RTEMS 6.1-rc1
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_dma_ex.h File Reference
Header file of DMA HAL extension module. More...
#include "stm32h7xx_hal_def.h"
struct  HAL_DMA_MuxSyncConfigTypeDef
 HAL DMAMUX Synchronization configuration structure definition. More...
struct  HAL_DMA_MuxRequestGeneratorConfigTypeDef
 HAL DMAMUX request generator parameters structure definition. More...
#define HAL_DMAMUX1_SYNC_DMAMUX1_CH0_EVT   0U
#define HAL_DMAMUX1_SYNC_DMAMUX1_CH1_EVT   1U
#define HAL_DMAMUX1_SYNC_DMAMUX1_CH2_EVT   2U
#define HAL_DMAMUX1_SYNC_LPTIM1_OUT   3U
#define HAL_DMAMUX1_SYNC_LPTIM2_OUT   4U
#define HAL_DMAMUX1_SYNC_LPTIM3_OUT   5U
#define HAL_DMAMUX1_SYNC_EXTI0   6U
#define HAL_DMAMUX1_SYNC_TIM12_TRGO   7U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH0_EVT   0U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH1_EVT   1U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH2_EVT   2U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH3_EVT   3U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH4_EVT   4U
#define HAL_DMAMUX2_SYNC_DMAMUX2_CH5_EVT   5U
#define HAL_DMAMUX2_SYNC_LPUART1_RX_WKUP   6U
#define HAL_DMAMUX2_SYNC_LPUART1_TX_WKUP   7U
#define HAL_DMAMUX2_SYNC_LPTIM2_OUT   8U
#define HAL_DMAMUX2_SYNC_LPTIM3_OUT   9U
#define HAL_DMAMUX2_SYNC_I2C4_WKUP   10U
#define HAL_DMAMUX2_SYNC_SPI6_WKUP   11U
#define HAL_DMAMUX2_SYNC_COMP1_OUT   12U
#define HAL_DMAMUX2_SYNC_RTC_WKUP   13U
#define HAL_DMAMUX2_SYNC_EXTI0   14U
#define HAL_DMAMUX2_SYNC_EXTI2   15U
#define HAL_DMAMUX_SYNC_NO_EVENT   0x00000000U
#define HAL_DMAMUX_SYNC_RISING   DMAMUX_CxCR_SPOL_0
#define HAL_DMAMUX_SYNC_FALLING   DMAMUX_CxCR_SPOL_1
#define HAL_DMAMUX_SYNC_RISING_FALLING   DMAMUX_CxCR_SPOL
#define HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH0_EVT   0U
#define HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH1_EVT   1U
#define HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH2_EVT   2U
#define HAL_DMAMUX1_REQ_GEN_LPTIM1_OUT   3U
#define HAL_DMAMUX1_REQ_GEN_LPTIM2_OUT   4U
#define HAL_DMAMUX1_REQ_GEN_LPTIM3_OUT   5U
#define HAL_DMAMUX1_REQ_GEN_EXTI0   6U
#define HAL_DMAMUX1_REQ_GEN_TIM12_TRGO   7U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH0_EVT   0U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH1_EVT   1U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH2_EVT   2U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH3_EVT   3U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH4_EVT   4U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH5_EVT   5U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH6_EVT   6U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_RX_WKUP   7U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_TX_WKUP   8U
#define HAL_DMAMUX2_REQ_GEN_LPTIM2_WKUP   9U
