C_CON_IC_RESTART_EN_GET(value) (((value) & 0x00000020) >> 5)
327#define ALT_I2C_CON_IC_RESTART_EN_SET(value) (((value) << 5) & 0x00000020)
353#define ALT_I2C_CON_IC_SLV_DIS_E_DIS 0x1
359#define ALT_I2C_CON_IC_SLV_DIS_E_EN 0x0
362#define ALT_I2C_CON_IC_SLV_DIS_LSB 6
364#define ALT_I2C_CON_IC_SLV_DIS_MSB 6
366#define ALT_I2C_CON_IC_SLV_DIS_WIDTH 1
368#define ALT_I2C_CON_IC_SLV_DIS_SET_MSK 0x00000040
370#define ALT_I2C_CON_IC_SLV_DIS_CLR_MSK 0xffffffbf
372#define ALT_I2C_CON_IC_SLV_DIS_RESET 0x1
374#define ALT_I2C_CON_IC_SLV_DIS_GET(value) (((value) & 0x00000040) >> 6)
376#define ALT_I2C_CON_IC_SLV_DIS_SET(value) (((value) << 6) & 0x00000040)
391 uint32_t master_mode : 1;
393 uint32_t ic_10bitaddr_slave : 1;
394 uint32_t ic_10bitaddr_master : 1;
395 uint32_t ic_restart_en : 1;
396 uint32_t ic_slave_disable : 1;
405#define ALT_I2C_CON_OFST 0x0
407#define ALT_I2C_CON_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CON_OFST))
447#define ALT_I2C_TAR_IC_TAR_LSB 0
449#define ALT_I2C_TAR_IC_TAR_MSB 9
451#define ALT_I2C_TAR_IC_TAR_WIDTH 10
453#define ALT_I2C_TAR_IC_TAR_SET_MSK 0x000003ff
455#define ALT_I2C_TAR_IC_TAR_CLR_MSK 0xfffffc00
457#define ALT_I2C_TAR_IC_TAR_RESET 0x55
459#define ALT_I2C_TAR_IC_TAR_GET(value) (((value) & 0x000003ff) >> 0)
461#define ALT_I2C_TAR_IC_TAR_SET(value) (((value) << 0) & 0x000003ff)
488#define ALT_I2C_TAR_GC_OR_START_E_GENCALL 0x0
494#define ALT_I2C_TAR_GC_OR_START_E_STARTBYTE 0x1
497#define ALT_I2C_TAR_GC_OR_START_LSB 10
499#define ALT_I2C_TAR_GC_OR_START_MSB 10
501#define ALT_I2C_TAR_GC_OR_START_WIDTH 1
503#define ALT_I2C_TAR_GC_OR_START_SET_MSK 0x00000400
505#define ALT_I2C_TAR_GC_OR_START_CLR_MSK 0xfffffbff
507#define ALT_I2C_TAR_GC_OR_START_RESET 0x0
509#define ALT_I2C_TAR_GC_OR_START_GET(value) (((value) & 0x00000400) >> 10)
511#define ALT_I2C_TAR_GC_OR_START_SET(value) (((value) << 10) & 0x00000400)
536#define ALT_I2C_TAR_SPECIAL_E_GENCALL 0x0
542#define ALT_I2C_TAR_SPECIAL_E_STARTBYTE 0x1
545#define ALT_I2C_TAR_SPECIAL_LSB 11
547#define ALT_I2C_TAR_SPECIAL_MSB 11
549#define ALT_I2C_TAR_SPECIAL_WIDTH 1
551#define ALT_I2C_TAR_SPECIAL_SET_MSK 0x00000800
553#define ALT_I2C_TAR_SPECIAL_CLR_MSK 0xfffff7ff
555#define ALT_I2C_TAR_SPECIAL_RESET 0x0
557#define ALT_I2C_TAR_SPECIAL_GET(value) (((value) & 0x00000800) >> 11)
559#define ALT_I2C_TAR_SPECIAL_SET(value) (((value) << 11) & 0x00000800)
582#define ALT_I2C_TAR_IC_10BITADDR_MST_E_START7 0x0
588#define ALT_I2C_TAR_IC_10BITADDR_MST_E_START10 0x1
591#define ALT_I2C_TAR_IC_10BITADDR_MST_LSB 12
593#define ALT_I2C_TAR_IC_10BITADDR_MST_MSB 12
595#define ALT_I2C_TAR_IC_10BITADDR_MST_WIDTH 1
597#define ALT_I2C_TAR_IC_10BITADDR_MST_SET_MSK 0x00001000
599#define ALT_I2C_TAR_IC_10BITADDR_MST_CLR_MSK 0xffffefff
601#define ALT_I2C_TAR_IC_10BITADDR_MST_RESET 0x1
603#define ALT_I2C_TAR_IC_10BITADDR_MST_GET(value) (((value) & 0x00001000) >> 12)
605#define ALT_I2C_TAR_IC_10BITADDR_MST_SET(value) (((value) << 12) & 0x00001000)
620 uint32_t ic_tar : 10;
621 uint32_t gc_or_start : 1;
622 uint32_t special : 1;
623 uint32_t ic_10bitaddr_master : 1;
632#define ALT_I2C_TAR_OFST 0x4
634#define ALT_I2C_TAR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_TAR_OFST))
669#define ALT_I2C_SAR_IC_SAR_LSB 0
671#define ALT_I2C_SAR_IC_SAR_MSB 9
673#define ALT_I2C_SAR_IC_SAR_WIDTH 10
675#define ALT_I2C_SAR_IC_SAR_SET_MSK 0x000003ff
677#define ALT_I2C_SAR_IC_SAR_CLR_MSK 0xfffffc00
679#define ALT_I2C_SAR_IC_SAR_RESET 0x55
681#define ALT_I2C_SAR_IC_SAR_GET(value) (((value) & 0x000003ff) >> 0)
683#define ALT_I2C_SAR_IC_SAR_SET(value) (((value) << 0) & 0x000003ff)
698 uint32_t ic_sar : 10;
707#define ALT_I2C_SAR_OFST 0x8
709#define ALT_I2C_SAR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_SAR_OFST))
740#define ALT_I2C_DATA_CMD_DAT_LSB 0
742#define ALT_I2C_DATA_CMD_DAT_MSB 7
744#define ALT_I2C_DATA_CMD_DAT_WIDTH 8
746#define ALT_I2C_DATA_CMD_DAT_SET_MSK 0x000000ff
748#define ALT_I2C_DATA_CMD_DAT_CLR_MSK 0xffffff00
750#define ALT_I2C_DATA_CMD_DAT_RESET 0x0
752#define ALT_I2C_DATA_CMD_DAT_GET(value) (((value) & 0x000000ff) >> 0)
754#define ALT_I2C_DATA_CMD_DAT_SET(value) (((value) << 0) & 0x000000ff)
791#define ALT_I2C_DATA_CMD_CMD_E_RD 0x1
797#define ALT_I2C_DATA_CMD_CMD_E_WR 0x0
800#define ALT_I2C_DATA_CMD_CMD_LSB 8
802#define ALT_I2C_DATA_CMD_CMD_MSB 8
804#define ALT_I2C_DATA_CMD_CMD_WIDTH 1
806#define ALT_I2C_DATA_CMD_CMD_SET_MSK 0x00000100
808#define ALT_I2C_DATA_CMD_CMD_CLR_MSK 0xfffffeff
810#define ALT_I2C_DATA_CMD_CMD_RESET 0x0
812#define ALT_I2C_DATA_CMD_CMD_GET(value) (((value) & 0x00000100) >> 8)
814#define ALT_I2C_DATA_CMD_CMD_SET(value) (((value) << 8) & 0x00000100)
846#define ALT_I2C_DATA_CMD_STOP_E_STOP 0x1
852#define ALT_I2C_DATA_CMD_STOP_E_NO_STOP 0x0
855#define ALT_I2C_DATA_CMD_STOP_LSB 9
857#define ALT_I2C_DATA_CMD_STOP_MSB 9
859#define ALT_I2C_DATA_CMD_STOP_WIDTH 1
861#define ALT_I2C_DATA_CMD_STOP_SET_MSK 0x00000200
863#define ALT_I2C_DATA_CMD_STOP_CLR_MSK 0xfffffdff
865#define ALT_I2C_DATA_CMD_STOP_RESET 0x0
867#define ALT_I2C_DATA_CMD_STOP_GET(value) (((value) & 0x00000200) >> 9)
869#define ALT_I2C_DATA_CMD_STOP_SET(value) (((value) << 9) & 0x00000200)
899#define ALT_I2C_DATA_CMD_RESTART_E_RESTART 0x1
905#define ALT_I2C_DATA_CMD_RESTART_E_RESTART_ON_DIR_CHANGE 0x0
908#define ALT_I2C_DATA_CMD_RESTART_LSB 10
910#define ALT_I2C_DATA_CMD_RESTART_MSB 10
912#define ALT_I2C_DATA_CMD_RESTART_WIDTH 1
914#define ALT_I2C_DATA_CMD_RESTART_SET_MSK 0x00000400
916#define ALT_I2C_DATA_CMD_RESTART_CLR_MSK 0xfffffbff
918#define ALT_I2C_DATA_CMD_RESTART_RESET 0x0
920#define ALT_I2C_DATA_CMD_RESTART_GET(value) (((value) & 0x00000400) >> 10)
922#define ALT_I2C_DATA_CMD_RESTART_SET(value) (((value) << 10) & 0x00000400)
940 uint32_t restart : 1;
949#define ALT_I2C_DATA_CMD_OFST 0x10
951#define ALT_I2C_DATA_CMD_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_DATA_CMD_OFST))
985#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_LSB 0
987#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_MSB 15
989#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_WIDTH 16
991#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_SET_MSK 0x0000ffff
993#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_CLR_MSK 0xffff0000
995#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_RESET 0x190
997#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_GET(value) (((value) & 0x0000ffff) >> 0)
999#define ALT_I2C_SS_SCL_HCNT_IC_SS_SCL_HCNT_SET(value) (((value) << 0) & 0x0000ffff)
1014 uint32_t ic_ss_scl_hcnt : 16;
1023#define ALT_I2C_SS_SCL_HCNT_OFST 0x14
1025#define ALT_I2C_SS_SCL_HCNT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_SS_SCL_HCNT_OFST))
1055#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_LSB 0
1057#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_MSB 15
1059#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_WIDTH 16
1061#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_SET_MSK 0x0000ffff
1063#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_CLR_MSK 0xffff0000
1065#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_RESET 0x1d6
1067#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_GET(value) (((value) & 0x0000ffff) >> 0)
1069#define ALT_I2C_SS_SCL_LCNT_IC_SS_SCL_LCNT_SET(value) (((value) << 0) & 0x0000ffff)
1084 uint32_t ic_ss_scl_lcnt : 16;
1093#define ALT_I2C_SS_SCL_LCNT_OFST 0x18
1095#define ALT_I2C_SS_SCL_LCNT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_SS_SCL_LCNT_OFST))
1127#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_LSB 0
1129#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_MSB 15
1131#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_WIDTH 16
1133#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_SET_MSK 0x0000ffff
1135#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_CLR_MSK 0xffff0000
1137#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_RESET 0x3c
1139#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_GET(value) (((value) & 0x0000ffff) >> 0)
1141#define ALT_I2C_FS_SCL_HCNT_IC_FS_SCL_HCNT_SET(value) (((value) << 0) & 0x0000ffff)
1156 uint32_t ic_fs_scl_hcnt : 16;
1165#define ALT_I2C_FS_SCL_HCNT_OFST 0x1c
1167#define ALT_I2C_FS_SCL_HCNT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_FS_SCL_HCNT_OFST))
1197#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_LSB 0
1199#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_MSB 15
1201#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_WIDTH 16
1203#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_SET_MSK 0x0000ffff
1205#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_CLR_MSK 0xffff0000
1207#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_RESET 0x82
1209#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_GET(value) (((value) & 0x0000ffff) >> 0)
1211#define ALT_I2C_FS_SCL_LCNT_IC_FS_SCL_LCNT_SET(value) (((value) << 0) & 0x0000ffff)
1226 uint32_t ic_fs_scl_lcnt : 16;
1235#define ALT_I2C_FS_SCL_LCNT_OFST 0x20
1237#define ALT_I2C_FS_SCL_LCNT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_FS_SCL_LCNT_OFST))
1278#define ALT_I2C_INTR_STAT_R_RX_UNDER_LSB 0
1280#define ALT_I2C_INTR_STAT_R_RX_UNDER_MSB 0
