RTEMS 6.1-rc1
Data Structures | Macros | Typedefs
l2cache-regs.h File Reference
This header file defines the L2CACHE register block interface. More...
#include <stdint.h>
struct  l2cache
 This structure defines the L2CACHE register block memory map. More...
#define L2CACHE_L2CC_EN   0x80000000U
#define L2CACHE_L2CC_EDAC   0x40000000U
#define L2CACHE_L2CC_REPL_SHIFT   28
#define L2CACHE_L2CC_REPL_MASK   0x30000000U
#define L2CACHE_L2CC_REPL_GET(_reg)
#define L2CACHE_L2CC_REPL_SET(_reg, _val)
#define L2CACHE_L2CC_REPL(_val)
#define L2CACHE_L2CC_BBS_SHIFT   16
#define L2CACHE_L2CC_BBS_MASK   0x70000U
#define L2CACHE_L2CC_BBS_GET(_reg)
#define L2CACHE_L2CC_BBS_SET(_reg, _val)
#define L2CACHE_L2CC_BBS(_val)
#define L2CACHE_L2CC_INDEX_WAY_SHIFT   12
#define L2CACHE_L2CC_INDEX_WAY_MASK   0xf000U
#define L2CACHE_L2CC_INDEX_WAY_GET(_reg)
#define L2CACHE_L2CC_INDEX_WAY_SET(_reg, _val)
#define L2CACHE_L2CC_INDEX_WAY(_val)
#define L2CACHE_L2CC_LOCK_SHIFT   8
#define L2CACHE_L2CC_LOCK_MASK   0xf00U
#define L2CACHE_L2CC_LOCK_GET(_reg)
#define L2CACHE_L2CC_LOCK_SET(_reg, _val)
#define L2CACHE_L2CC_LOCK(_val)
#define L2CACHE_L2CC_HPRHB   0x20U
#define L2CACHE_L2CC_HPB   0x10U
#define L2CACHE_L2CC_UC   0x8U
#define L2CACHE_L2CC_HC   0x4U
#define L2CACHE_L2CC_WP   0x2U
#define L2CACHE_L2CC_HP   0x1U
#define L2CACHE_L2CS_LS   0x1000000U
#define L2CACHE_L2CS_AT   0x800000U
#define L2CACHE_L2CS_MP   0x400000U
#define L2CACHE_L2CS_MTRR_SHIFT   16
#define L2CACHE_L2CS_MTRR_MASK   0x3f0000U
#define L2CACHE_L2CS_MTRR_GET(_reg)
#define L2CACHE_L2CS_MTRR_SET(_reg, _val)
#define L2CACHE_L2CS_MTRR(_val)
#define L2CACHE_L2CS_BBUS_W_SHIFT   13
#define L2CACHE_L2CS_BBUS_W_MASK   0xe000U
#define L2CACHE_L2CS_BBUS_W_GET(_reg)
#define L2CACHE_L2CS_BBUS_W_SET(_reg, _val)
#define L2CACHE_L2CS_BBUS_W(_val)
#define L2CACHE_L2CS_WAY_SIZE_SHIFT   2
#define L2CACHE_L2CS_WAY_SIZE_MASK   0x1ffcU
#define L2CACHE_L2CS_WAY_SIZE_GET(_reg)
#define L2CACHE_L2CS_WAY_SIZE_SET(_reg, _val)
#define L2CACHE_L2CS_WAY_SIZE(_val)
#define L2CACHE_L2CS_WAY_SHIFT   0
#define L2CACHE_L2CS_WAY_MASK   0x3U
#define L2CACHE_L2CS_WAY_GET(_reg)
#define L2CACHE_L2CS_WAY_SET(_reg, _val)
#define L2CACHE_L2CS_WAY(_val)
#define L2CACHE_L2CFMA_ADDR_SHIFT   5
#define L2CACHE_L2CFMA_ADDR_MASK   0xffffffe0U
#define L2CACHE_L2CFMA_ADDR_GET(_reg)
#define L2CACHE_L2CFMA_ADDR_SET(_reg, _val)
#define L2CACHE_L2CFMA_ADDR(_val)
#define L2CACHE_L2CFMA_DI   0x8U
#define L2CACHE_L2CFMA_FMODE_SHIFT   0
#define L2CACHE_L2CFMA_FMODE_MASK   0x7U
#define L2CACHE_L2CFMA_FMODE_GET(_reg)
#define L2CACHE_L2CFMA_FMODE_SET(_reg, _val)
#define L2CACHE_L2CFMA_FMODE(_val)
#define L2CACHE_L2CFSI_INDEX_SHIFT   16
#define L2CACHE_L2CFSI_INDEX_MASK   0xffff0000U
#define L2CACHE_L2CFSI_INDEX_GET(_reg)
#define L2CACHE_L2CFSI_INDEX_SET(_reg, _val)
#define L2CACHE_L2CFSI_INDEX(_val)
