RTEMS 6.1-rc1
Macros | Functions
sparc64.h File Reference
Information Required to Build RTEMS for a Particular Member of the SPARC Family. More...
#define SPARC_HAS_BITSCAN   0
#define SPARC_NUMBER_OF_REGISTER_WINDOWS   8
#define SPARC_HAS_FPU   1
#define CPU_MODEL_NAME   "w/FPU"
#define CPU_NAME   "SPARC"
#define SPARC_PSTATE_AG_MASK   0x00000001 /* bit 0 */
#define SPARC_PSTATE_IE_MASK   0x00000002 /* bit 1 */
#define SPARC_PSTATE_PRIV_MASK   0x00000004 /* bit 2 */
#define SPARC_PSTATE_AM_MASK   0x00000008 /* bit 3 */
#define SPARC_PSTATE_PEF_MASK   0x00000010 /* bit 4 */
#define SPARC_PSTATE_MM_MASK   0x00000040 /* bit 6 */
#define SPARC_PSTATE_TLE_MASK   0x00000100 /* bit 8 */
#define SPARC_PSTATE_CLE_MASK   0x00000200 /* bit 9 */
#define SPARC_PSTATE_AG_BIT_POSITION   0 /* bit 0 */
#define SPARC_PSTATE_IE_BIT_POSITION   1 /* bit 1 */
#define SPARC_PSTATE_PRIV_BIT_POSITION   2 /* bit 2 */
#define SPARC_PSTATE_AM_BIT_POSITION   3 /* bit 3 */
#define SPARC_PSTATE_PEF_BIT_POSITION   4 /* bit 4 */
#define SPARC_PSTATE_MM_BIT_POSITION   6 /* bit 6 */
#define SPARC_PSTATE_TLE_BIT_POSITION   8 /* bit 8 */
#define SPARC_PSTATE_CLE_BIT_POSITION   9 /* bit 9 */
#define SPARC_FPRS_FEF_MASK   0x0100 /* bit 2 */
#define SPARC_FPRS_FEF_BIT_POSITION   2 /* bit 2 */
#define SPARC_TSTATE_IE_MASK   0x00000200 /* bit 9 */
#define SPARC_SOFTINT_TM_MASK   0x00000001 /* bit 0 */
#define SPARC_SOFTINT_SM_MASK   0x00010000 /* bit 16 */
#define SPARC_SOFTINT_TM_BIT_POSITION   1 /* bit 0 */
#define SPARC_SOFTINT_SM_BIT_POSITION   17 /* bit 16 */
#define STACK_BIAS   (2047)
#define nop()
#define sparc64_get_pstate(_pstate)
#define sparc64_set_pstate(_pstate)
#define sparc64_get_pil(_pil)
#define sparc64_set_pil(_pil)
#define sparc64_get_tba(_tba)
#define sparc64_set_tba(_tba)
#define sparc64_get_tl(_tl)
#define sparc64_set_tl(_tl)
#define sparc64_read_stick(_stick)
#define sparc64_write_stick_cmpr(_stick_cmpr)
#define sparc64_read_tick(_tick)
#define sparc64_write_tick_cmpr(_tick_cmpr)
#define sparc64_clear_interrupt_bits(_bit_mask)
#define sparc_get_y(_y)
#define sparc_set_y(_y)
#define sparc_flash_interrupts(_level)
#define sparc64_get_interrupt_level(_level)
uint32_t sparc_disable_interrupts (void)
void sparc_enable_interrupts (uint32_t)
This include file contains information pertaining to the SPARC processor family.