1282#define ALT_I2C_INTR_STAT_R_RX_UNDER_WIDTH 1
1284#define ALT_I2C_INTR_STAT_R_RX_UNDER_SET_MSK 0x00000001
1286#define ALT_I2C_INTR_STAT_R_RX_UNDER_CLR_MSK 0xfffffffe
1288#define ALT_I2C_INTR_STAT_R_RX_UNDER_RESET 0x0
1290#define ALT_I2C_INTR_STAT_R_RX_UNDER_GET(value) (((value) & 0x00000001) >> 0)
1292#define ALT_I2C_INTR_STAT_R_RX_UNDER_SET(value) (((value) << 0) & 0x00000001)
1307#define ALT_I2C_INTR_STAT_R_RX_OVER_LSB 1
1309#define ALT_I2C_INTR_STAT_R_RX_OVER_MSB 1
1311#define ALT_I2C_INTR_STAT_R_RX_OVER_WIDTH 1
1313#define ALT_I2C_INTR_STAT_R_RX_OVER_SET_MSK 0x00000002
1315#define ALT_I2C_INTR_STAT_R_RX_OVER_CLR_MSK 0xfffffffd
1317#define ALT_I2C_INTR_STAT_R_RX_OVER_RESET 0x0
1319#define ALT_I2C_INTR_STAT_R_RX_OVER_GET(value) (((value) & 0x00000002) >> 1)
1321#define ALT_I2C_INTR_STAT_R_RX_OVER_SET(value) (((value) << 1) & 0x00000002)
1337#define ALT_I2C_INTR_STAT_R_RX_FULL_LSB 2
1339#define ALT_I2C_INTR_STAT_R_RX_FULL_MSB 2
1341#define ALT_I2C_INTR_STAT_R_RX_FULL_WIDTH 1
1343#define ALT_I2C_INTR_STAT_R_RX_FULL_SET_MSK 0x00000004
1345#define ALT_I2C_INTR_STAT_R_RX_FULL_CLR_MSK 0xfffffffb
1347#define ALT_I2C_INTR_STAT_R_RX_FULL_RESET 0x0
1349#define ALT_I2C_INTR_STAT_R_RX_FULL_GET(value) (((value) & 0x00000004) >> 2)
1351#define ALT_I2C_INTR_STAT_R_RX_FULL_SET(value) (((value) << 2) & 0x00000004)
1365#define ALT_I2C_INTR_STAT_R_TX_OVER_LSB 3
1367#define ALT_I2C_INTR_STAT_R_TX_OVER_MSB 3
1369#define ALT_I2C_INTR_STAT_R_TX_OVER_WIDTH 1
1371#define ALT_I2C_INTR_STAT_R_TX_OVER_SET_MSK 0x00000008
1373#define ALT_I2C_INTR_STAT_R_TX_OVER_CLR_MSK 0xfffffff7
1375#define ALT_I2C_INTR_STAT_R_TX_OVER_RESET 0x0
1377#define ALT_I2C_INTR_STAT_R_TX_OVER_GET(value) (((value) & 0x00000008) >> 3)
1379#define ALT_I2C_INTR_STAT_R_TX_OVER_SET(value) (((value) << 3) & 0x00000008)
1395#define ALT_I2C_INTR_STAT_R_TX_EMPTY_LSB 4
1397#define ALT_I2C_INTR_STAT_R_TX_EMPTY_MSB 4
1399#define ALT_I2C_INTR_STAT_R_TX_EMPTY_WIDTH 1
1401#define ALT_I2C_INTR_STAT_R_TX_EMPTY_SET_MSK 0x00000010
1403#define ALT_I2C_INTR_STAT_R_TX_EMPTY_CLR_MSK 0xffffffef
1405#define ALT_I2C_INTR_STAT_R_TX_EMPTY_RESET 0x0
1407#define ALT_I2C_INTR_STAT_R_TX_EMPTY_GET(value) (((value) & 0x00000010) >> 4)
1409#define ALT_I2C_INTR_STAT_R_TX_EMPTY_SET(value) (((value) << 4) & 0x00000010)
1426#define ALT_I2C_INTR_STAT_R_RD_REQ_LSB 5
1428#define ALT_I2C_INTR_STAT_R_RD_REQ_MSB 5
1430#define ALT_I2C_INTR_STAT_R_RD_REQ_WIDTH 1
1432#define ALT_I2C_INTR_STAT_R_RD_REQ_SET_MSK 0x00000020
1434#define ALT_I2C_INTR_STAT_R_RD_REQ_CLR_MSK 0xffffffdf
1436#define ALT_I2C_INTR_STAT_R_RD_REQ_RESET 0x0
1438#define ALT_I2C_INTR_STAT_R_RD_REQ_GET(value) (((value) & 0x00000020) >> 5)
1440#define ALT_I2C_INTR_STAT_R_RD_REQ_SET(value) (((value) << 5) & 0x00000020)
1460#define ALT_I2C_INTR_STAT_R_TX_ABRT_LSB 6
1462#define ALT_I2C_INTR_STAT_R_TX_ABRT_MSB 6
1464#define ALT_I2C_INTR_STAT_R_TX_ABRT_WIDTH 1
1466#define ALT_I2C_INTR_STAT_R_TX_ABRT_SET_MSK 0x00000040
1468#define ALT_I2C_INTR_STAT_R_TX_ABRT_CLR_MSK 0xffffffbf
1470#define ALT_I2C_INTR_STAT_R_TX_ABRT_RESET 0x0
1472#define ALT_I2C_INTR_STAT_R_TX_ABRT_GET(value) (((value) & 0x00000040) >> 6)
1474#define ALT_I2C_INTR_STAT_R_TX_ABRT_SET(value) (((value) << 6) & 0x00000040)
1487#define ALT_I2C_INTR_STAT_R_RX_DONE_LSB 7
1489#define ALT_I2C_INTR_STAT_R_RX_DONE_MSB 7
1491#define ALT_I2C_INTR_STAT_R_RX_DONE_WIDTH 1
1493#define ALT_I2C_INTR_STAT_R_RX_DONE_SET_MSK 0x00000080
1495#define ALT_I2C_INTR_STAT_R_RX_DONE_CLR_MSK 0xffffff7f
1497#define ALT_I2C_INTR_STAT_R_RX_DONE_RESET 0x0
1499#define ALT_I2C_INTR_STAT_R_RX_DONE_GET(value) (((value) & 0x00000080) >> 7)
1501#define ALT_I2C_INTR_STAT_R_RX_DONE_SET(value) (((value) << 7) & 0x00000080)
1525#define ALT_I2C_INTR_STAT_R_ACTIVITY_LSB 8
1527#define ALT_I2C_INTR_STAT_R_ACTIVITY_MSB 8
1529#define ALT_I2C_INTR_STAT_R_ACTIVITY_WIDTH 1
1531#define ALT_I2C_INTR_STAT_R_ACTIVITY_SET_MSK 0x00000100
1533#define ALT_I2C_INTR_STAT_R_ACTIVITY_CLR_MSK 0xfffffeff
1535#define ALT_I2C_INTR_STAT_R_ACTIVITY_RESET 0x0
1537#define ALT_I2C_INTR_STAT_R_ACTIVITY_GET(value) (((value) & 0x00000100) >> 8)
1539#define ALT_I2C_INTR_STAT_R_ACTIVITY_SET(value) (((value) << 8) & 0x00000100)
1551#define ALT_I2C_INTR_STAT_R_STOP_DET_LSB 9
1553#define ALT_I2C_INTR_STAT_R_STOP_DET_MSB 9
1555#define ALT_I2C_INTR_STAT_R_STOP_DET_WIDTH 1
1557#define ALT_I2C_INTR_STAT_R_STOP_DET_SET_MSK 0x00000200
1559#define ALT_I2C_INTR_STAT_R_STOP_DET_CLR_MSK 0xfffffdff
1561#define ALT_I2C_INTR_STAT_R_STOP_DET_RESET 0x0
1563#define ALT_I2C_INTR_STAT_R_STOP_DET_GET(value) (((value) & 0x00000200) >> 9)
1565#define ALT_I2C_INTR_STAT_R_STOP_DET_SET(value) (((value) << 9) & 0x00000200)
1577#define ALT_I2C_INTR_STAT_R_START_DET_LSB 10
1579#define ALT_I2C_INTR_STAT_R_START_DET_MSB 10
1581#define ALT_I2C_INTR_STAT_R_START_DET_WIDTH 1
1583#define ALT_I2C_INTR_STAT_R_START_DET_SET_MSK 0x00000400
1585#define ALT_I2C_INTR_STAT_R_START_DET_CLR_MSK 0xfffffbff
1587#define ALT_I2C_INTR_STAT_R_START_DET_RESET 0x0
1589#define ALT_I2C_INTR_STAT_R_START_DET_GET(value) (((value) & 0x00000400) >> 10)
1591#define ALT_I2C_INTR_STAT_R_START_DET_SET(value) (((value) << 10) & 0x00000400)
1605#define ALT_I2C_INTR_STAT_R_GEN_CALL_LSB 11
1607#define ALT_I2C_INTR_STAT_R_GEN_CALL_MSB 11
1609#define ALT_I2C_INTR_STAT_R_GEN_CALL_WIDTH 1
1611#define ALT_I2C_INTR_STAT_R_GEN_CALL_SET_MSK 0x00000800
1613#define ALT_I2C_INTR_STAT_R_GEN_CALL_CLR_MSK 0xfffff7ff
1615#define ALT_I2C_INTR_STAT_R_GEN_CALL_RESET 0x0
1617#define ALT_I2C_INTR_STAT_R_GEN_CALL_GET(value) (((value) & 0x00000800) >> 11)
1619#define ALT_I2C_INTR_STAT_R_GEN_CALL_SET(value) (((value) << 11) & 0x00000800)
1634 const uint32_t r_rx_under : 1;
1635 const uint32_t r_rx_over : 1;
1636 const uint32_t r_rx_full : 1;
1637 const uint32_t r_tx_over : 1;
1638 const uint32_t r_tx_empty : 1;
1639 const uint32_t r_rd_req : 1;
1640 const uint32_t r_tx_abrt : 1;
1641 const uint32_t r_rx_done : 1;
1642 const uint32_t r_activity : 1;
1643 const uint32_t r_stop_det : 1;
1644 const uint32_t r_start_det : 1;
1645 const uint32_t r_gen_call : 1;
1654#define ALT_I2C_INTR_STAT_OFST 0x2c
1656#define ALT_I2C_INTR_STAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_INTR_STAT_OFST))
1694#define ALT_I2C_INTR_MSK_M_RX_UNDER_LSB 0
1696#define ALT_I2C_INTR_MSK_M_RX_UNDER_MSB 0
1698#define ALT_I2C_INTR_MSK_M_RX_UNDER_WIDTH 1
1700#define ALT_I2C_INTR_MSK_M_RX_UNDER_SET_MSK 0x00000001
1702#define ALT_I2C_INTR_MSK_M_RX_UNDER_CLR_MSK 0xfffffffe
1704#define ALT_I2C_INTR_MSK_M_RX_UNDER_RESET 0x1
1706#define ALT_I2C_INTR_MSK_M_RX_UNDER_GET(value) (((value) & 0x00000001) >> 0)
1708#define ALT_I2C_INTR_MSK_M_RX_UNDER_SET(value) (((value) << 0) & 0x00000001)
1723#define ALT_I2C_INTR_MSK_M_RX_OVER_LSB 1
1725#define ALT_I2C_INTR_MSK_M_RX_OVER_MSB 1
1727#define ALT_I2C_INTR_MSK_M_RX_OVER_WIDTH 1
1729#define ALT_I2C_INTR_MSK_M_RX_OVER_SET_MSK 0x00000002
1731#define ALT_I2C_INTR_MSK_M_RX_OVER_CLR_MSK 0xfffffffd
1733#define ALT_I2C_INTR_MSK_M_RX_OVER_RESET 0x1
1735#define ALT_I2C_INTR_MSK_M_RX_OVER_GET(value) (((value) & 0x00000002) >> 1)
1737#define ALT_I2C_INTR_MSK_M_RX_OVER_SET(value) (((value) << 1) & 0x00000002)
1753#define ALT_I2C_INTR_MSK_M_RX_FULL_LSB 2
1755#define ALT_I2C_INTR_MSK_M_RX_FULL_MSB 2
1757#define ALT_I2C_INTR_MSK_M_RX_FULL_WIDTH 1
1759#define ALT_I2C_INTR_MSK_M_RX_FULL_SET_MSK 0x00000004
1761#define ALT_I2C_INTR_MSK_M_RX_FULL_CLR_MSK 0xfffffffb
1763#define ALT_I2C_INTR_MSK_M_RX_FULL_RESET 0x1
1765#define ALT_I2C_INTR_MSK_M_RX_FULL_GET(value) (((value) & 0x00000004) >> 2)
1767#define ALT_I2C_INTR_MSK_M_RX_FULL_SET(value) (((value) << 2) & 0x00000004)
1781#define ALT_I2C_INTR_MSK_M_TX_OVER_LSB 3
1783#define ALT_I2C_INTR_MSK_M_TX_OVER_MSB 3
1785#define ALT_I2C_INTR_MSK_M_TX_OVER_WIDTH 1
1787#define ALT_I2C_INTR_MSK_M_TX_OVER_SET_MSK 0x00000008
1789#define ALT_I2C_INTR_MSK_M_TX_OVER_CLR_MSK 0xfffffff7
1791#define ALT_I2C_INTR_MSK_M_TX_OVER_RESET 0x1
1793#define ALT_I2C_INTR_MSK_M_TX_OVER_GET(value) (((value) & 0x00000008) >> 3)
1795#define ALT_I2C_INTR_MSK_M_TX_OVER_SET(value) (((value) << 3) & 0x00000008)
1812#define ALT_I2C_INTR_MSK_M_TX_EMPTY_LSB 4
1814#define ALT_I2C_INTR_MSK_M_TX_EMPTY_MSB 4
1816#define ALT_I2C_INTR_MSK_M_TX_EMPTY_WIDTH 1
1818#define ALT_I2C_INTR_MSK_M_TX_EMPTY_SET_MSK 0x00000010
1820#define ALT_I2C_INTR_MSK_M_TX_EMPTY_CLR_MSK 0xffffffef
1822#define ALT_I2C_INTR_MSK_M_TX_EMPTY_RESET 0x1
1824#define ALT_I2C_INTR_MSK_M_TX_EMPTY_GET(value) (((value) & 0x00000010) >> 4)
1826#define ALT_I2C_INTR_MSK_M_TX_EMPTY_SET(value) (((value) << 4) & 0x00000010)
1843#define ALT_I2C_INTR_MSK_M_RD_REQ_LSB 5
1845#define ALT_I2C_INTR_MSK_M_RD_REQ_MSB 5
1847#define ALT_I2C_INTR_MSK_M_RD_REQ_WIDTH 1
1849#define ALT_I2C_INTR_MSK_M_RD_REQ_SET_MSK 0x00000020
1851#define ALT_I2C_INTR_MSK_M_RD_REQ_CLR_MSK 0xffffffdf
1853#define ALT_I2C_INTR_MSK_M_RD_REQ_RESET 0x1
1855#define ALT_I2C_INTR_MSK_M_RD_REQ_GET(value) (((value) & 0x00000020) >> 5)
1857#define ALT_I2C_INTR_MSK_M_RD_REQ_SET(value) (((value) << 5) & 0x00000020)
1877#define ALT_I2C_INTR_MSK_M_TX_ABRT_LSB 6
1879#define ALT_I2C_INTR_MSK_M_TX_ABRT_MSB 6
