RTEMS 6.1-rc1
Header file of DMA HAL module. More...
#include "stm32h7xx_hal_def.h"
struct | MDMA_InitTypeDef |
MDMA Configuration Structure definition. More... | |
struct | MDMA_LinkNodeTypeDef |
HAL MDMA linked list node structure definition. More... | |
struct | MDMA_LinkNodeConfTypeDef |
HAL MDMA linked list node configuration structure definition. More... | |
struct | __MDMA_HandleTypeDef |
MDMA handle Structure definition. More... | |
#define | HAL_MDMA_ERROR_NONE ((uint32_t)0x00000000U) |
#define | HAL_MDMA_ERROR_READ_XFER ((uint32_t)0x00000001U) |
#define | HAL_MDMA_ERROR_WRITE_XFER ((uint32_t)0x00000002U) |
#define | HAL_MDMA_ERROR_MASK_DATA ((uint32_t)0x00000004U) |
#define | HAL_MDMA_ERROR_LINKED_LIST ((uint32_t)0x00000008U) |
#define | HAL_MDMA_ERROR_ALIGNMENT ((uint32_t)0x00000010U) |
#define | HAL_MDMA_ERROR_BLOCK_SIZE ((uint32_t)0x00000020U) |
#define | HAL_MDMA_ERROR_TIMEOUT ((uint32_t)0x00000040U) |
#define | HAL_MDMA_ERROR_NO_XFER ((uint32_t)0x00000080U) |
#define | HAL_MDMA_ERROR_BUSY ((uint32_t)0x00000100U) |
#define | MDMA_REQUEST_DMA1_Stream0_TC ((uint32_t)0x00000000U) |
#define | MDMA_REQUEST_DMA1_Stream1_TC ((uint32_t)0x00000001U) |
#define | MDMA_REQUEST_DMA1_Stream2_TC ((uint32_t)0x00000002U) |
#define | MDMA_REQUEST_DMA1_Stream3_TC ((uint32_t)0x00000003U) |
#define | MDMA_REQUEST_DMA1_Stream4_TC ((uint32_t)0x00000004U) |
#define | MDMA_REQUEST_DMA1_Stream5_TC ((uint32_t)0x00000005U) |
#define | MDMA_REQUEST_DMA1_Stream6_TC ((uint32_t)0x00000006U) |
#define | MDMA_REQUEST_DMA1_Stream7_TC ((uint32_t)0x00000007U) |
#define | MDMA_REQUEST_DMA2_Stream0_TC ((uint32_t)0x00000008U) |
#define | MDMA_REQUEST_DMA2_Stream1_TC ((uint32_t)0x00000009U) |
#define | MDMA_REQUEST_DMA2_Stream2_TC ((uint32_t)0x0000000AU) |
#define | MDMA_REQUEST_DMA2_Stream3_TC ((uint32_t)0x0000000BU) |
#define | MDMA_REQUEST_DMA2_Stream4_TC ((uint32_t)0x0000000CU) |
#define | MDMA_REQUEST_DMA2_Stream5_TC ((uint32_t)0x0000000DU) |
#define | MDMA_REQUEST_DMA2_Stream6_TC ((uint32_t)0x0000000EU) |
#define | MDMA_REQUEST_DMA2_Stream7_TC ((uint32_t)0x0000000FU) |
#define | MDMA_REQUEST_DMA2D_CLUT_TC ((uint32_t)0x00000018U) |
#define | MDMA_REQUEST_DMA2D_TC ((uint32_t)0x00000019U) |
#define | MDMA_REQUEST_DMA2D_TW ((uint32_t)0x0000001AU) |
#define | MDMA_REQUEST_SDMMC1_END_DATA ((uint32_t)0x0000001DU) |
#define | MDMA_REQUEST_SDMMC1_DMA_ENDBUFFER ((uint32_t)0x0000001EU) |
#define | MDMA_REQUEST_SDMMC1_COMMAND_END ((uint32_t)0x0000001FU) |
#define | MDMA_REQUEST_SW ((uint32_t)0x40000000U) |
#define | MDMA_BUFFER_TRANSFER ((uint32_t)0x00000000U) |
