RTEMS 6.1-rc1
Macros | Functions
rtd316.c File Reference
Driver for RTD316 ISA SCC Board. More...
#include <bsp.h>
#include <termios.h>
#include <rtems/termiostypes.h>
#include <libchip/serial.h>
#include <libchip/z85c30.h>
#include <rtems/bspIo.h>
#include <bsp/rtd316.h>
#include <rtems/score/i386.h>
#include "../../shared/dev/serial/legacy-console.h"
#define RTD_CLOCK_RATE   (460800 * 32)
uint8_t rtd316_com_get_register (uintptr_t addr, uint8_t reg)
 RTD316 Obtain Register Helper. More...
void rtd316_com_set_register (uintptr_t addr, uint8_t reg, uint8_t val)
 RTD316 Set Register Helper. More...
rtems_device_driver rtd316_initialize (rtems_device_major_number major, rtems_device_minor_number minor_arg, void *arg)
 RTD316 Initialization Entry Point. More...
The RTD316 has a single Z85C30.
◆ rtd316_com_get_register()
uint8_t rtd316_com_get_register ( uintptr_t  addr,
uint8_t  reg
This method is used to read registers on the RTD316.
Parameters
[in]addris the base address
[in]regis the register number
Returns
This method returns the value of the register.
◆ rtd316_com_set_register()
void rtd316_com_set_register ( uintptr_t  addr,
uint8_t  reg,
uint8_t  val
This method is used to set registers on the RTD316.
Parameters
◆ rtd316_initialize()
rtems_device_driver rtd316_initialize ( rtems_device_major_number  major,
rtems_device_minor_number  minor,
void *  arg
This method initializes the RTD316 device driver.
Parameters
[in]majoris the device driver major number
[in]minoris the device driver minor number
[in]argis the parameters to this call
Returns
This method returns RTEMS_SUCCESSFUL when the device driver is successfully initialized.