1881#define ALT_I2C_INTR_MSK_M_TX_ABRT_WIDTH 1
1883#define ALT_I2C_INTR_MSK_M_TX_ABRT_SET_MSK 0x00000040
1885#define ALT_I2C_INTR_MSK_M_TX_ABRT_CLR_MSK 0xffffffbf
1887#define ALT_I2C_INTR_MSK_M_TX_ABRT_RESET 0x1
1889#define ALT_I2C_INTR_MSK_M_TX_ABRT_GET(value) (((value) & 0x00000040) >> 6)
1891#define ALT_I2C_INTR_MSK_M_TX_ABRT_SET(value) (((value) << 6) & 0x00000040)
1904#define ALT_I2C_INTR_MSK_M_RX_DONE_LSB 7
1906#define ALT_I2C_INTR_MSK_M_RX_DONE_MSB 7
1908#define ALT_I2C_INTR_MSK_M_RX_DONE_WIDTH 1
1910#define ALT_I2C_INTR_MSK_M_RX_DONE_SET_MSK 0x00000080
1912#define ALT_I2C_INTR_MSK_M_RX_DONE_CLR_MSK 0xffffff7f
1914#define ALT_I2C_INTR_MSK_M_RX_DONE_RESET 0x1
1916#define ALT_I2C_INTR_MSK_M_RX_DONE_GET(value) (((value) & 0x00000080) >> 7)
1918#define ALT_I2C_INTR_MSK_M_RX_DONE_SET(value) (((value) << 7) & 0x00000080)
1942#define ALT_I2C_INTR_MSK_M_ACTIVITY_LSB 8
1944#define ALT_I2C_INTR_MSK_M_ACTIVITY_MSB 8
1946#define ALT_I2C_INTR_MSK_M_ACTIVITY_WIDTH 1
1948#define ALT_I2C_INTR_MSK_M_ACTIVITY_SET_MSK 0x00000100
1950#define ALT_I2C_INTR_MSK_M_ACTIVITY_CLR_MSK 0xfffffeff
1952#define ALT_I2C_INTR_MSK_M_ACTIVITY_RESET 0x0
1954#define ALT_I2C_INTR_MSK_M_ACTIVITY_GET(value) (((value) & 0x00000100) >> 8)
1956#define ALT_I2C_INTR_MSK_M_ACTIVITY_SET(value) (((value) << 8) & 0x00000100)
1968#define ALT_I2C_INTR_MSK_M_STOP_DET_LSB 9
1970#define ALT_I2C_INTR_MSK_M_STOP_DET_MSB 9
1972#define ALT_I2C_INTR_MSK_M_STOP_DET_WIDTH 1
1974#define ALT_I2C_INTR_MSK_M_STOP_DET_SET_MSK 0x00000200
1976#define ALT_I2C_INTR_MSK_M_STOP_DET_CLR_MSK 0xfffffdff
1978#define ALT_I2C_INTR_MSK_M_STOP_DET_RESET 0x0
1980#define ALT_I2C_INTR_MSK_M_STOP_DET_GET(value) (((value) & 0x00000200) >> 9)
1982#define ALT_I2C_INTR_MSK_M_STOP_DET_SET(value) (((value) << 9) & 0x00000200)
1994#define ALT_I2C_INTR_MSK_M_START_DET_LSB 10
1996#define ALT_I2C_INTR_MSK_M_START_DET_MSB 10
1998#define ALT_I2C_INTR_MSK_M_START_DET_WIDTH 1
2000#define ALT_I2C_INTR_MSK_M_START_DET_SET_MSK 0x00000400
2002#define ALT_I2C_INTR_MSK_M_START_DET_CLR_MSK 0xfffffbff
2004#define ALT_I2C_INTR_MSK_M_START_DET_RESET 0x0
2006#define ALT_I2C_INTR_MSK_M_START_DET_GET(value) (((value) & 0x00000400) >> 10)
2008#define ALT_I2C_INTR_MSK_M_START_DET_SET(value) (((value) << 10) & 0x00000400)
2022#define ALT_I2C_INTR_MSK_M_GEN_CALL_LSB 11
2024#define ALT_I2C_INTR_MSK_M_GEN_CALL_MSB 11
2026#define ALT_I2C_INTR_MSK_M_GEN_CALL_WIDTH 1
2028#define ALT_I2C_INTR_MSK_M_GEN_CALL_SET_MSK 0x00000800
2030#define ALT_I2C_INTR_MSK_M_GEN_CALL_CLR_MSK 0xfffff7ff
2032#define ALT_I2C_INTR_MSK_M_GEN_CALL_RESET 0x1
2034#define ALT_I2C_INTR_MSK_M_GEN_CALL_GET(value) (((value) & 0x00000800) >> 11)
2036#define ALT_I2C_INTR_MSK_M_GEN_CALL_SET(value) (((value) << 11) & 0x00000800)
2051 uint32_t m_rx_under : 1;
2052 uint32_t m_rx_over : 1;
2053 uint32_t m_rx_full : 1;
2054 uint32_t m_tx_over : 1;
2055 uint32_t m_tx_empty : 1;
2056 uint32_t m_rd_req : 1;
2057 uint32_t m_tx_abrt : 1;
2058 uint32_t m_rx_done : 1;
2059 uint32_t m_activity : 1;
2060 uint32_t m_stop_det : 1;
2061 uint32_t m_start_det : 1;
2062 uint32_t m_gen_call : 1;
2071#define ALT_I2C_INTR_MSK_OFST 0x30
2073#define ALT_I2C_INTR_MSK_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_INTR_MSK_OFST))
2112#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_LSB 0
2114#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_MSB 0
2116#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_WIDTH 1
2118#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_SET_MSK 0x00000001
2120#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_CLR_MSK 0xfffffffe
2122#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_RESET 0x0
2124#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_GET(value) (((value) & 0x00000001) >> 0)
2126#define ALT_I2C_RAW_INTR_STAT_RX_UNDER_SET(value) (((value) << 0) & 0x00000001)
2141#define ALT_I2C_RAW_INTR_STAT_RX_OVER_LSB 1
2143#define ALT_I2C_RAW_INTR_STAT_RX_OVER_MSB 1
2145#define ALT_I2C_RAW_INTR_STAT_RX_OVER_WIDTH 1
2147#define ALT_I2C_RAW_INTR_STAT_RX_OVER_SET_MSK 0x00000002
2149#define ALT_I2C_RAW_INTR_STAT_RX_OVER_CLR_MSK 0xfffffffd
2151#define ALT_I2C_RAW_INTR_STAT_RX_OVER_RESET 0x0
2153#define ALT_I2C_RAW_INTR_STAT_RX_OVER_GET(value) (((value) & 0x00000002) >> 1)
2155#define ALT_I2C_RAW_INTR_STAT_RX_OVER_SET(value) (((value) << 1) & 0x00000002)
2171#define ALT_I2C_RAW_INTR_STAT_RX_FULL_LSB 2
2173#define ALT_I2C_RAW_INTR_STAT_RX_FULL_MSB 2
2175#define ALT_I2C_RAW_INTR_STAT_RX_FULL_WIDTH 1
2177#define ALT_I2C_RAW_INTR_STAT_RX_FULL_SET_MSK 0x00000004
2179#define ALT_I2C_RAW_INTR_STAT_RX_FULL_CLR_MSK 0xfffffffb
2181#define ALT_I2C_RAW_INTR_STAT_RX_FULL_RESET 0x0
2183#define ALT_I2C_RAW_INTR_STAT_RX_FULL_GET(value) (((value) & 0x00000004) >> 2)
2185#define ALT_I2C_RAW_INTR_STAT_RX_FULL_SET(value) (((value) << 2) & 0x00000004)
2199#define ALT_I2C_RAW_INTR_STAT_TX_OVER_LSB 3
2201#define ALT_I2C_RAW_INTR_STAT_TX_OVER_MSB 3
2203#define ALT_I2C_RAW_INTR_STAT_TX_OVER_WIDTH 1
2205#define ALT_I2C_RAW_INTR_STAT_TX_OVER_SET_MSK 0x00000008
2207#define ALT_I2C_RAW_INTR_STAT_TX_OVER_CLR_MSK 0xfffffff7
2209#define ALT_I2C_RAW_INTR_STAT_TX_OVER_RESET 0x0
2211#define ALT_I2C_RAW_INTR_STAT_TX_OVER_GET(value) (((value) & 0x00000008) >> 3)
2213#define ALT_I2C_RAW_INTR_STAT_TX_OVER_SET(value) (((value) << 3) & 0x00000008)
2230#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_LSB 4
2232#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_MSB 4
2234#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_WIDTH 1
2236#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_SET_MSK 0x00000010
2238#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_CLR_MSK 0xffffffef
2240#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_RESET 0x0
2242#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_GET(value) (((value) & 0x00000010) >> 4)
2244#define ALT_I2C_RAW_INTR_STAT_TX_EMPTY_SET(value) (((value) << 4) & 0x00000010)
2261#define ALT_I2C_RAW_INTR_STAT_RD_REQ_LSB 5
2263#define ALT_I2C_RAW_INTR_STAT_RD_REQ_MSB 5
2265#define ALT_I2C_RAW_INTR_STAT_RD_REQ_WIDTH 1
2267#define ALT_I2C_RAW_INTR_STAT_RD_REQ_SET_MSK 0x00000020
2269#define ALT_I2C_RAW_INTR_STAT_RD_REQ_CLR_MSK 0xffffffdf
2271#define ALT_I2C_RAW_INTR_STAT_RD_REQ_RESET 0x0
2273#define ALT_I2C_RAW_INTR_STAT_RD_REQ_GET(value) (((value) & 0x00000020) >> 5)
2275#define ALT_I2C_RAW_INTR_STAT_RD_REQ_SET(value) (((value) << 5) & 0x00000020)
2295#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_LSB 6
2297#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_MSB 6
2299#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_WIDTH 1
2301#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_SET_MSK 0x00000040
2303#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_CLR_MSK 0xffffffbf
2305#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_RESET 0x0
2307#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_GET(value) (((value) & 0x00000040) >> 6)
2309#define ALT_I2C_RAW_INTR_STAT_TX_ABRT_SET(value) (((value) << 6) & 0x00000040)
2322#define ALT_I2C_RAW_INTR_STAT_RX_DONE_LSB 7
2324#define ALT_I2C_RAW_INTR_STAT_RX_DONE_MSB 7
2326#define ALT_I2C_RAW_INTR_STAT_RX_DONE_WIDTH 1
2328#define ALT_I2C_RAW_INTR_STAT_RX_DONE_SET_MSK 0x00000080
2330#define ALT_I2C_RAW_INTR_STAT_RX_DONE_CLR_MSK 0xffffff7f
2332#define ALT_I2C_RAW_INTR_STAT_RX_DONE_RESET 0x0
2334#define ALT_I2C_RAW_INTR_STAT_RX_DONE_GET(value) (((value) & 0x00000080) >> 7)
2336#define ALT_I2C_RAW_INTR_STAT_RX_DONE_SET(value) (((value) << 7) & 0x00000080)
2360#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_LSB 8
2362#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_MSB 8
2364#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_WIDTH 1
2366#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_SET_MSK 0x00000100
2368#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_CLR_MSK 0xfffffeff
2370#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_RESET 0x0
2372#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_GET(value) (((value) & 0x00000100) >> 8)
2374#define ALT_I2C_RAW_INTR_STAT_ACTIVITY_SET(value) (((value) << 8) & 0x00000100)
2386#define ALT_I2C_RAW_INTR_STAT_STOP_DET_LSB 9
2388#define ALT_I2C_RAW_INTR_STAT_STOP_DET_MSB 9
2390#define ALT_I2C_RAW_INTR_STAT_STOP_DET_WIDTH 1
2392#define ALT_I2C_RAW_INTR_STAT_STOP_DET_SET_MSK 0x00000200
2394#define ALT_I2C_RAW_INTR_STAT_STOP_DET_CLR_MSK 0xfffffdff
2396#define ALT_I2C_RAW_INTR_STAT_STOP_DET_RESET 0x0
2398#define ALT_I2C_RAW_INTR_STAT_STOP_DET_GET(value) (((value) & 0x00000200) >> 9)
2400#define ALT_I2C_RAW_INTR_STAT_STOP_DET_SET(value) (((value) << 9) & 0x00000200)
2412#define ALT_I2C_RAW_INTR_STAT_START_DET_LSB 10
2414#define ALT_I2C_RAW_INTR_STAT_START_DET_MSB 10
2416#define ALT_I2C_RAW_INTR_STAT_START_DET_WIDTH 1
2418#define ALT_I2C_RAW_INTR_STAT_START_DET_SET_MSK 0x00000400
2420#define ALT_I2C_RAW_INTR_STAT_START_DET_CLR_MSK 0xfffffbff
2422#define ALT_I2C_RAW_INTR_STAT_START_DET_RESET 0x0
2424#define ALT_I2C_RAW_INTR_STAT_START_DET_GET(value) (((value) & 0x00000400) >> 10)
2426#define ALT_I2C_RAW_INTR_STAT_START_DET_SET(value) (((value) << 10) & 0x00000400)