#define | MDMA_BLOCK_TRANSFER ((uint32_t)MDMA_CTCR_TRGM_0) |
#define | MDMA_REPEAT_BLOCK_TRANSFER ((uint32_t)MDMA_CTCR_TRGM_1) |
#define | MDMA_FULL_TRANSFER ((uint32_t)MDMA_CTCR_TRGM) |
#define | MDMA_PRIORITY_LOW ((uint32_t)0x00000000U) |
#define | MDMA_PRIORITY_MEDIUM ((uint32_t)MDMA_CCR_PL_0) |
#define | MDMA_PRIORITY_HIGH ((uint32_t)MDMA_CCR_PL_1) |
#define | MDMA_PRIORITY_VERY_HIGH ((uint32_t)MDMA_CCR_PL) |
#define | MDMA_LITTLE_ENDIANNESS_PRESERVE ((uint32_t)0x00000000U) |
#define | MDMA_LITTLE_BYTE_ENDIANNESS_EXCHANGE ((uint32_t)MDMA_CCR_BEX) |
#define | MDMA_LITTLE_HALFWORD_ENDIANNESS_EXCHANGE ((uint32_t)MDMA_CCR_HEX) |
#define | MDMA_LITTLE_WORD_ENDIANNESS_EXCHANGE ((uint32_t)MDMA_CCR_WEX) |
#define | MDMA_SRC_INC_DISABLE ((uint32_t)0x00000000U) |
#define | MDMA_SRC_INC_BYTE ((uint32_t)MDMA_CTCR_SINC_1) |
#define | MDMA_SRC_INC_HALFWORD ((uint32_t)MDMA_CTCR_SINC_1 | (uint32_t)MDMA_CTCR_SINCOS_0) |
#define | MDMA_SRC_INC_WORD ((uint32_t)MDMA_CTCR_SINC_1 | (uint32_t)MDMA_CTCR_SINCOS_1) |
#define | MDMA_SRC_INC_DOUBLEWORD ((uint32_t)MDMA_CTCR_SINC_1 | (uint32_t)MDMA_CTCR_SINCOS) |
#define | MDMA_SRC_DEC_BYTE ((uint32_t)MDMA_CTCR_SINC) |
#define | MDMA_SRC_DEC_HALFWORD ((uint32_t)MDMA_CTCR_SINC | (uint32_t)MDMA_CTCR_SINCOS_0) |
#define | MDMA_SRC_DEC_WORD ((uint32_t)MDMA_CTCR_SINC | (uint32_t)MDMA_CTCR_SINCOS_1) |
#define | MDMA_SRC_DEC_DOUBLEWORD ((uint32_t)MDMA_CTCR_SINC | (uint32_t)MDMA_CTCR_SINCOS) |
#define | MDMA_DEST_INC_DISABLE ((uint32_t)0x00000000U) |
#define | MDMA_DEST_INC_BYTE ((uint32_t)MDMA_CTCR_DINC_1) |
#define | MDMA_DEST_INC_HALFWORD ((uint32_t)MDMA_CTCR_DINC_1 | (uint32_t)MDMA_CTCR_DINCOS_0) |
#define | MDMA_DEST_INC_WORD ((uint32_t)MDMA_CTCR_DINC_1 | (uint32_t)MDMA_CTCR_DINCOS_1) |
#define | MDMA_DEST_INC_DOUBLEWORD ((uint32_t)MDMA_CTCR_DINC_1 | (uint32_t)MDMA_CTCR_DINCOS) |
#define | MDMA_DEST_DEC_BYTE ((uint32_t)MDMA_CTCR_DINC) |
#define | MDMA_DEST_DEC_HALFWORD ((uint32_t)MDMA_CTCR_DINC | (uint32_t)MDMA_CTCR_DINCOS_0) |
#define | MDMA_DEST_DEC_WORD ((uint32_t)MDMA_CTCR_DINC | (uint32_t)MDMA_CTCR_DINCOS_1) |
#define | MDMA_DEST_DEC_DOUBLEWORD ((uint32_t)MDMA_CTCR_DINC | (uint32_t)MDMA_CTCR_DINCOS) |
#define | MDMA_SRC_DATASIZE_BYTE ((uint32_t)0x00000000U) |
#define | MDMA_SRC_DATASIZE_HALFWORD ((uint32_t)MDMA_CTCR_SSIZE_0) |
#define | MDMA_SRC_DATASIZE_WORD ((uint32_t)MDMA_CTCR_SSIZE_1) |
#define | MDMA_SRC_DATASIZE_DOUBLEWORD ((uint32_t)MDMA_CTCR_SSIZE) |
#define | MDMA_DEST_DATASIZE_BYTE ((uint32_t)0x00000000U) |
#define | MDMA_DEST_DATASIZE_HALFWORD ((uint32_t)MDMA_CTCR_DSIZE_0) |
