RTEMS 6.1-rc1
Macros | Functions
stm32h7xx_ll_delayblock.h File Reference
Header file of Delay Block module. More...
#include "stm32h7xx_hal_def.h"
#define DLYB_MAX_UNIT   ((uint32_t)0x00000080U)
#define DLYB_MAX_SELECT   ((uint32_t)0x0000000CU)
HAL_StatusTypeDef DelayBlock_Enable (DLYB_TypeDef *DLYBx)
HAL_StatusTypeDef DelayBlock_Disable (DLYB_TypeDef *DLYBx)
HAL_StatusTypeDef DelayBlock_Configure (DLYB_TypeDef *DLYBx, uint32_t PhaseSel, uint32_t Units)
Author
MCD Application Team
Attention
