RTEMS 6.1-rc1
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_comp.h File Reference
Header file of COMP HAL module. More...
#include "stm32h7xx_hal_def.h"
struct  COMP_InitTypeDef
 COMP Init structure definition
More...
struct  COMP_HandleTypeDef
 COMP Handle Structure definition. More...
#define COMP_STATE_BITFIELD_LOCK   ((uint32_t)0x10)
 HAL COMP state machine: HAL COMP states definition.
#define HAL_COMP_ERROR_NONE   (0x00U)
#define COMP_WINDOWMODE_DISABLE   ((uint32_t)0x00000000)
#define COMP_WINDOWMODE_COMP1_INPUT_PLUS_COMMON   (COMP_CFGRx_WINMODE)
#define COMP_POWERMODE_HIGHSPEED   ((uint32_t)0x00000000)
#define COMP_POWERMODE_MEDIUMSPEED   (COMP_CFGRx_PWRMODE_0)
#define COMP_POWERMODE_ULTRALOWPOWER   (COMP_CFGRx_PWRMODE)
#define COMP_INPUT_PLUS_IO1   ((uint32_t)0x00000000)
#define COMP_INPUT_PLUS_IO2   (COMP_CFGRx_INPSEL)
#define COMP_INPUT_MINUS_1_4VREFINT   ( COMP_CFGRx_SCALEN | COMP_CFGRx_BRGEN)
#define COMP_INPUT_MINUS_1_2VREFINT   ( COMP_CFGRx_INMSEL_0 | COMP_CFGRx_SCALEN | COMP_CFGRx_BRGEN)
#define COMP_INPUT_MINUS_3_4VREFINT   ( COMP_CFGRx_INMSEL_1 | COMP_CFGRx_SCALEN | COMP_CFGRx_BRGEN)
#define COMP_INPUT_MINUS_VREFINT   ( COMP_CFGRx_INMSEL_1 | COMP_CFGRx_INMSEL_0 | COMP_CFGRx_SCALEN )
#define COMP_INPUT_MINUS_DAC1_CH1   ( COMP_CFGRx_INMSEL_2 )
#define COMP_INPUT_MINUS_DAC1_CH2   ( COMP_CFGRx_INMSEL_2 | COMP_CFGRx_INMSEL_0 )
#define COMP_INPUT_MINUS_IO1   ( COMP_CFGRx_INMSEL_2 | COMP_CFGRx_INMSEL_1 )
#define COMP_INPUT_MINUS_IO2   ( COMP_CFGRx_INMSEL_2 | COMP_CFGRx_INMSEL_1 | COMP_CFGRx_INMSEL_0 )
#define COMP_HYSTERESIS_NONE   ((uint32_t)0x00000000)
#define COMP_HYSTERESIS_LOW   (COMP_CFGRx_HYST_0)
#define COMP_HYSTERESIS_MEDIUM   (COMP_CFGRx_HYST_1)
#define COMP_HYSTERESIS_HIGH   (COMP_CFGRx_HYST)
#define COMP_OUTPUTPOL_NONINVERTED   ((uint32_t)0x00000000)
#define COMP_OUTPUTPOL_INVERTED   (COMP_CFGRx_POLARITY)
#define COMP_BLANKINGSRC_NONE   ((uint32_t)0x00000000)
#define COMP_BLANKINGSRC_TIM1_OC5   (COMP_CFGRx_BLANKING_0)
#define COMP_BLANKINGSRC_TIM2_OC3   (COMP_CFGRx_BLANKING_1)
#define COMP_BLANKINGSRC_TIM3_OC3   (COMP_CFGRx_BLANKING_0 |COMP_CFGRx_BLANKING_1)
#define COMP_BLANKINGSRC_TIM3_OC4   (COMP_CFGRx_BLANKING_2)
#define COMP_BLANKINGSRC_TIM8_OC5   (COMP_CFGRx_BLANKING_2|COMP_CFGRx_BLANKING_0)
#define COMP_BLANKINGSRC_TIM15_OC1   (COMP_CFGRx_BLANKING_2|COMP_CFGRx_BLANKING_1)
#define COMP_OUTPUT_LEVEL_LOW   ((uint32_t)0x00000000)
#define COMP_OUTPUT_LEVEL_HIGH   ((uint32_t)0x00000001)
#define COMP_TRIGGERMODE_NONE   ((uint32_t)0x00000000)
#define COMP_TRIGGERMODE_IT_RISING   (COMP_EXTI_IT | COMP_EXTI_RISING)
#define COMP_TRIGGERMODE_IT_FALLING   (COMP_EXTI_IT | COMP_EXTI_FALLING)
#define COMP_TRIGGERMODE_IT_RISING_FALLING   (COMP_EXTI_IT | COMP_EXTI_RISING | COMP_EXTI_FALLING)
#define COMP_TRIGGERMODE_EVENT_RISING   (COMP_EXTI_EVENT | COMP_EXTI_RISING)
#define COMP_TRIGGERMODE_EVENT_FALLING   (COMP_EXTI_EVENT | COMP_EXTI_FALLING)
#define COMP_TRIGGERMODE_EVENT_RISING_FALLING   (COMP_EXTI_EVENT | COMP_EXTI_RISING | COMP_EXTI_FALLING)
