RTEMS 6.1-rc1
Data Structures | Typedefs | Enumerations | Functions | Variables
serial.h File Reference
The generic libchip serial driver interface. More...
#include <termios.h>
struct  _console_fns
struct  _console_flow
struct  _console_tbl
struct  _console_data
typedef uint8_t(* getRegister_f) (uintptr_t port, uint8_t reg)
typedef void(* setRegister_f) (uintptr_t port, uint8_t reg, uint8_t value)
typedef uint8_t(* getData_f) (uintptr_t port)
typedef void(* setData_f) (uintptr_t port, uint8_t value)
typedef struct _console_fns console_fns
typedef struct _console_flow console_flow
typedef struct _console_tbl console_tbl
typedef struct _console_data console_data
enum  console_devs {
  SERIAL_MC68681 , SERIAL_NS16550 , SERIAL_NS16550_WITH_FDR , SERIAL_Z85C30 ,
  SERIAL_CUSTOM
void bsp_console_select (void)
 Selects the minor number of the console device. More...
console_tbl ** Console_Port_Tbl
unsigned long Console_Port_Count
console_tbl Console_Configuration_Ports []
unsigned long Console_Configuration_Count
console_dataConsole_Port_Data
rtems_device_minor_number Console_Port_Minor
Typedef Documentation
◆ console_data
This type defination provides data for the console port.
◆ console_tbl
This type defination provides an structure that is used to uniquely identify a specific serial port.
◆ getData_f
getData_f
This type function provides a hook for the bsp specific method that gets data from the specified port.
◆ setData_f
setData_f
This type function provides a hook for the bsp specific method that sets register data from the given port and register to the given value.
This type function provides a hook for the bsp specific method that writes value to the specified port.
◆ console_devs
This type defination provides an enumerated type of all supported libchip console drivers.
◆ bsp_console_select()
void bsp_console_select ( void  )
See also
Console_Port_Minor.
Variable Documentation
◆ Console_Configuration_Count
extern
The number of serial ports defined in Console_Configuration_Ports
◆ Console_Configuration_Ports
console_tbl Console_Configuration_Ports[]
extern
The statically configured serial port information tables which are used to initially populate the dynamic tables.
◆ Console_Port_Count
extern
This is the number of serial ports defined in the Console_Port_Tbl.
◆ Console_Port_Data
console_data* Console_Port_Data
extern
This is an array of per port information.
◆ Console_Port_Tbl
console_tbl** Console_Port_Tbl
extern
This is a dynamically sized set of tables containing the serial port information.