#define | MDMA_DEST_DATASIZE_WORD ((uint32_t)MDMA_CTCR_DSIZE_1) |
#define | MDMA_DEST_DATASIZE_DOUBLEWORD ((uint32_t)MDMA_CTCR_DSIZE) |
#define | MDMA_DATAALIGN_PACKENABLE ((uint32_t)MDMA_CTCR_PKE) |
#define | MDMA_DATAALIGN_RIGHT ((uint32_t)0x00000000U) |
#define | MDMA_DATAALIGN_RIGHT_SIGNED ((uint32_t)MDMA_CTCR_PAM_0) |
#define | MDMA_DATAALIGN_LEFT ((uint32_t)MDMA_CTCR_PAM_1) |
#define | MDMA_SOURCE_BURST_SINGLE ((uint32_t)0x00000000U) |
#define | MDMA_SOURCE_BURST_2BEATS ((uint32_t)MDMA_CTCR_SBURST_0) |
#define | MDMA_SOURCE_BURST_4BEATS ((uint32_t)MDMA_CTCR_SBURST_1) |
#define | MDMA_SOURCE_BURST_8BEATS ((uint32_t)MDMA_CTCR_SBURST_0 | (uint32_t)MDMA_CTCR_SBURST_1) |
#define | MDMA_SOURCE_BURST_16BEATS ((uint32_t)MDMA_CTCR_SBURST_2) |
#define | MDMA_SOURCE_BURST_32BEATS ((uint32_t)MDMA_CTCR_SBURST_0 | (uint32_t)MDMA_CTCR_SBURST_2) |
#define | MDMA_SOURCE_BURST_64BEATS ((uint32_t)MDMA_CTCR_SBURST_1 | (uint32_t)MDMA_CTCR_SBURST_2) |
#define | MDMA_SOURCE_BURST_128BEATS ((uint32_t)MDMA_CTCR_SBURST) |
#define | MDMA_DEST_BURST_SINGLE ((uint32_t)0x00000000U) |
#define | MDMA_DEST_BURST_2BEATS ((uint32_t)MDMA_CTCR_DBURST_0) |
#define | MDMA_DEST_BURST_4BEATS ((uint32_t)MDMA_CTCR_DBURST_1) |
#define | MDMA_DEST_BURST_8BEATS ((uint32_t)MDMA_CTCR_DBURST_0 | (uint32_t)MDMA_CTCR_DBURST_1) |
#define | MDMA_DEST_BURST_16BEATS ((uint32_t)MDMA_CTCR_DBURST_2) |
#define | MDMA_DEST_BURST_32BEATS ((uint32_t)MDMA_CTCR_DBURST_0 | (uint32_t)MDMA_CTCR_DBURST_2) |
#define | MDMA_DEST_BURST_64BEATS ((uint32_t)MDMA_CTCR_DBURST_1 | (uint32_t)MDMA_CTCR_DBURST_2) |
#define | MDMA_DEST_BURST_128BEATS ((uint32_t)MDMA_CTCR_DBURST) |
#define | MDMA_IT_TE ((uint32_t)MDMA_CCR_TEIE) |
#define | MDMA_IT_CTC ((uint32_t)MDMA_CCR_CTCIE) |
#define | MDMA_IT_BRT ((uint32_t)MDMA_CCR_BRTIE) |
#define | MDMA_IT_BT ((uint32_t)MDMA_CCR_BTIE) |
#define | MDMA_IT_BFTC ((uint32_t)MDMA_CCR_TCIE) |
#define | MDMA_FLAG_TE ((uint32_t)MDMA_CISR_TEIF) |
#define | MDMA_FLAG_CTC ((uint32_t)MDMA_CISR_CTCIF) |
#define | MDMA_FLAG_BRT ((uint32_t)MDMA_CISR_BRTIF) |
#define | MDMA_FLAG_BT ((uint32_t)MDMA_CISR_BTIF) |
#define | MDMA_FLAG_BFTC ((uint32_t)MDMA_CISR_TCIF) |
#define | MDMA_FLAG_CRQA ((uint32_t)MDMA_CISR_CRQA) |
#define | __HAL_MDMA_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CCR |= MDMA_CCR_EN) |
Enable the specified MDMA Channel. More... | |
#define | __HAL_MDMA_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CCR &= ~MDMA_CCR_EN) |
Disable the specified MDMA Channel. More... | |
#define | __HAL_MDMA_GET_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->CISR & (__FLAG__)) |
