RTEMS 6.1-rc1
stm32h7xx_hal_qspi.h
1
19/* Define to prevent recursive inclusion -------------------------------------*/
20#ifndef STM32H7xx_HAL_QSPI_H
21#define STM32H7xx_HAL_QSPI_H
22
23#ifdef __cplusplus
24 extern "C" {
25#endif
26
27/* Includes ------------------------------------------------------------------*/
28#include "stm32h7xx_hal_def.h"
29
30#if defined(QUADSPI)
31
40/* Exported types ------------------------------------------------------------*/
49typedef struct
50{
51 uint32_t ClockPrescaler; /* Specifies the prescaler factor for generating clock based on the AHB clock.
52 This parameter can be a number between 0 and 255 */
53 uint32_t FifoThreshold; /* Specifies the threshold number of bytes in the FIFO (used only in indirect mode)
54 This parameter can be a value between 1 and 32 */
55 uint32_t SampleShifting; /* Specifies the Sample Shift. The data is sampled 1/2 clock cycle delay later to
56 take in account external signal delays. (It should be QSPI_SAMPLE_SHIFTING_NONE in DDR mode)
57 This parameter can be a value of @ref QSPI_SampleShifting */
58 uint32_t FlashSize; /* Specifies the Flash Size. FlashSize+1 is effectively the number of address bits
59 required to address the flash memory. The flash capacity can be up to 4GB
60 (addressed using 32 bits) in indirect mode, but the addressable space in
61 memory-mapped mode is limited to 256MB
62 This parameter can be a number between 0 and 31 */
63 uint32_t ChipSelectHighTime; /* Specifies the Chip Select High Time. ChipSelectHighTime+1 defines the minimum number
64 of clock cycles which the chip select must remain high between commands.
65 This parameter can be a value of @ref QSPI_ChipSelectHighTime */
66 uint32_t ClockMode; /* Specifies the Clock Mode. It indicates the level that clock takes between commands.
67 This parameter can be a value of @ref QSPI_ClockMode */
68 uint32_t FlashID; /* Specifies the Flash which will be used,
69 This parameter can be a value of @ref QSPI_Flash_Select */
70 uint32_t DualFlash; /* Specifies the Dual Flash Mode State
71 This parameter can be a value of @ref QSPI_DualFlash_Mode */
72}QSPI_InitTypeDef;
73
77typedef enum
78{
79 HAL_QSPI_STATE_RESET = 0x00U,
80 HAL_QSPI_STATE_READY = 0x01U,
81 HAL_QSPI_STATE_BUSY = 0x02U,
82 HAL_QSPI_STATE_BUSY_INDIRECT_TX = 0x12U,
83 HAL_QSPI_STATE_BUSY_INDIRECT_RX = 0x22U,
84 HAL_QSPI_STATE_BUSY_AUTO_POLLING = 0x42U,
85 HAL_QSPI_STATE_BUSY_MEM_MAPPED = 0x82U,
86 HAL_QSPI_STATE_ABORT = 0x08U,
87 HAL_QSPI_STATE_ERROR = 0x04U
88}HAL_QSPI_StateTypeDef;
89
93#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
94typedef struct __QSPI_HandleTypeDef
95#else
96typedef struct
97#endif
98{
99 QUADSPI_TypeDef *Instance; /* QSPI registers base address */
100 QSPI_InitTypeDef Init; /* QSPI communication parameters */
101 uint8_t *pTxBuffPtr; /* Pointer to QSPI Tx transfer Buffer */
102 __IO uint32_t TxXferSize; /* QSPI Tx Transfer size */
103 __IO uint32_t TxXferCount; /* QSPI Tx Transfer Counter */
104 uint8_t *pRxBuffPtr; /* Pointer to QSPI Rx transfer Buffer */
105 __IO uint32_t RxXferSize; /* QSPI Rx Transfer size */
106 __IO uint32_t RxXferCount; /* QSPI Rx Transfer Counter */
107 MDMA_HandleTypeDef *hmdma; /* QSPI Rx/Tx MDMA Handle parameters */
108 __IO HAL_LockTypeDef Lock; /* Locking object */
109 __IO HAL_QSPI_StateTypeDef State; /* QSPI communication state */
