RTEMS 6.1-rc1
Header file of EXTI HAL module. More...
#include "stm32h7xx_hal_def.h"
struct | EXTI_HandleTypeDef |
EXTI Handle structure definition. More... | |
struct | EXTI_ConfigTypeDef |
EXTI Configuration structure definition. More... | |
#define | EXTI_LINE_0 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x00U) |
#define | EXTI_LINE_1 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x01U) |
#define | EXTI_LINE_2 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x02U) |
#define | EXTI_LINE_3 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x03U) |
#define | EXTI_LINE_4 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x04U) |
#define | EXTI_LINE_5 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x05U) |
#define | EXTI_LINE_6 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x06U) |
#define | EXTI_LINE_7 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x07U) |
#define | EXTI_LINE_8 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x08U) |
#define | EXTI_LINE_9 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x09U) |
#define | EXTI_LINE_10 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0AU) |
#define | EXTI_LINE_11 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0BU) |
#define | EXTI_LINE_12 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0CU) |
#define | EXTI_LINE_13 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0DU) |
#define | EXTI_LINE_14 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0EU) |
#define | EXTI_LINE_15 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0FU) |
#define | EXTI_LINE_16 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x10U) |
#define | EXTI_LINE_17 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x11U) |
#define | EXTI_LINE_18 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x12U) |
#define | EXTI_LINE_19 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x13U) |
#define | EXTI_LINE_20 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x14U) |
#define | EXTI_LINE_21 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x15U) |
#define | EXTI_LINE_22 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x16U) |
#define | EXTI_LINE_23 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x17U) |
#define | EXTI_LINE_24 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x18U) |
#define | EXTI_LINE_25 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x19U) |
#define | EXTI_LINE_26 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU) |
#define | EXTI_LINE_27 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1BU) |
#define | EXTI_LINE_28 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU) |
#define | EXTI_LINE_29 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU) |
#define | EXTI_LINE_30 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU) |
#define | EXTI_LINE_31 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU) |
#define | EXTI_LINE_32 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x00U) |
#define | EXTI_LINE_33 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x01U) |
#define | EXTI_LINE_34 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x02U) |
#define | EXTI_LINE_35 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x03U) |
#define | EXTI_LINE_36 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x04U) |
#define | EXTI_LINE_37 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x05U) |
#define | EXTI_LINE_38 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x06U) |
#define | EXTI_LINE_39 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x07U) |
#define | EXTI_LINE_40 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x08U) |
#define | EXTI_LINE_41 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x09U) |
#define | EXTI_LINE_42 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU) |