Get the MDMA Channel pending flags. More... | |
#define | __HAL_MDMA_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->CIFCR = (__FLAG__)) |
Clear the MDMA Stream pending flags. More... | |
#define | __HAL_MDMA_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CCR |= (__INTERRUPT__)) |
Enables the specified MDMA Channel interrupts. More... | |
#define | __HAL_MDMA_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CCR &= ~(__INTERRUPT__)) |
Disables the specified MDMA Channel interrupts. More... | |
#define | __HAL_MDMA_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((__HANDLE__)->Instance->CCR & (__INTERRUPT__))) |
Checks whether the specified MDMA Channel interrupt is enabled or not. More... | |
#define | __HAL_MDMA_SET_COUNTER(__HANDLE__, __COUNTER__) ((__HANDLE__)->Instance->CBNDTR |= ((__COUNTER__) & MDMA_CBNDTR_BNDT)) |
Writes the number of data in bytes to be transferred on the MDMA Channelx. More... | |
#define | __HAL_MDMA_GET_COUNTER(__HANDLE__) ((__HANDLE__)->Instance->CBNDTR & MDMA_CBNDTR_BNDT) |
Returns the number of remaining data in bytes in the current MDMA Channelx transfer. More... | |
#define | IS_MDMA_LEVEL_COMPLETE(__LEVEL__) |
#define | IS_MDMA_PRIORITY(__PRIORITY__) |
#define | IS_MDMA_ENDIANNESS_MODE(__ENDIANNESS__) |
#define | IS_MDMA_REQUEST(__REQUEST__) (((__REQUEST__) == MDMA_REQUEST_SW ) || ((__REQUEST__) <= MDMA_REQUEST_SDMMC1_COMMAND_END)) |
#define | IS_MDMA_SOURCE_INC(__INC__) |
#define | IS_MDMA_DESTINATION_INC(__INC__) |
#define | IS_MDMA_SOURCE_DATASIZE(__SIZE__) |
#define | IS_MDMA_DESTINATION_DATASIZE(__SIZE__) |
#define | IS_MDMA_DATA_ALIGNMENT(__ALIGNMENT__) |
#define | IS_MDMA_SOURCE_BURST(__BURST__) |
#define | IS_MDMA_DESTINATION_BURST(__BURST__) |
#define | IS_MDMA_TRANSFER_TRIGGER_MODE(__MODE__) |
#define | IS_MDMA_BUFFER_TRANSFER_LENGTH(__LENGTH__) (((__LENGTH__) >= 0x00000001U) && ((__LENGTH__) < 0x000000FFU)) |
#define | IS_MDMA_BLOCK_COUNT(__COUNT__) (((__COUNT__) > 0U ) && ((__COUNT__) <= 4096U)) |
#define | IS_MDMA_TRANSFER_LENGTH(SIZE) (((SIZE) > 0U) && ((SIZE) <= 65536U)) |
#define | IS_MDMA_BLOCK_ADDR_OFFSET(__BLOCK_ADD_OFFSET__) (((__BLOCK_ADD_OFFSET__) > (-65536)) && ((__BLOCK_ADD_OFFSET__) < 65536)) |
Typedefs | |
typedef struct __MDMA_HandleTypeDef | MDMA_HandleTypeDef |
MDMA handle Structure definition. | |
Enumerations | |
enum | HAL_MDMA_StateTypeDef { HAL_MDMA_STATE_RESET = 0x00U , HAL_MDMA_STATE_READY = 0x01U , HAL_MDMA_STATE_BUSY = 0x02U , HAL_MDMA_STATE_ERROR = 0x03U , HAL_MDMA_STATE_ABORT = 0x04U } |
HAL MDMA State structure definition. More... | |