110 __IO uint32_t ErrorCode; /* QSPI Error code */
111 uint32_t Timeout; /* Timeout for the QSPI memory access */
112#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
113 void (* ErrorCallback) (struct __QSPI_HandleTypeDef *hqspi);
114 void (* AbortCpltCallback) (struct __QSPI_HandleTypeDef *hqspi);
115 void (* FifoThresholdCallback)(struct __QSPI_HandleTypeDef *hqspi);
116 void (* CmdCpltCallback) (struct __QSPI_HandleTypeDef *hqspi);
117 void (* RxCpltCallback) (struct __QSPI_HandleTypeDef *hqspi);
118 void (* TxCpltCallback) (struct __QSPI_HandleTypeDef *hqspi);
119 void (* StatusMatchCallback) (struct __QSPI_HandleTypeDef *hqspi);
120 void (* TimeOutCallback) (struct __QSPI_HandleTypeDef *hqspi);
121
122 void (* MspInitCallback) (struct __QSPI_HandleTypeDef *hqspi);
123 void (* MspDeInitCallback) (struct __QSPI_HandleTypeDef *hqspi);
124#endif
125}QSPI_HandleTypeDef;
126
130typedef struct
131{
132 uint32_t Instruction; /* Specifies the Instruction to be sent
133 This parameter can be a value (8-bit) between 0x00 and 0xFF */
134 uint32_t Address; /* Specifies the Address to be sent (Size from 1 to 4 bytes according AddressSize)
135 This parameter can be a value (32-bits) between 0x0 and 0xFFFFFFFF */
136 uint32_t AlternateBytes; /* Specifies the Alternate Bytes to be sent (Size from 1 to 4 bytes according AlternateBytesSize)
137 This parameter can be a value (32-bits) between 0x0 and 0xFFFFFFFF */
138 uint32_t AddressSize; /* Specifies the Address Size
139 This parameter can be a value of @ref QSPI_AddressSize */
140 uint32_t AlternateBytesSize; /* Specifies the Alternate Bytes Size
141 This parameter can be a value of @ref QSPI_AlternateBytesSize */
142 uint32_t DummyCycles; /* Specifies the Number of Dummy Cycles.
143 This parameter can be a number between 0 and 31 */
144 uint32_t InstructionMode; /* Specifies the Instruction Mode
145 This parameter can be a value of @ref QSPI_InstructionMode */
146 uint32_t AddressMode; /* Specifies the Address Mode
147 This parameter can be a value of @ref QSPI_AddressMode */
148 uint32_t AlternateByteMode; /* Specifies the Alternate Bytes Mode
149 This parameter can be a value of @ref QSPI_AlternateBytesMode */
150 uint32_t DataMode; /* Specifies the Data Mode (used for dummy cycles and data phases)
151 This parameter can be a value of @ref QSPI_DataMode */
152 uint32_t NbData; /* Specifies the number of data to transfer. (This is the number of bytes)
153 This parameter can be any value between 0 and 0xFFFFFFFF (0 means undefined length
154 until end of memory)*/
155 uint32_t DdrMode; /* Specifies the double data rate mode for address, alternate byte and data phase
156 This parameter can be a value of @ref QSPI_DdrMode */
157 uint32_t DdrHoldHalfCycle; /* Specifies if the DDR hold is enabled. When enabled it delays the data
158 output by one half of system clock in DDR mode.
159 This parameter can be a value of @ref QSPI_DdrHoldHalfCycle */
160 uint32_t SIOOMode; /* Specifies the send instruction only once mode
161 This parameter can be a value of @ref QSPI_SIOOMode */
162}QSPI_CommandTypeDef;
163
167typedef struct
168{
169 uint32_t Match; /* Specifies the value to be compared with the masked status register to get a match.
170 This parameter can be any value between 0 and 0xFFFFFFFF */
171 uint32_t Mask; /* Specifies the mask to be applied to the status bytes received.
