RTEMS 6.1-rc1
imxrt1166-pinfunc.h
1/* SPDX-License-Identifier: BSD-3-Clause */
2
15/*
16 * Copyright 2016 Freescale Semiconductor, Inc.
17 * Copyright 2016-2021 NXP
18 * Copyright (C) 2023 embedded brains GmbH & Co. KG
19 *
20 * Redistribution and use in source and binary forms, with or without
21 * modification, are permitted provided that the following conditions
22 * are met:
23 * 1. Redistributions of source code must retain the above copyright
24 * notice, this list of conditions and the following disclaimer.
25 * 2. Redistributions in binary form must reproduce the above copyright
26 * notice, this list of conditions and the following disclaimer in the
27 * documentation and/or other materials provided with the distribution.
28 * 3. Neither the name of the copyright holder nor the names of its contributors
29 * may be used to endorse or promote products derived from this software
30 * without specific prior written permission.
31 *
32 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42 * POSSIBILITY OF SUCH DAMAGE.
43 */
44
45#ifndef LIBBSP_ARM_IMXRT_IMXRT1166_PINFUNC_H
46#define LIBBSP_ARM_IMXRT_IMXRT1166_PINFUNC_H
47
48#ifdef __cplusplus
49extern "C" {
50#endif /* __cplusplus */
51
52/* LPSR pins. Base address is 0x40c08000 */
53
54#define IMXRT_PAD_GPIO_LPSR_00_FLEXCAN3_TX 0x000 0x040 0 0x0 0
55#define IMXRT_PAD_GPIO_LPSR_00_MIC_CLK 0x000 0x040 0 0x1 0
56#define IMXRT_PAD_GPIO_LPSR_00_MQS_RIGHT 0x000 0x040 0 0x2 0
57#define IMXRT_PAD_GPIO_LPSR_00_ARM_CM4_EVENTO 0x000 0x040 0 0x3 0
58#define IMXRT_PAD_GPIO_LPSR_00_GPIO_MUX6_IO00 0x000 0x040 0 0x5 0
59#define IMXRT_PAD_GPIO_LPSR_00_LPUART12_TXD 0x000 0x040 0x0B0 0x6 0
60#define IMXRT_PAD_GPIO_LPSR_00_SAI4_MCLK 0x000 0x040 0x0C8 0x7 0
61#define IMXRT_PAD_GPIO_LPSR_00_GPIO12_IO00 0x000 0x040 0 0xA 0
62
63#define IMXRT_PAD_GPIO_LPSR_01_FLEXCAN3_RX 0x004 0x044 0x080 0x0 0
64#define IMXRT_PAD_GPIO_LPSR_01_MIC_BITSTREAM0 0x004 0x044 0x0B4 0x1 0
65#define IMXRT_PAD_GPIO_LPSR_01_MQS_LEFT 0x004 0x044 0 0x2 0
66#define IMXRT_PAD_GPIO_LPSR_01_ARM_CM4_EVENTI 0x004 0x044 0 0x3 0
67#define IMXRT_PAD_GPIO_LPSR_01_GPIO_MUX6_IO01 0x004 0x044 0 0x5 0
68#define IMXRT_PAD_GPIO_LPSR_01_LPUART12_RXD 0x004 0x044 0x0AC 0x6 0
69#define IMXRT_PAD_GPIO_LPSR_01_GPIO12_IO01 0x004 0x044 0 0xA 0
70
71#define IMXRT_PAD_GPIO_LPSR_02_GPIO12_IO02 0x008 0x048 0 0xA 0
72#define IMXRT_PAD_GPIO_LPSR_02_SRC_BOOT_MODE00 0x008 0x048 0 0x0 0
73#define IMXRT_PAD_GPIO_LPSR_02_LPSPI5_SCK 0x008 0x048 0x098 0x1 0
74#define IMXRT_PAD_GPIO_LPSR_02_SAI4_TX_DATA 0x008 0x048 0 0x2 0
75#define IMXRT_PAD_GPIO_LPSR_02_MQS_RIGHT 0x008 0x048 0 0x3 0
76#define IMXRT_PAD_GPIO_LPSR_02_GPIO_MUX6_IO02 0x008 0x048 0 0x5 0
77
78#define IMXRT_PAD_GPIO_LPSR_03_SRC_BOOT_MODE01 0x00C 0x04C 0 0x0 0
79#define IMXRT_PAD_GPIO_LPSR_03_LPSPI5_PCS0 0x00C 0x04C 0x094 0x1 0
80#define IMXRT_PAD_GPIO_LPSR_03_SAI4_TX_SYNC 0x00C 0x04C 0x0DC 0x2 0
81#define IMXRT_PAD_GPIO_LPSR_03_MQS_LEFT 0x00C 0x04C 0 0x3 0
82#define IMXRT_PAD_GPIO_LPSR_03_GPIO_MUX6_IO03 0x00C 0x04C 0 0x5 0
83#define IMXRT_PAD_GPIO_LPSR_03_GPIO12_IO03 0x00C 0x04C 0 0xA 0
84
85#define IMXRT_PAD_GPIO_LPSR_04_LPI2C5_SDA 0x010 0x050 0x088 0x0 0
86#define IMXRT_PAD_GPIO_LPSR_04_LPSPI5_SOUT 0x010 0x050 0x0A0 0x1 0
87#define IMXRT_PAD_GPIO_LPSR_04_SAI4_TX_BCLK 0x010 0x050 0x0D8 0x2 0
88#define IMXRT_PAD_GPIO_LPSR_04_LPUART12_RTS_B 0x010 0x050 0 0x3 0
89#define IMXRT_PAD_GPIO_LPSR_04_GPIO_MUX6_IO04 0x010 0x050 0 0x5 0
90#define IMXRT_PAD_GPIO_LPSR_04_LPUART11_TXD 0x010 0x050 0x0A8 0x6 0
91#define IMXRT_PAD_GPIO_LPSR_04_GPIO12_IO04 0x010 0x050 0 0xA 0
92
93#define IMXRT_PAD_GPIO_LPSR_05_GPIO12_IO05 0x014 0x054 0 0xA 0
94#define IMXRT_PAD_GPIO_LPSR_05_LPI2C5_SCL 0x014 0x054 0x084 0x0 0
95#define IMXRT_PAD_GPIO_LPSR_05_LPSPI5_SIN 0x014 0x054 0x09C 0x1 0
96#define IMXRT_PAD_GPIO_LPSR_05_SAI4_MCLK 0x014 0x054 0x0C8 0x2 1
97#define IMXRT_PAD_GPIO_LPSR_05_LPUART12_CTS_B 0x014 0x054 0 0x3 0
98#define IMXRT_PAD_GPIO_LPSR_05_GPIO_MUX6_IO05 0x014 0x054 0 0x5 0
99#define IMXRT_PAD_GPIO_LPSR_05_LPUART11_RXD 0x014 0x054 0x0A4 0x6 0
100#define IMXRT_PAD_GPIO_LPSR_05_NMI_GLUE_NMI 0x014 0x054 0x0C4 0x7 0
101
102#define IMXRT_PAD_GPIO_LPSR_06_LPI2C6_SDA 0x018 0x058 0x090 0x0 0
103#define IMXRT_PAD_GPIO_LPSR_06_SAI4_RX_DATA 0x018 0x058 0x0D0 0x2 0
104#define IMXRT_PAD_GPIO_LPSR_06_LPUART12_TXD 0x018 0x058 0x0B0 0x3 1
105#define IMXRT_PAD_GPIO_LPSR_06_LPSPI6_PCS3 0x018 0x058 0 0x4 0
106#define IMXRT_PAD_GPIO_LPSR_06_GPIO_MUX6_IO06 0x018 0x058 0 0x5 0
107#define IMXRT_PAD_GPIO_LPSR_06_FLEXCAN3_TX 0x018 0x058 0 0x6 0
108#define IMXRT_PAD_GPIO_LPSR_06_PIT2_TRIGGER3 0x018 0x058 0 0x7 0
109#define IMXRT_PAD_GPIO_LPSR_06_LPSPI5_PCS1 0x018 0x058 0 0x8 0
110#define IMXRT_PAD_GPIO_LPSR_06_GPIO12_IO06 0x018 0x058 0 0xA 0
111
112#define IMXRT_PAD_GPIO_LPSR_07_LPI2C6_SCL 0x01C 0x05C 0x08C 0x0 0
113#define IMXRT_PAD_GPIO_LPSR_07_SAI4_RX_BCLK 0x01C 0x05C 0x0CC 0x2 0
114#define IMXRT_PAD_GPIO_LPSR_07_LPUART12_RXD 0x01C 0x05C 0x0AC 0x3 1
115#define IMXRT_PAD_GPIO_LPSR_07_LPSPI6_PCS2 0x01C 0x05C 0 0x4 0
116#define IMXRT_PAD_GPIO_LPSR_07_GPIO_MUX6_IO07 0x01C 0x05C 0 0x5 0
117#define IMXRT_PAD_GPIO_LPSR_07_FLEXCAN3_RX 0x01C 0x05C 0x080 0x6 1
118#define IMXRT_PAD_GPIO_LPSR_07_PIT2_TRIGGER2 0x01C 0x05C 0 0x7 0
119#define IMXRT_PAD_GPIO_LPSR_07_LPSPI5_PCS2 0x01C 0x05C 0 0x8 0
120#define IMXRT_PAD_GPIO_LPSR_07_GPIO12_IO07 0x01C 0x05C 0 0xA 0
121
122#define IMXRT_PAD_GPIO_LPSR_08_GPIO12_IO08 0x020 0x060 0 0xA 0
123#define IMXRT_PAD_GPIO_LPSR_08_LPUART11_TXD 0x020 0x060 0x0A8 0x0 1
124#define IMXRT_PAD_GPIO_LPSR_08_FLEXCAN3_TX 0x020 0x060 0 0x1 0
125#define IMXRT_PAD_GPIO_LPSR_08_SAI4_RX_SYNC 0x020 0x060 0x0D4 0x2 0
126#define IMXRT_PAD_GPIO_LPSR_08_MIC_CLK 0x020 0x060 0 0x3 0
127#define IMXRT_PAD_GPIO_LPSR_08_LPSPI6_PCS1 0x020 0x060 0 0x4 0
128#define IMXRT_PAD_GPIO_LPSR_08_GPIO_MUX6_IO08 0x020 0x060 0 0x5 0
129#define IMXRT_PAD_GPIO_LPSR_08_LPI2C5_SDA 0x020 0x060 0x088 0x6 1
130#define IMXRT_PAD_GPIO_LPSR_08_PIT2_TRIGGER1 0x020 0x060 0 0x7 0
131#define IMXRT_PAD_GPIO_LPSR_08_LPSPI5_PCS3 0x020 0x060 0 0x8 0
132
133#define IMXRT_PAD_GPIO_LPSR_09_GPIO12_IO09 0x024 0x064 0 0xA 0
134#define IMXRT_PAD_GPIO_LPSR_09_LPUART11_RXD 0x024 0x064 0x0A4 0x0 1
135#define IMXRT_PAD_GPIO_LPSR_09_FLEXCAN3_RX 0x024 0x064 0x080 0x1 2
136#define IMXRT_PAD_GPIO_LPSR_09_PIT2_TRIGGER0 0x024 0x064 0 0x2 0
137#define IMXRT_PAD_GPIO_LPSR_09_MIC_BITSTREAM0 0x024 0x064 0x0B4 0x3 1
138#define IMXRT_PAD_GPIO_LPSR_09_LPSPI6_PCS0 0x024 0x064 0 0x4 0
139#define IMXRT_PAD_GPIO_LPSR_09_GPIO_MUX6_IO09 0x024 0x064 0 0x5 0
140#define IMXRT_PAD_GPIO_LPSR_09_LPI2C5_SCL 0x024 0x064 0x084 0x6 1
141#define IMXRT_PAD_GPIO_LPSR_09_SAI4_TX_DATA 0x024 0x064 0 0x7 0
142
143#define IMXRT_PAD_GPIO_LPSR_10_GPIO12_IO10 0x028 0x068 0 0xA 0
144#define IMXRT_PAD_GPIO_LPSR_10_JTAG_MUX_TRSTB 0x028 0x068 0 0x0 0
145#define IMXRT_PAD_GPIO_LPSR_10_LPUART11_CTS_B 0x028 0x068 0 0x1 0
146#define IMXRT_PAD_GPIO_LPSR_10_LPI2C6_SDA 0x028 0x068 0x090 0x2 1
147#define IMXRT_PAD_GPIO_LPSR_10_MIC_BITSTREAM1 0x028 0x068 0x0B8 0x3 0
148#define IMXRT_PAD_GPIO_LPSR_10_LPSPI6_SCK 0x028 0x068 0 0x4 0
149#define IMXRT_PAD_GPIO_LPSR_10_GPIO_MUX6_IO10 0x028 0x068 0 0x5 0
150#define IMXRT_PAD_GPIO_LPSR_10_LPI2C5_SCLS 0x028 0x068 0 0x6 0
151#define IMXRT_PAD_GPIO_LPSR_10_SAI4_TX_SYNC 0x028 0x068 0x0DC 0x7 1
152#define IMXRT_PAD_GPIO_LPSR_10_LPUART12_TXD 0x028 0x068 0x0B0 0x8 2
153
154#define IMXRT_PAD_GPIO_LPSR_11_JTAG_MUX_TDO 0x02C 0x06C 0 0x0 0
155#define IMXRT_PAD_GPIO_LPSR_11_LPUART11_RTS_B 0x02C 0x06C 0 0x1 0
156#define IMXRT_PAD_GPIO_LPSR_11_LPI2C6_SCL 0x02C 0x06C 0x08C 0x2 1
157#define IMXRT_PAD_GPIO_LPSR_11_MIC_BITSTREAM2 0x02C 0x06C 0x0BC 0x3 0
158#define IMXRT_PAD_GPIO_LPSR_11_LPSPI6_SOUT 0x02C 0x06C 0 0x4 0
159#define IMXRT_PAD_GPIO_LPSR_11_GPIO_MUX6_IO11 0x02C 0x06C 0 0x5 0
160#define IMXRT_PAD_GPIO_LPSR_11_LPI2C5_SDAS 0x02C 0x06C 0 0x6 0
161#define IMXRT_PAD_GPIO_LPSR_11_ARM_TRACE_SWO 0x02C 0x06C 0 0x7 0
162#define IMXRT_PAD_GPIO_LPSR_11_LPUART12_RXD 0x02C 0x06C 0x0AC 0x8 2
163#define IMXRT_PAD_GPIO_LPSR_11_GPIO12_IO11 0x02C 0x06C 0 0xA 0
164
165#define IMXRT_PAD_GPIO_LPSR_12_GPIO12_IO12 0x030 0x070 0 0xA 0
166#define IMXRT_PAD_GPIO_LPSR_12_JTAG_MUX_TDI 0x030 0x070 0 0x0 0
167#define IMXRT_PAD_GPIO_LPSR_12_PIT2_TRIGGER0 0x030 0x070 0 0x1 0