#define L2CACHE_L2CFSI_TAG_SHIFT   10
#define L2CACHE_L2CFSI_TAG_MASK   0xfffffc00U
#define L2CACHE_L2CFSI_TAG_GET(_reg)
#define L2CACHE_L2CFSI_TAG_SET(_reg, _val)
#define L2CACHE_L2CFSI_TAG(_val)
#define L2CACHE_L2CFSI_FL   0x200U
#define L2CACHE_L2CFSI_VB   0x100U
#define L2CACHE_L2CFSI_DB   0x80U
#define L2CACHE_L2CFSI_WAY_SHIFT   4
#define L2CACHE_L2CFSI_WAY_MASK   0x30U
#define L2CACHE_L2CFSI_WAY_GET(_reg)
#define L2CACHE_L2CFSI_WAY_SET(_reg, _val)
#define L2CACHE_L2CFSI_WAY(_val)
#define L2CACHE_L2CFSI_DI   0x8U
#define L2CACHE_L2CFSI_WF   0x4U
#define L2CACHE_L2CFSI_FMODE_SHIFT   0
#define L2CACHE_L2CFSI_FMODE_MASK   0x3U
#define L2CACHE_L2CFSI_FMODE_GET(_reg)
#define L2CACHE_L2CFSI_FMODE_SET(_reg, _val)
#define L2CACHE_L2CFSI_FMODE(_val)
#define L2CACHE_L2CERR_AHB_MASTER_INDEX_SHIFT   28
#define L2CACHE_L2CERR_AHB_MASTER_INDEX_MASK   0xf0000000U
#define L2CACHE_L2CERR_AHB_MASTER_INDEX_GET(_reg)
#define L2CACHE_L2CERR_AHB_MASTER_INDEX_SET(_reg, _val)
#define L2CACHE_L2CERR_AHB_MASTER_INDEX(_val)
#define L2CACHE_L2CERR_SCRUB   0x8000000U
#define L2CACHE_L2CERR_TYPE_SHIFT   24
#define L2CACHE_L2CERR_TYPE_MASK   0x7000000U
#define L2CACHE_L2CERR_TYPE_GET(_reg)
#define L2CACHE_L2CERR_TYPE_SET(_reg, _val)
#define L2CACHE_L2CERR_TYPE(_val)
#define L2CACHE_L2CERR_TAG_DATA   0x800000U
#define L2CACHE_L2CERR_COR_UCOR   0x400000U
#define L2CACHE_L2CERR_MULTI   0x200000U
#define L2CACHE_L2CERR_VALID   0x100000U
#define L2CACHE_L2CERR_DISERESP   0x80000U
#define L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_SHIFT   16
#define L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_MASK   0x70000U
#define L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_GET(_reg)
#define L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_SET(_reg, _val)
#define L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER(_val)
#define L2CACHE_L2CERR_IRQ_PENDING_SHIFT   12
#define L2CACHE_L2CERR_IRQ_PENDING_MASK   0xf000U
#define L2CACHE_L2CERR_IRQ_PENDING_GET(_reg)
#define L2CACHE_L2CERR_IRQ_PENDING_SET(_reg, _val)
#define L2CACHE_L2CERR_IRQ_PENDING(_val)
#define L2CACHE_L2CERR_IRQ_MASK_SHIFT   8
#define L2CACHE_L2CERR_IRQ_MASK_MASK   0xf00U
#define L2CACHE_L2CERR_IRQ_MASK_GET(_reg)
#define L2CACHE_L2CERR_IRQ_MASK_SET(_reg, _val)
#define L2CACHE_L2CERR_IRQ_MASK(_val)
#define L2CACHE_L2CERR_SELECT_CB_SHIFT   6
#define L2CACHE_L2CERR_SELECT_CB_MASK   0xc0U
#define L2CACHE_L2CERR_SELECT_CB_GET(_reg)
#define L2CACHE_L2CERR_SELECT_CB_SET(_reg, _val)
#define L2CACHE_L2CERR_SELECT_CB(_val)
#define L2CACHE_L2CERR_SELECT_TCB_SHIFT   4
#define L2CACHE_L2CERR_SELECT_TCB_MASK   0x30U
#define L2CACHE_L2CERR_SELECT_TCB_GET(_reg)
#define L2CACHE_L2CERR_SELECT_TCB_SET(_reg, _val)
#define L2CACHE_L2CERR_SELECT_TCB(_val)
#define L2CACHE_L2CERR_XCB   0x8U
#define L2CACHE_L2CERR_RCB   0x4U
