RTEMS 6.1-rc1
This source file contains the generic interrupt controller support implementation. More...
RTEMS_WEAK rtems_interrupt_entry ** | bsp_interrupt_get_dispatch_table_slot (rtems_vector_number index) |
Gets a reference to the interrupt handler table slot associated with the index. More... | |
rtems_status_code | bsp_interrupt_check_and_lock (rtems_vector_number vector, rtems_interrupt_handler routine) |
Checks the vector and routine. When the checks were successful, the interrupt support lock will be obtained. More... | |
rtems_interrupt_entry * | bsp_interrupt_entry_find (rtems_vector_number vector, rtems_interrupt_handler routine, void *arg, rtems_interrupt_entry ***previous_next) |
void | bsp_interrupt_initialize (void) |
Initialize Interrupt Manager implementation. More... | |
rtems_status_code | rtems_interrupt_entry_install (rtems_vector_number vector, rtems_option options, rtems_interrupt_entry *entry) |
Installs the interrupt entry at the interrupt vector. More... | |
rtems_interrupt_entry * | bsp_interrupt_dispatch_table [BSP_INTERRUPT_DISPATCH_TABLE_SIZE] |
Each member of this table references the first installed entry at the corresponding interrupt vector or is NULL. | |
uint8_t | bsp_interrupt_handler_unique_table [(BSP_INTERRUPT_DISPATCH_TABLE_SIZE+7+1)/8] |
This table contains a bit map which indicates if an entry is unique or shared. More... | |
rtems_status_code bsp_interrupt_check_and_lock | ( | rtems_vector_number | vector, |
rtems_interrupt_handler | handler | ||
vector | is the interrupt vector number to check. |
routine | is the routine to check. |
RTEMS_SUCCESSFUL | The requested operation was successful. |
RTEMS_INCORRECT_STATE | The interrupt support was not initialized. |
RTEMS_CALLED_FROM_ISR | The function was called from within interrupt context. |
RTEMS_INVALID_ADDRESS | The routine parameter was NULL. |
RTEMS_INVALID_ID | There was no interrupt vector associated with the number specified by vector . |
RTEMS_WEAK rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot | ( | rtems_vector_number | index | ) |
uint8_t bsp_interrupt_handler_unique_table[(BSP_INTERRUPT_DISPATCH_TABLE_SIZE+7+1)/8] |
If the bit associated with a vector is set, then the entry is unique, otherwise it may be shared. If the bit with index #BSP_INTERRUPT_DISPATCH_TABLE_SIZE is set, then the interrupt support is initialized, otherwise it is not initialized.