168#define IMXRT_PAD_GPIO_LPSR_12_MIC_BITSTREAM3 0x030 0x070 0x0C0 0x3 0
169#define IMXRT_PAD_GPIO_LPSR_12_LPSPI6_SIN 0x030 0x070 0 0x4 0
170#define IMXRT_PAD_GPIO_LPSR_12_GPIO_MUX6_IO12 0x030 0x070 0 0x5 0
171#define IMXRT_PAD_GPIO_LPSR_12_LPI2C5_HREQ 0x030 0x070 0 0x6 0
172#define IMXRT_PAD_GPIO_LPSR_12_SAI4_TX_BCLK 0x030 0x070 0x0D8 0x7 1
173#define IMXRT_PAD_GPIO_LPSR_12_LPSPI5_SCK 0x030 0x070 0x098 0x8 1
174
175#define IMXRT_PAD_GPIO_LPSR_13_GPIO12_IO13 0x034 0x074 0 0xA 0
176#define IMXRT_PAD_GPIO_LPSR_13_JTAG_MUX_MOD 0x034 0x074 0 0x0 0
177#define IMXRT_PAD_GPIO_LPSR_13_MIC_BITSTREAM1 0x034 0x074 0x0B8 0x1 1
178#define IMXRT_PAD_GPIO_LPSR_13_PIT2_TRIGGER1 0x034 0x074 0 0x2 0
179#define IMXRT_PAD_GPIO_LPSR_13_GPIO_MUX6_IO13 0x034 0x074 0 0x5 0
180#define IMXRT_PAD_GPIO_LPSR_13_SAI4_RX_DATA 0x034 0x074 0x0D0 0x7 1
181#define IMXRT_PAD_GPIO_LPSR_13_LPSPI5_PCS0 0x034 0x074 0x094 0x8 1
182
183#define IMXRT_PAD_GPIO_LPSR_14_JTAG_MUX_TCK 0x038 0x078 0 0x0 0
184#define IMXRT_PAD_GPIO_LPSR_14_MIC_BITSTREAM2 0x038 0x078 0x0BC 0x1 1
185#define IMXRT_PAD_GPIO_LPSR_14_PIT2_TRIGGER2 0x038 0x078 0 0x2 0
186#define IMXRT_PAD_GPIO_LPSR_14_GPIO_MUX6_IO14 0x038 0x078 0 0x5 0
187#define IMXRT_PAD_GPIO_LPSR_14_SAI4_RX_BCLK 0x038 0x078 0x0CC 0x7 1
188#define IMXRT_PAD_GPIO_LPSR_14_LPSPI5_SOUT 0x038 0x078 0x0A0 0x8 1
189#define IMXRT_PAD_GPIO_LPSR_14_GPIO12_IO14 0x038 0x078 0 0xA 0
190
191#define IMXRT_PAD_GPIO_LPSR_15_GPIO12_IO15 0x03C 0x07C 0 0xA 0
192#define IMXRT_PAD_GPIO_LPSR_15_JTAG_MUX_TMS 0x03C 0x07C 0 0x0 0
193#define IMXRT_PAD_GPIO_LPSR_15_MIC_BITSTREAM3 0x03C 0x07C 0x0C0 0x1 1
194#define IMXRT_PAD_GPIO_LPSR_15_PIT2_TRIGGER3 0x03C 0x07C 0 0x2 0
195#define IMXRT_PAD_GPIO_LPSR_15_GPIO_MUX6_IO15 0x03C 0x07C 0 0x5 0
196#define IMXRT_PAD_GPIO_LPSR_15_SAI4_RX_SYNC 0x03C 0x07C 0x0D4 0x7 1
197#define IMXRT_PAD_GPIO_LPSR_15_LPSPI5_SIN 0x03C 0x07C 0x09C 0x8 1
198
199/* SNVS pins. Base address is 0x40c94000 */
200
201#define IMXRT_PAD_WAKEUP_DIG_GPIO13_IO00 0x000 0x040 0 0x5 0
202/* NOTE: Can't handle that pin. It's distributed between SNVS and LPSR */
203// #define IMXRT_PAD_WAKEUP_DIG_NMI_GLUE_NMI 0x000 0x040 0x40C080C4 0x7 1
204
205#define IMXRT_PAD_PMIC_ON_REQ_DIG_SNVS_LP_PMIC_ON_REQ 0x004 0x044 0 0x0 0
206#define IMXRT_PAD_PMIC_ON_REQ_DIG_GPIO13_IO01 0x004 0x044 0 0x5 0
207
208#define IMXRT_PAD_PMIC_STBY_REQ_DIG_CCM_PMIC_VSTBY_REQ 0x008 0x048 0 0x0 0
209#define IMXRT_PAD_PMIC_STBY_REQ_DIG_GPIO13_IO02 0x008 0x048 0 0x5 0
210
211#define IMXRT_PAD_GPIO_SNVS_00_DIG_SNVS_TAMPER0 0x00C 0x04C 0 0x0 0
212#define IMXRT_PAD_GPIO_SNVS_00_DIG_GPIO13_IO03 0x00C 0x04C 0 0x5 0
213
214#define IMXRT_PAD_GPIO_SNVS_01_DIG_SNVS_TAMPER1 0x010 0x050 0 0x0 0
215#define IMXRT_PAD_GPIO_SNVS_01_DIG_GPIO13_IO04 0x010 0x050 0 0x5 0
216
217#define IMXRT_PAD_GPIO_SNVS_02_DIG_SNVS_TAMPER2 0x014 0x054 0 0x0 0
218#define IMXRT_PAD_GPIO_SNVS_02_DIG_GPIO13_IO05 0x014 0x054 0 0x5 0
219
220#define IMXRT_PAD_GPIO_SNVS_03_DIG_SNVS_TAMPER3 0x018 0x058 0 0x0 0
221#define IMXRT_PAD_GPIO_SNVS_03_DIG_GPIO13_IO06 0x018 0x058 0 0x5 0
222
223#define IMXRT_PAD_GPIO_SNVS_04_DIG_SNVS_TAMPER4 0x01C 0x05C 0 0x0 0
224#define IMXRT_PAD_GPIO_SNVS_04_DIG_GPIO13_IO07 0x01C 0x05C 0 0x5 0
225
226#define IMXRT_PAD_GPIO_SNVS_05_DIG_SNVS_TAMPER5 0x020 0x060 0 0x0 0
227#define IMXRT_PAD_GPIO_SNVS_05_DIG_GPIO13_IO08 0x020 0x060 0 0x5 0
228
229#define IMXRT_PAD_GPIO_SNVS_06_DIG_SNVS_TAMPER6 0x024 0x064 0 0x0 0
230#define IMXRT_PAD_GPIO_SNVS_06_DIG_GPIO13_IO09 0x024 0x064 0 0x5 0
231
232#define IMXRT_PAD_GPIO_SNVS_07_DIG_SNVS_TAMPER7 0x028 0x068 0 0x0 0
233#define IMXRT_PAD_GPIO_SNVS_07_DIG_GPIO13_IO10 0x028 0x068 0 0x5 0
234
235#define IMXRT_PAD_GPIO_SNVS_08_DIG_SNVS_TAMPER8 0x02C 0x06C 0 0x0 0
236#define IMXRT_PAD_GPIO_SNVS_08_DIG_GPIO13_IO11 0x02C 0x06C 0 0x5 0
237
238#define IMXRT_PAD_GPIO_SNVS_09_DIG_SNVS_TAMPER9 0x030 0x070 0 0x0 0
239#define IMXRT_PAD_GPIO_SNVS_09_DIG_GPIO13_IO12 0x030 0x070 0 0x5 0
240
241#define IMXRT_PAD_TEST_MODE_DIG 0 0x034 0 0 0
242
243#define IMXRT_PAD_POR_B_DIG 0 0x038 0 0 0
244
245#define IMXRT_PAD_ONOFF_DIG 0 0x03C 0 0 0
246
247/* Normal pins. Base address is 0x400e8000 */
248
249#define IMXRT_PAD_GPIO_EMC_B1_00_SEMC_DATA00 0x010 0x254 0 0x0 0
250#define IMXRT_PAD_GPIO_EMC_B1_00_FLEXPWM4_PWM0_A 0x010 0x254 0 0x1 0
251#define IMXRT_PAD_GPIO_EMC_B1_00_GPIO_MUX1_IO00 0x010 0x254 0 0x5 0
252#define IMXRT_PAD_GPIO_EMC_B1_00_FLEXIO1_D00 0x010 0x254 0 0x8 0
253#define IMXRT_PAD_GPIO_EMC_B1_00_GPIO7_IO00 0x010 0x254 0 0xA 0
254
255#define IMXRT_PAD_GPIO_EMC_B1_01_GPIO7_IO01 0x014 0x258 0 0xA 0
256#define IMXRT_PAD_GPIO_EMC_B1_01_SEMC_DATA01 0x014 0x258 0 0x0 0
257#define IMXRT_PAD_GPIO_EMC_B1_01_FLEXPWM4_PWM0_B 0x014 0x258 0 0x1 0
258#define IMXRT_PAD_GPIO_EMC_B1_01_GPIO_MUX1_IO01 0x014 0x258 0 0x5 0
259#define IMXRT_PAD_GPIO_EMC_B1_01_FLEXIO1_D01 0x014 0x258 0 0x8 0
260
261#define IMXRT_PAD_GPIO_EMC_B1_02_SEMC_DATA02 0x018 0x25C 0 0x0 0
262#define IMXRT_PAD_GPIO_EMC_B1_02_FLEXPWM4_PWM1_A 0x018 0x25C 0 0x1 0
263#define IMXRT_PAD_GPIO_EMC_B1_02_GPIO_MUX1_IO02 0x018 0x25C 0 0x5 0
264#define IMXRT_PAD_GPIO_EMC_B1_02_FLEXIO1_D02 0x018 0x25C 0 0x8 0
265#define IMXRT_PAD_GPIO_EMC_B1_02_GPIO7_IO02 0x018 0x25C 0 0xA 0
266
267#define IMXRT_PAD_GPIO_EMC_B1_03_SEMC_DATA03 0x01C 0x260 0 0x0 0
268#define IMXRT_PAD_GPIO_EMC_B1_03_FLEXPWM4_PWM1_B 0x01C 0x260 0 0x1 0
269#define IMXRT_PAD_GPIO_EMC_B1_03_GPIO_MUX1_IO03 0x01C 0x260 0 0x5 0
270#define IMXRT_PAD_GPIO_EMC_B1_03_FLEXIO1_D03 0x01C 0x260 0 0x8 0
271#define IMXRT_PAD_GPIO_EMC_B1_03_GPIO7_IO03 0x01C 0x260 0 0xA 0
272
273#define IMXRT_PAD_GPIO_EMC_B1_04_GPIO7_IO04 0x020 0x264 0 0xA 0
274#define IMXRT_PAD_GPIO_EMC_B1_04_SEMC_DATA04 0x020 0x264 0 0x0 0
275#define IMXRT_PAD_GPIO_EMC_B1_04_FLEXPWM4_PWM2_A 0x020 0x264 0 0x1 0
276#define IMXRT_PAD_GPIO_EMC_B1_04_GPIO_MUX1_IO04 0x020 0x264 0 0x5 0
277#define IMXRT_PAD_GPIO_EMC_B1_04_FLEXIO1_D04 0x020 0x264 0 0x8 0
278
279#define IMXRT_PAD_GPIO_EMC_B1_05_SEMC_DATA05 0x024 0x268 0 0x0 0
280#define IMXRT_PAD_GPIO_EMC_B1_05_FLEXPWM4_PWM2_B 0x024 0x268 0 0x1 0
281#define IMXRT_PAD_GPIO_EMC_B1_05_GPIO_MUX1_IO05 0x024 0x268 0 0x5 0
282#define IMXRT_PAD_GPIO_EMC_B1_05_FLEXIO1_D05 0x024 0x268 0 0x8 0
283#define IMXRT_PAD_GPIO_EMC_B1_05_GPIO7_IO05 0x024 0x268 0 0xA 0
284
285#define IMXRT_PAD_GPIO_EMC_B1_06_SEMC_DATA06 0x028 0x26C 0 0x0 0
286#define IMXRT_PAD_GPIO_EMC_B1_06_FLEXPWM2_PWM0_A 0x028 0x26C 0x518 0x1 0
287#define IMXRT_PAD_GPIO_EMC_B1_06_GPIO_MUX1_IO06 0x028 0x26C 0 0x5 0
288#define IMXRT_PAD_GPIO_EMC_B1_06_FLEXIO1_D06 0x028 0x26C 0 0x8 0
289#define IMXRT_PAD_GPIO_EMC_B1_06_GPIO7_IO06 0x028 0x26C 0 0xA 0
290
291#define IMXRT_PAD_GPIO_EMC_B1_07_GPIO7_IO07 0x02C 0x270 0 0xA 0
292#define IMXRT_PAD_GPIO_EMC_B1_07_SEMC_DATA07 0x02C 0x270 0 0x0 0
293#define IMXRT_PAD_GPIO_EMC_B1_07_FLEXPWM2_PWM0_B 0x02C 0x270 0x524 0x1 0
294#define IMXRT_PAD_GPIO_EMC_B1_07_GPIO_MUX1_IO07 0x02C 0x270 0 0x5 0
295#define IMXRT_PAD_GPIO_EMC_B1_07_FLEXIO1_D07 0x02C 0x270 0 0x8 0
296
297#define IMXRT_PAD_GPIO_EMC_B1_08_SEMC_DM00 0x030 0x274 0 0x0 0
298#define IMXRT_PAD_GPIO_EMC_B1_08_FLEXPWM2_PWM1_A 0x030 0x274 0x51C 0x1 0
299#define IMXRT_PAD_GPIO_EMC_B1_08_GPIO_MUX1_IO08 0x030 0x274 0 0x5 0
300#define IMXRT_PAD_GPIO_EMC_B1_08_FLEXIO1_D08 0x030 0x274 0 0x8 0
301#define IMXRT_PAD_GPIO_EMC_B1_08_GPIO7_IO08 0x030 0x274 0 0xA 0
302
303#define IMXRT_PAD_GPIO_EMC_B1_09_SEMC_ADDR00 0x034 0x278 0 0x0 0
304#define IMXRT_PAD_GPIO_EMC_B1_09_FLEXPWM2_PWM1_B 0x034 0x278 0x528 0x1 0
305#define IMXRT_PAD_GPIO_EMC_B1_09_GPT5_CAPTURE1 0x034 0x278 0 0x2 0
306#define IMXRT_PAD_GPIO_EMC_B1_09_GPIO_MUX1_IO09 0x034 0x278 0 0x5 0
307#define IMXRT_PAD_GPIO_EMC_B1_09_FLEXIO1_D09 0x034 0x278 0 0x8 0
308#define IMXRT_PAD_GPIO_EMC_B1_09_GPIO7_IO09 0x034 0x278 0 0xA 0
309
310#define IMXRT_PAD_GPIO_EMC_B1_10_SEMC_ADDR01 0x038 0x27C 0 0x0 0
311#define IMXRT_PAD_GPIO_EMC_B1_10_FLEXPWM2_PWM2_A 0x038 0x27C 0x520 0x1 0
312#define IMXRT_PAD_GPIO_EMC_B1_10_GPT5_CAPTURE2 0x038 0x27C 0 0x2 0
313#define IMXRT_PAD_GPIO_EMC_B1_10_GPIO_MUX1_IO10 0x038 0x27C 0 0x5 0
314#define IMXRT_PAD_GPIO_EMC_B1_10_FLEXIO1_D10 0x038 0x27C 0 0x8 0
315#define IMXRT_PAD_GPIO_EMC_B1_10_GPIO7_IO10 0x038 0x27C 0 0xA 0
316
317#define IMXRT_PAD_GPIO_EMC_B1_11_GPIO7_IO11 0x03C 0x280 0 0xA 0
