RTEMS 6.1-rc1
Macros | Functions
stm32h7xx_hal_usart_ex.h File Reference
Header file of USART HAL Extended module. More...
#include "stm32h7xx_hal_def.h"
#define USART_WORDLENGTH_7B   (USART_CR1_M1)
#define USART_WORDLENGTH_8B   (0x00000000U)
#define USART_WORDLENGTH_9B   (USART_CR1_M0)
#define USART_NSS_HARD   0x00000000U
#define USART_NSS_SOFT   USART_CR2_DIS_NSS
#define USART_SLAVEMODE_DISABLE   0x00000000U
#define USART_SLAVEMODE_ENABLE   USART_CR2_SLVEN
#define USART_FIFOMODE_DISABLE   0x00000000U
#define USART_FIFOMODE_ENABLE   USART_CR1_FIFOEN
#define USART_TXFIFO_THRESHOLD_1_8   0x00000000U
#define USART_TXFIFO_THRESHOLD_1_4   USART_CR3_TXFTCFG_0
#define USART_TXFIFO_THRESHOLD_1_2   USART_CR3_TXFTCFG_1
#define USART_TXFIFO_THRESHOLD_3_4   (USART_CR3_TXFTCFG_0|USART_CR3_TXFTCFG_1)
#define USART_TXFIFO_THRESHOLD_7_8   USART_CR3_TXFTCFG_2
#define USART_TXFIFO_THRESHOLD_8_8   (USART_CR3_TXFTCFG_2|USART_CR3_TXFTCFG_0)
#define USART_RXFIFO_THRESHOLD_1_8   0x00000000U
#define USART_RXFIFO_THRESHOLD_1_4   USART_CR3_RXFTCFG_0
#define USART_RXFIFO_THRESHOLD_1_2   USART_CR3_RXFTCFG_1
#define USART_RXFIFO_THRESHOLD_3_4   (USART_CR3_RXFTCFG_0|USART_CR3_RXFTCFG_1)
#define USART_RXFIFO_THRESHOLD_7_8   USART_CR3_RXFTCFG_2
#define USART_RXFIFO_THRESHOLD_8_8   (USART_CR3_RXFTCFG_2|USART_CR3_RXFTCFG_0)
#define USART_MASK_COMPUTATION(__HANDLE__)
 Compute the USART mask to apply to retrieve the received data according to the word length and to the parity bits activation. More...
#define IS_USART_WORD_LENGTH(__LENGTH__)
 Ensure that USART frame length is valid. More...
#define IS_USART_NSS(__NSS__)
 Ensure that USART Negative Slave Select (NSS) pin management is valid. More...
#define IS_USART_SLAVEMODE(__STATE__)
 Ensure that USART Slave Mode is valid. More...
#define IS_USART_FIFO_MODE_STATE(__STATE__)
 Ensure that USART FIFO mode is valid. More...
#define IS_USART_TXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that USART TXFIFO threshold level is valid. More...
#define IS_USART_RXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that USART RXFIFO threshold level is valid. More...
void HAL_USARTEx_RxFifoFullCallback (USART_HandleTypeDef *husart)
void HAL_USARTEx_TxFifoEmptyCallback (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USARTEx_EnableSlaveMode (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USARTEx_DisableSlaveMode (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USARTEx_ConfigNSS (USART_HandleTypeDef *husart, uint32_t NSSConfig)
HAL_StatusTypeDef HAL_USARTEx_EnableFifoMode (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USARTEx_DisableFifoMode (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USARTEx_SetTxFifoThreshold (USART_HandleTypeDef *husart, uint32_t Threshold)
HAL_StatusTypeDef HAL_USARTEx_SetRxFifoThreshold (USART_HandleTypeDef *husart, uint32_t Threshold)
Author
MCD Application Team
Attention
