RTEMS 6.1-rc1
stackchk.h File Reference
Stack Checker Information. More...
#include <rtems/print.h>
struct  rtems_stack_checker_info
 This structure contains the stack information provided by the stack checker for a stack. More...
#define RTEMS_STACK_CHECKER_EXTENSION
 Stack Checker Extension Set Definition. More...
typedef void(* rtems_stack_checker_visitor) (const rtems_stack_checker_info *info, void *arg)
 Visitor routines invoked by rtems_stack_checker_iterate() shall have this type. More...
bool rtems_stack_checker_is_blown (void)
 Checks if current task is blown its stack. More...
void rtems_stack_checker_report_usage (void)
 Print the stack usage report using printk. More...
void rtems_stack_checker_report_usage_with_plugin (const rtems_printer *printer)
 Print the stack usage report using caller's routine. More...
void rtems_stack_checker_iterate (rtems_stack_checker_visitor visit, void *arg)
 Iterates over all stacks used by the system and invokes the visitor routine for each stack. More...
bool rtems_stack_checker_create_extension (rtems_tcb *running, rtems_tcb *the_thread)
 Stack Checker Task Create Extension. More...
void rtems_stack_checker_begin_extension (rtems_tcb *executing)
void rtems_stack_checker_switch_extension (rtems_tcb *running, rtems_tcb *heir)
 Stack Checker Task Context Switch Extension. More...
This include file contains information necessary to utilize and install the stack checker mechanism.