318#define IMXRT_PAD_GPIO_EMC_B1_11_SEMC_ADDR02 0x03C 0x280 0 0x0 0
319#define IMXRT_PAD_GPIO_EMC_B1_11_FLEXPWM2_PWM2_B 0x03C 0x280 0x52C 0x1 0
320#define IMXRT_PAD_GPIO_EMC_B1_11_GPT5_COMPARE1 0x03C 0x280 0 0x2 0
321#define IMXRT_PAD_GPIO_EMC_B1_11_GPIO_MUX1_IO11 0x03C 0x280 0 0x5 0
322#define IMXRT_PAD_GPIO_EMC_B1_11_FLEXIO1_D11 0x03C 0x280 0 0x8 0
323
324#define IMXRT_PAD_GPIO_EMC_B1_12_SEMC_ADDR03 0x040 0x284 0 0x0 0
325#define IMXRT_PAD_GPIO_EMC_B1_12_XBAR1_INOUT04 0x040 0x284 0 0x1 0
326#define IMXRT_PAD_GPIO_EMC_B1_12_GPT5_COMPARE2 0x040 0x284 0 0x2 0
327#define IMXRT_PAD_GPIO_EMC_B1_12_GPIO_MUX1_IO12 0x040 0x284 0 0x5 0
328#define IMXRT_PAD_GPIO_EMC_B1_12_FLEXIO1_D12 0x040 0x284 0 0x8 0
329#define IMXRT_PAD_GPIO_EMC_B1_12_GPIO7_IO12 0x040 0x284 0 0xA 0
330
331#define IMXRT_PAD_GPIO_EMC_B1_13_SEMC_ADDR04 0x044 0x288 0 0x0 0
332#define IMXRT_PAD_GPIO_EMC_B1_13_XBAR1_INOUT05 0x044 0x288 0 0x1 0
333#define IMXRT_PAD_GPIO_EMC_B1_13_GPT5_COMPARE3 0x044 0x288 0 0x2 0
334#define IMXRT_PAD_GPIO_EMC_B1_13_GPIO_MUX1_IO13 0x044 0x288 0 0x5 0
335#define IMXRT_PAD_GPIO_EMC_B1_13_FLEXIO1_D13 0x044 0x288 0 0x8 0
336#define IMXRT_PAD_GPIO_EMC_B1_13_GPIO7_IO13 0x044 0x288 0 0xA 0
337
338#define IMXRT_PAD_GPIO_EMC_B1_14_GPIO7_IO14 0x048 0x28C 0 0xA 0
339#define IMXRT_PAD_GPIO_EMC_B1_14_SEMC_ADDR05 0x048 0x28C 0 0x0 0
340#define IMXRT_PAD_GPIO_EMC_B1_14_XBAR1_INOUT06 0x048 0x28C 0 0x1 0
341#define IMXRT_PAD_GPIO_EMC_B1_14_GPT5_CLK 0x048 0x28C 0 0x2 0
342#define IMXRT_PAD_GPIO_EMC_B1_14_GPIO_MUX1_IO14 0x048 0x28C 0 0x5 0
343#define IMXRT_PAD_GPIO_EMC_B1_14_FLEXIO1_D14 0x048 0x28C 0 0x8 0
344
345#define IMXRT_PAD_GPIO_EMC_B1_15_SEMC_ADDR06 0x04C 0x290 0 0x0 0
346#define IMXRT_PAD_GPIO_EMC_B1_15_XBAR1_INOUT07 0x04C 0x290 0 0x1 0
347#define IMXRT_PAD_GPIO_EMC_B1_15_GPIO_MUX1_IO15 0x04C 0x290 0 0x5 0
348#define IMXRT_PAD_GPIO_EMC_B1_15_FLEXIO1_D15 0x04C 0x290 0 0x8 0
349#define IMXRT_PAD_GPIO_EMC_B1_15_GPIO7_IO15 0x04C 0x290 0 0xA 0
350
351#define IMXRT_PAD_GPIO_EMC_B1_16_SEMC_ADDR07 0x050 0x294 0 0x0 0
352#define IMXRT_PAD_GPIO_EMC_B1_16_XBAR1_INOUT08 0x050 0x294 0 0x1 0
353#define IMXRT_PAD_GPIO_EMC_B1_16_GPIO_MUX1_IO16 0x050 0x294 0 0x5 0
354#define IMXRT_PAD_GPIO_EMC_B1_16_FLEXIO1_D16 0x050 0x294 0 0x8 0
355#define IMXRT_PAD_GPIO_EMC_B1_16_GPIO7_IO16 0x050 0x294 0 0xA 0
356
357#define IMXRT_PAD_GPIO_EMC_B1_17_GPIO7_IO17 0x054 0x298 0 0xA 0
358#define IMXRT_PAD_GPIO_EMC_B1_17_SEMC_ADDR08 0x054 0x298 0 0x0 0
359#define IMXRT_PAD_GPIO_EMC_B1_17_FLEXPWM4_PWM3_A 0x054 0x298 0 0x1 0
360#define IMXRT_PAD_GPIO_EMC_B1_17_TMR1_TIMER0 0x054 0x298 0x63C 0x2 0
361#define IMXRT_PAD_GPIO_EMC_B1_17_GPIO_MUX1_IO17 0x054 0x298 0 0x5 0
362#define IMXRT_PAD_GPIO_EMC_B1_17_FLEXIO1_D17 0x054 0x298 0 0x8 0
363
364#define IMXRT_PAD_GPIO_EMC_B1_18_SEMC_ADDR09 0x058 0x29C 0 0x0 0
365#define IMXRT_PAD_GPIO_EMC_B1_18_FLEXPWM4_PWM3_B 0x058 0x29C 0 0x1 0
366#define IMXRT_PAD_GPIO_EMC_B1_18_TMR2_TIMER0 0x058 0x29C 0x648 0x2 0
367#define IMXRT_PAD_GPIO_EMC_B1_18_GPIO_MUX1_IO18 0x058 0x29C 0 0x5 0
368#define IMXRT_PAD_GPIO_EMC_B1_18_FLEXIO1_D18 0x058 0x29C 0 0x8 0
369#define IMXRT_PAD_GPIO_EMC_B1_18_GPIO7_IO18 0x058 0x29C 0 0xA 0
370
371#define IMXRT_PAD_GPIO_EMC_B1_19_SEMC_ADDR11 0x05C 0x2A0 0 0x0 0
372#define IMXRT_PAD_GPIO_EMC_B1_19_FLEXPWM2_PWM3_A 0x05C 0x2A0 0 0x1 0
373#define IMXRT_PAD_GPIO_EMC_B1_19_TMR3_TIMER0 0x05C 0x2A0 0x654 0x2 0
374#define IMXRT_PAD_GPIO_EMC_B1_19_GPIO_MUX1_IO19 0x05C 0x2A0 0 0x5 0
375#define IMXRT_PAD_GPIO_EMC_B1_19_FLEXIO1_D19 0x05C 0x2A0 0 0x8 0
376#define IMXRT_PAD_GPIO_EMC_B1_19_GPIO7_IO19 0x05C 0x2A0 0 0xA 0
377
378#define IMXRT_PAD_GPIO_EMC_B1_20_SEMC_ADDR12 0x060 0x2A4 0 0x0 0
379#define IMXRT_PAD_GPIO_EMC_B1_20_FLEXPWM2_PWM3_B 0x060 0x2A4 0 0x1 0
380#define IMXRT_PAD_GPIO_EMC_B1_20_TMR4_TIMER0 0x060 0x2A4 0x660 0x2 0
381#define IMXRT_PAD_GPIO_EMC_B1_20_GPIO_MUX1_IO20 0x060 0x2A4 0 0x5 0
382#define IMXRT_PAD_GPIO_EMC_B1_20_FLEXIO1_D20 0x060 0x2A4 0 0x8 0
383#define IMXRT_PAD_GPIO_EMC_B1_20_GPIO7_IO20 0x060 0x2A4 0 0xA 0
384
385#define IMXRT_PAD_GPIO_EMC_B1_21_GPIO7_IO21 0x064 0x2A8 0 0xA 0
386#define IMXRT_PAD_GPIO_EMC_B1_21_SEMC_BA0 0x064 0x2A8 0 0x0 0
387#define IMXRT_PAD_GPIO_EMC_B1_21_FLEXPWM3_PWM3_A 0x064 0x2A8 0x53C 0x1 0
388#define IMXRT_PAD_GPIO_EMC_B1_21_GPIO_MUX1_IO21 0x064 0x2A8 0 0x5 0
389#define IMXRT_PAD_GPIO_EMC_B1_21_FLEXIO1_D21 0x064 0x2A8 0 0x8 0
390
391#define IMXRT_PAD_GPIO_EMC_B1_22_GPIO7_IO22 0x068 0x2AC 0 0xA 0
392#define IMXRT_PAD_GPIO_EMC_B1_22_SEMC_BA1 0x068 0x2AC 0 0x0 0
393#define IMXRT_PAD_GPIO_EMC_B1_22_FLEXPWM3_PWM3_B 0x068 0x2AC 0x54C 0x1 0
394#define IMXRT_PAD_GPIO_EMC_B1_22_GPIO_MUX1_IO22 0x068 0x2AC 0 0x5 0
395#define IMXRT_PAD_GPIO_EMC_B1_22_FLEXIO1_D22 0x068 0x2AC 0 0x8 0
396
397#define IMXRT_PAD_GPIO_EMC_B1_23_SEMC_ADDR10 0x06C 0x2B0 0 0x0 0
398#define IMXRT_PAD_GPIO_EMC_B1_23_FLEXPWM1_PWM0_A 0x06C 0x2B0 0x500 0x1 0
399#define IMXRT_PAD_GPIO_EMC_B1_23_GPIO_MUX1_IO23 0x06C 0x2B0 0 0x5 0
400#define IMXRT_PAD_GPIO_EMC_B1_23_FLEXIO1_D23 0x06C 0x2B0 0 0x8 0
401#define IMXRT_PAD_GPIO_EMC_B1_23_GPIO7_IO23 0x06C 0x2B0 0 0xA 0
402
403#define IMXRT_PAD_GPIO_EMC_B1_24_GPIO7_IO24 0x070 0x2B4 0 0xA 0
404#define IMXRT_PAD_GPIO_EMC_B1_24_SEMC_CAS 0x070 0x2B4 0 0x0 0
405#define IMXRT_PAD_GPIO_EMC_B1_24_FLEXPWM1_PWM0_B 0x070 0x2B4 0x50C 0x1 0
406#define IMXRT_PAD_GPIO_EMC_B1_24_GPIO_MUX1_IO24 0x070 0x2B4 0 0x5 0
407#define IMXRT_PAD_GPIO_EMC_B1_24_FLEXIO1_D24 0x070 0x2B4 0 0x8 0
408
409#define IMXRT_PAD_GPIO_EMC_B1_25_GPIO7_IO25 0x074 0x2B8 0 0xA 0
410#define IMXRT_PAD_GPIO_EMC_B1_25_SEMC_RAS 0x074 0x2B8 0 0x0 0
411#define IMXRT_PAD_GPIO_EMC_B1_25_FLEXPWM1_PWM1_A 0x074 0x2B8 0x504 0x1 0
412#define IMXRT_PAD_GPIO_EMC_B1_25_GPIO_MUX1_IO25 0x074 0x2B8 0 0x5 0
413#define IMXRT_PAD_GPIO_EMC_B1_25_FLEXIO1_D25 0x074 0x2B8 0 0x8 0
414
415#define IMXRT_PAD_GPIO_EMC_B1_26_SEMC_CLK 0x078 0x2BC 0 0x0 0
416#define IMXRT_PAD_GPIO_EMC_B1_26_FLEXPWM1_PWM1_B 0x078 0x2BC 0x510 0x1 0
417#define IMXRT_PAD_GPIO_EMC_B1_26_GPIO_MUX1_IO26 0x078 0x2BC 0 0x5 0
418#define IMXRT_PAD_GPIO_EMC_B1_26_FLEXIO1_D26 0x078 0x2BC 0 0x8 0
419#define IMXRT_PAD_GPIO_EMC_B1_26_GPIO7_IO26 0x078 0x2BC 0 0xA 0
420
421#define IMXRT_PAD_GPIO_EMC_B1_27_GPIO7_IO27 0x07C 0x2C0 0 0xA 0
422#define IMXRT_PAD_GPIO_EMC_B1_27_SEMC_CKE 0x07C 0x2C0 0 0x0 0
423#define IMXRT_PAD_GPIO_EMC_B1_27_FLEXPWM1_PWM2_A 0x07C 0x2C0 0x508 0x1 0
424#define IMXRT_PAD_GPIO_EMC_B1_27_GPIO_MUX1_IO27 0x07C 0x2C0 0 0x5 0
425#define IMXRT_PAD_GPIO_EMC_B1_27_FLEXIO1_D27 0x07C 0x2C0 0 0x8 0
426
427#define IMXRT_PAD_GPIO_EMC_B1_28_GPIO7_IO28 0x080 0x2C4 0 0xA 0
428#define IMXRT_PAD_GPIO_EMC_B1_28_SEMC_WE 0x080 0x2C4 0 0x0 0
429#define IMXRT_PAD_GPIO_EMC_B1_28_FLEXPWM1_PWM2_B 0x080 0x2C4 0x514 0x1 0
430#define IMXRT_PAD_GPIO_EMC_B1_28_GPIO_MUX1_IO28 0x080 0x2C4 0 0x5 0
431#define IMXRT_PAD_GPIO_EMC_B1_28_FLEXIO1_D28 0x080 0x2C4 0 0x8 0
432
433#define IMXRT_PAD_GPIO_EMC_B1_29_SEMC_CS0 0x084 0x2C8 0 0x0 0
434#define IMXRT_PAD_GPIO_EMC_B1_29_FLEXPWM3_PWM0_A 0x084 0x2C8 0x530 0x1 0
435#define IMXRT_PAD_GPIO_EMC_B1_29_GPIO_MUX1_IO29 0x084 0x2C8 0 0x5 0
436#define IMXRT_PAD_GPIO_EMC_B1_29_FLEXIO1_D29 0x084 0x2C8 0 0x8 0
437#define IMXRT_PAD_GPIO_EMC_B1_29_GPIO7_IO29 0x084 0x2C8 0 0xA 0
438
439#define IMXRT_PAD_GPIO_EMC_B1_30_SEMC_DATA08 0x088 0x2CC 0 0x0 0
440#define IMXRT_PAD_GPIO_EMC_B1_30_FLEXPWM3_PWM0_B 0x088 0x2CC 0x540 0x1 0
441#define IMXRT_PAD_GPIO_EMC_B1_30_GPIO_MUX1_IO30 0x088 0x2CC 0 0x5 0
442#define IMXRT_PAD_GPIO_EMC_B1_30_FLEXIO1_D30 0x088 0x2CC 0 0x8 0
443#define IMXRT_PAD_GPIO_EMC_B1_30_GPIO7_IO30 0x088 0x2CC 0 0xA 0
444
445#define IMXRT_PAD_GPIO_EMC_B1_31_GPIO7_IO31 0x08C 0x2D0 0 0xA 0
446#define IMXRT_PAD_GPIO_EMC_B1_31_SEMC_DATA09 0x08C 0x2D0 0 0x0 0
447#define IMXRT_PAD_GPIO_EMC_B1_31_FLEXPWM3_PWM1_A 0x08C 0x2D0 0x534 0x1 0
448#define IMXRT_PAD_GPIO_EMC_B1_31_GPIO_MUX1_IO31 0x08C 0x2D0 0 0x5 0
449#define IMXRT_PAD_GPIO_EMC_B1_31_FLEXIO1_D31 0x08C 0x2D0 0 0x8 0
450
451#define IMXRT_PAD_GPIO_EMC_B1_32_GPIO8_IO00 0x090 0x2D4 0 0xA 0
452#define IMXRT_PAD_GPIO_EMC_B1_32_SEMC_DATA10 0x090 0x2D4 0 0x0 0
453#define IMXRT_PAD_GPIO_EMC_B1_32_FLEXPWM3_PWM1_B 0x090 0x2D4 0x544 0x1 0
454#define IMXRT_PAD_GPIO_EMC_B1_32_GPIO_MUX2_IO00 0x090 0x2D4 0 0x5 0
455
456#define IMXRT_PAD_GPIO_EMC_B1_33_SEMC_DATA11 0x094 0x2D8 0 0x0 0