2440#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_LSB 11
2442#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_MSB 11
2444#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_WIDTH 1
2446#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_SET_MSK 0x00000800
2448#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_CLR_MSK 0xfffff7ff
2450#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_RESET 0x0
2452#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_GET(value) (((value) & 0x00000800) >> 11)
2454#define ALT_I2C_RAW_INTR_STAT_GEN_CALL_SET(value) (((value) << 11) & 0x00000800)
2469 const uint32_t rx_under : 1;
2470 const uint32_t rx_over : 1;
2471 const uint32_t rx_full : 1;
2472 const uint32_t tx_over : 1;
2473 const uint32_t tx_empty : 1;
2474 const uint32_t rd_req : 1;
2475 const uint32_t tx_abrt : 1;
2476 const uint32_t rx_done : 1;
2477 const uint32_t activity : 1;
2478 const uint32_t stop_det : 1;
2479 const uint32_t start_det : 1;
2480 const uint32_t gen_call : 1;
2489#define ALT_I2C_RAW_INTR_STAT_OFST 0x34
2491#define ALT_I2C_RAW_INTR_STAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_RAW_INTR_STAT_OFST))
2520#define ALT_I2C_RX_TL_RX_TL_LSB 0
2522#define ALT_I2C_RX_TL_RX_TL_MSB 7
2524#define ALT_I2C_RX_TL_RX_TL_WIDTH 8
2526#define ALT_I2C_RX_TL_RX_TL_SET_MSK 0x000000ff
2528#define ALT_I2C_RX_TL_RX_TL_CLR_MSK 0xffffff00
2530#define ALT_I2C_RX_TL_RX_TL_RESET 0x0
2532#define ALT_I2C_RX_TL_RX_TL_GET(value) (((value) & 0x000000ff) >> 0)
2534#define ALT_I2C_RX_TL_RX_TL_SET(value) (((value) << 0) & 0x000000ff)
2558#define ALT_I2C_RX_TL_OFST 0x38
2560#define ALT_I2C_RX_TL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_RX_TL_OFST))
2589#define ALT_I2C_TX_TL_TX_TL_LSB 0
2591#define ALT_I2C_TX_TL_TX_TL_MSB 7
2593#define ALT_I2C_TX_TL_TX_TL_WIDTH 8
2595#define ALT_I2C_TX_TL_TX_TL_SET_MSK 0x000000ff
2597#define ALT_I2C_TX_TL_TX_TL_CLR_MSK 0xffffff00
2599#define ALT_I2C_TX_TL_TX_TL_RESET 0x0
2601#define ALT_I2C_TX_TL_TX_TL_GET(value) (((value) & 0x000000ff) >> 0)
2603#define ALT_I2C_TX_TL_TX_TL_SET(value) (((value) << 0) & 0x000000ff)
2627#define ALT_I2C_TX_TL_OFST 0x3c
2629#define ALT_I2C_TX_TL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_TX_TL_OFST))
2656#define ALT_I2C_CLR_INTR_CLR_INTR_LSB 0
2658#define ALT_I2C_CLR_INTR_CLR_INTR_MSB 0
2660#define ALT_I2C_CLR_INTR_CLR_INTR_WIDTH 1
2662#define ALT_I2C_CLR_INTR_CLR_INTR_SET_MSK 0x00000001
2664#define ALT_I2C_CLR_INTR_CLR_INTR_CLR_MSK 0xfffffffe
2666#define ALT_I2C_CLR_INTR_CLR_INTR_RESET 0x0
2668#define ALT_I2C_CLR_INTR_CLR_INTR_GET(value) (((value) & 0x00000001) >> 0)
2670#define ALT_I2C_CLR_INTR_CLR_INTR_SET(value) (((value) << 0) & 0x00000001)
2685 const uint32_t clr_intr : 1;
2694#define ALT_I2C_CLR_INTR_OFST 0x40
2696#define ALT_I2C_CLR_INTR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_INTR_OFST))
2721#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_LSB 0
2723#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_MSB 0
2725#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_WIDTH 1
2727#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_SET_MSK 0x00000001
2729#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_CLR_MSK 0xfffffffe
2731#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_RESET 0x0
2733#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_GET(value) (((value) & 0x00000001) >> 0)
2735#define ALT_I2C_CLR_RX_UNDER_CLR_RX_UNDER_SET(value) (((value) << 0) & 0x00000001)
2750 const uint32_t clr_rx_under : 1;
2759#define ALT_I2C_CLR_RX_UNDER_OFST 0x44
2761#define ALT_I2C_CLR_RX_UNDER_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_RX_UNDER_OFST))
2786#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_LSB 0
2788#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_MSB 0
2790#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_WIDTH 1
2792#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_SET_MSK 0x00000001
2794#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_CLR_MSK 0xfffffffe
2796#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_RESET 0x0
2798#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_GET(value) (((value) & 0x00000001) >> 0)
2800#define ALT_I2C_CLR_RX_OVER_CLR_RX_OVER_SET(value) (((value) << 0) & 0x00000001)
2815 const uint32_t clr_rx_over : 1;
2824#define ALT_I2C_CLR_RX_OVER_OFST 0x48
2826#define ALT_I2C_CLR_RX_OVER_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_RX_OVER_OFST))
2851#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_LSB 0
2853#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_MSB 0
2855#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_WIDTH 1
2857#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_SET_MSK 0x00000001
2859#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_CLR_MSK 0xfffffffe
2861#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_RESET 0x0
2863#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_GET(value) (((value) & 0x00000001) >> 0)
2865#define ALT_I2C_CLR_TX_OVER_CLR_TX_OVER_SET(value) (((value) << 0) & 0x00000001)
2880 const uint32_t clr_tx_over : 1;
2889#define ALT_I2C_CLR_TX_OVER_OFST 0x4c
2891#define ALT_I2C_CLR_TX_OVER_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_TX_OVER_OFST))
2916#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_LSB 0
2918#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_MSB 0
2920#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_WIDTH 1
2922#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_SET_MSK 0x00000001
2924#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_CLR_MSK 0xfffffffe
2926#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_RESET 0x0
2928#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_GET(value) (((value) & 0x00000001) >> 0)
2930#define ALT_I2C_CLR_RD_REQ_CLR_RD_REQ_SET(value) (((value) << 0) & 0x00000001)
2945 const uint32_t clr_rd_req : 1;
2954#define ALT_I2C_CLR_RD_REQ_OFST 0x50
2956#define ALT_I2C_CLR_RD_REQ_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_RD_REQ_OFST))
2984#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_LSB 0
2986#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_MSB 0
2988#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_WIDTH 1
2990#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_SET_MSK 0x00000001
2992#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_CLR_MSK 0xfffffffe
2994#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_RESET 0x0
2996#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_GET(value) (((value) & 0x00000001) >> 0)
2998#define ALT_I2C_CLR_TX_ABRT_CLR_TX_ABT_SET(value) (((value) << 0) & 0x00000001)
3013 const uint32_t clr_tx_abort : 1;
3022#define ALT_I2C_CLR_TX_ABRT_OFST 0x54
3024#define ALT_I2C_CLR_TX_ABRT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_TX_ABRT_OFST))
3049#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_LSB 0
3051#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_MSB 0
3053#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_WIDTH 1
3055#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_SET_MSK 0x00000001
3057#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_CLR_MSK 0xfffffffe
3059#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_RESET 0x0
3061#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_GET(value) (((value) & 0x00000001) >> 0)
3063#define ALT_I2C_CLR_RX_DONE_CLR_RX_DONE_SET(value) (((value) << 0) & 0x00000001)
3078 const uint32_t clr_rx_done : 1;
3087#define ALT_I2C_CLR_RX_DONE_OFST 0x58
3089#define ALT_I2C_CLR_RX_DONE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_RX_DONE_OFST))
3118#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_LSB 0
3120#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_MSB 0
3122#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_WIDTH 1
3124#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_SET_MSK 0x00000001
3126#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_CLR_MSK 0xfffffffe
3128#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_RESET 0x0
3130#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_GET(value) (((value) & 0x00000001) >> 0)
3132#define ALT_I2C_CLR_ACTIVITY_CLR_ACTIVITY_SET(value) (((value) << 0) & 0x00000001)
3147 const uint32_t clr_activity : 1;
3156#define ALT_I2C_CLR_ACTIVITY_OFST 0x5c
3158#define ALT_I2C_CLR_ACTIVITY_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_ACTIVITY_OFST))
3183#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_LSB 0
3185#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_MSB 0
3187#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_WIDTH 1
3189#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_SET_MSK 0x00000001
3191#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_CLR_MSK 0xfffffffe
3193#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_RESET 0x0
3195#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_GET(value) (((value) & 0x00000001) >> 0)
3197#define ALT_I2C_CLR_STOP_DET_CLR_STOP_DET_SET(value) (((value) << 0) & 0x00000001)
3212 const uint32_t clr_stop_det : 1;
3221#define ALT_I2C_CLR_STOP_DET_OFST 0x60
