RTEMS 6.1-rc1
PCI bus driver Interface. More...
struct | pci_dev_id |
struct | pci_dev_id_match |
struct | pcibus_res |
struct | pci_dev_info |
struct | pci_drv_info |
struct | pcibus_regmem_ops |
struct | pcibus_config |
#define | DRIVER_PCI_ID(vendor, device) |
#define | DRIVER_PCI_CLASS(class) DRIVER_ID(DRVMGR_BUS_TYPE_PCI, ((1 << 32) | ((class) & 0xffffff))) |
#define | DRIVER_PCI_GAISLER_RASTAIO_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_IO) |
#define | DRIVER_PCI_GAISLER_RASTATMTC_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_TMTC) |
#define | DRIVER_PCI_GAISLER_GR701_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_701) |
#define | DRIVER_PCI_GAISLER_RASTAADCDAC_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_ADCDAC) |
#define | DRIVER_PCI_GAISLER_TMTC_1553_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_TMTC_1553) |
#define | DRIVER_PCI_GAISLER_RASTA_SPW_ROUTER_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_SPW_RTR) |
#define | DRIVER_PCI_GAISLER_LEON4_N2X_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_LEON4_N2X) |
#define | DRIVER_PCI_GAISLER_CPCI_GR740_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_CPCI_GR740) |
#define | PCIID_DEVVEND(vendor, device) {vendor, device, PCI_ID_ANY, PCI_ID_ANY, 0, 0} |
#define | PCIID_END_TABLE {0, 0, 0, 0, 0, 0} |
#define | PCIDEV_RES_CNT (PCIDEV_RES_ROM + 1) |
#define | PCI_FUNC_CFG_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_CFG) |
#define | PCI_FUNC_CFG_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_CFG) |
#define | PCI_FUNC_CFG_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_CFG) |
#define | PCI_FUNC_CFG_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_CFG) |
#define | PCI_FUNC_CFG_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_CFG) |
#define | PCI_FUNC_CFG_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_CFG) |
#define | PCI_FUNC_IO_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_IO) |
#define | PCI_FUNC_IO_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_IO) |
#define | PCI_FUNC_IO_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_IO) |
#define | PCI_FUNC_IO_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_IO) |
#define | PCI_FUNC_IO_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_IO) |
#define | PCI_FUNC_IO_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_IO) |
#define | PCI_FUNC_MREG_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_MEMREG) |
#define | PCI_FUNC_MREG_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_MEMREG|RW_LITTLE) |
#define | PCI_FUNC_MREG_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_MEMREG|RW_LITTLE) |
#define | PCI_FUNC_MREG_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_MEMREG) |
#define | PCI_FUNC_MREG_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_MEMREG|RW_LITTLE) |
#define | PCI_FUNC_MREG_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_MEMREG|RW_LITTLE) |
Enumerations | |
enum | { PCIDEV_RES_BAR1 = 0 , PCIDEV_RES_BAR2 = 1 , PCIDEV_RES_BAR3 = 2 , PCIDEV_RES_BAR4 = 3 , PCIDEV_RES_BAR5 = 4 , PCIDEV_RES_BAR6 = 5 , PCIDEV_RES_ROM = 6 } |
int | pcibus_register (struct drvmgr_dev *dev, struct pcibus_config *cfg) |
struct drvmgr_bus_res | pcibus_drv_resources |
#define DRIVER_PCI_ID | ( | vendor, | |
device | |||