enum | HAL_MDMA_LevelCompleteTypeDef { HAL_MDMA_FULL_TRANSFER = 0x00U , HAL_MDMA_BUFFER_TRANSFER = 0x01U , HAL_MDMA_BLOCK_TRANSFER = 0x02U , HAL_MDMA_REPEAT_BLOCK_TRANSFER = 0x03U } |
HAL MDMA Level Complete structure definition. More... | |
enum | HAL_MDMA_CallbackIDTypeDef { HAL_MDMA_XFER_CPLT_CB_ID = 0x00U , HAL_MDMA_XFER_BUFFERCPLT_CB_ID = 0x01U , HAL_MDMA_XFER_BLOCKCPLT_CB_ID = 0x02U , HAL_MDMA_XFER_REPBLOCKCPLT_CB_ID = 0x03U , HAL_MDMA_XFER_ERROR_CB_ID = 0x04U , HAL_MDMA_XFER_ABORT_CB_ID = 0x05U , HAL_MDMA_XFER_ALL_CB_ID = 0x06U } |
HAL MDMA Callbacks IDs structure definition. More... | |
HAL_StatusTypeDef | HAL_MDMA_Init (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_MDMA_DeInit (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_MDMA_ConfigPostRequestMask (MDMA_HandleTypeDef *hmdma, uint32_t MaskAddress, uint32_t MaskData) |
HAL_StatusTypeDef | HAL_MDMA_RegisterCallback (MDMA_HandleTypeDef *hmdma, HAL_MDMA_CallbackIDTypeDef CallbackID, void(*pCallback)(MDMA_HandleTypeDef *_hmdma)) |
HAL_StatusTypeDef | HAL_MDMA_UnRegisterCallback (MDMA_HandleTypeDef *hmdma, HAL_MDMA_CallbackIDTypeDef CallbackID) |
HAL_StatusTypeDef | HAL_MDMA_LinkedList_CreateNode (MDMA_LinkNodeTypeDef *pNode, MDMA_LinkNodeConfTypeDef *pNodeConfig) |
HAL_StatusTypeDef | HAL_MDMA_LinkedList_AddNode (MDMA_HandleTypeDef *hmdma, MDMA_LinkNodeTypeDef *pNewNode, MDMA_LinkNodeTypeDef *pPrevNode) |
HAL_StatusTypeDef | HAL_MDMA_LinkedList_RemoveNode (MDMA_HandleTypeDef *hmdma, MDMA_LinkNodeTypeDef *pNode) |
HAL_StatusTypeDef | HAL_MDMA_LinkedList_EnableCircularMode (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_MDMA_LinkedList_DisableCircularMode (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_MDMA_Start (MDMA_HandleTypeDef *hmdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t BlockDataLength, uint32_t BlockCount) |
HAL_StatusTypeDef | HAL_MDMA_Start_IT (MDMA_HandleTypeDef *hmdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t BlockDataLength, uint32_t BlockCount) |
HAL_StatusTypeDef | HAL_MDMA_Abort (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_MDMA_Abort_IT (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_MDMA_PollForTransfer (MDMA_HandleTypeDef *hmdma, HAL_MDMA_LevelCompleteTypeDef CompleteLevel, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_MDMA_GenerateSWRequest (MDMA_HandleTypeDef *hmdma) |
void | HAL_MDMA_IRQHandler (MDMA_HandleTypeDef *hmdma) |
HAL_MDMA_StateTypeDef | HAL_MDMA_GetState (MDMA_HandleTypeDef *hmdma) |
uint32_t | HAL_MDMA_GetError (MDMA_HandleTypeDef *hmdma) |