3223#define ALT_I2C_CLR_STOP_DET_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_STOP_DET_OFST))
3248#define ALT_I2C_CLR_START_DET_CLR_START_DET_LSB 0
3250#define ALT_I2C_CLR_START_DET_CLR_START_DET_MSB 0
3252#define ALT_I2C_CLR_START_DET_CLR_START_DET_WIDTH 1
3254#define ALT_I2C_CLR_START_DET_CLR_START_DET_SET_MSK 0x00000001
3256#define ALT_I2C_CLR_START_DET_CLR_START_DET_CLR_MSK 0xfffffffe
3258#define ALT_I2C_CLR_START_DET_CLR_START_DET_RESET 0x0
3260#define ALT_I2C_CLR_START_DET_CLR_START_DET_GET(value) (((value) & 0x00000001) >> 0)
3262#define ALT_I2C_CLR_START_DET_CLR_START_DET_SET(value) (((value) << 0) & 0x00000001)
3277 const uint32_t clr_start_det : 1;
3286#define ALT_I2C_CLR_START_DET_OFST 0x64
3288#define ALT_I2C_CLR_START_DET_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_START_DET_OFST))
3313#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_LSB 0
3315#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_MSB 0
3317#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_WIDTH 1
3319#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_SET_MSK 0x00000001
3321#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_CLR_MSK 0xfffffffe
3323#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_RESET 0x0
3325#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_GET(value) (((value) & 0x00000001) >> 0)
3327#define ALT_I2C_CLR_GEN_CALL_CLR_GEN_CALL_SET(value) (((value) << 0) & 0x00000001)
3342 const uint32_t clr_gen_call : 1;
3351#define ALT_I2C_CLR_GEN_CALL_OFST 0x68
3353#define ALT_I2C_CLR_GEN_CALL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_CLR_GEN_CALL_OFST))
3423#define ALT_I2C_EN_EN_E_DIS 0x0
3429#define ALT_I2C_EN_EN_E_EN 0x1
3432#define ALT_I2C_EN_EN_LSB 0
3434#define ALT_I2C_EN_EN_MSB 0
3436#define ALT_I2C_EN_EN_WIDTH 1
3438#define ALT_I2C_EN_EN_SET_MSK 0x00000001
3440#define ALT_I2C_EN_EN_CLR_MSK 0xfffffffe
3442#define ALT_I2C_EN_EN_RESET 0x0
3444#define ALT_I2C_EN_EN_GET(value) (((value) & 0x00000001) >> 0)
3446#define ALT_I2C_EN_EN_SET(value) (((value) << 0) & 0x00000001)
3457#define ALT_I2C_EN_TXABT_LSB 1
3459#define ALT_I2C_EN_TXABT_MSB 1
3461#define ALT_I2C_EN_TXABT_WIDTH 1
3463#define ALT_I2C_EN_TXABT_SET_MSK 0x00000002
3465#define ALT_I2C_EN_TXABT_CLR_MSK 0xfffffffd
3467#define ALT_I2C_EN_TXABT_RESET 0x0
3469#define ALT_I2C_EN_TXABT_GET(value) (((value) & 0x00000002) >> 1)
3471#define ALT_I2C_EN_TXABT_SET(value) (((value) << 1) & 0x00000002)
3486 uint32_t enable : 1;
3487 uint32_t txabort : 1;
3496#define ALT_I2C_EN_OFST 0x6c
3498#define ALT_I2C_EN_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_EN_OFST))
3539#define ALT_I2C_STAT_ACTIVITY_LSB 0
3541#define ALT_I2C_STAT_ACTIVITY_MSB 0
3543#define ALT_I2C_STAT_ACTIVITY_WIDTH 1
3545#define ALT_I2C_STAT_ACTIVITY_SET_MSK 0x00000001
3547#define ALT_I2C_STAT_ACTIVITY_CLR_MSK 0xfffffffe
3549#define ALT_I2C_STAT_ACTIVITY_RESET 0x0
3551#define ALT_I2C_STAT_ACTIVITY_GET(value) (((value) & 0x00000001) >> 0)
3553#define ALT_I2C_STAT_ACTIVITY_SET(value) (((value) << 0) & 0x00000001)
3575#define ALT_I2C_STAT_TFNF_E_FULL 0x0
3581#define ALT_I2C_STAT_TFNF_E_NOTFULL 0x1
3584#define ALT_I2C_STAT_TFNF_LSB 1
3586#define ALT_I2C_STAT_TFNF_MSB 1
3588#define ALT_I2C_STAT_TFNF_WIDTH 1
3590#define ALT_I2C_STAT_TFNF_SET_MSK 0x00000002
3592#define ALT_I2C_STAT_TFNF_CLR_MSK 0xfffffffd
3594#define ALT_I2C_STAT_TFNF_RESET 0x1
3596#define ALT_I2C_STAT_TFNF_GET(value) (((value) & 0x00000002) >> 1)
3598#define ALT_I2C_STAT_TFNF_SET(value) (((value) << 1) & 0x00000002)
3620#define ALT_I2C_STAT_TFE_E_NOTEMPTY 0x0
3626#define ALT_I2C_STAT_TFE_E_EMPTY 0x1
3629#define ALT_I2C_STAT_TFE_LSB 2
3631#define ALT_I2C_STAT_TFE_MSB 2
3633#define ALT_I2C_STAT_TFE_WIDTH 1
3635#define ALT_I2C_STAT_TFE_SET_MSK 0x00000004
3637#define ALT_I2C_STAT_TFE_CLR_MSK 0xfffffffb
3639#define ALT_I2C_STAT_TFE_RESET 0x1
3641#define ALT_I2C_STAT_TFE_GET(value) (((value) & 0x00000004) >> 2)
3643#define ALT_I2C_STAT_TFE_SET(value) (((value) << 2) & 0x00000004)
3665#define ALT_I2C_STAT_RFNE_E_EMPTY 0x0
3671#define ALT_I2C_STAT_RFNE_E_NOTEMPTY 0x1
3674#define ALT_I2C_STAT_RFNE_LSB 3
3676#define ALT_I2C_STAT_RFNE_MSB 3
3678#define ALT_I2C_STAT_RFNE_WIDTH 1
3680#define ALT_I2C_STAT_RFNE_SET_MSK 0x00000008
3682#define ALT_I2C_STAT_RFNE_CLR_MSK 0xfffffff7
3684#define ALT_I2C_STAT_RFNE_RESET 0x0
3686#define ALT_I2C_STAT_RFNE_GET(value) (((value) & 0x00000008) >> 3)
3688#define ALT_I2C_STAT_RFNE_SET(value) (((value) << 3) & 0x00000008)
3710#define ALT_I2C_STAT_RFF_E_NOTFULL 0x0
3716#define ALT_I2C_STAT_RFF_E_FULL 0x1
3719#define ALT_I2C_STAT_RFF_LSB 4
3721#define ALT_I2C_STAT_RFF_MSB 4
3723#define ALT_I2C_STAT_RFF_WIDTH 1
3725#define ALT_I2C_STAT_RFF_SET_MSK 0x00000010
3727#define ALT_I2C_STAT_RFF_CLR_MSK 0xffffffef
3729#define ALT_I2C_STAT_RFF_RESET 0x0
3731#define ALT_I2C_STAT_RFF_GET(value) (((value) & 0x00000010) >> 4)
3733#define ALT_I2C_STAT_RFF_SET(value) (((value) << 4) & 0x00000010)
3759#define ALT_I2C_STAT_MST_ACTIVITY_E_IDLE 0x0
3765#define ALT_I2C_STAT_MST_ACTIVITY_E_NOTIDLE 0x1
3768#define ALT_I2C_STAT_MST_ACTIVITY_LSB 5
3770#define ALT_I2C_STAT_MST_ACTIVITY_MSB 5
3772#define ALT_I2C_STAT_MST_ACTIVITY_WIDTH 1
3774#define ALT_I2C_STAT_MST_ACTIVITY_SET_MSK 0x00000020
3776#define ALT_I2C_STAT_MST_ACTIVITY_CLR_MSK 0xffffffdf
3778#define ALT_I2C_STAT_MST_ACTIVITY_RESET 0x0
3780#define ALT_I2C_STAT_MST_ACTIVITY_GET(value) (((value) & 0x00000020) >> 5)
3782#define ALT_I2C_STAT_MST_ACTIVITY_SET(value) (((value) << 5) & 0x00000020)
3807#define ALT_I2C_STAT_SLV_ACTIVITY_E_IDLE 0x0
3813#define ALT_I2C_STAT_SLV_ACTIVITY_E_NOTIDLE 0x1
3816#define ALT_I2C_STAT_SLV_ACTIVITY_LSB 6
3818#define ALT_I2C_STAT_SLV_ACTIVITY_MSB 6
3820#define ALT_I2C_STAT_SLV_ACTIVITY_WIDTH 1
3822#define ALT_I2C_STAT_SLV_ACTIVITY_SET_MSK 0x00000040
3824#define ALT_I2C_STAT_SLV_ACTIVITY_CLR_MSK 0xffffffbf
3826#define ALT_I2C_STAT_SLV_ACTIVITY_RESET 0x0
3828#define ALT_I2C_STAT_SLV_ACTIVITY_GET(value) (((value) & 0x00000040) >> 6)
3830#define ALT_I2C_STAT_SLV_ACTIVITY_SET(value) (((value) << 6) & 0x00000040)
3845 const uint32_t activity : 1;
3846 const uint32_t tfnf : 1;
3847 const uint32_t tfe : 1;
3848 const uint32_t rfne : 1;
3849 const uint32_t rff : 1;
3850 const uint32_t mst_activity : 1;
3851 const uint32_t slv_activity : 1;
3860#define ALT_I2C_STAT_OFST 0x70
3862#define ALT_I2C_STAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_STAT_OFST))
3895#define ALT_I2C_TXFLR_TXFLR_LSB 0
3897#define ALT_I2C_TXFLR_TXFLR_MSB 6
3899#define ALT_I2C_TXFLR_TXFLR_WIDTH 7
3901#define ALT_I2C_TXFLR_TXFLR_SET_MSK 0x0000007f
3903#define ALT_I2C_TXFLR_TXFLR_CLR_MSK 0xffffff80
3905#define ALT_I2C_TXFLR_TXFLR_RESET 0x0
3907#define ALT_I2C_TXFLR_TXFLR_GET(value) (((value) & 0x0000007f) >> 0)
3909#define ALT_I2C_TXFLR_TXFLR_SET(value) (((value) << 0) & 0x0000007f)
3924 const uint32_t txflr : 7;
3933#define ALT_I2C_TXFLR_OFST 0x74
3935#define ALT_I2C_TXFLR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_TXFLR_OFST))
3967#define ALT_I2C_RXFLR_RXFLR_LSB 0
3969#define ALT_I2C_RXFLR_RXFLR_MSB 6
3971#define ALT_I2C_RXFLR_RXFLR_WIDTH 7
3973#define ALT_I2C_RXFLR_RXFLR_SET_MSK 0x0000007f
3975#define ALT_I2C_RXFLR_RXFLR_CLR_MSK 0xffffff80
3977#define ALT_I2C_RXFLR_RXFLR_RESET 0x0
3979#define ALT_I2C_RXFLR_RXFLR_GET(value) (((value) & 0x0000007f) >> 0)
3981#define ALT_I2C_RXFLR_RXFLR_SET(value) (((value) << 0) & 0x0000007f)
3996 const uint32_t rxflr : 7;
4005#define ALT_I2C_RXFLR_OFST 0x78
4007#define ALT_I2C_RXFLR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_RXFLR_OFST))
4034#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_LSB 0
4036#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_MSB 15
4038#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_WIDTH 16
4040#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_SET_MSK 0x0000ffff
4042#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_CLR_MSK 0xffff0000
4044#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_RESET 0x1
4046#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_GET(value) (((value) & 0x0000ffff) >> 0)
4048#define ALT_I2C_SDA_HOLD_IC_SDA_HOLD_SET(value) (((value) << 0) & 0x0000ffff)
4063 uint32_t ic_sda_hold : 16;
4072#define ALT_I2C_SDA_HOLD_OFST 0x7c
4074#define ALT_I2C_SDA_HOLD_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_SDA_HOLD_OFST))
4122#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_LSB 0
4124#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_MSB 0
4126#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_WIDTH 1
4128#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_SET_MSK 0x00000001
4130#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_CLR_MSK 0xfffffffe
4132#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_RESET 0x0
4134#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_GET(value) (((value) & 0x00000001) >> 0)
4136#define ALT_I2C_TX_ABRT_SRC_ABRT_7B_ADDR_NOACK_SET(value) (((value) << 0) & 0x00000001)
4148#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_LSB 1
4150#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_MSB 1
4152#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_WIDTH 1
