RTEMS 6.1-rc1
Functions | Variables
console-generic.c File Reference
Generic console driver implementation. More...
#include <sys/cdefs.h>
#include <bsp.h>
#include <bsp/console-generic.h>
#include <bsp/fatal.h>
#include <rtems/bspIo.h>
#include <rtems/console.h>
rtems_device_driver console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console initialization entry point. More...
rtems_device_driver console_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console open entry point. More...
rtems_device_driver console_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console close entry point. More...
rtems_device_driver console_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console read entry point. More...
rtems_device_driver console_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console write entry point. More...
rtems_device_driver console_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console IO control entry point. More...
BSP_output_char_function_type BSP_output_char = console_generic_char_out_init
 This function pointer references the kernel character output implementation. More...
BSP_polling_getchar_function_type BSP_poll_char = console_generic_char_in
 This function pointer may reference the kernel character input implementation. More...
◆ console_close()
rtems_device_driver console_close ( rtems_device_major_number  major,
void *  arg
This method closes a specific device supported by the console device driver.
Parameters
[in]majoris the device driver major number
[in]minoris the device driver minor number
[in]argis the parameters to this call
Return values
RTEMS_SUCCESSFULThe device driver is successfully closed.
◆ console_control()
rtems_device_driver console_control ( rtems_device_major_number  major,
void *  arg
This method performs an IO Control operation on a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULthe device driver IO control operation is successfully performed.
◆ console_initialize()
rtems_device_driver console_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the console device driver.
Parameters
[in]majoris the device driver major number.
[in]minoris the device driver minor number.
[in]argis the parameters to this call.
Return values
RTEMS_SUCCESSFULThe device driver is successfully initialized.
Initialize all serial drivers specified in driver_context_table
Parameters
[in]major
[in]minor
[in]arg
Return values
RTEMS_SUCCESSFULInitialization completed
This routine initializes the console IO driver.
Parameters
Parameters
majormajor number
minorminor number
Output parameters: NONE
Returns
void
◆ console_open()
rtems_device_driver console_open ( rtems_device_major_number  major,
void *  arg
This method opens a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device driver is successfully opened.
◆ console_read()
rtems_device_driver console_read ( rtems_device_major_number  major,
void *  arg
This method reads from a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device is successfully read from.
◆ console_write()
rtems_device_driver console_write ( rtems_device_major_number  major,
void *  arg
This method writes to a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device is successfully written.
