RTEMS 6.1-rc1
This group contains the SPICTRL interfaces. More...
Modules | |
Automatic slave select register (ASLVSEL) | |
This group contains register bit definitions. | |
Capability register (CAP) | |
Command register (CMD) | |
Event register (EVENT) | |
Mask register (MASK) | |
Mode register (MODE) | |
Receive register (RX) | |
Slave select register (SLVSEL) | |
Transmit register (TX) | |
Files | |
file | spictrl-regs.h |
This header file defines the SPICTRL register block interface. | |
struct | spictrl |
This structure defines the SPICTRL register block memory map. More... | |
Typedefs | |
typedef struct spictrl | spictrl |
This structure defines the SPICTRL register block memory map. | |