#define COMP_FLAG_C1I   COMP_SR_C1IF
#define COMP_FLAG_C2I   COMP_SR_C2IF
#define COMP_FLAG_LOCK   COMP_CFGRx_LOCK
#define COMP_CLEAR_C1IF   COMP_ICFR_C1IF
#define COMP_CLEAR_C2IF   COMP_ICFR_C2IF
#define COMP_IT_EN   COMP_CFGRx_ITEN
#define __HAL_COMP_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_COMP_STATE_RESET)
 Reset COMP handle state. More...
#define COMP_CLEAR_ERRORCODE(__HANDLE__)   ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE)
 Clear COMP error code (set it to no error code "HAL_COMP_ERROR_NONE"). More...
#define __HAL_COMP_ENABLE(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN)
 Enable the specified comparator. More...
#define __HAL_COMP_DISABLE(__HANDLE__)   CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN)
 Disable the specified comparator. More...
#define __HAL_COMP_LOCK(__HANDLE__)   SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK)
 Lock the specified comparator configuration. More...
#define __HAL_COMP_IS_LOCKED(__HANDLE__)   (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK)
 Check whether the specified comparator is locked. More...
#define __HAL_COMP_COMP1_EXTI_ENABLE_RISING_EDGE()   SET_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP1)
 Enable the COMP1 EXTI line rising edge trigger. More...
#define __HAL_COMP_COMP1_EXTI_DISABLE_RISING_EDGE()   CLEAR_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP1)
 Disable the COMP1 EXTI line rising edge trigger. More...
#define __HAL_COMP_COMP1_EXTI_ENABLE_FALLING_EDGE()   SET_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP1)
 Enable the COMP1 EXTI line falling edge trigger. More...
#define __HAL_COMP_COMP1_EXTI_DISABLE_FALLING_EDGE()   CLEAR_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP1)
 Disable the COMP1 EXTI line falling edge trigger. More...
#define __HAL_COMP_COMP1_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable the COMP1 EXTI line rising & falling edge trigger. More...
#define __HAL_COMP_COMP1_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable the COMP1 EXTI line rising & falling edge trigger. More...
#define __HAL_COMP_COMP1_EXTI_ENABLE_IT()   SET_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP1)
 Enable the COMP1 EXTI line in interrupt mode. More...
#define __HAL_COMP_COMP1_EXTI_DISABLE_IT()   CLEAR_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP1)
 Disable the COMP1 EXTI line in interrupt mode. More...
#define __HAL_COMP_COMP1_EXTI_ENABLE_EVENT()   SET_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP1)
 Enable the COMP1 EXTI Line in event mode. More...
#define __HAL_COMP_COMP1_EXTI_DISABLE_EVENT()   CLEAR_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP1)
 Disable the COMP1 EXTI Line in event mode. More...
#define __HAL_COMP_COMP1_EXTI_GET_FLAG()   READ_BIT(EXTI_D1->PR1, COMP_EXTI_LINE_COMP1)
 Check whether the COMP1 EXTI line flag is set or not. More...
#define __HAL_COMP_COMP1_EXTI_CLEAR_FLAG()   WRITE_REG(EXTI_D1->PR1, COMP_EXTI_LINE_COMP1)
 Clear the COMP1 EXTI flag. More...
