RTEMS 6.1-rc1
Header file of SD HAL extended module. More...
#include "stm32h7xx_hal_def.h"
Enumerations | |
enum | HAL_SDEx_DMABuffer_MemoryTypeDef { SD_DMA_BUFFER0 = 0x00U , SD_DMA_BUFFER1 = 0x01U } |
HAL_StatusTypeDef | HAL_SDEx_ConfigDMAMultiBuffer (SD_HandleTypeDef *hsd, uint32_t *pDataBuffer0, uint32_t *pDataBuffer1, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SDEx_ReadBlocksDMAMultiBuffer (SD_HandleTypeDef *hsd, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_SDEx_WriteBlocksDMAMultiBuffer (SD_HandleTypeDef *hsd, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
HAL_StatusTypeDef | HAL_SDEx_ChangeDMABuffer (SD_HandleTypeDef *hsd, HAL_SDEx_DMABuffer_MemoryTypeDef Buffer, uint32_t *pDataBuffer) |
void | HAL_SDEx_Read_DMADoubleBuf0CpltCallback (SD_HandleTypeDef *hsd) |
void | HAL_SDEx_Read_DMADoubleBuf1CpltCallback (SD_HandleTypeDef *hsd) |
void | HAL_SDEx_Write_DMADoubleBuf0CpltCallback (SD_HandleTypeDef *hsd) |
void | HAL_SDEx_Write_DMADoubleBuf1CpltCallback (SD_HandleTypeDef *hsd) |