172 This parameter can be any value between 0 and 0xFFFFFFFF */
173 uint32_t Interval; /* Specifies the number of clock cycles between two read during automatic polling phases.
174 This parameter can be any value between 0 and 0xFFFF */
175 uint32_t StatusBytesSize; /* Specifies the size of the status bytes received.
176 This parameter can be any value between 1 and 4 */
177 uint32_t MatchMode; /* Specifies the method used for determining a match.
178 This parameter can be a value of @ref QSPI_MatchMode */
179 uint32_t AutomaticStop; /* Specifies if automatic polling is stopped after a match.
180 This parameter can be a value of @ref QSPI_AutomaticStop */
181}QSPI_AutoPollingTypeDef;
182
186typedef struct
187{
188 uint32_t TimeOutPeriod; /* Specifies the number of clock to wait when the FIFO is full before to release the chip select.
189 This parameter can be any value between 0 and 0xFFFF */
190 uint32_t TimeOutActivation; /* Specifies if the timeout counter is enabled to release the chip select.
191 This parameter can be a value of @ref QSPI_TimeOutActivation */
192}QSPI_MemoryMappedTypeDef;
193
194#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
198typedef enum
199{
200 HAL_QSPI_ERROR_CB_ID = 0x00U,
201 HAL_QSPI_ABORT_CB_ID = 0x01U,
202 HAL_QSPI_FIFO_THRESHOLD_CB_ID = 0x02U,
203 HAL_QSPI_CMD_CPLT_CB_ID = 0x03U,
204 HAL_QSPI_RX_CPLT_CB_ID = 0x04U,
205 HAL_QSPI_TX_CPLT_CB_ID = 0x05U,
206 HAL_QSPI_STATUS_MATCH_CB_ID = 0x08U,
207 HAL_QSPI_TIMEOUT_CB_ID = 0x09U,
209 HAL_QSPI_MSP_INIT_CB_ID = 0x0AU,
210 HAL_QSPI_MSP_DEINIT_CB_ID = 0x0B0
211}HAL_QSPI_CallbackIDTypeDef;
212
216typedef void (*pQSPI_CallbackTypeDef)(QSPI_HandleTypeDef *hqspi);
217#endif
222/* Exported constants --------------------------------------------------------*/
232#define HAL_QSPI_ERROR_NONE 0x00000000U
233#define HAL_QSPI_ERROR_TIMEOUT 0x00000001U
234#define HAL_QSPI_ERROR_TRANSFER 0x00000002U
235#define HAL_QSPI_ERROR_DMA 0x00000004U
236#define HAL_QSPI_ERROR_INVALID_PARAM 0x00000008U
237#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
238#define HAL_QSPI_ERROR_INVALID_CALLBACK 0x00000010U
239#endif
248#define QSPI_SAMPLE_SHIFTING_NONE 0x00000000U
249#define QSPI_SAMPLE_SHIFTING_HALFCYCLE ((uint32_t)QUADSPI_CR_SSHIFT)
258#define QSPI_CS_HIGH_TIME_1_CYCLE 0x00000000U
259#define QSPI_CS_HIGH_TIME_2_CYCLE ((uint32_t)QUADSPI_DCR_CSHT_0)
260#define QSPI_CS_HIGH_TIME_3_CYCLE ((uint32_t)QUADSPI_DCR_CSHT_1)
261#define QSPI_CS_HIGH_TIME_4_CYCLE ((uint32_t)QUADSPI_DCR_CSHT_0 | QUADSPI_DCR_CSHT_1)