457#define IMXRT_PAD_GPIO_EMC_B1_33_FLEXPWM3_PWM2_A 0x094 0x2D8 0x538 0x1 0
458#define IMXRT_PAD_GPIO_EMC_B1_33_GPIO_MUX2_IO01 0x094 0x2D8 0 0x5 0
459#define IMXRT_PAD_GPIO_EMC_B1_33_GPIO8_IO01 0x094 0x2D8 0 0xA 0
460
461#define IMXRT_PAD_GPIO_EMC_B1_34_GPIO8_IO02 0x098 0x2DC 0 0xA 0
462#define IMXRT_PAD_GPIO_EMC_B1_34_SEMC_DATA12 0x098 0x2DC 0 0x0 0
463#define IMXRT_PAD_GPIO_EMC_B1_34_FLEXPWM3_PWM2_B 0x098 0x2DC 0x548 0x1 0
464#define IMXRT_PAD_GPIO_EMC_B1_34_GPIO_MUX2_IO02 0x098 0x2DC 0 0x5 0
465
466#define IMXRT_PAD_GPIO_EMC_B1_35_GPIO8_IO03 0x09C 0x2E0 0 0xA 0
467#define IMXRT_PAD_GPIO_EMC_B1_35_SEMC_DATA13 0x09C 0x2E0 0 0x0 0
468#define IMXRT_PAD_GPIO_EMC_B1_35_XBAR1_INOUT09 0x09C 0x2E0 0 0x1 0
469#define IMXRT_PAD_GPIO_EMC_B1_35_GPIO_MUX2_IO03 0x09C 0x2E0 0 0x5 0
470
471#define IMXRT_PAD_GPIO_EMC_B1_36_SEMC_DATA14 0x0A0 0x2E4 0 0x0 0
472#define IMXRT_PAD_GPIO_EMC_B1_36_XBAR1_INOUT10 0x0A0 0x2E4 0 0x1 0
473#define IMXRT_PAD_GPIO_EMC_B1_36_GPIO_MUX2_IO04 0x0A0 0x2E4 0 0x5 0
474#define IMXRT_PAD_GPIO_EMC_B1_36_GPIO8_IO04 0x0A0 0x2E4 0 0xA 0
475
476#define IMXRT_PAD_GPIO_EMC_B1_37_GPIO8_IO05 0x0A4 0x2E8 0 0xA 0
477#define IMXRT_PAD_GPIO_EMC_B1_37_SEMC_DATA15 0x0A4 0x2E8 0 0x0 0
478#define IMXRT_PAD_GPIO_EMC_B1_37_XBAR1_INOUT11 0x0A4 0x2E8 0 0x1 0
479#define IMXRT_PAD_GPIO_EMC_B1_37_GPIO_MUX2_IO05 0x0A4 0x2E8 0 0x5 0
480
481#define IMXRT_PAD_GPIO_EMC_B1_38_GPIO8_IO06 0x0A8 0x2EC 0 0xA 0
482#define IMXRT_PAD_GPIO_EMC_B1_38_SEMC_DM01 0x0A8 0x2EC 0 0x0 0
483#define IMXRT_PAD_GPIO_EMC_B1_38_FLEXPWM1_PWM3_A 0x0A8 0x2EC 0 0x1 0
484#define IMXRT_PAD_GPIO_EMC_B1_38_TMR1_TIMER1 0x0A8 0x2EC 0x640 0x2 0
485#define IMXRT_PAD_GPIO_EMC_B1_38_GPIO_MUX2_IO06 0x0A8 0x2EC 0 0x5 0
486
487#define IMXRT_PAD_GPIO_EMC_B1_39_SEMC_DQS 0x0AC 0x2F0 0 0x0 0
488#define IMXRT_PAD_GPIO_EMC_B1_39_FLEXPWM1_PWM3_B 0x0AC 0x2F0 0 0x1 0
489#define IMXRT_PAD_GPIO_EMC_B1_39_TMR2_TIMER1 0x0AC 0x2F0 0x64C 0x2 0
490#define IMXRT_PAD_GPIO_EMC_B1_39_GPIO_MUX2_IO07 0x0AC 0x2F0 0 0x5 0
491#define IMXRT_PAD_GPIO_EMC_B1_39_GPIO8_IO07 0x0AC 0x2F0 0 0xA 0
492
493#define IMXRT_PAD_GPIO_EMC_B1_40_SEMC_RDY 0x0B0 0x2F4 0 0x0 0
494#define IMXRT_PAD_GPIO_EMC_B1_40_XBAR1_INOUT12 0x0B0 0x2F4 0 0x1 0
495#define IMXRT_PAD_GPIO_EMC_B1_40_MQS_RIGHT 0x0B0 0x2F4 0 0x2 0
496#define IMXRT_PAD_GPIO_EMC_B1_40_LPUART6_TXD 0x0B0 0x2F4 0 0x3 0
497#define IMXRT_PAD_GPIO_EMC_B1_40_GPIO_MUX2_IO08 0x0B0 0x2F4 0 0x5 0
498#define IMXRT_PAD_GPIO_EMC_B1_40_ENET_1G_MDC 0x0B0 0x2F4 0 0x7 0
499#define IMXRT_PAD_GPIO_EMC_B1_40_CCM_CLKO1 0x0B0 0x2F4 0 0x9 0
500#define IMXRT_PAD_GPIO_EMC_B1_40_GPIO8_IO08 0x0B0 0x2F4 0 0xA 0
501
502#define IMXRT_PAD_GPIO_EMC_B1_41_GPIO8_IO09 0x0B4 0x2F8 0 0xA 0
503#define IMXRT_PAD_GPIO_EMC_B1_41_SEMC_CSX00 0x0B4 0x2F8 0 0x0 0
504#define IMXRT_PAD_GPIO_EMC_B1_41_XBAR1_INOUT13 0x0B4 0x2F8 0 0x1 0
505#define IMXRT_PAD_GPIO_EMC_B1_41_MQS_LEFT 0x0B4 0x2F8 0 0x2 0
506#define IMXRT_PAD_GPIO_EMC_B1_41_LPUART6_RXD 0x0B4 0x2F8 0 0x3 0
507#define IMXRT_PAD_GPIO_EMC_B1_41_FLEXSPI2_B_DATA07 0x0B4 0x2F8 0 0x4 0
508#define IMXRT_PAD_GPIO_EMC_B1_41_GPIO_MUX2_IO09 0x0B4 0x2F8 0 0x5 0
509#define IMXRT_PAD_GPIO_EMC_B1_41_ENET_1G_MDIO 0x0B4 0x2F8 0x4C8 0x7 0
510#define IMXRT_PAD_GPIO_EMC_B1_41_CCM_CLKO2 0x0B4 0x2F8 0 0x9 0
511
512#define IMXRT_PAD_GPIO_EMC_B2_00_SEMC_DATA16 0x0B8 0x2FC 0 0x0 0
513#define IMXRT_PAD_GPIO_EMC_B2_00_CCM_ENET_REF_CLK_25M 0x0B8 0x2FC 0 0x1 0
514#define IMXRT_PAD_GPIO_EMC_B2_00_TMR3_TIMER1 0x0B8 0x2FC 0x658 0x2 0
515#define IMXRT_PAD_GPIO_EMC_B2_00_LPUART6_CTS_B 0x0B8 0x2FC 0 0x3 0
516#define IMXRT_PAD_GPIO_EMC_B2_00_FLEXSPI2_B_DATA06 0x0B8 0x2FC 0 0x4 0
517#define IMXRT_PAD_GPIO_EMC_B2_00_GPIO_MUX2_IO10 0x0B8 0x2FC 0 0x5 0
518#define IMXRT_PAD_GPIO_EMC_B2_00_XBAR1_INOUT20 0x0B8 0x2FC 0x6D8 0x6 0
519#define IMXRT_PAD_GPIO_EMC_B2_00_ENET_QOS_1588_EVENT1_OUT 0x0B8 0x2FC 0 0x7 0
520#define IMXRT_PAD_GPIO_EMC_B2_00_LPSPI1_SCK 0x0B8 0x2FC 0x5D0 0x8 0
521#define IMXRT_PAD_GPIO_EMC_B2_00_LPI2C2_SCL 0x0B8 0x2FC 0x5B4 0x9 0
522#define IMXRT_PAD_GPIO_EMC_B2_00_GPIO8_IO10 0x0B8 0x2FC 0 0xA 0
523#define IMXRT_PAD_GPIO_EMC_B2_00_FLEXPWM3_PWM0_A 0x0B8 0x2FC 0x530 0xB 1
524
525#define IMXRT_PAD_GPIO_EMC_B2_01_SEMC_DATA17 0x0BC 0x300 0 0x0 0
526#define IMXRT_PAD_GPIO_EMC_B2_01_USDHC2_CD_B 0x0BC 0x300 0x6D0 0x1 0
527#define IMXRT_PAD_GPIO_EMC_B2_01_TMR4_TIMER1 0x0BC 0x300 0x664 0x2 0
528#define IMXRT_PAD_GPIO_EMC_B2_01_LPUART6_RTS_B 0x0BC 0x300 0 0x3 0
529#define IMXRT_PAD_GPIO_EMC_B2_01_FLEXSPI2_B_DATA05 0x0BC 0x300 0 0x4 0
530#define IMXRT_PAD_GPIO_EMC_B2_01_GPIO_MUX2_IO11 0x0BC 0x300 0 0x5 0
531#define IMXRT_PAD_GPIO_EMC_B2_01_XBAR1_INOUT21 0x0BC 0x300 0x6DC 0x6 0
532#define IMXRT_PAD_GPIO_EMC_B2_01_ENET_QOS_1588_EVENT1_IN 0x0BC 0x300 0 0x7 0
533#define IMXRT_PAD_GPIO_EMC_B2_01_LPSPI1_PCS0 0x0BC 0x300 0x5CC 0x8 0
534#define IMXRT_PAD_GPIO_EMC_B2_01_LPI2C2_SDA 0x0BC 0x300 0x5B8 0x9 0
535#define IMXRT_PAD_GPIO_EMC_B2_01_GPIO8_IO11 0x0BC 0x300 0 0xA 0
536#define IMXRT_PAD_GPIO_EMC_B2_01_FLEXPWM3_PWM0_B 0x0BC 0x300 0x540 0xB 1
537
538#define IMXRT_PAD_GPIO_EMC_B2_02_SEMC_DATA18 0x0C0 0x304 0 0x0 0
539#define IMXRT_PAD_GPIO_EMC_B2_02_USDHC2_WP 0x0C0 0x304 0x6D4 0x1 0
540#define IMXRT_PAD_GPIO_EMC_B2_02_VIDEO_MUX_CSI_DATA23 0x0C0 0x304 0 0x3 0
541#define IMXRT_PAD_GPIO_EMC_B2_02_FLEXSPI2_B_DATA04 0x0C0 0x304 0 0x4 0
542#define IMXRT_PAD_GPIO_EMC_B2_02_GPIO_MUX2_IO12 0x0C0 0x304 0 0x5 0
543#define IMXRT_PAD_GPIO_EMC_B2_02_XBAR1_INOUT22 0x0C0 0x304 0x6E0 0x6 0
544#define IMXRT_PAD_GPIO_EMC_B2_02_ENET_QOS_1588_EVENT1_AUX_IN 0x0C0 0x304 0 0x7 0
545#define IMXRT_PAD_GPIO_EMC_B2_02_LPSPI1_SOUT 0x0C0 0x304 0x5D8 0x8 0
546#define IMXRT_PAD_GPIO_EMC_B2_02_GPIO8_IO12 0x0C0 0x304 0 0xA 0
547#define IMXRT_PAD_GPIO_EMC_B2_02_FLEXPWM3_PWM1_A 0x0C0 0x304 0x534 0xB 1
548
549#define IMXRT_PAD_GPIO_EMC_B2_03_SEMC_DATA19 0x0C4 0x308 0 0x0 0
550#define IMXRT_PAD_GPIO_EMC_B2_03_USDHC2_VSELECT 0x0C4 0x308 0 0x1 0
551#define IMXRT_PAD_GPIO_EMC_B2_03_VIDEO_MUX_CSI_DATA22 0x0C4 0x308 0 0x3 0
552#define IMXRT_PAD_GPIO_EMC_B2_03_FLEXSPI2_B_DATA03 0x0C4 0x308 0 0x4 0
553#define IMXRT_PAD_GPIO_EMC_B2_03_GPIO_MUX2_IO13 0x0C4 0x308 0 0x5 0
554#define IMXRT_PAD_GPIO_EMC_B2_03_XBAR1_INOUT23 0x0C4 0x308 0x6E4 0x6 0
555#define IMXRT_PAD_GPIO_EMC_B2_03_ENET_1G_TX_DATA03 0x0C4 0x308 0 0x7 0
556#define IMXRT_PAD_GPIO_EMC_B2_03_LPSPI1_SIN 0x0C4 0x308 0x5D4 0x8 0
557#define IMXRT_PAD_GPIO_EMC_B2_03_GPIO8_IO13 0x0C4 0x308 0 0xA 0
558#define IMXRT_PAD_GPIO_EMC_B2_03_FLEXPWM3_PWM1_B 0x0C4 0x308 0x544 0xB 1
559
560#define IMXRT_PAD_GPIO_EMC_B2_04_SEMC_DATA20 0x0C8 0x30C 0 0x0 0
561#define IMXRT_PAD_GPIO_EMC_B2_04_USDHC2_RESET_B 0x0C8 0x30C 0 0x1 0
562#define IMXRT_PAD_GPIO_EMC_B2_04_SAI2_MCLK 0x0C8 0x30C 0 0x2 0
563#define IMXRT_PAD_GPIO_EMC_B2_04_VIDEO_MUX_CSI_DATA21 0x0C8 0x30C 0 0x3 0
564#define IMXRT_PAD_GPIO_EMC_B2_04_FLEXSPI2_B_DATA02 0x0C8 0x30C 0 0x4 0
565#define IMXRT_PAD_GPIO_EMC_B2_04_GPIO_MUX2_IO14 0x0C8 0x30C 0 0x5 0
566#define IMXRT_PAD_GPIO_EMC_B2_04_XBAR1_INOUT24 0x0C8 0x30C 0x6E8 0x6 0
567#define IMXRT_PAD_GPIO_EMC_B2_04_ENET_1G_TX_DATA02 0x0C8 0x30C 0 0x7 0
568#define IMXRT_PAD_GPIO_EMC_B2_04_LPSPI3_SCK 0x0C8 0x30C 0x600 0x8 0
569#define IMXRT_PAD_GPIO_EMC_B2_04_GPIO8_IO14 0x0C8 0x30C 0 0xA 0
570#define IMXRT_PAD_GPIO_EMC_B2_04_FLEXPWM3_PWM2_A 0x0C8 0x30C 0x538 0xB 1
571
572#define IMXRT_PAD_GPIO_EMC_B2_05_SEMC_DATA21 0x0CC 0x310 0 0x0 0
573#define IMXRT_PAD_GPIO_EMC_B2_05_GPT3_CLK 0x0CC 0x310 0x598 0x1 0
574#define IMXRT_PAD_GPIO_EMC_B2_05_SAI2_RX_SYNC 0x0CC 0x310 0 0x2 0
575#define IMXRT_PAD_GPIO_EMC_B2_05_VIDEO_MUX_CSI_DATA20 0x0CC 0x310 0 0x3 0
576#define IMXRT_PAD_GPIO_EMC_B2_05_FLEXSPI2_B_DATA01 0x0CC 0x310 0 0x4 0
577#define IMXRT_PAD_GPIO_EMC_B2_05_GPIO_MUX2_IO15 0x0CC 0x310 0 0x5 0
578#define IMXRT_PAD_GPIO_EMC_B2_05_XBAR1_INOUT25 0x0CC 0x310 0x6EC 0x6 0
579#define IMXRT_PAD_GPIO_EMC_B2_05_ENET_1G_RX_CLK 0x0CC 0x310 0x4CC 0x7 0
580#define IMXRT_PAD_GPIO_EMC_B2_05_LPSPI3_PCS0 0x0CC 0x310 0x5F0 0x8 0
581#define IMXRT_PAD_GPIO_EMC_B2_05_PIT1_TRIGGER0 0x0CC 0x310 0 0x9 0
582#define IMXRT_PAD_GPIO_EMC_B2_05_GPIO8_IO15 0x0CC 0x310 0 0xA 0
583#define IMXRT_PAD_GPIO_EMC_B2_05_FLEXPWM3_PWM2_B 0x0CC 0x310 0x548 0xB 1
584
585#define IMXRT_PAD_GPIO_EMC_B2_06_SEMC_DATA22 0x0D0 0x314 0 0x0 0
