RTEMS 6.1-rc1
stm32h7xx_hal_wwdg.h File Reference
Header file of WWDG HAL module. More...
#include "stm32h7xx_hal_def.h"
struct  WWDG_InitTypeDef
 WWDG Init structure definition. More...
struct  WWDG_HandleTypeDef
 WWDG handle Structure definition. More...
#define WWDG_IT_EWI   WWDG_CFR_EWI
#define WWDG_FLAG_EWIF   WWDG_SR_EWIF
#define WWDG_PRESCALER_1   0x00000000u
#define WWDG_PRESCALER_2   WWDG_CFR_WDGTB_0
#define WWDG_PRESCALER_4   WWDG_CFR_WDGTB_1
#define WWDG_PRESCALER_8   (WWDG_CFR_WDGTB_1 | WWDG_CFR_WDGTB_0)
#define WWDG_PRESCALER_16   WWDG_CFR_WDGTB_2
#define WWDG_PRESCALER_32   (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_0)
#define WWDG_PRESCALER_64   (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_1)
#define WWDG_PRESCALER_128   WWDG_CFR_WDGTB
#define WWDG_EWI_DISABLE   0x00000000u
#define WWDG_EWI_ENABLE   WWDG_CFR_EWI
#define IS_WWDG_PRESCALER(__PRESCALER__)
#define IS_WWDG_WINDOW(__WINDOW__)   (((__WINDOW__) >= WWDG_CFR_W_6) && ((__WINDOW__) <= WWDG_CFR_W))
#define IS_WWDG_COUNTER(__COUNTER__)   (((__COUNTER__) >= WWDG_CR_T_6) && ((__COUNTER__) <= WWDG_CR_T))
#define IS_WWDG_EWI_MODE(__MODE__)
#define __HAL_WWDG_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CR, WWDG_CR_WDGA)
 Enable the WWDG peripheral. More...
#define __HAL_WWDG_ENABLE_IT(__HANDLE__, __INTERRUPT__)   SET_BIT((__HANDLE__)->Instance->CFR, (__INTERRUPT__))
 Enable the WWDG early wakeup interrupt. More...
#define __HAL_WWDG_GET_IT(__HANDLE__, __INTERRUPT__)   __HAL_WWDG_GET_FLAG((__HANDLE__),(__INTERRUPT__))
 Check whether the selected WWDG interrupt has occurred or not. More...
#define __HAL_WWDG_CLEAR_IT(__HANDLE__, __INTERRUPT__)   __HAL_WWDG_CLEAR_FLAG((__HANDLE__), (__INTERRUPT__))
 Clear the WWDG interrupt pending bits. bits to clear the selected interrupt pending bits. More...
#define __HAL_WWDG_GET_FLAG(__HANDLE__, __FLAG__)   (((__HANDLE__)->Instance->SR & (__FLAG__)) == (__FLAG__))
 Check whether the specified WWDG flag is set or not. More...
#define __HAL_WWDG_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->SR = ~(__FLAG__))
 Clear the WWDG's pending flags. More...
#define __HAL_WWDG_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified WWDG interrupt source is enabled or not. More...
HAL_StatusTypeDef HAL_WWDG_Init (WWDG_HandleTypeDef *hwwdg)
void HAL_WWDG_MspInit (WWDG_HandleTypeDef *hwwdg)
HAL_StatusTypeDef HAL_WWDG_Refresh (WWDG_HandleTypeDef *hwwdg)
void HAL_WWDG_IRQHandler (WWDG_HandleTypeDef *hwwdg)
void HAL_WWDG_EarlyWakeupCallback (WWDG_HandleTypeDef *hwwdg)
Author
MCD Application Team
Attention
