RTEMS 6.1-rc1
Macros | Functions
stm32h7xx_hal_crc_ex.h File Reference
Header file of CRC HAL extended module. More...
#include "stm32h7xx_hal_def.h"
#define CRC_INPUTDATA_INVERSION_NONE   0x00000000U
#define CRC_INPUTDATA_INVERSION_BYTE   CRC_CR_REV_IN_0
#define CRC_INPUTDATA_INVERSION_HALFWORD   CRC_CR_REV_IN_1
#define CRC_INPUTDATA_INVERSION_WORD   CRC_CR_REV_IN
#define CRC_OUTPUTDATA_INVERSION_DISABLE   0x00000000U
#define CRC_OUTPUTDATA_INVERSION_ENABLE   CRC_CR_REV_OUT
#define __HAL_CRC_OUTPUTREVERSAL_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT)
 Set CRC output reversal. More...
#define __HAL_CRC_OUTPUTREVERSAL_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT))
 Unset CRC output reversal. More...
#define __HAL_CRC_POLYNOMIAL_CONFIG(__HANDLE__, __POLYNOMIAL__)   ((__HANDLE__)->Instance->POL = (__POLYNOMIAL__))
 Set CRC non-default polynomial. More...
#define IS_CRC_INPUTDATA_INVERSION_MODE(MODE)
#define IS_CRC_OUTPUTDATA_INVERSION_MODE(MODE)
HAL_StatusTypeDef HAL_CRCEx_Polynomial_Set (CRC_HandleTypeDef *hcrc, uint32_t Pol, uint32_t PolyLength)
HAL_StatusTypeDef HAL_CRCEx_Input_Data_Reverse (CRC_HandleTypeDef *hcrc, uint32_t InputReverseMode)
HAL_StatusTypeDef HAL_CRCEx_Output_Data_Reverse (CRC_HandleTypeDef *hcrc, uint32_t OutputReverseMode)
Author
MCD Application Team
Attention