262#define QSPI_CS_HIGH_TIME_5_CYCLE ((uint32_t)QUADSPI_DCR_CSHT_2)
263#define QSPI_CS_HIGH_TIME_6_CYCLE ((uint32_t)QUADSPI_DCR_CSHT_2 | QUADSPI_DCR_CSHT_0)
264#define QSPI_CS_HIGH_TIME_7_CYCLE ((uint32_t)QUADSPI_DCR_CSHT_2 | QUADSPI_DCR_CSHT_1)
265#define QSPI_CS_HIGH_TIME_8_CYCLE ((uint32_t)QUADSPI_DCR_CSHT)
274#define QSPI_CLOCK_MODE_0 0x00000000U
275#define QSPI_CLOCK_MODE_3 ((uint32_t)QUADSPI_DCR_CKMODE)
284#define QSPI_FLASH_ID_1 0x00000000U
285#define QSPI_FLASH_ID_2 ((uint32_t)QUADSPI_CR_FSEL)
294#define QSPI_DUALFLASH_ENABLE ((uint32_t)QUADSPI_CR_DFM)
295#define QSPI_DUALFLASH_DISABLE 0x00000000U
304#define QSPI_ADDRESS_8_BITS 0x00000000U
305#define QSPI_ADDRESS_16_BITS ((uint32_t)QUADSPI_CCR_ADSIZE_0)
306#define QSPI_ADDRESS_24_BITS ((uint32_t)QUADSPI_CCR_ADSIZE_1)
307#define QSPI_ADDRESS_32_BITS ((uint32_t)QUADSPI_CCR_ADSIZE)
316#define QSPI_ALTERNATE_BYTES_8_BITS 0x00000000U
317#define QSPI_ALTERNATE_BYTES_16_BITS ((uint32_t)QUADSPI_CCR_ABSIZE_0)
318#define QSPI_ALTERNATE_BYTES_24_BITS ((uint32_t)QUADSPI_CCR_ABSIZE_1)
319#define QSPI_ALTERNATE_BYTES_32_BITS ((uint32_t)QUADSPI_CCR_ABSIZE)
328#define QSPI_INSTRUCTION_NONE 0x00000000U
329#define QSPI_INSTRUCTION_1_LINE ((uint32_t)QUADSPI_CCR_IMODE_0)
330#define QSPI_INSTRUCTION_2_LINES ((uint32_t)QUADSPI_CCR_IMODE_1)
331#define QSPI_INSTRUCTION_4_LINES ((uint32_t)QUADSPI_CCR_IMODE)
340#define QSPI_ADDRESS_NONE 0x00000000U
341#define QSPI_ADDRESS_1_LINE ((uint32_t)QUADSPI_CCR_ADMODE_0)
342#define QSPI_ADDRESS_2_LINES ((uint32_t)QUADSPI_CCR_ADMODE_1)
343#define QSPI_ADDRESS_4_LINES ((uint32_t)QUADSPI_CCR_ADMODE)
352#define QSPI_ALTERNATE_BYTES_NONE 0x00000000U
353#define QSPI_ALTERNATE_BYTES_1_LINE ((uint32_t)QUADSPI_CCR_ABMODE_0)
354#define QSPI_ALTERNATE_BYTES_2_LINES ((uint32_t)QUADSPI_CCR_ABMODE_1)
355#define QSPI_ALTERNATE_BYTES_4_LINES ((uint32_t)QUADSPI_CCR_ABMODE)
364#define QSPI_DATA_NONE 0x00000000U
365#define QSPI_DATA_1_LINE ((uint32_t)QUADSPI_CCR_DMODE_0)
366#define QSPI_DATA_2_LINES ((uint32_t)QUADSPI_CCR_DMODE_1)
367#define QSPI_DATA_4_LINES ((uint32_t)QUADSPI_CCR_DMODE)
376#define QSPI_DDR_MODE_DISABLE 0x00000000U
377#define QSPI_DDR_MODE_ENABLE ((uint32_t)QUADSPI_CCR_DDRM)
386#define QSPI_DDR_HHC_ANALOG_DELAY 0x00000000U
387#define QSPI_DDR_HHC_HALF_CLK_DELAY ((uint32_t)QUADSPI_CCR_DHHC)
396#define QSPI_SIOO_INST_EVERY_CMD 0x00000000U
397#define QSPI_SIOO_INST_ONLY_FIRST_CMD ((uint32_t)QUADSPI_CCR_SIOO)
406#define QSPI_MATCH_MODE_AND 0x00000000U
407#define QSPI_MATCH_MODE_OR ((uint32_t)QUADSPI_CR_PMM)