#define HAL_DMAMUX2_REQ_GEN_LPTIM2_OUT   10U
#define HAL_DMAMUX2_REQ_GEN_LPTIM3_WKUP   11U
#define HAL_DMAMUX2_REQ_GEN_LPTIM3_OUT   12U
#define HAL_DMAMUX2_REQ_GEN_I2C4_WKUP   15U
#define HAL_DMAMUX2_REQ_GEN_SPI6_WKUP   16U
#define HAL_DMAMUX2_REQ_GEN_COMP1_OUT   17U
#define HAL_DMAMUX2_REQ_GEN_COMP2_OUT   18U
#define HAL_DMAMUX2_REQ_GEN_RTC_WKUP   19U
#define HAL_DMAMUX2_REQ_GEN_EXTI0   20U
#define HAL_DMAMUX2_REQ_GEN_EXTI2   21U
#define HAL_DMAMUX2_REQ_GEN_I2C4_IT_EVT   22U
#define HAL_DMAMUX2_REQ_GEN_SPI6_IT   23U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_TX_IT   24U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_RX_IT   25U
#define HAL_DMAMUX2_REQ_GEN_BDMA_CH0_IT   28U
#define HAL_DMAMUX2_REQ_GEN_BDMA_CH1_IT   29U
#define HAL_DMAMUX_REQ_GEN_NO_EVENT   0x00000000U
#define HAL_DMAMUX_REQ_GEN_RISING   DMAMUX_RGxCR_GPOL_0
#define HAL_DMAMUX_REQ_GEN_FALLING   DMAMUX_RGxCR_GPOL_1
#define HAL_DMAMUX_REQ_GEN_RISING_FALLING   DMAMUX_RGxCR_GPOL
#define IS_DMA_DMAMUX_SYNC_SIGNAL_ID(SIGNAL_ID)   ((SIGNAL_ID) <= HAL_DMAMUX1_SYNC_TIM12_TRGO)
#define IS_BDMA_DMAMUX_SYNC_SIGNAL_ID(SIGNAL_ID)   ((SIGNAL_ID) <= HAL_DMAMUX2_SYNC_EXTI2)
#define IS_DMAMUX_SYNC_REQUEST_NUMBER(REQUEST_NUMBER)   (((REQUEST_NUMBER) > 0U) && ((REQUEST_NUMBER) <= 32U))
#define IS_DMAMUX_SYNC_POLARITY(POLARITY)
#define IS_DMAMUX_SYNC_STATE(SYNC)   (((SYNC) == DISABLE) || ((SYNC) == ENABLE))
#define IS_DMAMUX_SYNC_EVENT(EVENT)
#define IS_DMA_DMAMUX_REQUEST_GEN_SIGNAL_ID(SIGNAL_ID)   ((SIGNAL_ID) <= HAL_DMAMUX1_REQ_GEN_TIM12_TRGO)
#define IS_BDMA_DMAMUX_REQUEST_GEN_SIGNAL_ID(SIGNAL_ID)   ((SIGNAL_ID) <= HAL_DMAMUX2_REQ_GEN_BDMA_CH1_IT)
#define IS_DMAMUX_REQUEST_GEN_REQUEST_NUMBER(REQUEST_NUMBER)   (((REQUEST_NUMBER) > 0U) && ((REQUEST_NUMBER) <= 32U))
#define IS_DMAMUX_REQUEST_GEN_POLARITY(POLARITY)
enum  HAL_DMA_MemoryTypeDef { MEMORY0 = 0x00U , MEMORY1 = 0x01U }
 HAL DMA Memory definition. More...
HAL_StatusTypeDef HAL_DMAEx_MultiBufferStart (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t SecondMemAddress, uint32_t DataLength)
HAL_StatusTypeDef HAL_DMAEx_MultiBufferStart_IT (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t SecondMemAddress, uint32_t DataLength)
HAL_StatusTypeDef HAL_DMAEx_ChangeMemory (DMA_HandleTypeDef *hdma, uint32_t Address, HAL_DMA_MemoryTypeDef memory)
HAL_StatusTypeDef HAL_DMAEx_ConfigMuxSync (DMA_HandleTypeDef *hdma, HAL_DMA_MuxSyncConfigTypeDef *pSyncConfig)
HAL_StatusTypeDef HAL_DMAEx_ConfigMuxRequestGenerator (DMA_HandleTypeDef *hdma, HAL_DMA_MuxRequestGeneratorConfigTypeDef *pRequestGeneratorConfig)
HAL_StatusTypeDef HAL_DMAEx_EnableMuxRequestGenerator (DMA_HandleTypeDef *hdma)
HAL_StatusTypeDef HAL_DMAEx_DisableMuxRequestGenerator (DMA_HandleTypeDef *hdma)
void HAL_DMAEx_MUX_IRQHandler (DMA_HandleTypeDef *hdma)
Author
MCD Application Team
Attention