586#define IMXRT_PAD_GPIO_EMC_B2_06_GPT3_CAPTURE1 0x0D0 0x314 0x590 0x1 0
587#define IMXRT_PAD_GPIO_EMC_B2_06_GPIO8_IO16 0x0D0 0x314 0 0xA 0
588#define IMXRT_PAD_GPIO_EMC_B2_06_SAI2_RX_BCLK 0x0D0 0x314 0 0x2 0
589#define IMXRT_PAD_GPIO_EMC_B2_06_FLEXPWM3_PWM3_A 0x0D0 0x314 0x53C 0xB 1
590#define IMXRT_PAD_GPIO_EMC_B2_06_VIDEO_MUX_CSI_DATA19 0x0D0 0x314 0 0x3 0
591#define IMXRT_PAD_GPIO_EMC_B2_06_FLEXSPI2_B_DATA00 0x0D0 0x314 0 0x4 0
592#define IMXRT_PAD_GPIO_EMC_B2_06_GPIO_MUX2_IO16 0x0D0 0x314 0 0x5 0
593#define IMXRT_PAD_GPIO_EMC_B2_06_XBAR1_INOUT26 0x0D0 0x314 0x6F0 0x6 0
594#define IMXRT_PAD_GPIO_EMC_B2_06_ENET_1G_TX_ER 0x0D0 0x314 0 0x7 0
595#define IMXRT_PAD_GPIO_EMC_B2_06_LPSPI3_SOUT 0x0D0 0x314 0x608 0x8 0
596#define IMXRT_PAD_GPIO_EMC_B2_06_PIT1_TRIGGER1 0x0D0 0x314 0 0x9 0
597
598#define IMXRT_PAD_GPIO_EMC_B2_07_SEMC_DATA23 0x0D4 0x318 0 0x0 0
599#define IMXRT_PAD_GPIO_EMC_B2_07_GPT3_CAPTURE2 0x0D4 0x318 0x594 0x1 0
600#define IMXRT_PAD_GPIO_EMC_B2_07_SAI2_RX_DATA 0x0D4 0x318 0 0x2 0
601#define IMXRT_PAD_GPIO_EMC_B2_07_VIDEO_MUX_CSI_DATA18 0x0D4 0x318 0 0x3 0
602#define IMXRT_PAD_GPIO_EMC_B2_07_FLEXSPI2_B_DQS 0x0D4 0x318 0 0x4 0
603#define IMXRT_PAD_GPIO_EMC_B2_07_GPIO_MUX2_IO17 0x0D4 0x318 0 0x5 0
604#define IMXRT_PAD_GPIO_EMC_B2_07_XBAR1_INOUT27 0x0D4 0x318 0x6F4 0x6 0
605#define IMXRT_PAD_GPIO_EMC_B2_07_ENET_1G_RX_DATA03 0x0D4 0x318 0x4DC 0x7 0
606#define IMXRT_PAD_GPIO_EMC_B2_07_LPSPI3_SIN 0x0D4 0x318 0x604 0x8 0
607#define IMXRT_PAD_GPIO_EMC_B2_07_PIT1_TRIGGER2 0x0D4 0x318 0 0x9 0
608#define IMXRT_PAD_GPIO_EMC_B2_07_GPIO8_IO17 0x0D4 0x318 0 0xA 0
609#define IMXRT_PAD_GPIO_EMC_B2_07_FLEXPWM3_PWM3_B 0x0D4 0x318 0x54C 0xB 1
610
611#define IMXRT_PAD_GPIO_EMC_B2_08_SEMC_DM02 0x0D8 0x31C 0 0x0 0
612#define IMXRT_PAD_GPIO_EMC_B2_08_GPT3_COMPARE1 0x0D8 0x31C 0 0x1 0
613#define IMXRT_PAD_GPIO_EMC_B2_08_SAI2_TX_DATA 0x0D8 0x31C 0 0x2 0
614#define IMXRT_PAD_GPIO_EMC_B2_08_VIDEO_MUX_CSI_DATA17 0x0D8 0x31C 0 0x3 0
615#define IMXRT_PAD_GPIO_EMC_B2_08_FLEXSPI2_B_SS0_B 0x0D8 0x31C 0 0x4 0
616#define IMXRT_PAD_GPIO_EMC_B2_08_GPIO_MUX2_IO18 0x0D8 0x31C 0 0x5 0
617#define IMXRT_PAD_GPIO_EMC_B2_08_XBAR1_INOUT28 0x0D8 0x31C 0x6F8 0x6 0
618#define IMXRT_PAD_GPIO_EMC_B2_08_ENET_1G_RX_DATA02 0x0D8 0x31C 0x4D8 0x7 0
619#define IMXRT_PAD_GPIO_EMC_B2_08_LPSPI3_PCS1 0x0D8 0x31C 0x5F4 0x8 0
620#define IMXRT_PAD_GPIO_EMC_B2_08_PIT1_TRIGGER3 0x0D8 0x31C 0 0x9 0
621#define IMXRT_PAD_GPIO_EMC_B2_08_GPIO8_IO18 0x0D8 0x31C 0 0xA 0
622
623#define IMXRT_PAD_GPIO_EMC_B2_09_GPIO8_IO19 0x0DC 0x320 0 0xA 0
624#define IMXRT_PAD_GPIO_EMC_B2_09_SEMC_DATA24 0x0DC 0x320 0 0x0 0
625#define IMXRT_PAD_GPIO_EMC_B2_09_GPT3_COMPARE2 0x0DC 0x320 0 0x1 0
626#define IMXRT_PAD_GPIO_EMC_B2_09_SAI2_TX_BCLK 0x0DC 0x320 0 0x2 0
627#define IMXRT_PAD_GPIO_EMC_B2_09_VIDEO_MUX_CSI_DATA16 0x0DC 0x320 0 0x3 0
628#define IMXRT_PAD_GPIO_EMC_B2_09_FLEXSPI2_B_SCLK 0x0DC 0x320 0 0x4 0
629#define IMXRT_PAD_GPIO_EMC_B2_09_GPIO_MUX2_IO19 0x0DC 0x320 0 0x5 0
630#define IMXRT_PAD_GPIO_EMC_B2_09_XBAR1_INOUT29 0x0DC 0x320 0x6FC 0x6 0
631#define IMXRT_PAD_GPIO_EMC_B2_09_ENET_1G_CRS 0x0DC 0x320 0 0x7 0
632#define IMXRT_PAD_GPIO_EMC_B2_09_LPSPI3_PCS2 0x0DC 0x320 0x5F8 0x8 0
633#define IMXRT_PAD_GPIO_EMC_B2_09_TMR1_TIMER0 0x0DC 0x320 0x63C 0x9 1
634
635#define IMXRT_PAD_GPIO_EMC_B2_10_GPIO8_IO20 0x0E0 0x324 0 0xA 0
636#define IMXRT_PAD_GPIO_EMC_B2_10_SEMC_DATA25 0x0E0 0x324 0 0x0 0
637#define IMXRT_PAD_GPIO_EMC_B2_10_GPT3_COMPARE3 0x0E0 0x324 0 0x1 0
638#define IMXRT_PAD_GPIO_EMC_B2_10_SAI2_TX_SYNC 0x0E0 0x324 0 0x2 0
639#define IMXRT_PAD_GPIO_EMC_B2_10_VIDEO_MUX_CSI_FIELD 0x0E0 0x324 0 0x3 0
640#define IMXRT_PAD_GPIO_EMC_B2_10_FLEXSPI2_A_SCLK 0x0E0 0x324 0x58C 0x4 0
641#define IMXRT_PAD_GPIO_EMC_B2_10_GPIO_MUX2_IO20 0x0E0 0x324 0 0x5 0
642#define IMXRT_PAD_GPIO_EMC_B2_10_XBAR1_INOUT30 0x0E0 0x324 0x700 0x6 0
643#define IMXRT_PAD_GPIO_EMC_B2_10_ENET_1G_COL 0x0E0 0x324 0 0x7 0
644#define IMXRT_PAD_GPIO_EMC_B2_10_LPSPI3_PCS3 0x0E0 0x324 0x5FC 0x8 0
645#define IMXRT_PAD_GPIO_EMC_B2_10_TMR1_TIMER1 0x0E0 0x324 0x640 0x9 1
646
647#define IMXRT_PAD_GPIO_EMC_B2_11_SEMC_DATA26 0x0E4 0x328 0 0x0 0
648#define IMXRT_PAD_GPIO_EMC_B2_11_SPDIF_IN 0x0E4 0x328 0x6B4 0x1 0
649#define IMXRT_PAD_GPIO_EMC_B2_11_ENET_1G_TX_DATA00 0x0E4 0x328 0 0x2 0
650#define IMXRT_PAD_GPIO_EMC_B2_11_SAI3_RX_SYNC 0x0E4 0x328 0 0x3 0
651#define IMXRT_PAD_GPIO_EMC_B2_11_FLEXSPI2_A_SS0_B 0x0E4 0x328 0 0x4 0
652#define IMXRT_PAD_GPIO_EMC_B2_11_GPIO_MUX2_IO21 0x0E4 0x328 0 0x5 0
653#define IMXRT_PAD_GPIO_EMC_B2_11_XBAR1_INOUT31 0x0E4 0x328 0x704 0x6 0
654#define IMXRT_PAD_GPIO_EMC_B2_11_EMVSIM1_IO 0x0E4 0x328 0x69C 0x8 0
655#define IMXRT_PAD_GPIO_EMC_B2_11_TMR1_TIMER2 0x0E4 0x328 0x644 0x9 0
656#define IMXRT_PAD_GPIO_EMC_B2_11_GPIO8_IO21 0x0E4 0x328 0 0xA 0
657
658#define IMXRT_PAD_GPIO_EMC_B2_12_SEMC_DATA27 0x0E8 0x32C 0 0x0 0
659#define IMXRT_PAD_GPIO_EMC_B2_12_SPDIF_OUT 0x0E8 0x32C 0 0x1 0
660#define IMXRT_PAD_GPIO_EMC_B2_12_ENET_1G_TX_DATA01 0x0E8 0x32C 0 0x2 0
661#define IMXRT_PAD_GPIO_EMC_B2_12_SAI3_RX_BCLK 0x0E8 0x32C 0 0x3 0
662#define IMXRT_PAD_GPIO_EMC_B2_12_FLEXSPI2_A_DQS 0x0E8 0x32C 0 0x4 0
663#define IMXRT_PAD_GPIO_EMC_B2_12_GPIO_MUX2_IO22 0x0E8 0x32C 0 0x5 0
664#define IMXRT_PAD_GPIO_EMC_B2_12_XBAR1_INOUT32 0x0E8 0x32C 0x708 0x6 0
665#define IMXRT_PAD_GPIO_EMC_B2_12_EMVSIM1_CLK 0x0E8 0x32C 0 0x8 0
666#define IMXRT_PAD_GPIO_EMC_B2_12_TMR1_TIMER3 0x0E8 0x32C 0 0x9 0
667#define IMXRT_PAD_GPIO_EMC_B2_12_GPIO8_IO22 0x0E8 0x32C 0 0xA 0
668
669#define IMXRT_PAD_GPIO_EMC_B2_13_GPIO8_IO23 0x0EC 0x330 0 0xA 0
670#define IMXRT_PAD_GPIO_EMC_B2_13_SEMC_DATA28 0x0EC 0x330 0 0x0 0
671#define IMXRT_PAD_GPIO_EMC_B2_13_ENET_1G_TX_EN 0x0EC 0x330 0 0x2 0
672#define IMXRT_PAD_GPIO_EMC_B2_13_SAI3_RX_DATA 0x0EC 0x330 0 0x3 0
673#define IMXRT_PAD_GPIO_EMC_B2_13_FLEXSPI2_A_DATA00 0x0EC 0x330 0x57C 0x4 0
674#define IMXRT_PAD_GPIO_EMC_B2_13_GPIO_MUX2_IO23 0x0EC 0x330 0 0x5 0
675#define IMXRT_PAD_GPIO_EMC_B2_13_XBAR1_INOUT33 0x0EC 0x330 0x70C 0x6 0
676#define IMXRT_PAD_GPIO_EMC_B2_13_EMVSIM1_RST 0x0EC 0x330 0 0x8 0
677#define IMXRT_PAD_GPIO_EMC_B2_13_TMR2_TIMER0 0x0EC 0x330 0x648 0x9 1
678
679#define IMXRT_PAD_GPIO_EMC_B2_14_SEMC_DATA29 0x0F0 0x334 0 0x0 0
680#define IMXRT_PAD_GPIO_EMC_B2_14_ENET_1G_TX_CLK_IO 0x0F0 0x334 0x4E8 0x2 0
681#define IMXRT_PAD_GPIO_EMC_B2_14_SAI3_TX_DATA 0x0F0 0x334 0 0x3 0
682#define IMXRT_PAD_GPIO_EMC_B2_14_FLEXSPI2_A_DATA01 0x0F0 0x334 0x580 0x4 0
683#define IMXRT_PAD_GPIO_EMC_B2_14_GPIO_MUX2_IO24 0x0F0 0x334 0 0x5 0
684#define IMXRT_PAD_GPIO_EMC_B2_14_XBAR1_INOUT34 0x0F0 0x334 0x710 0x6 0
685#define IMXRT_PAD_GPIO_EMC_B2_14_SFA_ipp_do_atx_clk_under_test 0x0F0 0x334 0 0x7 0
686#define IMXRT_PAD_GPIO_EMC_B2_14_EMVSIM1_SVEN 0x0F0 0x334 0 0x8 0
687#define IMXRT_PAD_GPIO_EMC_B2_14_TMR2_TIMER1 0x0F0 0x334 0x64C 0x9 1
688#define IMXRT_PAD_GPIO_EMC_B2_14_GPIO8_IO24 0x0F0 0x334 0 0xA 0
689
690#define IMXRT_PAD_GPIO_EMC_B2_15_SEMC_DATA30 0x0F4 0x338 0 0x0 0
691#define IMXRT_PAD_GPIO_EMC_B2_15_ENET_1G_RX_DATA00 0x0F4 0x338 0x4D0 0x2 0
692#define IMXRT_PAD_GPIO_EMC_B2_15_SAI3_TX_BCLK 0x0F4 0x338 0 0x3 0
693#define IMXRT_PAD_GPIO_EMC_B2_15_FLEXSPI2_A_DATA02 0x0F4 0x338 0x584 0x4 0
694#define IMXRT_PAD_GPIO_EMC_B2_15_GPIO_MUX2_IO25 0x0F4 0x338 0 0x5 0
695#define IMXRT_PAD_GPIO_EMC_B2_15_XBAR1_INOUT35 0x0F4 0x338 0x714 0x6 0
696#define IMXRT_PAD_GPIO_EMC_B2_15_EMVSIM1_PD 0x0F4 0x338 0x6A0 0x8 0
697#define IMXRT_PAD_GPIO_EMC_B2_15_TMR2_TIMER2 0x0F4 0x338 0x650 0x9 0
698#define IMXRT_PAD_GPIO_EMC_B2_15_GPIO8_IO25 0x0F4 0x338 0 0xA 0
699
700#define IMXRT_PAD_GPIO_EMC_B2_16_GPIO8_IO26 0x0F8 0x33C 0 0xA 0
701#define IMXRT_PAD_GPIO_EMC_B2_16_SEMC_DATA31 0x0F8 0x33C 0 0x0 0
702#define IMXRT_PAD_GPIO_EMC_B2_16_XBAR1_INOUT14 0x0F8 0x33C 0 0x1 0
703#define IMXRT_PAD_GPIO_EMC_B2_16_ENET_1G_RX_DATA01 0x0F8 0x33C 0x4D4 0x2 0
704#define IMXRT_PAD_GPIO_EMC_B2_16_SAI3_TX_SYNC 0x0F8 0x33C 0 0x3 0
705#define IMXRT_PAD_GPIO_EMC_B2_16_FLEXSPI2_A_DATA03 0x0F8 0x33C 0x588 0x4 0
706#define IMXRT_PAD_GPIO_EMC_B2_16_GPIO_MUX2_IO26 0x0F8 0x33C 0 0x5 0
707#define IMXRT_PAD_GPIO_EMC_B2_16_EMVSIM1_POWER_FAIL 0x0F8 0x33C 0x6A4 0x8 0
708#define IMXRT_PAD_GPIO_EMC_B2_16_TMR2_TIMER3 0x0F8 0x33C 0 0x9 0
709
710#define IMXRT_PAD_GPIO_EMC_B2_17_SEMC_DM03 0x0FC 0x340 0 0x0 0
711#define IMXRT_PAD_GPIO_EMC_B2_17_XBAR1_INOUT15 0x0FC 0x340 0 0x1 0