◆ nop
#define nop ( )
Value:
do { \
__asm__ volatile ( "nop" ); \
} while ( 0 )
◆ sparc64_clear_interrupt_bits
#define sparc64_clear_interrupt_bits (   _bit_mask)
Value:
do { \
__asm__ volatile( "wr %%g0, %0, %%clear_softint" : "=r" (_bit_mask) \
: "0" (_bit_mask)); \
} while ( 0 )
◆ sparc64_get_interrupt_level
#define sparc64_get_interrupt_level (   _level)
Value:
do { \
_level = 0; \
sparc64_get_pil( _level ); \
} while ( 0 )
◆ sparc64_get_pil
#define sparc64_get_pil (   _pil)
Value:
do { \
(_pil) = 0; \
__asm__ volatile( "rdpr %%pil, %0" : "=r" (_pil) : "0" (_pil) ); \
} while ( 0 )
◆ sparc64_get_pstate
#define sparc64_get_pstate (   _pstate)
Value:
do { \
(_pstate) = 0; \
__asm__ volatile( "rdpr %%pstate, %0" : "=r" (_pstate) : "0" (_pstate) ); \
} while ( 0 )
◆ sparc64_get_tba
#define sparc64_get_tba (   _tba)
Value:
do { \
(_tba) = 0; /* to avoid unitialized warnings */ \
__asm__ volatile( "rdpr %%tba, %0" : "=r" (_tba) : "0" (_tba) ); \
} while ( 0 )
◆ sparc64_get_tl
#define sparc64_get_tl (   _tl)
Value:
do { \
(_tl) = 0; /* to avoid unitialized warnings */ \
__asm__ volatile( "rdpr %%tl, %0" : "=r" (_tl) : "0" (_tl) ); \
} while ( 0 )
◆ sparc64_read_stick
#define sparc64_read_stick (   _stick)
Value:
do { \
(_stick) = 0; \
__asm__ volatile( "rd %%stick, %0" : "=r" (_stick) : "0" (_stick) ); \
} while ( 0 )
◆ sparc64_read_tick
#define sparc64_read_tick (   _tick)
Value:
do { \
(_tick) = 0; \
__asm__ volatile( "rd %%tick, %0" : "=r" (_tick) : "0" (_tick) ); \
} while ( 0 )
◆ sparc64_set_pil
#define sparc64_set_pil (   _pil)
Value:
do { \
__asm__ volatile ( "wrpr %%g0, %0, %%pil " : "=r" ((_pil)) : "0" ((_pil)) ); \
} while ( 0 )
◆ sparc64_set_pstate
#define sparc64_set_pstate (   _pstate)
Value:
do { \
__asm__ volatile ( \
"wrpr %%g0, %0, %%pstate " : "=r" ((_pstate)) : "0" ((_pstate)) ); \
} while ( 0 )
◆ sparc64_set_tba
#define sparc64_set_tba (   _tba)
Value:
do { \
__asm__ volatile( "wrpr %%g0, %0, %%tba" : "=r" (_tba) : "0" (_tba) ); \
} while ( 0 )
◆ sparc64_set_tl
#define sparc64_set_tl (   _tl)
Value:
do { \
__asm__ volatile( "wrpr %%g0, %0, %%tl" : "=r" (_tl) : "0" (_tl) ); \
} while ( 0 )
◆ sparc64_write_stick_cmpr
#define sparc64_write_stick_cmpr (   _stick_cmpr)
Value:
do { \
__asm__ volatile( "wr %%g0, %0, %%stick_cmpr" : "=r" (_stick_cmpr) \
: "0" (_stick_cmpr) ); \
} while ( 0 )
◆ sparc64_write_tick_cmpr
#define sparc64_write_tick_cmpr (   _tick_cmpr)
Value:
do { \
__asm__ volatile( "wr %%g0, %0, %%tick_cmpr" : "=r" (_tick_cmpr) \
: "0" (_tick_cmpr) ); \
} while ( 0 )
◆ sparc_flash_interrupts
#define sparc_flash_interrupts (   _level)
Value:
do { \
uint32_t _ignored; \
sparc_enable_interrupts( (_level) ); \
_ignored = sparc_disable_interrupts(); \
(void) _ignored; \
} while ( 0 )
◆ sparc_get_y
#define sparc_get_y (   _y)
Value:
do { \
__asm__ volatile( "rd %%y, %0" : "=r" (_y) : "0" (_y) ); \
} while ( 0 )
◆ sparc_set_y
#define sparc_set_y (   _y)
Value:
do { \
__asm__ volatile( "wr %0, %%y" : "=r" (_y) : "0" (_y) ); \
} while ( 0 )