416#define QSPI_AUTOMATIC_STOP_DISABLE 0x00000000U
417#define QSPI_AUTOMATIC_STOP_ENABLE ((uint32_t)QUADSPI_CR_APMS)
426#define QSPI_TIMEOUT_COUNTER_DISABLE 0x00000000U
427#define QSPI_TIMEOUT_COUNTER_ENABLE ((uint32_t)QUADSPI_CR_TCEN)
436#define QSPI_FLAG_BUSY QUADSPI_SR_BUSY
437#define QSPI_FLAG_TO QUADSPI_SR_TOF
438#define QSPI_FLAG_SM QUADSPI_SR_SMF
439#define QSPI_FLAG_FT QUADSPI_SR_FTF
440#define QSPI_FLAG_TC QUADSPI_SR_TCF
441#define QSPI_FLAG_TE QUADSPI_SR_TEF
450#define QSPI_IT_TO QUADSPI_CR_TOIE
451#define QSPI_IT_SM QUADSPI_CR_SMIE
452#define QSPI_IT_FT QUADSPI_CR_FTIE
453#define QSPI_IT_TC QUADSPI_CR_TCIE
454#define QSPI_IT_TE QUADSPI_CR_TEIE
464#define HAL_QSPI_TIMEOUT_DEFAULT_VALUE 5000U /* 5 s */
473/* Exported macros -----------------------------------------------------------*/
482#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
483#define __HAL_QSPI_RESET_HANDLE_STATE(__HANDLE__) do { \
484 (__HANDLE__)->State = HAL_QSPI_STATE_RESET; \
485 (__HANDLE__)->MspInitCallback = NULL; \
486 (__HANDLE__)->MspDeInitCallback = NULL; \
487 } while(0)
488#else
489#define __HAL_QSPI_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_QSPI_STATE_RESET)
490#endif
491
496#define __HAL_QSPI_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR, QUADSPI_CR_EN)
497
502#define __HAL_QSPI_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CR, QUADSPI_CR_EN)
503
515#define __HAL_QSPI_ENABLE_IT(__HANDLE__, __INTERRUPT__) SET_BIT((__HANDLE__)->Instance->CR, (__INTERRUPT__))
516
517
529#define __HAL_QSPI_DISABLE_IT(__HANDLE__, __INTERRUPT__) CLEAR_BIT((__HANDLE__)->Instance->CR, (__INTERRUPT__))
530
542#define __HAL_QSPI_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (READ_BIT((__HANDLE__)->Instance->CR, (__INTERRUPT__)) == (__INTERRUPT__))
543
557#define __HAL_QSPI_GET_FLAG(__HANDLE__, __FLAG__) ((READ_BIT((__HANDLE__)->Instance->SR, (__FLAG__)) != 0U) ? SET : RESET)
558
569#define __HAL_QSPI_CLEAR_FLAG(__HANDLE__, __FLAG__) WRITE_REG((__HANDLE__)->Instance->FCR, (__FLAG__))
574/* Exported functions --------------------------------------------------------*/
582/* Initialization/de-initialization functions ********************************/
583HAL_StatusTypeDef HAL_QSPI_Init (QSPI_HandleTypeDef *hqspi);
584HAL_StatusTypeDef HAL_QSPI_DeInit (QSPI_HandleTypeDef *hqspi);
585void HAL_QSPI_MspInit (QSPI_HandleTypeDef *hqspi);
586void HAL_QSPI_MspDeInit(QSPI_HandleTypeDef *hqspi);
594/* IO operation functions *****************************************************/