712#define IMXRT_PAD_GPIO_EMC_B2_17_ENET_1G_RX_EN 0x0FC 0x340 0x4E0 0x2 0
713#define IMXRT_PAD_GPIO_EMC_B2_17_SAI3_MCLK 0x0FC 0x340 0 0x3 0
714#define IMXRT_PAD_GPIO_EMC_B2_17_FLEXSPI2_A_DATA04 0x0FC 0x340 0 0x4 0
715#define IMXRT_PAD_GPIO_EMC_B2_17_GPIO_MUX2_IO27 0x0FC 0x340 0 0x5 0
716#define IMXRT_PAD_GPIO_EMC_B2_17_WDOG1_ANY 0x0FC 0x340 0 0x8 0
717#define IMXRT_PAD_GPIO_EMC_B2_17_TMR3_TIMER0 0x0FC 0x340 0x654 0x9 1
718#define IMXRT_PAD_GPIO_EMC_B2_17_GPIO8_IO27 0x0FC 0x340 0 0xA 0
719
720#define IMXRT_PAD_GPIO_EMC_B2_18_SEMC_DQS4 0x100 0x344 0 0x0 0
721#define IMXRT_PAD_GPIO_EMC_B2_18_XBAR1_INOUT16 0x100 0x344 0 0x1 0
722#define IMXRT_PAD_GPIO_EMC_B2_18_ENET_1G_RX_ER 0x100 0x344 0x4E4 0x2 0
723#define IMXRT_PAD_GPIO_EMC_B2_18_EWM_OUT_B 0x100 0x344 0 0x3 0
724#define IMXRT_PAD_GPIO_EMC_B2_18_FLEXSPI2_A_DATA05 0x100 0x344 0 0x4 0
725#define IMXRT_PAD_GPIO_EMC_B2_18_GPIO_MUX2_IO28 0x100 0x344 0 0x5 0
726#define IMXRT_PAD_GPIO_EMC_B2_18_FLEXSPI1_A_DQS 0x100 0x344 0x550 0x6 0
727#define IMXRT_PAD_GPIO_EMC_B2_18_WDOG1_B 0x100 0x344 0 0x8 0
728#define IMXRT_PAD_GPIO_EMC_B2_18_TMR3_TIMER1 0x100 0x344 0x658 0x9 1
729#define IMXRT_PAD_GPIO_EMC_B2_18_GPIO8_IO28 0x100 0x344 0 0xA 0
730
731#define IMXRT_PAD_GPIO_EMC_B2_19_GPIO8_IO29 0x104 0x348 0 0xA 0
732#define IMXRT_PAD_GPIO_EMC_B2_19_SEMC_CLKX00 0x104 0x348 0 0x0 0
733#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_MDC 0x104 0x348 0 0x1 0
734#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_1G_MDC 0x104 0x348 0 0x2 0
735#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_1G_REF_CLK 0x104 0x348 0x4C4 0x3 0
736#define IMXRT_PAD_GPIO_EMC_B2_19_FLEXSPI2_A_DATA06 0x104 0x348 0 0x4 0
737#define IMXRT_PAD_GPIO_EMC_B2_19_GPIO_MUX2_IO29 0x104 0x348 0 0x5 0
738#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_QOS_MDC 0x104 0x348 0 0x8 0
739#define IMXRT_PAD_GPIO_EMC_B2_19_TMR3_TIMER2 0x104 0x348 0x65C 0x9 0
740
741#define IMXRT_PAD_GPIO_EMC_B2_20_GPIO8_IO30 0x108 0x34C 0 0xA 0
742#define IMXRT_PAD_GPIO_EMC_B2_20_SEMC_CLKX01 0x108 0x34C 0 0x0 0
743#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_MDIO 0x108 0x34C 0x4AC 0x1 0
744#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_1G_MDIO 0x108 0x34C 0x4C8 0x2 1
745#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_QOS_REF_CLK 0x108 0x34C 0x4A0 0x3 0
746#define IMXRT_PAD_GPIO_EMC_B2_20_FLEXSPI2_A_DATA07 0x108 0x34C 0 0x4 0
747#define IMXRT_PAD_GPIO_EMC_B2_20_GPIO_MUX2_IO30 0x108 0x34C 0 0x5 0
748#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_QOS_MDIO 0x108 0x34C 0x4EC 0x8 0
749#define IMXRT_PAD_GPIO_EMC_B2_20_TMR3_TIMER3 0x108 0x34C 0 0x9 0
750
751#define IMXRT_PAD_GPIO_AD_00_GPIO8_IO31 0x10C 0x350 0 0xA 0
752#define IMXRT_PAD_GPIO_AD_00_EMVSIM1_IO 0x10C 0x350 0x69C 0x0 1
753#define IMXRT_PAD_GPIO_AD_00_FLEXCAN2_TX 0x10C 0x350 0 0x1 0
754#define IMXRT_PAD_GPIO_AD_00_ENET_1G_1588_EVENT1_IN 0x10C 0x350 0 0x2 0
755#define IMXRT_PAD_GPIO_AD_00_GPT2_CAPTURE1 0x10C 0x350 0 0x3 0
756#define IMXRT_PAD_GPIO_AD_00_FLEXPWM1_PWM0_A 0x10C 0x350 0x500 0x4 1
757#define IMXRT_PAD_GPIO_AD_00_GPIO_MUX2_IO31 0x10C 0x350 0 0x5 0
758#define IMXRT_PAD_GPIO_AD_00_LPUART7_TXD 0x10C 0x350 0x630 0x6 0
759#define IMXRT_PAD_GPIO_AD_00_FLEXIO2_D00 0x10C 0x350 0 0x8 0
760#define IMXRT_PAD_GPIO_AD_00_FLEXSPI2_B_SS1_B 0x10C 0x350 0 0x9 0
761
762#define IMXRT_PAD_GPIO_AD_01_GPIO9_IO00 0x110 0x354 0 0xA 0
763#define IMXRT_PAD_GPIO_AD_01_EMVSIM1_CLK 0x110 0x354 0 0x0 0
764#define IMXRT_PAD_GPIO_AD_01_FLEXCAN2_RX 0x110 0x354 0x49C 0x1 0
765#define IMXRT_PAD_GPIO_AD_01_ENET_1G_1588_EVENT1_OUT 0x110 0x354 0 0x2 0
766#define IMXRT_PAD_GPIO_AD_01_GPT2_CAPTURE2 0x110 0x354 0 0x3 0
767#define IMXRT_PAD_GPIO_AD_01_FLEXPWM1_PWM0_B 0x110 0x354 0x50C 0x4 1
768#define IMXRT_PAD_GPIO_AD_01_GPIO_MUX3_IO00 0x110 0x354 0 0x5 0
769#define IMXRT_PAD_GPIO_AD_01_LPUART7_RXD 0x110 0x354 0x62C 0x6 0
770#define IMXRT_PAD_GPIO_AD_01_FLEXIO2_D01 0x110 0x354 0 0x8 0
771#define IMXRT_PAD_GPIO_AD_01_FLEXSPI2_A_SS1_B 0x110 0x354 0 0x9 0
772
773#define IMXRT_PAD_GPIO_AD_02_GPIO9_IO01 0x114 0x358 0 0xA 0
774#define IMXRT_PAD_GPIO_AD_02_EMVSIM1_RST 0x114 0x358 0 0x0 0
775#define IMXRT_PAD_GPIO_AD_02_LPUART7_CTS_B 0x114 0x358 0 0x1 0
776#define IMXRT_PAD_GPIO_AD_02_ENET_1G_1588_EVENT2_IN 0x114 0x358 0 0x2 0
777#define IMXRT_PAD_GPIO_AD_02_GPT2_COMPARE1 0x114 0x358 0 0x3 0
778#define IMXRT_PAD_GPIO_AD_02_FLEXPWM1_PWM1_A 0x114 0x358 0x504 0x4 1
779#define IMXRT_PAD_GPIO_AD_02_GPIO_MUX3_IO01 0x114 0x358 0 0x5 0
780#define IMXRT_PAD_GPIO_AD_02_LPUART8_TXD 0x114 0x358 0x638 0x6 0
781#define IMXRT_PAD_GPIO_AD_02_FLEXIO2_D02 0x114 0x358 0 0x8 0
782#define IMXRT_PAD_GPIO_AD_02_VIDEO_MUX_EXT_DCIC1 0x114 0x358 0 0x9 0
783
784#define IMXRT_PAD_GPIO_AD_03_GPIO9_IO02 0x118 0x35C 0 0xA 0
785#define IMXRT_PAD_GPIO_AD_03_EMVSIM1_SVEN 0x118 0x35C 0 0x0 0
786#define IMXRT_PAD_GPIO_AD_03_LPUART7_RTS_B 0x118 0x35C 0 0x1 0
787#define IMXRT_PAD_GPIO_AD_03_ENET_1G_1588_EVENT2_OUT 0x118 0x35C 0 0x2 0
788#define IMXRT_PAD_GPIO_AD_03_GPT2_COMPARE2 0x118 0x35C 0 0x3 0
789#define IMXRT_PAD_GPIO_AD_03_FLEXPWM1_PWM1_B 0x118 0x35C 0x510 0x4 1
790#define IMXRT_PAD_GPIO_AD_03_GPIO_MUX3_IO02 0x118 0x35C 0 0x5 0
791#define IMXRT_PAD_GPIO_AD_03_LPUART8_RXD 0x118 0x35C 0x634 0x6 0
792#define IMXRT_PAD_GPIO_AD_03_FLEXIO2_D03 0x118 0x35C 0 0x8 0
793#define IMXRT_PAD_GPIO_AD_03_VIDEO_MUX_EXT_DCIC2 0x118 0x35C 0 0x9 0
794
795#define IMXRT_PAD_GPIO_AD_04_EMVSIM1_PD 0x11C 0x360 0x6A0 0x0 1
796#define IMXRT_PAD_GPIO_AD_04_LPUART8_CTS_B 0x11C 0x360 0 0x1 0
797#define IMXRT_PAD_GPIO_AD_04_ENET_1G_1588_EVENT3_IN 0x11C 0x360 0 0x2 0
798#define IMXRT_PAD_GPIO_AD_04_GPT2_COMPARE3 0x11C 0x360 0 0x3 0
799#define IMXRT_PAD_GPIO_AD_04_FLEXPWM1_PWM2_A 0x11C 0x360 0x508 0x4 1
800#define IMXRT_PAD_GPIO_AD_04_GPIO_MUX3_IO03 0x11C 0x360 0 0x5 0
801#define IMXRT_PAD_GPIO_AD_04_WDOG1_B 0x11C 0x360 0 0x6 0
802#define IMXRT_PAD_GPIO_AD_04_FLEXIO2_D04 0x11C 0x360 0 0x8 0
803#define IMXRT_PAD_GPIO_AD_04_TMR4_TIMER0 0x11C 0x360 0x660 0x9 1
804#define IMXRT_PAD_GPIO_AD_04_GPIO9_IO03 0x11C 0x360 0 0xA 0
805
806#define IMXRT_PAD_GPIO_AD_05_EMVSIM1_POWER_FAIL 0x120 0x364 0x6A4 0x0 1
807#define IMXRT_PAD_GPIO_AD_05_LPUART8_RTS_B 0x120 0x364 0 0x1 0
808#define IMXRT_PAD_GPIO_AD_05_ENET_1G_1588_EVENT3_OUT 0x120 0x364 0 0x2 0
809#define IMXRT_PAD_GPIO_AD_05_GPT2_CLK 0x120 0x364 0 0x3 0
810#define IMXRT_PAD_GPIO_AD_05_FLEXPWM1_PWM2_B 0x120 0x364 0x514 0x4 1
811#define IMXRT_PAD_GPIO_AD_05_GPIO_MUX3_IO04 0x120 0x364 0 0x5 0
812#define IMXRT_PAD_GPIO_AD_05_WDOG2_B 0x120 0x364 0 0x6 0
813#define IMXRT_PAD_GPIO_AD_05_FLEXIO2_D05 0x120 0x364 0 0x8 0
814#define IMXRT_PAD_GPIO_AD_05_TMR4_TIMER1 0x120 0x364 0x664 0x9 1
815#define IMXRT_PAD_GPIO_AD_05_GPIO9_IO04 0x120 0x364 0 0xA 0
816
817#define IMXRT_PAD_GPIO_AD_06_USB_OTG2_OC 0x124 0x368 0x6B8 0x0 0
818#define IMXRT_PAD_GPIO_AD_06_FLEXCAN1_TX 0x124 0x368 0 0x1 0
819#define IMXRT_PAD_GPIO_AD_06_EMVSIM2_IO 0x124 0x368 0x6A8 0x2 0
820#define IMXRT_PAD_GPIO_AD_06_GPT3_CAPTURE1 0x124 0x368 0x590 0x3 1
821#define IMXRT_PAD_GPIO_AD_06_VIDEO_MUX_CSI_DATA15 0x124 0x368 0 0x4 0
822#define IMXRT_PAD_GPIO_AD_06_GPIO_MUX3_IO05 0x124 0x368 0 0x5 0
823#define IMXRT_PAD_GPIO_AD_06_ENET_1588_EVENT1_IN 0x124 0x368 0 0x6 0
824#define IMXRT_PAD_GPIO_AD_06_FLEXIO2_D06 0x124 0x368 0 0x8 0
825#define IMXRT_PAD_GPIO_AD_06_TMR4_TIMER2 0x124 0x368 0x668 0x9 0
826#define IMXRT_PAD_GPIO_AD_06_GPIO9_IO05 0x124 0x368 0 0xA 0
827#define IMXRT_PAD_GPIO_AD_06_FLEXPWM1_PWM0_X 0x124 0x368 0 0xB 0
828
829#define IMXRT_PAD_GPIO_AD_07_USB_OTG2_PWR 0x128 0x36C 0 0x0 0
830#define IMXRT_PAD_GPIO_AD_07_FLEXCAN1_RX 0x128 0x36C 0x498 0x1 0
831#define IMXRT_PAD_GPIO_AD_07_EMVSIM2_CLK 0x128 0x36C 0 0x2 0
832#define IMXRT_PAD_GPIO_AD_07_GPT3_CAPTURE2 0x128 0x36C 0x594 0x3 1
833#define IMXRT_PAD_GPIO_AD_07_VIDEO_MUX_CSI_DATA14 0x128 0x36C 0 0x4 0
834#define IMXRT_PAD_GPIO_AD_07_GPIO_MUX3_IO06 0x128 0x36C 0 0x5 0
835#define IMXRT_PAD_GPIO_AD_07_ENET_1588_EVENT1_OUT 0x128 0x36C 0 0x6 0
836#define IMXRT_PAD_GPIO_AD_07_FLEXIO2_D07 0x128 0x36C 0 0x8 0
837#define IMXRT_PAD_GPIO_AD_07_TMR4_TIMER3 0x128 0x36C 0 0x9 0
838#define IMXRT_PAD_GPIO_AD_07_GPIO9_IO06 0x128 0x36C 0 0xA 0
839#define IMXRT_PAD_GPIO_AD_07_FLEXPWM1_PWM1_X 0x128 0x36C 0 0xB 0
840
