RTEMS 6.1-rc1
microblaze-gpio.c File Reference
MicroBlaze AXI GPIO implementation. More...
#include <assert.h>
#include <bsp/fatal.h>
#include <bsp/fdt.h>
#include <bsp/microblaze-gpio.h>
#include <libfdt.h>
void microblaze_gpio_set_data_direction (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask)
 Set pin configuration for the specified GPIO channel. More...
uint32_t microblaze_gpio_get_data_direction (Microblaze_GPIO_context *ctx, uint32_t channel)
 Get pin configuration for specified GPIO channel. More...
uint32_t microblaze_gpio_discrete_read (Microblaze_GPIO_context *ctx, uint32_t channel)
 Reads data for specified GPIO channel. More...
void microblaze_gpio_discrete_write (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask)
 Writes to data register for specified GPIO channel. More...
void microblaze_gpio_discrete_set (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask)
 Set bits to 1 on specified GPIO channel. More...
void microblaze_gpio_discrete_clear (Microblaze_GPIO_context *ctx, uint32_t channel, uint32_t mask)
 Set bits to 0 on specified GPIO channel. More...
rtems_vector_number microblaze_gpio_get_irq (Microblaze_GPIO_context *ctx)
 Returns the vector number of the interrupt handler. More...
void microblaze_gpio_interrupt_global_enable (Microblaze_GPIO_context *ctx)
 Turns on interrupts globally. More...
void microblaze_gpio_interrupt_global_disable (Microblaze_GPIO_context *ctx)
 Turns off interrupts globally. More...
void microblaze_gpio_interrupt_enable (Microblaze_GPIO_context *ctx, uint32_t channel)
 Enables interrupts on specified channel. More...
void microblaze_gpio_interrupt_disable (Microblaze_GPIO_context *ctx, uint32_t channel)
 Disables interrupts on specified channel. More...
void microblaze_gpio_interrupt_clear (Microblaze_GPIO_context *ctx, uint32_t channel)
 Clear status of interrupt signals on a specific channel. More...
uint32_t microblaze_gpio_interrupt_get_enabled (Microblaze_GPIO_context *ctx)
 Return a bitmask of the interrupts that are enabled. More...
uint32_t microblaze_gpio_interrupt_get_status (Microblaze_GPIO_context *ctx)
 Return a bitmask of the status of the interrupt signals. More...
◆ microblaze_gpio_discrete_clear()
void microblaze_gpio_discrete_clear ( Microblaze_GPIO_context ctx,
uint32_t  channel,
uint32_t  mask
Parameters
[in]ctxthe GPIO context
[in]channelthe GPIO channel
[in]maskthe mask to be applied to @ channel
Return values
None
◆ microblaze_gpio_discrete_read()
uint32_t microblaze_gpio_discrete_read ( Microblaze_GPIO_context ctx,
uint32_t  channel
Parameters
Return values
Currentvalues in discretes register.
◆ microblaze_gpio_discrete_set()
void microblaze_gpio_discrete_set ( Microblaze_GPIO_context ctx,
uint32_t  channel,
uint32_t  mask
Parameters
Return values
None
◆ microblaze_gpio_discrete_write()
void microblaze_gpio_discrete_write ( Microblaze_GPIO_context ctx,
uint32_t  channel,
uint32_t  mask
Parameters
Return values
None
◆ microblaze_gpio_get_data_direction()
uint32_t microblaze_gpio_get_data_direction ( Microblaze_GPIO_context ctx,
uint32_t  channel
Gets the current pin configuration for a specified GPIO channel. Bits set to 0 are output, and bits set to 1 are input.
Parameters
Return values
bitmaskspecifiying which pins on a channel are input or output
◆ microblaze_gpio_get_irq()
rtems_vector_number microblaze_gpio_get_irq ( Microblaze_GPIO_context ctx)
Parameters
Return values
thevector number
◆ microblaze_gpio_interrupt_clear()
void microblaze_gpio_interrupt_clear ( Microblaze_GPIO_context ctx,
uint32_t  channel
Parameters
[in]channelthe channel to clear the interrupt pending status from
Return values
None
◆ microblaze_gpio_interrupt_disable()
void microblaze_gpio_interrupt_disable ( Microblaze_GPIO_context ctx,
uint32_t  channel
Parameters
[in]channelthe channel to turn interrupts on for
Return values
None
◆ microblaze_gpio_interrupt_enable()
void microblaze_gpio_interrupt_enable ( Microblaze_GPIO_context ctx,
uint32_t  channel
Parameters
[in]channelthe channel to enable interrupts on
Return values
None
◆ microblaze_gpio_interrupt_get_enabled()
uint32_t microblaze_gpio_interrupt_get_enabled ( Microblaze_GPIO_context ctx)
Parameters
Return values
thebitmask of enabled interrupts
◆ microblaze_gpio_interrupt_get_status()
uint32_t microblaze_gpio_interrupt_get_status ( Microblaze_GPIO_context ctx)
Parameters
Return values
bitmaskcontaining statuses of interrupt signals
◆ microblaze_gpio_interrupt_global_disable()
void microblaze_gpio_interrupt_global_disable ( Microblaze_GPIO_context ctx)
Parameters
Return values
None
◆ microblaze_gpio_interrupt_global_enable()
void microblaze_gpio_interrupt_global_enable ( Microblaze_GPIO_context ctx)
Parameters
Return values
None
◆ microblaze_gpio_set_data_direction()
void microblaze_gpio_set_data_direction ( Microblaze_GPIO_context ctx,
uint32_t  channel,
uint32_t  mask
Changes the pin configuration for a channel. Bits set to 0 are output, and bits set to 1 are input.
Parameters
Return values
None
