RTEMS 6.1-rc1
Data Structures | Macros | Typedefs
spictrl-regs.h File Reference
This header file defines the SPICTRL register block interface. More...
#include <stdint.h>
struct  spictrl
 This structure defines the SPICTRL register block memory map. More...
#define SPICTRL_CAP_SSSZ_SHIFT   24
#define SPICTRL_CAP_SSSZ_MASK   0xff000000U
#define SPICTRL_CAP_SSSZ_GET(_reg)
#define SPICTRL_CAP_SSSZ_SET(_reg, _val)
#define SPICTRL_CAP_SSSZ(_val)
#define SPICTRL_CAP_MAXWLEN_SHIFT   20
#define SPICTRL_CAP_MAXWLEN_MASK   0xf00000U
#define SPICTRL_CAP_MAXWLEN_GET(_reg)
#define SPICTRL_CAP_MAXWLEN_SET(_reg, _val)
#define SPICTRL_CAP_MAXWLEN(_val)
#define SPICTRL_CAP_TWEN   0x80000U
#define SPICTRL_CAP_AMODE   0x40000U
#define SPICTRL_CAP_ASELA   0x20000U
#define SPICTRL_CAP_SSEN   0x10000U
#define SPICTRL_CAP_FDEPTH_SHIFT   8
#define SPICTRL_CAP_FDEPTH_MASK   0xff00U
#define SPICTRL_CAP_FDEPTH_GET(_reg)
#define SPICTRL_CAP_FDEPTH_SET(_reg, _val)
#define SPICTRL_CAP_FDEPTH(_val)
#define SPICTRL_CAP_SR   0x80U
#define SPICTRL_CAP_FT_SHIFT   5
#define SPICTRL_CAP_FT_MASK   0x60U
#define SPICTRL_CAP_FT_GET(_reg)
#define SPICTRL_CAP_FT_SET(_reg, _val)
#define SPICTRL_CAP_FT(_val)
#define SPICTRL_CAP_REV_SHIFT   0
#define SPICTRL_CAP_REV_MASK   0x1fU
#define SPICTRL_CAP_REV_GET(_reg)
#define SPICTRL_CAP_REV_SET(_reg, _val)
#define SPICTRL_CAP_REV(_val)
#define SPICTRL_MODE_LOOP   0x40000000U
#define SPICTRL_MODE_CPOL   0x20000000U
#define SPICTRL_MODE_CPHA   0x10000000U
#define SPICTRL_MODE_DIV_16   0x8000000U
#define SPICTRL_MODE_REV   0x4000000U
#define SPICTRL_MODE_MX   0x2000000U
#define SPICTRL_MODE_EN   0x1000000U
#define SPICTRL_MODE_LEN_SHIFT   20
#define SPICTRL_MODE_LEN_MASK   0xf00000U
#define SPICTRL_MODE_LEN_GET(_reg)
#define SPICTRL_MODE_LEN_SET(_reg, _val)
#define SPICTRL_MODE_LEN(_val)
#define SPICTRL_MODE_PM_SHIFT   16
#define SPICTRL_MODE_PM_MASK   0xf0000U
#define SPICTRL_MODE_PM_GET(_reg)
#define SPICTRL_MODE_PM_SET(_reg, _val)
#define SPICTRL_MODE_PM(_val)
#define SPICTRL_MODE_TWEN   0x8000U
#define SPICTRL_MODE_ASEL   0x4000U
#define SPICTRL_MODE_FACT   0x2000U
#define SPICTRL_MODE_OD   0x1000U
#define SPICTRL_MODE_CG_SHIFT   7
#define SPICTRL_MODE_CG_MASK   0xf80U
#define SPICTRL_MODE_CG_GET(_reg)
#define SPICTRL_MODE_CG_SET(_reg, _val)
#define SPICTRL_MODE_CG(_val)
#define SPICTRL_MODE_ASELDEL_SHIFT   5
#define SPICTRL_MODE_ASELDEL_MASK   0x60U
#define SPICTRL_MODE_ASELDEL_GET(_reg)
#define SPICTRL_MODE_ASELDEL_SET(_reg, _val)
#define SPICTRL_MODE_ASELDEL(_val)
#define SPICTRL_MODE_TAC   0x10U
#define SPICTRL_MODE_TTO   0x8U
#define SPICTRL_MODE_IGSEL   0x4U
#define SPICTRL_MODE_CITE   0x2U
#define SPICTRL_EVENT_TIP   0x80000000U
#define SPICTRL_EVENT_LT   0x4000U
#define SPICTRL_EVENT_OV   0x1000U
#define SPICTRL_EVENT_UN   0x800U
#define SPICTRL_EVENT_MME   0x400U
#define SPICTRL_EVENT_NE   0x200U
#define SPICTRL_EVENT_NF   0x100U
#define SPICTRL_MASK_TIPE   0x80000000U
#define SPICTRL_MASK_LTE   0x4000U
#define SPICTRL_MASK_OVE   0x1000U
#define SPICTRL_MASK_UNE   0x800U
#define SPICTRL_MASK_MMEE   0x400U
#define SPICTRL_MASK_NEEE   0x200U
#define SPICTRL_MASK_NFE   0x100U
#define SPICTRL_CMD_LST   0x400000U
#define SPICTRL_TX_TDATA_SHIFT   0
#define SPICTRL_TX_TDATA_MASK   0xffffffffU
#define SPICTRL_TX_TDATA_GET(_reg)
#define SPICTRL_TX_TDATA_SET(_reg, _val)
#define SPICTRL_TX_TDATA(_val)
#define SPICTRL_RX_RDATA_SHIFT   0
#define SPICTRL_RX_RDATA_MASK   0xffffffffU
#define SPICTRL_RX_RDATA_GET(_reg)
#define SPICTRL_RX_RDATA_SET(_reg, _val)
#define SPICTRL_RX_RDATA(_val)
#define SPICTRL_SLVSEL_SLVSEL_SHIFT   0
#define SPICTRL_SLVSEL_SLVSEL_MASK   0x3U
#define SPICTRL_SLVSEL_SLVSEL_GET(_reg)
#define SPICTRL_SLVSEL_SLVSEL_SET(_reg, _val)
#define SPICTRL_SLVSEL_SLVSEL(_val)
#define SPICTRL_ASLVSEL_ASLVSEL_SHIFT   0
#define SPICTRL_ASLVSEL_ASLVSEL_MASK   0x3U
#define SPICTRL_ASLVSEL_ASLVSEL_GET(_reg)
#define SPICTRL_ASLVSEL_ASLVSEL_SET(_reg, _val)
#define SPICTRL_ASLVSEL_ASLVSEL(_val)
typedef struct spictrl spictrl
