RTEMS 6.1-rc1
mpc55xx.h
2
11/*
12 * Copyright (C) 2008, 2012 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
51#ifndef LIBCPU_POWERPC_MPC55XX_H
52#define LIBCPU_POWERPC_MPC55XX_H
53
54#include <mpc55xx/regs.h>
55#include <mpc55xx/regs-mmu.h>
56
58
59#ifdef __cplusplus
60extern "C" {
61#endif /* __cplusplus */
62
63int mpc55xx_flash_copy(void *dest, const void *src, size_t nbytes);
64int mpc55xx_flash_copy_op(void *rdest, const void *src, size_t nbytes,
65 uint32_t opmask, uint32_t *p_fail_addr);
66int mpc55xx_flash_size(uint32_t *p_size);
67int mpc55xx_flash_writable(void);
68uint32_t mpc55xx_flash_address(void);
69void mpc55xx_flash_set_read_only(void);
70void mpc55xx_flash_set_read_write(void);
71
72int mpc55xx_physical_address(const void *addr, uint32_t *p_result);
73int mpc55xx_mapped_address(const void *addr, uint32_t *p_result);
74
75/* Bits for opmask. */
76#define MPC55XX_FLASH_BLANK_CHECK 0x01
77#define MPC55XX_FLASH_UNLOCK 0x02
78#define MPC55XX_FLASH_ERASE 0x04
79#define MPC55XX_FLASH_PROGRAM 0x08
80#define MPC55XX_FLASH_VERIFY 0x10
81
82/* Error returns. CONFIG or SIZE might mean you just
83 * need to check for new configuration bits.
84 * SIZE and RANGE mean you are outside of a known flash region.
85 * ERASE means the erase failed,
86 * PROGRAM means the program failed,
87 * BLANK means it wasn't blank and BLANK_CHECK was specified,
88 * VERIFY means VERIFY was set and it didn't match the source,
89 * and LOCK means either the locking failed or you needed to
90 * specify MPC55XX_FLASH_UNLOCK and didn't.
91 */
92#define MPC55XX_FLASH_CONFIG_ERR (-1)
93#define MPC55XX_FLASH_SIZE_ERR (-2)
94#define MPC55XX_FLASH_RANGE_ERR (-3)
95#define MPC55XX_FLASH_ERASE_ERR (-4)
96#define MPC55XX_FLASH_PROGRAM_ERR (-5)
97#define MPC55XX_FLASH_NOT_BLANK_ERR (-6)
98#define MPC55XX_FLASH_VERIFY_ERR (-7)
99#define MPC55XX_FLASH_LOCK_ERR (-8)
100
101#define MPC55XX_CACHE_ALIGNED_MASK ((uintptr_t) 0x1f)
102
103#define MPC55XX_CACHE_LINE_SIZE 32
104
108static inline int mpc55xx_is_cache_aligned( const void *s, size_t n)
109{
110 return !(((uintptr_t) s & MPC55XX_CACHE_ALIGNED_MASK) || (n & MPC55XX_CACHE_ALIGNED_MASK));
111}
112
113static inline uintptr_t mpc55xx_cache_aligned_start( const void *s)
114{
115 return ((uintptr_t) s & MPC55XX_CACHE_ALIGNED_MASK) ? (((uintptr_t) s & ~MPC55XX_CACHE_ALIGNED_MASK) + MPC55XX_CACHE_LINE_SIZE) : (uintptr_t)s;
116}
117
118static inline size_t mpc55xx_non_cache_aligned_size( const void *s)
119{
120 return (uintptr_t) mpc55xx_cache_aligned_start( s) - (uintptr_t) s;
121}
122
123static inline size_t mpc55xx_cache_aligned_size( const void *s, size_t n)
124{
125 return (n - mpc55xx_non_cache_aligned_size( s)) & ~MPC55XX_CACHE_ALIGNED_MASK;
126}
127
131static inline uint32_t mpc55xx_count_leading_zeros( uint32_t value)
132{
133 uint32_t count;
134 __asm__ (
135 "cntlzw %0, %1;"
136 : "=r" (count)
137 : "r" (value)
138 );
139 return count;
140}
141
142static inline void mpc55xx_wait_for_interrupt(void)
143{
144 #ifdef MPC55XX_HAS_WAIT_INSTRUCTION
145 __asm__ volatile (
146 ".machine \"push\"\n"
147 ".machine \"any\"\n"
148 "wait\n"
149 ".machine \"pop\""
150 );
151 #else
152 __asm__ volatile ("");
153 #endif
154}
155
156static inline void mpc55xx_mmu_apply_config(const struct MMU_tag *config)
157{
158 PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS0, config->MAS0.R);
159 PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS1, config->MAS1.R);
160 PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS2, config->MAS2.R);
161 PPC_SET_SPECIAL_PURPOSE_REGISTER(FSL_EIS_MAS3, config->MAS3.R);
162 __asm__ volatile ("tlbwe");
163}
164
165#ifdef __cplusplus
166}
167#endif /* __cplusplus */
168
169#endif /* LIBCPU_POWERPC_MPC55XX_H */
#define PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val)
Sets the Special Purpose Register with number spr to the value in val.
Definition: powerpc-utility.h:590
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
General purpose assembler macros, linker command file support and some inline functions for direct re...
Register definitions for the MPC55xx and MPC56xx microcontroller family.
Definition: regs-mmu.h:60
Definition: deflate.c:114