4154#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_SET_MSK 0x00000002
4156#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_CLR_MSK 0xfffffffd
4158#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_RESET 0x0
4160#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_GET(value) (((value) & 0x00000002) >> 1)
4162#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR1_NOACK_SET(value) (((value) << 1) & 0x00000002)
4175#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_LSB 2
4177#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_MSB 2
4179#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_WIDTH 1
4181#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_SET_MSK 0x00000004
4183#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_CLR_MSK 0xfffffffb
4185#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_RESET 0x0
4187#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_GET(value) (((value) & 0x00000004) >> 2)
4189#define ALT_I2C_TX_ABRT_SRC_ABRT_10ADDR2_NOACK_SET(value) (((value) << 2) & 0x00000004)
4202#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_LSB 3
4204#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_MSB 3
4206#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_WIDTH 1
4208#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_SET_MSK 0x00000008
4210#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_CLR_MSK 0xfffffff7
4212#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_RESET 0x0
4214#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_GET(value) (((value) & 0x00000008) >> 3)
4216#define ALT_I2C_TX_ABRT_SRC_ABRT_TXDATA_NOACK_SET(value) (((value) << 3) & 0x00000008)
4228#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_LSB 4
4230#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_MSB 4
4232#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_WIDTH 1
4234#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_SET_MSK 0x00000010
4236#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_CLR_MSK 0xffffffef
4238#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_RESET 0x0
4240#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_GET(value) (((value) & 0x00000010) >> 4)
4242#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_NOACK_SET(value) (((value) << 4) & 0x00000010)
4255#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_LSB 5
4257#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_MSB 5
4259#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_WIDTH 1
4261#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_SET_MSK 0x00000020
4263#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_CLR_MSK 0xffffffdf
4265#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_RESET 0x0
4267#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_GET(value) (((value) & 0x00000020) >> 5)
4269#define ALT_I2C_TX_ABRT_SRC_ABRT_GCALL_RD_SET(value) (((value) << 5) & 0x00000020)
4281#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_LSB 6
4283#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_MSB 6
4285#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_WIDTH 1
4287#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_SET_MSK 0x00000040
4289#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_CLR_MSK 0xffffffbf
4291#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_RESET 0x0
4293#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_GET(value) (((value) & 0x00000040) >> 6)
4295#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_ACKDET_SET(value) (((value) << 6) & 0x00000040)
4307#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_LSB 7
4309#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_MSB 7
4311#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_WIDTH 1
4313#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_SET_MSK 0x00000080
4315#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_CLR_MSK 0xffffff7f
4317#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_RESET 0x0
4319#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_GET(value) (((value) & 0x00000080) >> 7)
4321#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_ACKDET_SET(value) (((value) << 7) & 0x00000080)
4334#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_LSB 8
4336#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_MSB 8
4338#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_WIDTH 1
4340#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_SET_MSK 0x00000100
4342#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_CLR_MSK 0xfffffeff
4344#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_RESET 0x0
4346#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_GET(value) (((value) & 0x00000100) >> 8)
4348#define ALT_I2C_TX_ABRT_SRC_ABRT_HS_NORSTRT_SET(value) (((value) << 8) & 0x00000100)
4367#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_LSB 9
4369#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_MSB 9
4371#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_WIDTH 1
4373#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_SET_MSK 0x00000200
4375#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_CLR_MSK 0xfffffdff
4377#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_RESET 0x0
4379#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_GET(value) (((value) & 0x00000200) >> 9)
4381#define ALT_I2C_TX_ABRT_SRC_ABRT_SBYTE_NORSTRT_SET(value) (((value) << 9) & 0x00000200)
4393#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_LSB 10
4395#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_MSB 10
4397#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_WIDTH 1
4399#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_SET_MSK 0x00000400
4401#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_CLR_MSK 0xfffffbff
4403#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_RESET 0x0
4405#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_GET(value) (((value) & 0x00000400) >> 10)
4407#define ALT_I2C_TX_ABRT_SRC_ABRT_10B_RD_NORSTRT_SET(value) (((value) << 10) & 0x00000400)
4419#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_LSB 11
4421#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_MSB 11
4423#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_WIDTH 1
4425#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_SET_MSK 0x00000800
4427#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_CLR_MSK 0xfffff7ff
4429#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_RESET 0x0
4431#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_GET(value) (((value) & 0x00000800) >> 11)
4433#define ALT_I2C_TX_ABRT_SRC_ABRT_MST_DIS_SET(value) (((value) << 11) & 0x00000800)
4446#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_LSB 12
4448#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_MSB 12
4450#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_WIDTH 1
4452#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_SET_MSK 0x00001000
4454#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_CLR_MSK 0xffffefff
4456#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_RESET 0x0
4458#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_GET(value) (((value) & 0x00001000) >> 12)
4460#define ALT_I2C_TX_ABRT_SRC_ARB_LOST_SET(value) (((value) << 12) & 0x00001000)
4473#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_LSB 13
4475#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_MSB 13
4477#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_WIDTH 1
4479#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_SET_MSK 0x00002000
4481#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_CLR_MSK 0xffffdfff
4483#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_RESET 0x0
4485#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_GET(value) (((value) & 0x00002000) >> 13)
4487#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVFLUSH_TXFIFO_SET(value) (((value) << 13) & 0x00002000)
4503#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_LSB 14
4505#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_MSB 14
4507#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_WIDTH 1
4509#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_SET_MSK 0x00004000
4511#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_CLR_MSK 0xffffbfff
4513#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_RESET 0x0
4515#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_GET(value) (((value) & 0x00004000) >> 14)
4517#define ALT_I2C_TX_ABRT_SRC_ABRT_SLV_ARBLOST_SET(value) (((value) << 14) & 0x00004000)
4530#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_LSB 15
4532#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_MSB 15
4534#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_WIDTH 1
4536#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_SET_MSK 0x00008000
4538#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_CLR_MSK 0xffff7fff
4540#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_RESET 0x0
4542#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_GET(value) (((value) & 0x00008000) >> 15)
4544#define ALT_I2C_TX_ABRT_SRC_ABRT_SLVRD_INTX_SET(value) (((value) << 15) & 0x00008000)