#define __HAL_COMP_COMP1_EXTI_GENERATE_SWIT()   SET_BIT(EXTI->SWIER1, COMP_EXTI_LINE_COMP1)
 Generate a software interrupt on the COMP1 EXTI line. More...
#define __HAL_COMP_COMP1_EXTID3_ENABLE_EVENT()   SET_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP1)
 Enable the COMP1 D3 EXTI Line in event mode. More...
#define __HAL_COMP_COMP1_EXTID3_DISABLE_EVENT()   CLEAR_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP1)
 Disable the COMP1 D3 EXTI Line in event mode. More...
#define __HAL_COMP_COMP2_EXTI_ENABLE_RISING_EDGE()   SET_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP2)
 Enable the COMP2 EXTI line rising edge trigger. More...
#define __HAL_COMP_COMP2_EXTI_DISABLE_RISING_EDGE()   CLEAR_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP2)
 Disable the COMP2 EXTI line rising edge trigger. More...
#define __HAL_COMP_COMP2_EXTI_ENABLE_FALLING_EDGE()   SET_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP2)
 Enable the COMP2 EXTI line falling edge trigger. More...
#define __HAL_COMP_COMP2_EXTI_DISABLE_FALLING_EDGE()   CLEAR_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP2)
 Disable the COMP2 EXTI line falling edge trigger. More...
#define __HAL_COMP_COMP2_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable the COMP2 EXTI line rising & falling edge trigger. More...
#define __HAL_COMP_COMP2_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable the COMP2 EXTI line rising & falling edge trigger. More...
#define __HAL_COMP_COMP2_EXTI_ENABLE_IT()   SET_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP2)
 Enable the COMP2 EXTI line. More...
#define __HAL_COMP_COMP2_EXTI_DISABLE_IT()   CLEAR_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP2)
 Disable the COMP2 EXTI line. More...
#define __HAL_COMP_COMP2_EXTI_ENABLE_EVENT()   SET_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP2)
 Enable the COMP2 EXTI Line in event mode. More...
#define __HAL_COMP_COMP2_EXTI_DISABLE_EVENT()   CLEAR_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP2)
 Disable the COMP2 EXTI Line in event mode. More...
#define __HAL_COMP_COMP2_EXTI_GET_FLAG()   READ_BIT(EXTI_D1->PR1, COMP_EXTI_LINE_COMP2)
 Check whether the COMP2 EXTI line flag is set or not. More...
#define __HAL_COMP_COMP2_EXTI_CLEAR_FLAG()   WRITE_REG(EXTI_D1->PR1, COMP_EXTI_LINE_COMP2)
 Clear the the COMP2 EXTI flag. More...
#define __HAL_COMP_COMP2_EXTID3_ENABLE_EVENT()   SET_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP2)
 Enable the COMP2 D3 EXTI Line in event mode. More...
#define __HAL_COMP_COMP2_EXTID3_DISABLE_EVENT()   CLEAR_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP2)
 Disable the COMP2 D3 EXTI Line in event mode. More...
#define __HAL_COMP_COMP2_EXTI_GENERATE_SWIT()   SET_BIT(EXTI->SWIER1, COMP_EXTI_LINE_COMP2)
 Generate a software interrupt on the COMP2 EXTI line. More...
#define __HAL_COMP_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)   ((((__HANDLE__)->Instance->CFGR & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET)
 Checks if the specified COMP interrupt source is enabled or disabled. More...
#define __HAL_COMP_GET_FLAG(__FLAG__)   ((COMP12->SR & (__FLAG__)) == (__FLAG__))
 Checks whether the specified COMP flag is set or not. More...
#define __HAL_COMP_CLEAR_FLAG(__FLAG__)   (COMP12->ICFR = (__FLAG__))
 Clears the specified COMP pending flag. More...
#define __HAL_COMP_CLEAR_C1IFLAG()   __HAL_COMP_CLEAR_FLAG( COMP_CLEAR_C1IF)
 Clear the COMP C1I flag. More...
#define __HAL_COMP_CLEAR_C2IFLAG()   __HAL_COMP_CLEAR_FLAG( COMP_CLEAR_C2IF)
 Clear the COMP C2I flag. More...