841#define IMXRT_PAD_GPIO_AD_08_USBPHY2_OTG_ID 0x12C 0x370 0x6C4 0x0 0
842#define IMXRT_PAD_GPIO_AD_08_LPI2C1_SCL 0x12C 0x370 0x5AC 0x1 0
843#define IMXRT_PAD_GPIO_AD_08_EMVSIM2_RST 0x12C 0x370 0 0x2 0
844#define IMXRT_PAD_GPIO_AD_08_GPT3_COMPARE1 0x12C 0x370 0 0x3 0
845#define IMXRT_PAD_GPIO_AD_08_VIDEO_MUX_CSI_DATA13 0x12C 0x370 0 0x4 0
846#define IMXRT_PAD_GPIO_AD_08_GPIO_MUX3_IO07 0x12C 0x370 0 0x5 0
847#define IMXRT_PAD_GPIO_AD_08_ENET_1588_EVENT2_IN 0x12C 0x370 0 0x6 0
848#define IMXRT_PAD_GPIO_AD_08_FLEXIO2_D08 0x12C 0x370 0 0x8 0
849#define IMXRT_PAD_GPIO_AD_08_GPIO9_IO07 0x12C 0x370 0 0xA 0
850#define IMXRT_PAD_GPIO_AD_08_FLEXPWM1_PWM2_X 0x12C 0x370 0 0xB 0
851
852#define IMXRT_PAD_GPIO_AD_09_USBPHY1_OTG_ID 0x130 0x374 0x6C0 0x0 0
853#define IMXRT_PAD_GPIO_AD_09_LPI2C1_SDA 0x130 0x374 0x5B0 0x1 0
854#define IMXRT_PAD_GPIO_AD_09_EMVSIM2_SVEN 0x130 0x374 0 0x2 0
855#define IMXRT_PAD_GPIO_AD_09_GPT3_COMPARE2 0x130 0x374 0 0x3 0
856#define IMXRT_PAD_GPIO_AD_09_VIDEO_MUX_CSI_DATA12 0x130 0x374 0 0x4 0
857#define IMXRT_PAD_GPIO_AD_09_GPIO_MUX3_IO08 0x130 0x374 0 0x5 0
858#define IMXRT_PAD_GPIO_AD_09_ENET_1588_EVENT2_OUT 0x130 0x374 0 0x6 0
859#define IMXRT_PAD_GPIO_AD_09_FLEXIO2_D09 0x130 0x374 0 0x8 0
860#define IMXRT_PAD_GPIO_AD_09_GPIO9_IO08 0x130 0x374 0 0xA 0
861#define IMXRT_PAD_GPIO_AD_09_FLEXPWM1_PWM3_X 0x130 0x374 0 0xB 0
862
863#define IMXRT_PAD_GPIO_AD_10_USB_OTG1_PWR 0x134 0x378 0 0x0 0
864#define IMXRT_PAD_GPIO_AD_10_LPI2C1_SCLS 0x134 0x378 0 0x1 0
865#define IMXRT_PAD_GPIO_AD_10_EMVSIM2_PD 0x134 0x378 0x6AC 0x2 0
866#define IMXRT_PAD_GPIO_AD_10_GPT3_COMPARE3 0x134 0x378 0 0x3 0
867#define IMXRT_PAD_GPIO_AD_10_VIDEO_MUX_CSI_DATA11 0x134 0x378 0 0x4 0
868#define IMXRT_PAD_GPIO_AD_10_GPIO_MUX3_IO09 0x134 0x378 0 0x5 0
869#define IMXRT_PAD_GPIO_AD_10_ENET_1588_EVENT3_IN 0x134 0x378 0 0x6 0
870#define IMXRT_PAD_GPIO_AD_10_FLEXIO2_D10 0x134 0x378 0 0x8 0
871#define IMXRT_PAD_GPIO_AD_10_GPIO9_IO09 0x134 0x378 0 0xA 0
872#define IMXRT_PAD_GPIO_AD_10_FLEXPWM2_PWM0_X 0x134 0x378 0 0xB 0
873
874#define IMXRT_PAD_GPIO_AD_11_USB_OTG1_OC 0x138 0x37C 0x6BC 0x0 0
875#define IMXRT_PAD_GPIO_AD_11_LPI2C1_SDAS 0x138 0x37C 0 0x1 0
876#define IMXRT_PAD_GPIO_AD_11_EMVSIM2_POWER_FAIL 0x138 0x37C 0x6B0 0x2 0
877#define IMXRT_PAD_GPIO_AD_11_GPT3_CLK 0x138 0x37C 0x598 0x3 1
878#define IMXRT_PAD_GPIO_AD_11_VIDEO_MUX_CSI_DATA10 0x138 0x37C 0 0x4 0
879#define IMXRT_PAD_GPIO_AD_11_GPIO_MUX3_IO10 0x138 0x37C 0 0x5 0
880#define IMXRT_PAD_GPIO_AD_11_ENET_1588_EVENT3_OUT 0x138 0x37C 0 0x6 0
881#define IMXRT_PAD_GPIO_AD_11_FLEXIO2_D11 0x138 0x37C 0 0x8 0
882#define IMXRT_PAD_GPIO_AD_11_GPIO9_IO10 0x138 0x37C 0 0xA 0
883#define IMXRT_PAD_GPIO_AD_11_FLEXPWM2_PWM1_X 0x138 0x37C 0 0xB 0
884
885#define IMXRT_PAD_GPIO_AD_12_SPDIF_LOCK 0x13C 0x380 0 0x0 0
886#define IMXRT_PAD_GPIO_AD_12_LPI2C1_HREQ 0x13C 0x380 0 0x1 0
887#define IMXRT_PAD_GPIO_AD_12_GPT1_CAPTURE1 0x13C 0x380 0 0x2 0
888#define IMXRT_PAD_GPIO_AD_12_FLEXSPI1_B_DATA03 0x13C 0x380 0x570 0x3 0
889#define IMXRT_PAD_GPIO_AD_12_VIDEO_MUX_CSI_PIXCLK 0x13C 0x380 0 0x4 0
890#define IMXRT_PAD_GPIO_AD_12_GPIO_MUX3_IO11 0x13C 0x380 0 0x5 0
891#define IMXRT_PAD_GPIO_AD_12_ENET_TX_DATA03 0x13C 0x380 0 0x6 0
892#define IMXRT_PAD_GPIO_AD_12_FLEXIO2_D12 0x13C 0x380 0 0x8 0
893#define IMXRT_PAD_GPIO_AD_12_EWM_OUT_B 0x13C 0x380 0 0x9 0
894#define IMXRT_PAD_GPIO_AD_12_GPIO9_IO11 0x13C 0x380 0 0xA 0
895#define IMXRT_PAD_GPIO_AD_12_FLEXPWM2_PWM2_X 0x13C 0x380 0 0xB 0
896
897#define IMXRT_PAD_GPIO_AD_13_SPDIF_SR_CLK 0x140 0x384 0 0x0 0
898#define IMXRT_PAD_GPIO_AD_13_PIT1_TRIGGER0 0x140 0x384 0 0x1 0
899#define IMXRT_PAD_GPIO_AD_13_GPT1_CAPTURE2 0x140 0x384 0 0x2 0
900#define IMXRT_PAD_GPIO_AD_13_FLEXSPI1_B_DATA02 0x140 0x384 0x56C 0x3 0
901#define IMXRT_PAD_GPIO_AD_13_VIDEO_MUX_CSI_MCLK 0x140 0x384 0 0x4 0
902#define IMXRT_PAD_GPIO_AD_13_GPIO_MUX3_IO12 0x140 0x384 0 0x5 0
903#define IMXRT_PAD_GPIO_AD_13_ENET_TX_DATA02 0x140 0x384 0 0x6 0
904#define IMXRT_PAD_GPIO_AD_13_FLEXIO2_D13 0x140 0x384 0 0x8 0
905#define IMXRT_PAD_GPIO_AD_13_REF_CLK_32K 0x140 0x384 0 0x9 0
906#define IMXRT_PAD_GPIO_AD_13_GPIO9_IO12 0x140 0x384 0 0xA 0
907#define IMXRT_PAD_GPIO_AD_13_FLEXPWM2_PWM3_X 0x140 0x384 0 0xB 0
908
909#define IMXRT_PAD_GPIO_AD_14_SPDIF_EXT_CLK 0x144 0x388 0 0x0 0
910#define IMXRT_PAD_GPIO_AD_14_REF_CLK_24M 0x144 0x388 0 0x1 0
911#define IMXRT_PAD_GPIO_AD_14_GPT1_COMPARE1 0x144 0x388 0 0x2 0
912#define IMXRT_PAD_GPIO_AD_14_FLEXSPI1_B_DATA01 0x144 0x388 0x568 0x3 0
913#define IMXRT_PAD_GPIO_AD_14_VIDEO_MUX_CSI_VSYNC 0x144 0x388 0 0x4 0
914#define IMXRT_PAD_GPIO_AD_14_GPIO_MUX3_IO13 0x144 0x388 0 0x5 0
915#define IMXRT_PAD_GPIO_AD_14_ENET_RX_CLK 0x144 0x388 0 0x6 0
916#define IMXRT_PAD_GPIO_AD_14_FLEXIO2_D14 0x144 0x388 0 0x8 0
917#define IMXRT_PAD_GPIO_AD_14_CCM_ENET_REF_CLK_25M 0x144 0x388 0 0x9 0
918#define IMXRT_PAD_GPIO_AD_14_GPIO9_IO13 0x144 0x388 0 0xA 0
919#define IMXRT_PAD_GPIO_AD_14_FLEXPWM3_PWM0_X 0x144 0x388 0 0xB 0
920
921#define IMXRT_PAD_GPIO_AD_15_GPIO9_IO14 0x148 0x38C 0 0xA 0
922#define IMXRT_PAD_GPIO_AD_15_FLEXPWM3_PWM1_X 0x148 0x38C 0 0xB 0
923#define IMXRT_PAD_GPIO_AD_15_SPDIF_IN 0x148 0x38C 0x6B4 0x0 1
924#define IMXRT_PAD_GPIO_AD_15_LPUART10_TXD 0x148 0x38C 0x628 0x1 0
925#define IMXRT_PAD_GPIO_AD_15_GPT1_COMPARE2 0x148 0x38C 0 0x2 0
926#define IMXRT_PAD_GPIO_AD_15_FLEXSPI1_B_DATA00 0x148 0x38C 0x564 0x3 0
927#define IMXRT_PAD_GPIO_AD_15_VIDEO_MUX_CSI_HSYNC 0x148 0x38C 0 0x4 0
928#define IMXRT_PAD_GPIO_AD_15_GPIO_MUX3_IO14 0x148 0x38C 0 0x5 0
929#define IMXRT_PAD_GPIO_AD_15_ENET_TX_ER 0x148 0x38C 0 0x6 0
930#define IMXRT_PAD_GPIO_AD_15_FLEXIO2_D15 0x148 0x38C 0 0x8 0
931
932#define IMXRT_PAD_GPIO_AD_16_SPDIF_OUT 0x14C 0x390 0 0x0 0
933#define IMXRT_PAD_GPIO_AD_16_LPUART10_RXD 0x14C 0x390 0x624 0x1 0
934#define IMXRT_PAD_GPIO_AD_16_GPT1_COMPARE3 0x14C 0x390 0 0x2 0
935#define IMXRT_PAD_GPIO_AD_16_FLEXSPI1_B_SCLK 0x14C 0x390 0x578 0x3 0
936#define IMXRT_PAD_GPIO_AD_16_VIDEO_MUX_CSI_DATA09 0x14C 0x390 0 0x4 0
937#define IMXRT_PAD_GPIO_AD_16_GPIO_MUX3_IO15 0x14C 0x390 0 0x5 0
938#define IMXRT_PAD_GPIO_AD_16_ENET_RX_DATA03 0x14C 0x390 0 0x6 0
939#define IMXRT_PAD_GPIO_AD_16_FLEXIO2_D16 0x14C 0x390 0 0x8 0
940#define IMXRT_PAD_GPIO_AD_16_ENET_1G_MDC 0x14C 0x390 0 0x9 0
941#define IMXRT_PAD_GPIO_AD_16_GPIO9_IO15 0x14C 0x390 0 0xA 0
942#define IMXRT_PAD_GPIO_AD_16_FLEXPWM3_PWM2_X 0x14C 0x390 0 0xB 0
943
944#define IMXRT_PAD_GPIO_AD_17_SAI1_MCLK 0x150 0x394 0x66C 0x0 0
945#define IMXRT_PAD_GPIO_AD_17_ACMP1_OUT 0x150 0x394 0 0x1 0
946#define IMXRT_PAD_GPIO_AD_17_GPT1_CLK 0x150 0x394 0 0x2 0
947#define IMXRT_PAD_GPIO_AD_17_FLEXSPI1_A_DQS 0x150 0x394 0x550 0x3 1
948#define IMXRT_PAD_GPIO_AD_17_VIDEO_MUX_CSI_DATA08 0x150 0x394 0 0x4 0
949#define IMXRT_PAD_GPIO_AD_17_GPIO_MUX3_IO16 0x150 0x394 0 0x5 0
950#define IMXRT_PAD_GPIO_AD_17_ENET_RX_DATA02 0x150 0x394 0 0x6 0
951#define IMXRT_PAD_GPIO_AD_17_FLEXIO2_D17 0x150 0x394 0 0x8 0
952#define IMXRT_PAD_GPIO_AD_17_ENET_1G_MDIO 0x150 0x394 0x4C8 0x9 2
953#define IMXRT_PAD_GPIO_AD_17_GPIO9_IO16 0x150 0x394 0 0xA 0
954#define IMXRT_PAD_GPIO_AD_17_FLEXPWM3_PWM3_X 0x150 0x394 0 0xB 0
955
956#define IMXRT_PAD_GPIO_AD_18_GPIO9_IO17 0x154 0x398 0 0xA 0
957#define IMXRT_PAD_GPIO_AD_18_FLEXPWM4_PWM0_X 0x154 0x398 0 0xB 0
958#define IMXRT_PAD_GPIO_AD_18_SAI1_RX_SYNC 0x154 0x398 0x678 0x0 0
959#define IMXRT_PAD_GPIO_AD_18_ACMP2_OUT 0x154 0x398 0 0x1 0
960#define IMXRT_PAD_GPIO_AD_18_LPSPI1_PCS1 0x154 0x398 0 0x2 0
961#define IMXRT_PAD_GPIO_AD_18_FLEXSPI1_A_SS0_B 0x154 0x398 0 0x3 0
962#define IMXRT_PAD_GPIO_AD_18_VIDEO_MUX_CSI_DATA07 0x154 0x398 0 0x4 0
963#define IMXRT_PAD_GPIO_AD_18_GPIO_MUX3_IO17 0x154 0x398 0 0x5 0
964#define IMXRT_PAD_GPIO_AD_18_ENET_CRS 0x154 0x398 0 0x6 0
965#define IMXRT_PAD_GPIO_AD_18_FLEXIO2_D18 0x154 0x398 0 0x8 0
966#define IMXRT_PAD_GPIO_AD_18_LPI2C2_SCL 0x154 0x398 0x5B4 0x9 1
967
968#define IMXRT_PAD_GPIO_AD_19_SAI1_RX_BCLK 0x158 0x39C 0x670 0x0 0
969#define IMXRT_PAD_GPIO_AD_19_ACMP3_OUT 0x158 0x39C 0 0x1 0
970#define IMXRT_PAD_GPIO_AD_19_LPSPI1_PCS2 0x158 0x39C 0 0x2 0
971#define IMXRT_PAD_GPIO_AD_19_FLEXSPI1_A_SCLK 0x158 0x39C 0x574 0x3 0
972#define IMXRT_PAD_GPIO_AD_19_VIDEO_MUX_CSI_DATA06 0x158 0x39C 0 0x4 0
973#define IMXRT_PAD_GPIO_AD_19_GPIO_MUX3_IO18 0x158 0x39C 0 0x5 0