595/* QSPI IRQ handler method */
596void HAL_QSPI_IRQHandler(QSPI_HandleTypeDef *hqspi);
597
598/* QSPI indirect mode */
599HAL_StatusTypeDef HAL_QSPI_Command (QSPI_HandleTypeDef *hqspi, QSPI_CommandTypeDef *cmd, uint32_t Timeout);
600HAL_StatusTypeDef HAL_QSPI_Transmit (QSPI_HandleTypeDef *hqspi, uint8_t *pData, uint32_t Timeout);
601HAL_StatusTypeDef HAL_QSPI_Receive (QSPI_HandleTypeDef *hqspi, uint8_t *pData, uint32_t Timeout);
602HAL_StatusTypeDef HAL_QSPI_Command_IT (QSPI_HandleTypeDef *hqspi, QSPI_CommandTypeDef *cmd);
603HAL_StatusTypeDef HAL_QSPI_Transmit_IT (QSPI_HandleTypeDef *hqspi, uint8_t *pData);
604HAL_StatusTypeDef HAL_QSPI_Receive_IT (QSPI_HandleTypeDef *hqspi, uint8_t *pData);
605HAL_StatusTypeDef HAL_QSPI_Transmit_DMA (QSPI_HandleTypeDef *hqspi, uint8_t *pData);
606HAL_StatusTypeDef HAL_QSPI_Receive_DMA (QSPI_HandleTypeDef *hqspi, uint8_t *pData);
607
608/* QSPI status flag polling mode */
609HAL_StatusTypeDef HAL_QSPI_AutoPolling (QSPI_HandleTypeDef *hqspi, QSPI_CommandTypeDef *cmd, QSPI_AutoPollingTypeDef *cfg, uint32_t Timeout);
610HAL_StatusTypeDef HAL_QSPI_AutoPolling_IT(QSPI_HandleTypeDef *hqspi, QSPI_CommandTypeDef *cmd, QSPI_AutoPollingTypeDef *cfg);
611
612/* QSPI memory-mapped mode */
613HAL_StatusTypeDef HAL_QSPI_MemoryMapped(QSPI_HandleTypeDef *hqspi, QSPI_CommandTypeDef *cmd, QSPI_MemoryMappedTypeDef *cfg);
614
615/* Callback functions in non-blocking modes ***********************************/
616void HAL_QSPI_ErrorCallback (QSPI_HandleTypeDef *hqspi);
617void HAL_QSPI_AbortCpltCallback (QSPI_HandleTypeDef *hqspi);
618void HAL_QSPI_FifoThresholdCallback(QSPI_HandleTypeDef *hqspi);
619
620/* QSPI indirect mode */
621void HAL_QSPI_CmdCpltCallback (QSPI_HandleTypeDef *hqspi);
622void HAL_QSPI_RxCpltCallback (QSPI_HandleTypeDef *hqspi);
623void HAL_QSPI_TxCpltCallback (QSPI_HandleTypeDef *hqspi);
624
625/* QSPI status flag polling mode */
626void HAL_QSPI_StatusMatchCallback (QSPI_HandleTypeDef *hqspi);
627
628/* QSPI memory-mapped mode */
629void HAL_QSPI_TimeOutCallback (QSPI_HandleTypeDef *hqspi);
630
631#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
632/* QSPI callback registering/unregistering */
633HAL_StatusTypeDef HAL_QSPI_RegisterCallback (QSPI_HandleTypeDef *hqspi, HAL_QSPI_CallbackIDTypeDef CallbackId, pQSPI_CallbackTypeDef pCallback);
634HAL_StatusTypeDef HAL_QSPI_UnRegisterCallback (QSPI_HandleTypeDef *hqspi, HAL_QSPI_CallbackIDTypeDef CallbackId);
635#endif
643/* Peripheral Control and State functions ************************************/