#define | EXTI_LINE_43 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0BU) |
#define | EXTI_LINE_44 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0CU) |
#define | EXTI_LINE_45 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0DU) |
#define | EXTI_LINE_46 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0EU) |
#define | EXTI_LINE_47 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0FU) |
#define | EXTI_LINE_48 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x10U) |
#define | EXTI_LINE_49 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x11U) |
#define | EXTI_LINE_50 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x12U) |
#define | EXTI_LINE_51 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x13U) |
#define | EXTI_LINE_52 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x14U) |
#define | EXTI_LINE_53 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x15U) |
#define | EXTI_LINE_54 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x16U) |
#define | EXTI_LINE_55 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x17U) |
#define | EXTI_LINE_56 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x18U) |
#define | EXTI_LINE_57 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x19U) |
#define | EXTI_LINE_58 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU) |
#define | EXTI_LINE_59 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x1BU) |
#define | EXTI_LINE_60 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU) |
#define | EXTI_LINE_61 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU) |
#define | EXTI_LINE_62 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU) |
#define | EXTI_LINE_63 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU) |
#define | EXTI_LINE_64 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x00U) |
#define | EXTI_LINE_65 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x01U) |
#define | EXTI_LINE_66 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x02U) |
#define | EXTI_LINE_67 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x03U) |
#define | EXTI_LINE_68 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x04U) |
#define | EXTI_LINE_69 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x05U) |
#define | EXTI_LINE_70 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x06U) |
#define | EXTI_LINE_71 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x07U) |
#define | EXTI_LINE_72 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x08U) |
#define | EXTI_LINE_73 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x09U) |
#define | EXTI_LINE_74 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU) |
#define | EXTI_LINE_75 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0BU) |
#define | EXTI_LINE_76 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0CU) |
#define | EXTI_LINE_77 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0DU) |
#define | EXTI_LINE_78 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0EU) |
#define | EXTI_LINE_79 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0FU) |
#define | EXTI_LINE_80 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x10U) |
#define | EXTI_LINE_81 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x11U) |
#define | EXTI_LINE_82 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x12U) |
#define | EXTI_LINE_83 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x13U) |
#define | EXTI_LINE_84 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x14U) |
#define | EXTI_LINE_85 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x15U) |
#define | EXTI_LINE_86 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x16U) |
#define | EXTI_LINE_87 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x17U) |
#define | EXTI_MODE_NONE 0x00000000U |
#define | EXTI_MODE_INTERRUPT 0x00000001U |
#define | EXTI_MODE_EVENT 0x00000002U |
