RTEMS
6.1-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_rtp.h
1
/* The header file is generated by make_header.py from RTP.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_RTP
40
#define LIBBSP_ARM_TMS570_RTP
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GLBCTRL;
/*RTP Global Control Register*/
46
uint32_t TRENA;
/*RTP Trace Enable Register*/
47
uint32_t GSR;
/*RTP Global Status Register*/
48
uint32_t RAM1REG1;
/*RTP RAM 1 Trace Region 1 Register*/
49
uint32_t RAM1REG2;
/*RTP RAM 1 Trace Region 2 Register*/
50
uint32_t RAM2REG1;
/*RTP RAM 2 Trace Region 1 Register*/
51
uint32_t RAM2REG2;
/*RTP RAM 2 Trace Region 2 Register*/
52
uint8_t reserved1 [8];
53
uint32_t PERREG1;
/*RTP Peripheral Trace Region 1 Register*/
54
uint32_t PERREG2;
/*RTP Peripheral Trace Region 2 Register*/
55
uint32_t DDMW;
/*RTP Direct Data Mode Write Register*/
56
uint8_t reserved2 [4];
57
uint32_t PC0;
/*RTP Pin Control 0 Register*/
58
uint32_t PC1;
/*RTP Pin Control 1 Register*/
59
uint32_t PC2;
/*RTP Pin Control 2 Register*/
60
uint32_t PC3;
/*RTP Pin Control 3 Register*/
61
uint32_t PC4;
/*RTP Pin Control 4 Register*/
62
uint32_t PC5;
/*RTP Pin Control 5 Register*/
63
uint32_t PC6;
/*RTP Pin Control 6 Register*/
64
uint32_t PC7;
/*RTP Pin Control 7 Register*/
65
uint32_t PC8;
/*RTP Pin Control 8 Register*/
66
tms570_rtp_t
67
68
69
/*---------------------TMS570_RTP_GLBCTRL---------------------*/
70
/* field: TEST - By setting the bit, the FIFO RAM will be mapped into the SYSTEM Peripheral frame starting at */
71
#define TMS570_RTP_GLBCTRL_TEST BSP_BIT32(24)
72
73
/* field: PRESCALER - The prescaler divides HCLK down to the desired RTPCLK frequency. */
74
#define TMS570_RTP_GLBCTRL_PRESCALER(val) BSP_FLD32(val,16, 18)
75
#define TMS570_RTP_GLBCTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg,16, 18)
76
#define TMS570_RTP_GLBCTRL_PRESCALER_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
77
78
/* field: DDM_WIDTH - Direct data mode word size width. */
79
#define TMS570_RTP_GLBCTRL_DDM_WIDTH(val) BSP_FLD32(val,12, 13)
80
#define TMS570_RTP_GLBCTRL_DDM_WIDTH_GET(reg) BSP_FLD32GET(reg,12, 13)
81
#define TMS570_RTP_GLBCTRL_DDM_WIDTH_SET(reg,val) BSP_FLD32SET(reg, val,12, 13)
82
83
/* field: DDM_RW - */
84
#define TMS570_RTP_GLBCTRL_DDM_RW BSP_BIT32(11)
85
86
/* field: TM_DDM - Trace Mode or Direct Data Mode */
87
#define TMS570_RTP_GLBCTRL_TM_DDM BSP_BIT32(10)
88
89
/* field: PW - Port width. This bit field configures the RTP to the desired port width. */
90
#define TMS570_RTP_GLBCTRL_PW(val) BSP_FLD32(val,8, 9)
91
#define TMS570_RTP_GLBCTRL_PW_GET(reg) BSP_FLD32GET(reg,8, 9)
92
#define TMS570_RTP_GLBCTRL_PW_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
93
94
/* field: RESET - This bit resets the state machine and the registers to their reset value. */
95
#define TMS570_RTP_GLBCTRL_RESET BSP_BIT32(7)
96
97
/* field: CONTCLK - Continuous RTPCLK enable. */
98
#define TMS570_RTP_GLBCTRL_CONTCLK BSP_BIT32(6)
99
100
/* field: HOVF - Halt on overflow. */
101
#define TMS570_RTP_GLBCTRL_HOVF BSP_BIT32(5)
102
103
/* field: INV_RGN - Trace inside or outside of defined trace regions. */
104
#define TMS570_RTP_GLBCTRL_INV_RGN BSP_BIT32(4)
105
106
/* field: ON_OFF - ON/Off switch. */
107
#define TMS570_RTP_GLBCTRL_ON_OFF(val) BSP_FLD32(val,0, 3)
108
#define TMS570_RTP_GLBCTRL_ON_OFF_GET(reg) BSP_FLD32GET(reg,0, 3)
109
#define TMS570_RTP_GLBCTRL_ON_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
110
111
112
/*----------------------TMS570_RTP_TRENA----------------------*/
113
/* field: ENA4 - Enable tracing for peripherals. */
114
#define TMS570_RTP_TRENA_ENA4 BSP_BIT32(24)
115
116
/* field: ENA2 - Enable tracing for RAM block 2. */
117
#define TMS570_RTP_TRENA_ENA2 BSP_BIT32(8)
118
119
/* field: ENA1 - */
120
#define TMS570_RTP_TRENA_ENA1 BSP_BIT32(0)
121
122
123
/*-----------------------TMS570_RTP_GSR-----------------------*/
124
/* field: EMPTYSER - Serializer empty. This bit determines if there is data left in the serializer. */
125
#define TMS570_RTP_GSR_EMPTYSER BSP_BIT32(12)
126
127
/* field: EMPTYPER - Peripheral FIFO empty. This bit determines if there are entries left in the FIFO. */
128
#define TMS570_RTP_GSR_EMPTYPER BSP_BIT32(11)
129
130
/* field: EMPTY2 - RAM block 2 FIFO empty. This bit determines if there are entries left in the FIFO. */
131
#define TMS570_RTP_GSR_EMPTY2 BSP_BIT32(9)
132
133
