RTEMS 6.1-rc1
ns16550_p.h
1
6/*
7 * COPYRIGHT (c) 1998 by Radstone Technology
8 *
9 *
10 * THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
11 * KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
12 * IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
13 * AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
14 *
15 * You are hereby granted permission to use, copy, modify, and distribute
16 * this file, provided that this notice, plus the above copyright notice
17 * and disclaimer, appears in all copies. Radstone Technology will provide
18 * no support for this code.
19 *
20 * COPYRIGHT (c) 1989-2012.
21 * On-Line Applications Research Corporation (OAR).
22 *
23 * The license and distribution terms for this file may be
24 * found in the file LICENSE in this distribution or at
25 * http://www.rtems.org/license/LICENSE.
26 */
27
28#ifndef _NS16550_P_H_
29#define _NS16550_P_H_
30
31#ifndef ASM
32#include <libchip/serial.h>
33#endif
34
35#ifdef __cplusplus
36extern "C" {
37#endif
38
39/*
40 * Define NS16550_STATIC to nothing while debugging so the entry points
41 * will show up in the symbol table.
42 */
43
44#define NS16550_STATIC static
45
46#define NS16550_RECEIVE_BUFFER 0
47#define NS16550_TRANSMIT_BUFFER 0
48#define NS16550_DIVISOR_LATCH_L 0
49#define NS16550_INTERRUPT_ENABLE 1
50#define NS16550_DIVISOR_LATCH_M 1
51#define NS16550_INTERRUPT_ID 2
52#define NS16550_FIFO_CONTROL 2
53#define NS16550_LINE_CONTROL 3
54#define NS16550_MODEM_CONTROL 4
55#define NS16550_LINE_STATUS 5
56#define NS16550_MODEM_STATUS 6
57#define NS16550_SCRATCH_PAD 7
58#define NS16550_FRACTIONAL_DIVIDER 10
59
60/*
61 * Define serial port interrupt enable register structure.
62 */
63
64#define SP_INT_RX_ENABLE 0x01
65#define SP_INT_TX_ENABLE 0x02
66#define SP_INT_LS_ENABLE 0x04
67#define SP_INT_MS_ENABLE 0x08
68
69#define NS16550_ENABLE_ALL_INTR (SP_INT_RX_ENABLE | SP_INT_TX_ENABLE)
70#define NS16550_DISABLE_ALL_INTR 0x00
71#define NS16550_ENABLE_ALL_INTR_EXCEPT_TX (SP_INT_RX_ENABLE)
72
73/*
74 * Define serial port interrupt ID register structure.
75 */
76
77#define SP_IID_0 0x01
78#define SP_IID_1 0x02
79#define SP_IID_2 0x04
80#define SP_IID_3 0x08
81
82/*
83 * Define serial port fifo control register structure.
84 */
85
86#define SP_FIFO_ENABLE 0x01
87#define SP_FIFO_RXRST 0x02
88#define SP_FIFO_TXRST 0x04
89#define SP_FIFO_DMA 0x08
90#define SP_FIFO_RXLEVEL 0xc0
91
92#define SP_FIFO_SIZE 16
93
94/*
95 * Define serial port line control register structure.
96 */
97
98#define SP_LINE_SIZE 0x03
99#define SP_LINE_STOP 0x04
100#define SP_LINE_PAR 0x08
101#define SP_LINE_ODD 0x10
102#define SP_LINE_STICK 0x20
103#define SP_LINE_BREAK 0x40
104#define SP_LINE_DLAB 0x80
105
106/*
107 * Line status register character size definitions.
108 */
109
110#define FIVE_BITS 0x0 /* five bits per character */
111#define SIX_BITS 0x1 /* six bits per character */
112#define SEVEN_BITS 0x2 /* seven bits per character */
113#define EIGHT_BITS 0x3 /* eight bits per character */
114
115/*
116 * Define serial port modem control register structure.
117 */
118
119#define SP_MODEM_DTR 0x01
120#define SP_MODEM_RTS 0x02
121#define SP_MODEM_IRQ 0x08
122#define SP_MODEM_LOOP 0x10
123#define SP_MODEM_DIV4 0x80
124
125/*
126 * Define serial port line status register structure.
127 */
128
129#define SP_LSR_RDY 0x01
130#define SP_LSR_EOVRUN 0x02
131#define SP_LSR_EPAR 0x04
132#define SP_LSR_EFRAME 0x08
133#define SP_LSR_BREAK 0x10
134#define SP_LSR_THOLD 0x20
135#define SP_LSR_TX 0x40
136#define SP_LSR_EFIFO 0x80
137
138#ifdef __cplusplus
139}
140#endif
141
142#endif /* _NS16550_P_H_ */
The generic libchip serial driver interface.