4559 uint32_t abrt_7b_addr_noack : 1;
4560 uint32_t abrt_10addr1_noack : 1;
4561 uint32_t abrt_10addr2_noack : 1;
4562 uint32_t abrt_txdata_noack : 1;
4563 uint32_t abrt_gcall_noack : 1;
4564 uint32_t abrt_gcall_read : 1;
4565 uint32_t abrt_hs_ackdet : 1;
4566 uint32_t abrt_sbyte_ackdet : 1;
4567 uint32_t abrt_hs_norstrt : 1;
4568 uint32_t abrt_sbyte_norstrt : 1;
4569 uint32_t abrt_10b_rd_norstrt : 1;
4570 uint32_t abrt_master_dis : 1;
4571 uint32_t arb_lost : 1;
4572 uint32_t abrt_slvflush_txfifo : 1;
4573 uint32_t abrt_slv_arblost : 1;
4574 uint32_t abrt_slvrd_intx : 1;
4583#define ALT_I2C_TX_ABRT_SRC_OFST 0x80
4585#define ALT_I2C_TX_ABRT_SRC_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_TX_ABRT_SRC_OFST))
4621#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_E_AFTERDBYTE 0x1
4627#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_E_NORM 0x0
4630#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_LSB 0
4632#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_MSB 0
4634#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_WIDTH 1
4636#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_SET_MSK 0x00000001
4638#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_CLR_MSK 0xfffffffe
4640#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_RESET 0x0
4642#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_GET(value) (((value) & 0x00000001) >> 0)
4644#define ALT_I2C_SLV_DATA_NACK_ONLY_NACK_SET(value) (((value) << 0) & 0x00000001)
4668#define ALT_I2C_SLV_DATA_NACK_ONLY_OFST 0x84
4670#define ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_SLV_DATA_NACK_ONLY_OFST))
4708#define ALT_I2C_DMA_CR_RDMAE_E_DIS 0x0
4714#define ALT_I2C_DMA_CR_RDMAE_E_EN 0x1
4717#define ALT_I2C_DMA_CR_RDMAE_LSB 0
4719#define ALT_I2C_DMA_CR_RDMAE_MSB 0
4721#define ALT_I2C_DMA_CR_RDMAE_WIDTH 1
4723#define ALT_I2C_DMA_CR_RDMAE_SET_MSK 0x00000001
4725#define ALT_I2C_DMA_CR_RDMAE_CLR_MSK 0xfffffffe
4727#define ALT_I2C_DMA_CR_RDMAE_RESET 0x0
4729#define ALT_I2C_DMA_CR_RDMAE_GET(value) (((value) & 0x00000001) >> 0)
4731#define ALT_I2C_DMA_CR_RDMAE_SET(value) (((value) << 0) & 0x00000001)
4753#define ALT_I2C_DMA_CR_TDMAE_E_DIS 0x0
4759#define ALT_I2C_DMA_CR_TDMAE_E_EN 0x1
4762#define ALT_I2C_DMA_CR_TDMAE_LSB 1
4764#define ALT_I2C_DMA_CR_TDMAE_MSB 1
4766#define ALT_I2C_DMA_CR_TDMAE_WIDTH 1
4768#define ALT_I2C_DMA_CR_TDMAE_SET_MSK 0x00000002
4770#define ALT_I2C_DMA_CR_TDMAE_CLR_MSK 0xfffffffd
4772#define ALT_I2C_DMA_CR_TDMAE_RESET 0x0
4774#define ALT_I2C_DMA_CR_TDMAE_GET(value) (((value) & 0x00000002) >> 1)
4776#define ALT_I2C_DMA_CR_TDMAE_SET(value) (((value) << 1) & 0x00000002)
4801#define ALT_I2C_DMA_CR_OFST 0x88
4803#define ALT_I2C_DMA_CR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_DMA_CR_OFST))
4830#define ALT_I2C_DMA_TDLR_DMATDL_LSB 0
4832#define ALT_I2C_DMA_TDLR_DMATDL_MSB 5
4834#define ALT_I2C_DMA_TDLR_DMATDL_WIDTH 6
4836#define ALT_I2C_DMA_TDLR_DMATDL_SET_MSK 0x0000003f
4838#define ALT_I2C_DMA_TDLR_DMATDL_CLR_MSK 0xffffffc0
4840#define ALT_I2C_DMA_TDLR_DMATDL_RESET 0x0
4842#define ALT_I2C_DMA_TDLR_DMATDL_GET(value) (((value) & 0x0000003f) >> 0)
4844#define ALT_I2C_DMA_TDLR_DMATDL_SET(value) (((value) << 0) & 0x0000003f)
4859 uint32_t dmatdl : 6;
4868#define ALT_I2C_DMA_TDLR_OFST 0x8c
4870#define ALT_I2C_DMA_TDLR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_DMA_TDLR_OFST))
4899#define ALT_I2C_DMA_RDLR_DMARDL_LSB 0
4901#define ALT_I2C_DMA_RDLR_DMARDL_MSB 5
4903#define ALT_I2C_DMA_RDLR_DMARDL_WIDTH 6
4905#define ALT_I2C_DMA_RDLR_DMARDL_SET_MSK 0x0000003f
4907#define ALT_I2C_DMA_RDLR_DMARDL_CLR_MSK 0xffffffc0
4909#define ALT_I2C_DMA_RDLR_DMARDL_RESET 0x0
4911#define ALT_I2C_DMA_RDLR_DMARDL_GET(value) (((value) & 0x0000003f) >> 0)
4913#define ALT_I2C_DMA_RDLR_DMARDL_SET(value) (((value) << 0) & 0x0000003f)
4928 uint32_t dmardl : 6;
4937#define ALT_I2C_DMA_RDLR_OFST 0x90
4939#define ALT_I2C_DMA_RDLR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_DMA_RDLR_OFST))
4974#define ALT_I2C_SDA_SETUP_SDA_SETUP_LSB 0
4976#define ALT_I2C_SDA_SETUP_SDA_SETUP_MSB 7
4978#define ALT_I2C_SDA_SETUP_SDA_SETUP_WIDTH 8
4980#define ALT_I2C_SDA_SETUP_SDA_SETUP_SET_MSK 0x000000ff
4982#define ALT_I2C_SDA_SETUP_SDA_SETUP_CLR_MSK 0xffffff00
4984#define ALT_I2C_SDA_SETUP_SDA_SETUP_RESET 0x64
4986#define ALT_I2C_SDA_SETUP_SDA_SETUP_GET(value) (((value) & 0x000000ff) >> 0)
4988#define ALT_I2C_SDA_SETUP_SDA_SETUP_SET(value) (((value) << 0) & 0x000000ff)
5003 uint32_t sda_setup : 8;
5012#define ALT_I2C_SDA_SETUP_OFST 0x94
5014#define ALT_I2C_SDA_SETUP_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_SDA_SETUP_OFST))
5051#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_E_NACK 0x0
5057#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_E_ACK 0x1
5060#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_LSB 0
5062#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_MSB 0
5064#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_WIDTH 1
5066#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_SET_MSK 0x00000001
5068#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_CLR_MSK 0xfffffffe
5070#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_RESET 0x1
5072#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_GET(value) (((value) & 0x00000001) >> 0)
5074#define ALT_I2C_ACK_GENERAL_CALL_ACK_GEN_CALL_SET(value) (((value) << 0) & 0x00000001)
5089 uint32_t ack_gen_call : 1;
5098#define ALT_I2C_ACK_GENERAL_CALL_OFST 0x98
5100#define ALT_I2C_ACK_GENERAL_CALL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_ACK_GENERAL_CALL_OFST))
5136#define ALT_I2C_EN_STAT_IC_EN_LSB 0
5138#define ALT_I2C_EN_STAT_IC_EN_MSB 0
5140#define ALT_I2C_EN_STAT_IC_EN_WIDTH 1
5142#define ALT_I2C_EN_STAT_IC_EN_SET_MSK 0x00000001
5144#define ALT_I2C_EN_STAT_IC_EN_CLR_MSK 0xfffffffe
5146#define ALT_I2C_EN_STAT_IC_EN_RESET 0x0
5148#define ALT_I2C_EN_STAT_IC_EN_GET(value) (((value) & 0x00000001) >> 0)
5150#define ALT_I2C_EN_STAT_IC_EN_SET(value) (((value) << 0) & 0x00000001)
5174#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_LSB 1
5176#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_MSB 1
5178#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_WIDTH 1
5180#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_SET_MSK 0x00000002
5182#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_CLR_MSK 0xfffffffd
5184#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_RESET 0x0
5186#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_GET(value) (((value) & 0x00000002) >> 1)
5188#define ALT_I2C_EN_STAT_SLV_DISD_WHILE_BUSY_SET(value) (((value) << 1) & 0x00000002)
5209#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_LSB 2
5211#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_MSB 2
5213#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_WIDTH 1
5215#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_SET_MSK 0x00000004
5217#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_CLR_MSK 0xfffffffb
5219#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_RESET 0x0
5221#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_GET(value) (((value) & 0x00000004) >> 2)
5223#define ALT_I2C_EN_STAT_SLV_RX_DATA_LOST_SET(value) (((value) << 2) & 0x00000004)
5238 const uint32_t ic_en : 1;
5239 const uint32_t slv_disabled_while_busy : 1;
5240 const uint32_t slv_rx_data_lost : 1;
5249#define ALT_I2C_EN_STAT_OFST 0x9c
5251#define ALT_I2C_EN_STAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_EN_STAT_OFST))
5284#define ALT_I2C_FS_SPKLEN_SPKLEN_LSB 0
5286#define ALT_I2C_FS_SPKLEN_SPKLEN_MSB 7
5288#define ALT_I2C_FS_SPKLEN_SPKLEN_WIDTH 8
5290#define ALT_I2C_FS_SPKLEN_SPKLEN_SET_MSK 0x000000ff
5292#define ALT_I2C_FS_SPKLEN_SPKLEN_CLR_MSK 0xffffff00
5294#define ALT_I2C_FS_SPKLEN_SPKLEN_RESET 0x2
5296#define ALT_I2C_FS_SPKLEN_SPKLEN_GET(value) (((value) & 0x000000ff) >> 0)
5298#define ALT_I2C_FS_SPKLEN_SPKLEN_SET(value) (((value) << 0) & 0x000000ff)
5313 uint32_t spklen : 8;
5322#define ALT_I2C_FS_SPKLEN_OFST 0xa0
5324#define ALT_I2C_FS_SPKLEN_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_FS_SPKLEN_OFST))
5366#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_E_WIDTH32BITS 0x2
5369#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_LSB 0
5371#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_MSB 1
5373#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_WIDTH 2
5375#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_SET_MSK 0x00000003
5377#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_CLR_MSK 0xfffffffc
5379#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_RESET 0x2
5381#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_GET(value) (((value) & 0x00000003) >> 0)
5383#define ALT_I2C_COMP_PARAM_1_APB_DATA_WIDTH_SET(value) (((value) << 0) & 0x00000003)
5404#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_E_FAST 0x2
5407#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_LSB 2
5409#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_MSB 3
5411#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_WIDTH 2
5413#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_SET_MSK 0x0000000c