/* field: EMPTY1 - RAM block 1 FIFO empty. This bit determines if there are entries left in the FIFO. */
134
#define TMS570_RTP_GSR_EMPTY1 BSP_BIT32(8)
135
136
/* field: OVFPER - Overflow peripheral FIFO. */
137
#define TMS570_RTP_GSR_OVFPER BSP_BIT32(3)
138
139
/* field: OVF2 - Overflow RAM block 2 FIFO. */
140
#define TMS570_RTP_GSR_OVF2 BSP_BIT32(1)
141
142
/* field: OVF1 - Overflow RAM block 1 FIFO. */
143
#define TMS570_RTP_GSR_OVF1 BSP_BIT32(0)
144
145
146
/*--------------------TMS570_RTP_RAM1REGx--------------------*/
147
/* field: CPU_DMA - CPU and/or other master access. */
148
#define TMS570_RTP_RAM1REGx_CPU_DMA(val) BSP_FLD32(val,29, 30)
149
#define TMS570_RTP_RAM1REGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30)
150
#define TMS570_RTP_RAM1REGx_CPU_DMA_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
151
152
/* field: RW - Read/Write. */
153
#define TMS570_RTP_RAM1REGx_RW BSP_BIT32(28)
154
155
/* field: BLOCKSIZE - These bits define the length of the trace region. */
156
#define TMS570_RTP_RAM1REGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27)
157
#define TMS570_RTP_RAM1REGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27)
158
#define TMS570_RTP_RAM1REGx_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
159
160
/* field: STARTADDR - These bits define the starting address of the address region that should be traced. */
161
#define TMS570_RTP_RAM1REGx_STARTADDR(val) BSP_FLD32(val,0, 17)
162
#define TMS570_RTP_RAM1REGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 17)
163
#define TMS570_RTP_RAM1REGx_STARTADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 17)
164
165
166
/*--------------------TMS570_RTP_RAM2REGx--------------------*/
167
168
#define TMS570_RTP_RAM2REGx_CPU_DMA(val) BSP_FLD32(val,29, 30)
169
#define TMS570_RTP_RAM2REGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30)
170
#define TMS570_RTP_RAM2REGx_CPU_DMA_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
171
172
173
#define TMS570_RTP_RAM2REGx_RW BSP_BIT32(28)
174
175
176
#define TMS570_RTP_RAM2REGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27)
177
#define TMS570_RTP_RAM2REGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27)
178
#define TMS570_RTP_RAM2REGx_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
179
180
181
#define TMS570_RTP_RAM2REGx_STARTADDR(val) BSP_FLD32(val,0, 23)
182
#define TMS570_RTP_RAM2REGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 23)
183
#define TMS570_RTP_RAM2REGx_STARTADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
184
185
186
/*---------------------TMS570_RTP_PERREGx---------------------*/
187
188
#define TMS570_RTP_PERREGx_CPU_DMA(val) BSP_FLD32(val,29, 30)
189
#define TMS570_RTP_PERREGx_CPU_DMA_GET(reg) BSP_FLD32GET(reg,29, 30)
190
#define TMS570_RTP_PERREGx_CPU_DMA_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
191
192
193
#define TMS570_RTP_PERREGx_RW BSP_BIT32(28)
194
195
196
#define TMS570_RTP_PERREGx_BLOCKSIZE(val) BSP_FLD32(val,24, 27)
197
#define TMS570_RTP_PERREGx_BLOCKSIZE_GET(reg) BSP_FLD32GET(reg,24, 27)
198
#define TMS570_RTP_PERREGx_BLOCKSIZE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
199
200
201
#define TMS570_RTP_PERREGx_STARTADDR(val) BSP_FLD32(val,0, 23)
202
#define TMS570_RTP_PERREGx_STARTADDR_GET(reg) BSP_FLD32GET(reg,0, 23)
203
#define TMS570_RTP_PERREGx_STARTADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
204
205
206
/*----------------------TMS570_RTP_DDMW----------------------*/
207
/* field: DATA - This register must be written to in a Direct Data Mode write operation to store the data into */
208
/* Whole 32 bits */
209
210
/*-----------------------TMS570_RTP_PCx-----------------------*/
211
/* field: ENAFUNC - Functional mode of RTPENA pin. */
212
#define TMS570_RTP_PCx_ENAFUNC BSP_BIT32(18)
213
214
/* field: CLKFUNC - Functional mode of RTPCLK pin. */
215
#define TMS570_RTP_PCx_CLKFUNC BSP_BIT32(17)
216
217
/* field: SYNCFUNC - Functional mode of RTPSYNC pin. */
218
#define TMS570_RTP_PCx_SYNCFUNC BSP_BIT32(16)
219
220
/* field: DATAFUNC - Functional mode of RTPDATA[15:0] pins. */
221
#define TMS570_RTP_PCx_DATAFUNC(val) BSP_FLD32(val,0, 15)
222
#define TMS570_RTP_PCx_DATAFUNC_GET(reg) BSP_FLD32GET(reg,0, 15)
223
#define TMS570_RTP_PCx_DATAFUNC_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
224
225
226
227
#endif
/* LIBBSP_ARM_TMS570_RTP */
utility.h
This header file provides utility macros for BSPs.
tms570_rtp_t
Definition:
reg_rtp.h:44