644HAL_QSPI_StateTypeDef HAL_QSPI_GetState (QSPI_HandleTypeDef *hqspi);
645uint32_t HAL_QSPI_GetError (QSPI_HandleTypeDef *hqspi);
646HAL_StatusTypeDef HAL_QSPI_Abort (QSPI_HandleTypeDef *hqspi);
647HAL_StatusTypeDef HAL_QSPI_Abort_IT (QSPI_HandleTypeDef *hqspi);
648void HAL_QSPI_SetTimeout (QSPI_HandleTypeDef *hqspi, uint32_t Timeout);
649HAL_StatusTypeDef HAL_QSPI_SetFifoThreshold(QSPI_HandleTypeDef *hqspi, uint32_t Threshold);
650uint32_t HAL_QSPI_GetFifoThreshold(QSPI_HandleTypeDef *hqspi);
651HAL_StatusTypeDef HAL_QSPI_SetFlashID (QSPI_HandleTypeDef *hqspi, uint32_t FlashID);
659/* End of exported functions -------------------------------------------------*/
660
661/* Private macros ------------------------------------------------------------*/
666#define IS_QSPI_CLOCK_PRESCALER(PRESCALER) ((PRESCALER) <= 0xFFU)
667
668#define IS_QSPI_FIFO_THRESHOLD(THR) (((THR) > 0U) && ((THR) <= 32U))
669
670#define IS_QSPI_SSHIFT(SSHIFT) (((SSHIFT) == QSPI_SAMPLE_SHIFTING_NONE) || \
671 ((SSHIFT) == QSPI_SAMPLE_SHIFTING_HALFCYCLE))
672
673#define IS_QSPI_FLASH_SIZE(FSIZE) (((FSIZE) <= 31U))
674
675#define IS_QSPI_CS_HIGH_TIME(CSHTIME) (((CSHTIME) == QSPI_CS_HIGH_TIME_1_CYCLE) || \
676 ((CSHTIME) == QSPI_CS_HIGH_TIME_2_CYCLE) || \
677 ((CSHTIME) == QSPI_CS_HIGH_TIME_3_CYCLE) || \
678 ((CSHTIME) == QSPI_CS_HIGH_TIME_4_CYCLE) || \
679 ((CSHTIME) == QSPI_CS_HIGH_TIME_5_CYCLE) || \
680 ((CSHTIME) == QSPI_CS_HIGH_TIME_6_CYCLE) || \
681 ((CSHTIME) == QSPI_CS_HIGH_TIME_7_CYCLE) || \
682 ((CSHTIME) == QSPI_CS_HIGH_TIME_8_CYCLE))
683
684#define IS_QSPI_CLOCK_MODE(CLKMODE) (((CLKMODE) == QSPI_CLOCK_MODE_0) || \
685 ((CLKMODE) == QSPI_CLOCK_MODE_3))
686
687#define IS_QSPI_FLASH_ID(FLASH_ID) (((FLASH_ID) == QSPI_FLASH_ID_1) || \
688 ((FLASH_ID) == QSPI_FLASH_ID_2))
689
690#define IS_QSPI_DUAL_FLASH_MODE(MODE) (((MODE) == QSPI_DUALFLASH_ENABLE) || \
691 ((MODE) == QSPI_DUALFLASH_DISABLE))
692
693#define IS_QSPI_INSTRUCTION(INSTRUCTION) ((INSTRUCTION) <= 0xFFU)
694
695#define IS_QSPI_ADDRESS_SIZE(ADDR_SIZE) (((ADDR_SIZE) == QSPI_ADDRESS_8_BITS) || \
696 ((ADDR_SIZE) == QSPI_ADDRESS_16_BITS) || \
697 ((ADDR_SIZE) == QSPI_ADDRESS_24_BITS) || \
698 ((ADDR_SIZE) == QSPI_ADDRESS_32_BITS))
699
700#define IS_QSPI_ALTERNATE_BYTES_SIZE(SIZE) (((SIZE) == QSPI_ALTERNATE_BYTES_8_BITS) || \
701 ((SIZE) == QSPI_ALTERNATE_BYTES_16_BITS) || \
702 ((SIZE) == QSPI_ALTERNATE_BYTES_24_BITS) || \
703 ((SIZE) == QSPI_ALTERNATE_BYTES_32_BITS))
704
705#define IS_QSPI_DUMMY_CYCLES(DCY) ((DCY) <= 31U)