#define L2CACHE_L2CERR_COMP   0x2U
#define L2CACHE_L2CERR_RST   0x1U
#define L2CACHE_L2CERRA_EADDR_SHIFT   0
#define L2CACHE_L2CERRA_EADDR_MASK   0xffffffffU
#define L2CACHE_L2CERRA_EADDR_GET(_reg)
#define L2CACHE_L2CERRA_EADDR_SET(_reg, _val)
#define L2CACHE_L2CERRA_EADDR(_val)
#define L2CACHE_L2CTCB_TCB_SHIFT   0
#define L2CACHE_L2CTCB_TCB_MASK   0x7fU
#define L2CACHE_L2CTCB_TCB_GET(_reg)
#define L2CACHE_L2CTCB_TCB_SET(_reg, _val)
#define L2CACHE_L2CTCB_TCB(_val)
#define L2CACHE_L2CCB_CB_SHIFT   0
#define L2CACHE_L2CCB_CB_MASK   0xfffffffU
#define L2CACHE_L2CCB_CB_GET(_reg)
#define L2CACHE_L2CCB_CB_SET(_reg, _val)
#define L2CACHE_L2CCB_CB(_val)
#define L2CACHE_L2CSCRUB_INDEX_SHIFT   16
#define L2CACHE_L2CSCRUB_INDEX_MASK   0xffff0000U
#define L2CACHE_L2CSCRUB_INDEX_GET(_reg)
#define L2CACHE_L2CSCRUB_INDEX_SET(_reg, _val)
#define L2CACHE_L2CSCRUB_INDEX(_val)
#define L2CACHE_L2CSCRUB_WAY_SHIFT   2
#define L2CACHE_L2CSCRUB_WAY_MASK   0xcU
#define L2CACHE_L2CSCRUB_WAY_GET(_reg)
#define L2CACHE_L2CSCRUB_WAY_SET(_reg, _val)
#define L2CACHE_L2CSCRUB_WAY(_val)
#define L2CACHE_L2CSCRUB_PEN   0x2U
#define L2CACHE_L2CSCRUB_EN   0x1U
#define L2CACHE_L2CSDEL_DEL_SHIFT   0
#define L2CACHE_L2CSDEL_DEL_MASK   0xffffU
#define L2CACHE_L2CSDEL_DEL_GET(_reg)
#define L2CACHE_L2CSDEL_DEL_SET(_reg, _val)
#define L2CACHE_L2CSDEL_DEL(_val)
#define L2CACHE_L2CEINJ_ADDR_SHIFT   2
#define L2CACHE_L2CEINJ_ADDR_MASK   0xfffffffcU
#define L2CACHE_L2CEINJ_ADDR_GET(_reg)
#define L2CACHE_L2CEINJ_ADDR_SET(_reg, _val)
#define L2CACHE_L2CEINJ_ADDR(_val)
#define L2CACHE_L2CEINJ_INJ   0x1U
#define L2CACHE_L2CACCC_DSC   0x4000U
#define L2CACHE_L2CACCC_SH   0x2000U
#define L2CACHE_L2CACCC_SPLITQ   0x400U
#define L2CACHE_L2CACCC_NHM   0x200U
#define L2CACHE_L2CACCC_BERR   0x100U
#define L2CACHE_L2CACCC_OAPM   0x80U
#define L2CACHE_L2CACCC_FLINE   0x40U
#define L2CACHE_L2CACCC_DBPF   0x20U
#define L2CACHE_L2CACCC_128WF   0x10U
#define L2CACHE_L2CACCC_DBPWS   0x4U
#define L2CACHE_L2CACCC_SPLIT   0x2U
#define L2CACHE_L2CEINJCFG_EDI   0x400U
#define L2CACHE_L2CEINJCFG_TER   0x200U
#define L2CACHE_L2CEINJCFG_IMD   0x100U
#define L2CACHE_L2CMTRR_ADDR_SHIFT   18
#define L2CACHE_L2CMTRR_ADDR_MASK   0xfffc0000U
#define L2CACHE_L2CMTRR_ADDR_GET(_reg)
#define L2CACHE_L2CMTRR_ADDR_SET(_reg, _val)
#define L2CACHE_L2CMTRR_ADDR(_val)
#define L2CACHE_L2CMTRR_ACC_SHIFT   16
#define L2CACHE_L2CMTRR_ACC_MASK   0x30000U
#define L2CACHE_L2CMTRR_ACC_GET(_reg)
#define L2CACHE_L2CMTRR_ACC_SET(_reg, _val)
#define L2CACHE_L2CMTRR_ACC(_val)
#define L2CACHE_L2CMTRR_MASK_SHIFT   2
#define L2CACHE_L2CMTRR_MASK_MASK   0xfffcU
#define L2CACHE_L2CMTRR_MASK_GET(_reg)
#define L2CACHE_L2CMTRR_MASK_SET(_reg, _val)
#define L2CACHE_L2CMTRR_MASK(_val)
#define L2CACHE_L2CMTRR_WP   0x2U
#define L2CACHE_L2CMTRR_AC   0x1U
typedef struct l2cache l2cache