#define | EXTI_TRIGGER_NONE 0x00000000U |
#define | EXTI_TRIGGER_RISING 0x00000001U |
#define | EXTI_TRIGGER_FALLING 0x00000002U |
#define | EXTI_TRIGGER_RISING_FALLING (EXTI_TRIGGER_RISING | EXTI_TRIGGER_FALLING) |
#define | EXTI_GPIOA 0x00000000U |
#define | EXTI_GPIOB 0x00000001U |
#define | EXTI_GPIOC 0x00000002U |
#define | EXTI_GPIOD 0x00000003U |
#define | EXTI_GPIOE 0x00000004U |
#define | EXTI_GPIOF 0x00000005U |
#define | EXTI_GPIOG 0x00000006U |
#define | EXTI_GPIOH 0x00000007U |
#define | EXTI_GPIOJ 0x00000009U |
#define | EXTI_GPIOK 0x0000000AU |
#define | EXTI_D3_PENDCLR_SRC_NONE 0x00000000U |
#define | EXTI_D3_PENDCLR_SRC_DMACH6 0x00000001U |
#define | EXTI_D3_PENDCLR_SRC_DMACH7 0x00000002U |
#define | EXTI_D3_PENDCLR_SRC_LPTIM2 0x00000003U |
#define | EXTI_D3_PENDCLR_SRC_LPTIM3 0x00000004U |
#define | EXTI_PROPERTY_SHIFT 24U |
EXTI Line property definition. | |
#define | EXTI_DIRECT (0x01UL << EXTI_PROPERTY_SHIFT) |
#define | EXTI_CONFIG (0x02UL << EXTI_PROPERTY_SHIFT) |
#define | EXTI_GPIO ((0x04UL << EXTI_PROPERTY_SHIFT) | EXTI_CONFIG) |
#define | EXTI_RESERVED (0x08UL << EXTI_PROPERTY_SHIFT) |
#define | EXTI_PROPERTY_MASK (EXTI_DIRECT | EXTI_CONFIG | EXTI_GPIO) |
#define | EXTI_EVENT_PRESENCE_SHIFT 28U |
EXTI Event presence definition. | |
#define | EXTI_EVENT (0x01UL << EXTI_EVENT_PRESENCE_SHIFT) |
#define | EXTI_EVENT_PRESENCE_MASK (EXTI_EVENT) |
#define | EXTI_REG_SHIFT 16U |
EXTI Register and bit usage. | |
#define | EXTI_REG1 (0x00UL << EXTI_REG_SHIFT) |
#define | EXTI_REG2 (0x01UL << EXTI_REG_SHIFT) |
#define | EXTI_REG3 (0x02UL << EXTI_REG_SHIFT) |
#define | EXTI_REG_MASK (EXTI_REG1 | EXTI_REG2 | EXTI_REG3) |
#define | EXTI_PIN_MASK 0x0000001FUL |
#define | EXTI_TARGET_SHIFT 20U |
EXTI Target and bit usage. | |
#define | EXTI_TARGET_MSK_NONE (0x00UL << EXTI_TARGET_SHIFT) |
#define | EXTI_TARGET_MSK_D3SRD (0x01UL << EXTI_TARGET_SHIFT) |
#define | EXTI_TARGET_MSK_CPU1 (0x02UL << EXTI_TARGET_SHIFT) |
#define | EXTI_TARGET_MASK (EXTI_TARGET_MSK_D3SRD | EXTI_TARGET_MSK_CPU1) |
#define | EXTI_TARGET_MSK_ALL_CPU EXTI_TARGET_MSK_CPU1 |
#define | EXTI_TARGET_MSK_ALL EXTI_TARGET_MASK |
#define | EXTI_MODE_MASK (EXTI_MODE_EVENT | EXTI_MODE_INTERRUPT) |
EXTI Mask for interrupt & event mode. | |
#define | EXTI_TRIGGER_MASK (EXTI_TRIGGER_RISING | EXTI_TRIGGER_FALLING) |
EXTI Mask for trigger possibilities. | |
#define | EXTI_LINE_NB 88UL |
EXTI Line number. | |
#define | IS_EXTI_PROPERTY(__EXTI_LINE__) |
#define | IS_EXTI_TARGET(__EXTI_LINE__) |
#define | IS_EXTI_LINE(__EXTI_LINE__) |
#define | IS_EXTI_MODE(__MODE__) (((__MODE__) & ~EXTI_MODE_MASK) == 0x00UL) |
#define | IS_EXTI_TRIGGER(__EXTI_LINE__) (((__EXTI_LINE__) & ~EXTI_TRIGGER_MASK) == 0x00UL) |
#define | IS_EXTI_PENDING_EDGE(__EXTI_LINE__) |
#define | IS_EXTI_CONFIG_LINE(__EXTI_LINE__) (((__EXTI_LINE__) & EXTI_CONFIG) != 0x00UL) |
#define | IS_EXTI_GPIO_PORT(__PORT__) |
#define | IS_EXTI_GPIO_PIN(__PIN__) ((__PIN__) < 16UL) |
#define | IS_EXTI_D3_PENDCLR_SRC(__SRC__) |
Enumerations | |
enum | EXTI_CallbackIDTypeDef { HAL_EXTI_COMMON_CB_ID = 0x00U } |
HAL_StatusTypeDef | HAL_EXTI_SetConfigLine (EXTI_HandleTypeDef *hexti, EXTI_ConfigTypeDef *pExtiConfig) |
HAL_StatusTypeDef | HAL_EXTI_GetConfigLine (EXTI_HandleTypeDef *hexti, EXTI_ConfigTypeDef *pExtiConfig) |
HAL_StatusTypeDef | HAL_EXTI_ClearConfigLine (EXTI_HandleTypeDef *hexti) |
HAL_StatusTypeDef | HAL_EXTI_RegisterCallback (EXTI_HandleTypeDef *hexti, EXTI_CallbackIDTypeDef CallbackID, void(*pPendingCbfn)(void)) |
HAL_StatusTypeDef | HAL_EXTI_GetHandle (EXTI_HandleTypeDef *hexti, uint32_t ExtiLine) |
void | HAL_EXTI_IRQHandler (EXTI_HandleTypeDef *hexti) |
uint32_t | HAL_EXTI_GetPending (EXTI_HandleTypeDef *hexti, uint32_t Edge) |
void | HAL_EXTI_ClearPending (EXTI_HandleTypeDef *hexti, uint32_t Edge) |
void | HAL_EXTI_GenerateSWI (EXTI_HandleTypeDef *hexti) |