5415#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_CLR_MSK 0xfffffff3
5417#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_RESET 0x2
5419#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_GET(value) (((value) & 0x0000000c) >> 2)
5421#define ALT_I2C_COMP_PARAM_1_MAX_SPEED_MOD_SET(value) (((value) << 2) & 0x0000000c)
5442#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_E_RDWR 0x0
5445#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_LSB 4
5447#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_MSB 4
5449#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_WIDTH 1
5451#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_SET_MSK 0x00000010
5453#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_CLR_MSK 0xffffffef
5455#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_RESET 0x0
5457#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_GET(value) (((value) & 0x00000010) >> 4)
5459#define ALT_I2C_COMP_PARAM_1_HC_COUNT_VALUES_SET(value) (((value) << 4) & 0x00000010)
5480#define ALT_I2C_COMP_PARAM_1_INTR_IO_E_COMBINED 0x1
5483#define ALT_I2C_COMP_PARAM_1_INTR_IO_LSB 5
5485#define ALT_I2C_COMP_PARAM_1_INTR_IO_MSB 5
5487#define ALT_I2C_COMP_PARAM_1_INTR_IO_WIDTH 1
5489#define ALT_I2C_COMP_PARAM_1_INTR_IO_SET_MSK 0x00000020
5491#define ALT_I2C_COMP_PARAM_1_INTR_IO_CLR_MSK 0xffffffdf
5493#define ALT_I2C_COMP_PARAM_1_INTR_IO_RESET 0x1
5495#define ALT_I2C_COMP_PARAM_1_INTR_IO_GET(value) (((value) & 0x00000020) >> 5)
5497#define ALT_I2C_COMP_PARAM_1_INTR_IO_SET(value) (((value) << 5) & 0x00000020)
5518#define ALT_I2C_COMP_PARAM_1_HAS_DMA_E_PRESENT 0x1
5521#define ALT_I2C_COMP_PARAM_1_HAS_DMA_LSB 6
5523#define ALT_I2C_COMP_PARAM_1_HAS_DMA_MSB 6
5525#define ALT_I2C_COMP_PARAM_1_HAS_DMA_WIDTH 1
5527#define ALT_I2C_COMP_PARAM_1_HAS_DMA_SET_MSK 0x00000040
5529#define ALT_I2C_COMP_PARAM_1_HAS_DMA_CLR_MSK 0xffffffbf
5531#define ALT_I2C_COMP_PARAM_1_HAS_DMA_RESET 0x1
5533#define ALT_I2C_COMP_PARAM_1_HAS_DMA_GET(value) (((value) & 0x00000040) >> 6)
5535#define ALT_I2C_COMP_PARAM_1_HAS_DMA_SET(value) (((value) << 6) & 0x00000040)
5560#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_E_ADDENCPARAMS 0x1
5563#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_LSB 7
5565#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_MSB 7
5567#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_WIDTH 1
5569#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_SET_MSK 0x00000080
5571#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_CLR_MSK 0xffffff7f
5573#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_RESET 0x1
5575#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_GET(value) (((value) & 0x00000080) >> 7)
5577#define ALT_I2C_COMP_PARAM_1_ADD_ENC_PARAMS_SET(value) (((value) << 7) & 0x00000080)
5598#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_E_FIFO64BYTES 0x40
5601#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_LSB 8
5603#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_MSB 15
5605#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_WIDTH 8
5607#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_SET_MSK 0x0000ff00
5609#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_CLR_MSK 0xffff00ff
5611#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_RESET 0x3f
5613#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_GET(value) (((value) & 0x0000ff00) >> 8)
5615#define ALT_I2C_COMP_PARAM_1_RX_BUF_DEPTH_SET(value) (((value) << 8) & 0x0000ff00)
5636#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_E_FIFO64BYTES 0x40
5639#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_LSB 16
5641#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_MSB 23
5643#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_WIDTH 8
5645#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_SET_MSK 0x00ff0000
5647#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_CLR_MSK 0xff00ffff
5649#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_RESET 0x3f
5651#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_GET(value) (((value) & 0x00ff0000) >> 16)
5653#define ALT_I2C_COMP_PARAM_1_TX_BUF_DEPTH_SET(value) (((value) << 16) & 0x00ff0000)
5668 const uint32_t apb_data_width : 2;
5669 const uint32_t max_speed_mode : 2;
5670 const uint32_t hc_count_values : 1;
5671 const uint32_t intr_io : 1;
5672 const uint32_t has_dma : 1;
5673 const uint32_t add_encoded_params : 1;
5674 const uint32_t rx_buffer_depth : 8;
5675 const uint32_t tx_buffer_depth : 8;
5684#define ALT_I2C_COMP_PARAM_1_OFST 0xf4
5686#define ALT_I2C_COMP_PARAM_1_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_COMP_PARAM_1_OFST))
5719#define ALT_I2C_COMP_VER_IC_COMP_VER_E_VER_1_20A 0x3132302a
5722#define ALT_I2C_COMP_VER_IC_COMP_VER_LSB 0
5724#define ALT_I2C_COMP_VER_IC_COMP_VER_MSB 31
5726#define ALT_I2C_COMP_VER_IC_COMP_VER_WIDTH 32
5728#define ALT_I2C_COMP_VER_IC_COMP_VER_SET_MSK 0xffffffff
5730#define ALT_I2C_COMP_VER_IC_COMP_VER_CLR_MSK 0x00000000
5732#define ALT_I2C_COMP_VER_IC_COMP_VER_RESET 0x3132302a
5734#define ALT_I2C_COMP_VER_IC_COMP_VER_GET(value) (((value) & 0xffffffff) >> 0)
5736#define ALT_I2C_COMP_VER_IC_COMP_VER_SET(value) (((value) << 0) & 0xffffffff)
5751 const uint32_t ic_comp_version : 32;
5759#define ALT_I2C_COMP_VER_OFST 0xf8
5761#define ALT_I2C_COMP_VER_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_COMP_VER_OFST))
5786#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_LSB 0
5788#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_MSB 31
5790#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_WIDTH 32
5792#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_SET_MSK 0xffffffff
5794#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_CLR_MSK 0x00000000
5796#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_RESET 0x44570140
5798#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_GET(value) (((value) & 0xffffffff) >> 0)
5800#define ALT_I2C_COMP_TYPE_IC_COMP_TYPE_SET(value) (((value) << 0) & 0xffffffff)
5815 const uint32_t ic_comp_type : 32;
5823#define ALT_I2C_COMP_TYPE_OFST 0xfc
5825#define ALT_I2C_COMP_TYPE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_I2C_COMP_TYPE_OFST))
5843 volatile uint32_t _pad_0xc_0xf;
5849 volatile uint32_t _pad_0x24_0x2b[2];
5880 volatile uint32_t _pad_0xa4_0xf3[20];
5891 volatile uint32_t ic_con;
5892 volatile uint32_t ic_tar;
5893 volatile uint32_t ic_sar;
5894 volatile uint32_t _pad_0xc_0xf;
5895 volatile uint32_t ic_data_cmd;
5896 volatile uint32_t ic_ss_scl_hcnt;
5897 volatile uint32_t ic_ss_scl_lcnt;
5898 volatile uint32_t ic_fs_scl_hcnt;
5899 volatile uint32_t ic_fs_scl_lcnt;
5900 volatile uint32_t _pad_0x24_0x2b[2];
5901 volatile uint32_t ic_intr_stat;
5902 volatile uint32_t ic_intr_mask;
5903 volatile uint32_t ic_raw_intr_stat;
5904 volatile uint32_t ic_rx_tl;
5905 volatile uint32_t ic_tx_tl;
5906 volatile uint32_t ic_clr_intr;
5907 volatile uint32_t ic_clr_rx_under;
5908 volatile uint32_t ic_clr_rx_over;
5909 volatile uint32_t ic_clr_tx_over;
5910 volatile uint32_t ic_clr_rd_req;
5911 volatile uint32_t ic_clr_tx_abrt;
5912 volatile uint32_t ic_clr_rx_done;
5913 volatile uint32_t ic_clr_activity;
5914 volatile uint32_t ic_clr_stop_det;
5915 volatile uint32_t ic_clr_start_det;
5916 volatile uint32_t ic_clr_gen_call;
5917 volatile uint32_t ic_enable;
5918 volatile uint32_t ic_status;
5919 volatile uint32_t ic_txflr;
5920 volatile uint32_t ic_rxflr;
5921 volatile uint32_t ic_sda_hold;
5922 volatile uint32_t ic_tx_abrt_source;
5923 volatile uint32_t ic_slv_data_nack_only;
5924 volatile uint32_t ic_dma_cr;
5925 volatile uint32_t ic_dma_tdlr;
5926 volatile uint32_t ic_dma_rdlr;
5927 volatile uint32_t ic_sda_setup;
5928 volatile uint32_t ic_ack_general_call;
5929 volatile uint32_t ic_enable_status;
5930 volatile uint32_t ic_fs_spklen;
5931 volatile uint32_t _pad_0xa4_0xf3[20];
5932 volatile uint32_t ic_comp_param_1;
5933 volatile uint32_t ic_comp_version;
5934 volatile uint32_t ic_comp_type;
Definition: alt_i2c.h:5088
Definition: alt_i2c.h:3146
Definition: alt_i2c.h:3341
Definition: alt_i2c.h:2684
Definition: alt_i2c.h:2944
Definition: alt_i2c.h:3077
Definition: alt_i2c.h:2814
Definition: alt_i2c.h:2749
Definition: alt_i2c.h:3276
Definition: alt_i2c.h:3211
Definition: alt_i2c.h:3012
Definition: alt_i2c.h:2879
Definition: alt_i2c.h:5667
Definition: alt_i2c.h:5814
Definition: alt_i2c.h:5750
Definition: alt_i2c.h:390
Definition: alt_i2c.h:936
Definition: alt_i2c.h:4790
Definition: alt_i2c.h:4927
Definition: alt_i2c.h:4858
Definition: alt_i2c.h:5237
Definition: alt_i2c.h:3485
Definition: alt_i2c.h:1155
Definition: alt_i2c.h:1225
Definition: alt_i2c.h:5312
Definition: alt_i2c.h:2050
Definition: alt_i2c.h:1633
Definition: alt_i2c.h:2468
Definition: alt_i2c.h:3995
Definition: alt_i2c.h:2548
Definition: alt_i2c.h:697
Definition: alt_i2c.h:4062
Definition: alt_i2c.h:5002
Definition: alt_i2c.h:4658
Definition: alt_i2c.h:1013
Definition: alt_i2c.h:1083
Definition: alt_i2c.h:3844
Definition: alt_i2c.h:619
Definition: alt_i2c.h:3923
Definition: alt_i2c.h:4558
Definition: alt_i2c.h:2617
Definition: alt_i2c.h:5890
Definition: alt_i2c.h:5839