706
707#define IS_QSPI_INSTRUCTION_MODE(MODE) (((MODE) == QSPI_INSTRUCTION_NONE) || \
708 ((MODE) == QSPI_INSTRUCTION_1_LINE) || \
709 ((MODE) == QSPI_INSTRUCTION_2_LINES) || \
710 ((MODE) == QSPI_INSTRUCTION_4_LINES))
711
712#define IS_QSPI_ADDRESS_MODE(MODE) (((MODE) == QSPI_ADDRESS_NONE) || \
713 ((MODE) == QSPI_ADDRESS_1_LINE) || \
714 ((MODE) == QSPI_ADDRESS_2_LINES) || \
715 ((MODE) == QSPI_ADDRESS_4_LINES))
716
717#define IS_QSPI_ALTERNATE_BYTES_MODE(MODE) (((MODE) == QSPI_ALTERNATE_BYTES_NONE) || \
718 ((MODE) == QSPI_ALTERNATE_BYTES_1_LINE) || \
719 ((MODE) == QSPI_ALTERNATE_BYTES_2_LINES) || \
720 ((MODE) == QSPI_ALTERNATE_BYTES_4_LINES))
721
722#define IS_QSPI_DATA_MODE(MODE) (((MODE) == QSPI_DATA_NONE) || \
723 ((MODE) == QSPI_DATA_1_LINE) || \
724 ((MODE) == QSPI_DATA_2_LINES) || \
725 ((MODE) == QSPI_DATA_4_LINES))
726
727#define IS_QSPI_DDR_MODE(DDR_MODE) (((DDR_MODE) == QSPI_DDR_MODE_DISABLE) || \
728 ((DDR_MODE) == QSPI_DDR_MODE_ENABLE))
729
730#define IS_QSPI_DDR_HHC(DDR_HHC) (((DDR_HHC) == QSPI_DDR_HHC_ANALOG_DELAY) || \
731 ((DDR_HHC) == QSPI_DDR_HHC_HALF_CLK_DELAY))
732
733#define IS_QSPI_SIOO_MODE(SIOO_MODE) (((SIOO_MODE) == QSPI_SIOO_INST_EVERY_CMD) || \
734 ((SIOO_MODE) == QSPI_SIOO_INST_ONLY_FIRST_CMD))
735
736#define IS_QSPI_INTERVAL(INTERVAL) ((INTERVAL) <= QUADSPI_PIR_INTERVAL)
737
738#define IS_QSPI_STATUS_BYTES_SIZE(SIZE) (((SIZE) >= 1U) && ((SIZE) <= 4U))
739
740#define IS_QSPI_MATCH_MODE(MODE) (((MODE) == QSPI_MATCH_MODE_AND) || \
741 ((MODE) == QSPI_MATCH_MODE_OR))
742
743#define IS_QSPI_AUTOMATIC_STOP(APMS) (((APMS) == QSPI_AUTOMATIC_STOP_DISABLE) || \
744 ((APMS) == QSPI_AUTOMATIC_STOP_ENABLE))
745
746#define IS_QSPI_TIMEOUT_ACTIVATION(TCEN) (((TCEN) == QSPI_TIMEOUT_COUNTER_DISABLE) || \
747 ((TCEN) == QSPI_TIMEOUT_COUNTER_ENABLE))
748
749#define IS_QSPI_TIMEOUT_PERIOD(PERIOD) ((PERIOD) <= 0xFFFFU)
753/* End of private macros -----------------------------------------------------*/
754
763#endif /* defined(QUADSPI) */
764
765#ifdef __cplusplus
766}
767#endif
768
769#endif /* STM32H7xx_HAL_QSPI_H */
#define __IO
Definition: core_cm4.h:239
This file contains HAL common defines, enumeration, macros and structures definitions.
HAL_StatusTypeDef
HAL Status structures definition.
Definition: stm32h7xx_hal_def.h:47
HAL_LockTypeDef
HAL Lock structures definition.
Definition: stm32h7xx_hal_def.h:58
QUAD Serial Peripheral Interface.
Definition: stm32h742xx.h:1415
MDMA handle Structure definition.
Definition: stm32h7xx_hal_mdma.h:204