#define __HAL_COMP_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ( ((__HANDLE__)->Instance->CFGR) |= (__INTERRUPT__) )
 Enable the specified COMP interrupt. More...
#define __HAL_COMP_DISABLE_IT(__HANDLE__, __INTERRUPT__)   (((__HANDLE__)->Instance->CFGR) &= ~(__INTERRUPT__))
 Disable the specified COMP interrupt. More...
#define __HAL_COMP_ENABLE_OR(__AF__)   SET_BIT(COMP12->OR, (__AF__))
 Enable the specified bit in the Option register. More...
#define __HAL_COMP_DISABLE_OR(__AF__)   CLEAR_BIT(COMP12->OR, (__AF__))
 Disable the specified bit in the Option register. More...
#define COMP_EXTI_LINE_COMP1   (EXTI_IMR1_IM20)
#define COMP_EXTI_LINE_COMP2   (EXTI_IMR1_IM21)
#define COMP_EXTI_IT   ((uint32_t) 0x01)
#define COMP_EXTI_EVENT   ((uint32_t) 0x02)
#define COMP_EXTI_RISING   ((uint32_t) 0x10)
#define COMP_EXTI_FALLING   ((uint32_t) 0x20)
#define COMP_GET_EXTI_LINE(__INSTANCE__)
 Get the specified EXTI line for a comparator instance. More...
#define IS_COMP_WINDOWMODE(__WINDOWMODE__)
#define IS_COMP_POWERMODE(__POWERMODE__)
#define IS_COMP_INPUT_PLUS(__COMP_INSTANCE__, __INPUT_PLUS__)
#define IS_COMP_INPUT_MINUS(__COMP_INSTANCE__, __INPUT_MINUS__)
#define IS_COMP_HYSTERESIS(__HYSTERESIS__)
#define IS_COMP_OUTPUTPOL(__POL__)
#define IS_COMP_BLANKINGSRCE(__SOURCE__)
#define IS_COMP_TRIGGERMODE(__MODE__)
#define IS_COMP_OUTPUT_LEVEL(__OUTPUT_LEVEL__)
enum  HAL_COMP_StateTypeDef {
  HAL_COMP_STATE_RESET = 0x00 , HAL_COMP_STATE_RESET_LOCKED = (HAL_COMP_STATE_RESET | COMP_STATE_BITFIELD_LOCK) , HAL_COMP_STATE_READY = 0x01 , HAL_COMP_STATE_READY_LOCKED = (HAL_COMP_STATE_READY | COMP_STATE_BITFIELD_LOCK) ,
  HAL_COMP_STATE_BUSY = 0x02 , HAL_COMP_STATE_BUSY_LOCKED = (HAL_COMP_STATE_BUSY | COMP_STATE_BITFIELD_LOCK)
HAL_StatusTypeDef HAL_COMP_Init (COMP_HandleTypeDef *hcomp)
HAL_StatusTypeDef HAL_COMP_DeInit (COMP_HandleTypeDef *hcomp)
void HAL_COMP_MspInit (COMP_HandleTypeDef *hcomp)
void HAL_COMP_MspDeInit (COMP_HandleTypeDef *hcomp)
HAL_StatusTypeDef HAL_COMP_Start (COMP_HandleTypeDef *hcomp)
HAL_StatusTypeDef HAL_COMP_Stop (COMP_HandleTypeDef *hcomp)
HAL_StatusTypeDef HAL_COMP_Start_IT (COMP_HandleTypeDef *hcomp)
HAL_StatusTypeDef HAL_COMP_Stop_IT (COMP_HandleTypeDef *hcomp)
void HAL_COMP_IRQHandler (COMP_HandleTypeDef *hcomp)
HAL_StatusTypeDef HAL_COMP_Lock (COMP_HandleTypeDef *hcomp)
uint32_t HAL_COMP_GetOutputLevel (COMP_HandleTypeDef *hcomp)
void HAL_COMP_TriggerCallback (COMP_HandleTypeDef *hcomp)
HAL_COMP_StateTypeDef HAL_COMP_GetState (COMP_HandleTypeDef *hcomp)
uint32_t HAL_COMP_GetError (COMP_HandleTypeDef *hcomp)
Author
MCD Application Team
Attention