974#define IMXRT_PAD_GPIO_AD_19_ENET_COL 0x158 0x39C 0 0x6 0
975#define IMXRT_PAD_GPIO_AD_19_FLEXIO2_D19 0x158 0x39C 0 0x8 0
976#define IMXRT_PAD_GPIO_AD_19_LPI2C2_SDA 0x158 0x39C 0x5B8 0x9 1
977#define IMXRT_PAD_GPIO_AD_19_GPIO9_IO18 0x158 0x39C 0 0xA 0
978#define IMXRT_PAD_GPIO_AD_19_FLEXPWM4_PWM1_X 0x158 0x39C 0 0xB 0
979
980#define IMXRT_PAD_GPIO_AD_20_SAI1_RX_DATA00 0x15C 0x3A0 0x674 0x0 0
981#define IMXRT_PAD_GPIO_AD_20_ACMP4_OUT 0x15C 0x3A0 0 0x1 0
982#define IMXRT_PAD_GPIO_AD_20_LPSPI1_PCS3 0x15C 0x3A0 0 0x2 0
983#define IMXRT_PAD_GPIO_AD_20_FLEXSPI1_A_DATA00 0x15C 0x3A0 0x554 0x3 0
984#define IMXRT_PAD_GPIO_AD_20_VIDEO_MUX_CSI_DATA05 0x15C 0x3A0 0 0x4 0
985#define IMXRT_PAD_GPIO_AD_20_GPIO_MUX3_IO19 0x15C 0x3A0 0 0x5 0
986#define IMXRT_PAD_GPIO_AD_20_KPP_ROW07 0x15C 0x3A0 0x5A8 0x6 0
987#define IMXRT_PAD_GPIO_AD_20_FLEXIO2_D20 0x15C 0x3A0 0 0x8 0
988#define IMXRT_PAD_GPIO_AD_20_ENET_QOS_1588_EVENT2_OUT 0x15C 0x3A0 0 0x9 0
989#define IMXRT_PAD_GPIO_AD_20_GPIO9_IO19 0x15C 0x3A0 0 0xA 0
990#define IMXRT_PAD_GPIO_AD_20_FLEXPWM4_PWM2_X 0x15C 0x3A0 0 0xB 0
991
992#define IMXRT_PAD_GPIO_AD_21_SAI1_TX_DATA00 0x160 0x3A4 0 0x0 0
993#define IMXRT_PAD_GPIO_AD_21_LPSPI2_PCS1 0x160 0x3A4 0x5E0 0x2 0
994#define IMXRT_PAD_GPIO_AD_21_FLEXSPI1_A_DATA01 0x160 0x3A4 0x558 0x3 0
995#define IMXRT_PAD_GPIO_AD_21_VIDEO_MUX_CSI_DATA04 0x160 0x3A4 0 0x4 0
996#define IMXRT_PAD_GPIO_AD_21_GPIO_MUX3_IO20 0x160 0x3A4 0 0x5 0
997#define IMXRT_PAD_GPIO_AD_21_KPP_COL07 0x160 0x3A4 0x5A0 0x6 0
998#define IMXRT_PAD_GPIO_AD_21_FLEXIO2_D21 0x160 0x3A4 0 0x8 0
999#define IMXRT_PAD_GPIO_AD_21_ENET_QOS_1588_EVENT2_IN 0x160 0x3A4 0 0x9 0
1000#define IMXRT_PAD_GPIO_AD_21_GPIO9_IO20 0x160 0x3A4 0 0xA 0
1001#define IMXRT_PAD_GPIO_AD_21_FLEXPWM4_PWM3_X 0x160 0x3A4 0 0xB 0
1002
1003#define IMXRT_PAD_GPIO_AD_22_GPIO9_IO21 0x164 0x3A8 0 0xA 0
1004#define IMXRT_PAD_GPIO_AD_22_SAI1_TX_BCLK 0x164 0x3A8 0x67C 0x0 0
1005#define IMXRT_PAD_GPIO_AD_22_LPSPI2_PCS2 0x164 0x3A8 0 0x2 0
1006#define IMXRT_PAD_GPIO_AD_22_FLEXSPI1_A_DATA02 0x164 0x3A8 0x55C 0x3 0
1007#define IMXRT_PAD_GPIO_AD_22_VIDEO_MUX_CSI_DATA03 0x164 0x3A8 0 0x4 0
1008#define IMXRT_PAD_GPIO_AD_22_GPIO_MUX3_IO21 0x164 0x3A8 0 0x5 0
1009#define IMXRT_PAD_GPIO_AD_22_KPP_ROW06 0x164 0x3A8 0x5A4 0x6 0
1010#define IMXRT_PAD_GPIO_AD_22_FLEXIO2_D22 0x164 0x3A8 0 0x8 0
1011#define IMXRT_PAD_GPIO_AD_22_ENET_QOS_1588_EVENT3_OUT 0x164 0x3A8 0 0x9 0
1012
1013#define IMXRT_PAD_GPIO_AD_23_SAI1_TX_SYNC 0x168 0x3AC 0x680 0x0 0
1014#define IMXRT_PAD_GPIO_AD_23_LPSPI2_PCS3 0x168 0x3AC 0 0x2 0
1015#define IMXRT_PAD_GPIO_AD_23_FLEXSPI1_A_DATA03 0x168 0x3AC 0x560 0x3 0
1016#define IMXRT_PAD_GPIO_AD_23_VIDEO_MUX_CSI_DATA02 0x168 0x3AC 0 0x4 0
1017#define IMXRT_PAD_GPIO_AD_23_GPIO_MUX3_IO22 0x168 0x3AC 0 0x5 0
1018#define IMXRT_PAD_GPIO_AD_23_KPP_COL06 0x168 0x3AC 0x59C 0x6 0
1019#define IMXRT_PAD_GPIO_AD_23_FLEXIO2_D23 0x168 0x3AC 0 0x8 0
1020#define IMXRT_PAD_GPIO_AD_23_ENET_QOS_1588_EVENT3_IN 0x168 0x3AC 0 0x9 0
1021#define IMXRT_PAD_GPIO_AD_23_GPIO9_IO22 0x168 0x3AC 0 0xA 0
1022
1023#define IMXRT_PAD_GPIO_AD_24_LPUART1_TXD 0x16C 0x3B0 0x620 0x0 0
1024#define IMXRT_PAD_GPIO_AD_24_LPSPI2_SCK 0x16C 0x3B0 0x5E4 0x1 0
1025#define IMXRT_PAD_GPIO_AD_24_VIDEO_MUX_CSI_DATA00 0x16C 0x3B0 0 0x2 0
1026#define IMXRT_PAD_GPIO_AD_24_ENET_RX_EN 0x16C 0x3B0 0x4B8 0x3 0
1027#define IMXRT_PAD_GPIO_AD_24_FLEXPWM2_PWM0_A 0x16C 0x3B0 0x518 0x4 1
1028#define IMXRT_PAD_GPIO_AD_24_GPIO_MUX3_IO23 0x16C 0x3B0 0 0x5 0
1029#define IMXRT_PAD_GPIO_AD_24_KPP_ROW05 0x16C 0x3B0 0 0x6 0
1030#define IMXRT_PAD_GPIO_AD_24_FLEXIO2_D24 0x16C 0x3B0 0 0x8 0
1031#define IMXRT_PAD_GPIO_AD_24_LPI2C4_SCL 0x16C 0x3B0 0x5C4 0x9 0
1032#define IMXRT_PAD_GPIO_AD_24_GPIO9_IO23 0x16C 0x3B0 0 0xA 0
1033
1034#define IMXRT_PAD_GPIO_AD_25_GPIO9_IO24 0x170 0x3B4 0 0xA 0
1035#define IMXRT_PAD_GPIO_AD_25_LPUART1_RXD 0x170 0x3B4 0x61C 0x0 0
1036#define IMXRT_PAD_GPIO_AD_25_LPSPI2_PCS0 0x170 0x3B4 0x5DC 0x1 0
1037#define IMXRT_PAD_GPIO_AD_25_VIDEO_MUX_CSI_DATA01 0x170 0x3B4 0 0x2 0
1038#define IMXRT_PAD_GPIO_AD_25_ENET_RX_ER 0x170 0x3B4 0x4BC 0x3 0
1039#define IMXRT_PAD_GPIO_AD_25_FLEXPWM2_PWM0_B 0x170 0x3B4 0x524 0x4 1
1040#define IMXRT_PAD_GPIO_AD_25_GPIO_MUX3_IO24 0x170 0x3B4 0 0x5 0
1041#define IMXRT_PAD_GPIO_AD_25_KPP_COL05 0x170 0x3B4 0 0x6 0
1042#define IMXRT_PAD_GPIO_AD_25_FLEXIO2_D25 0x170 0x3B4 0 0x8 0
1043#define IMXRT_PAD_GPIO_AD_25_LPI2C4_SDA 0x170 0x3B4 0x5C8 0x9 0
1044
1045#define IMXRT_PAD_GPIO_AD_26_LPUART1_CTS_B 0x174 0x3B8 0 0x0 0
1046#define IMXRT_PAD_GPIO_AD_26_LPSPI2_SOUT 0x174 0x3B8 0x5EC 0x1 0
1047#define IMXRT_PAD_GPIO_AD_26_SEMC_CSX01 0x174 0x3B8 0 0x2 0
1048#define IMXRT_PAD_GPIO_AD_26_ENET_RX_DATA00 0x174 0x3B8 0x4B0 0x3 0
1049#define IMXRT_PAD_GPIO_AD_26_FLEXPWM2_PWM1_A 0x174 0x3B8 0x51C 0x4 1
1050#define IMXRT_PAD_GPIO_AD_26_GPIO_MUX3_IO25 0x174 0x3B8 0 0x5 0
1051#define IMXRT_PAD_GPIO_AD_26_KPP_ROW04 0x174 0x3B8 0 0x6 0
1052#define IMXRT_PAD_GPIO_AD_26_FLEXIO2_D26 0x174 0x3B8 0 0x8 0
1053#define IMXRT_PAD_GPIO_AD_26_ENET_QOS_MDC 0x174 0x3B8 0 0x9 0
1054#define IMXRT_PAD_GPIO_AD_26_GPIO9_IO25 0x174 0x3B8 0 0xA 0
1055#define IMXRT_PAD_GPIO_AD_26_USDHC2_CD_B 0x174 0x3B8 0x6D0 0xB 1
1056
1057#define IMXRT_PAD_GPIO_AD_27_LPUART1_RTS_B 0x178 0x3BC 0 0x0 0
1058#define IMXRT_PAD_GPIO_AD_27_LPSPI2_SIN 0x178 0x3BC 0x5E8 0x1 0
1059#define IMXRT_PAD_GPIO_AD_27_SEMC_CSX02 0x178 0x3BC 0 0x2 0
1060#define IMXRT_PAD_GPIO_AD_27_ENET_RX_DATA01 0x178 0x3BC 0x4B4 0x3 0
1061#define IMXRT_PAD_GPIO_AD_27_FLEXPWM2_PWM1_B 0x178 0x3BC 0x528 0x4 1
1062#define IMXRT_PAD_GPIO_AD_27_GPIO_MUX3_IO26 0x178 0x3BC 0 0x5 0
1063#define IMXRT_PAD_GPIO_AD_27_KPP_COL04 0x178 0x3BC 0 0x6 0
1064#define IMXRT_PAD_GPIO_AD_27_FLEXIO2_D27 0x178 0x3BC 0 0x8 0
1065#define IMXRT_PAD_GPIO_AD_27_ENET_QOS_MDIO 0x178 0x3BC 0x4EC 0x9 1
1066#define IMXRT_PAD_GPIO_AD_27_GPIO9_IO26 0x178 0x3BC 0 0xA 0
1067#define IMXRT_PAD_GPIO_AD_27_USDHC2_WP 0x178 0x3BC 0x6D4 0xB 1
1068
1069#define IMXRT_PAD_GPIO_AD_28_GPIO9_IO27 0x17C 0x3C0 0 0xA 0
1070#define IMXRT_PAD_GPIO_AD_28_USDHC2_VSELECT 0x17C 0x3C0 0 0xB 0
1071#define IMXRT_PAD_GPIO_AD_28_LPSPI1_SCK 0x17C 0x3C0 0x5D0 0x0 1
1072#define IMXRT_PAD_GPIO_AD_28_LPUART5_TXD 0x17C 0x3C0 0 0x1 0
1073#define IMXRT_PAD_GPIO_AD_28_SEMC_CSX03 0x17C 0x3C0 0 0x2 0
1074#define IMXRT_PAD_GPIO_AD_28_ENET_TX_EN 0x17C 0x3C0 0 0x3 0
1075#define IMXRT_PAD_GPIO_AD_28_FLEXPWM2_PWM2_A 0x17C 0x3C0 0x520 0x4 1
1076#define IMXRT_PAD_GPIO_AD_28_GPIO_MUX3_IO27 0x17C 0x3C0 0 0x5 0
1077#define IMXRT_PAD_GPIO_AD_28_KPP_ROW03 0x17C 0x3C0 0 0x6 0
1078#define IMXRT_PAD_GPIO_AD_28_FLEXIO2_D28 0x17C 0x3C0 0 0x8 0
1079#define IMXRT_PAD_GPIO_AD_28_VIDEO_MUX_EXT_DCIC1 0x17C 0x3C0 0 0x9 0
1080
1081#define IMXRT_PAD_GPIO_AD_29_LPSPI1_PCS0 0x180 0x3C4 0x5CC 0x0 1
1082#define IMXRT_PAD_GPIO_AD_29_LPUART5_RXD 0x180 0x3C4 0 0x1 0
1083#define IMXRT_PAD_GPIO_AD_29_ENET_REF_CLK 0x180 0x3C4 0x4A8 0x2 0
1084#define IMXRT_PAD_GPIO_AD_29_ENET_TX_CLK 0x180 0x3C4 0x4C0 0x3 0
1085#define IMXRT_PAD_GPIO_AD_29_FLEXPWM2_PWM2_B 0x180 0x3C4 0x52C 0x4 1
1086#define IMXRT_PAD_GPIO_AD_29_GPIO_MUX3_IO28 0x180 0x3C4 0 0x5 0
1087#define IMXRT_PAD_GPIO_AD_29_KPP_COL03 0x180 0x3C4 0 0x6 0
1088#define IMXRT_PAD_GPIO_AD_29_FLEXIO2_D29 0x180 0x3C4 0 0x8 0
1089#define IMXRT_PAD_GPIO_AD_29_VIDEO_MUX_EXT_DCIC2 0x180 0x3C4 0 0x9 0
1090#define IMXRT_PAD_GPIO_AD_29_GPIO9_IO28 0x180 0x3C4 0 0xA 0
1091#define IMXRT_PAD_GPIO_AD_29_USDHC2_RESET_B 0x180 0x3C4 0 0xB 0
1092
1093#define IMXRT_PAD_GPIO_AD_30_LPSPI1_SOUT 0x184 0x3C8 0x5D8 0x0 1
1094#define IMXRT_PAD_GPIO_AD_30_USB_OTG2_OC 0x184 0x3C8 0x6B8 0x1 1
1095#define IMXRT_PAD_GPIO_AD_30_FLEXCAN2_TX 0x184 0x3C8 0 0x2 0
1096#define IMXRT_PAD_GPIO_AD_30_ENET_TX_DATA00 0x184 0x3C8 0 0x3 0
1097#define IMXRT_PAD_GPIO_AD_30_LPUART3_TXD 0x184 0x3C8 0 0x4 0
1098#define IMXRT_PAD_GPIO_AD_30_GPIO_MUX3_IO29 0x184 0x3C8 0 0x5 0
1099#define IMXRT_PAD_GPIO_AD_30_KPP_ROW02 0x184 0x3C8 0 0x6 0
1100#define IMXRT_PAD_GPIO_AD_30_FLEXIO2_D30 0x184 0x3C8 0 0x8 0
1101#define IMXRT_PAD_GPIO_AD_30_WDOG2_RESET_B_DEB 0x184 0x3C8 0 0x9 0
1102#define IMXRT_PAD_GPIO_AD_30_GPIO9_IO29 0x184 0x3C8 0 0xA 0
1103
1104#define IMXRT_PAD_GPIO_AD_31_LPSPI1_SIN 0x188 0x3CC 0x5D4 0x0 1
1105#define IMXRT_PAD_GPIO_AD_31_USB_OTG2_PWR 0x188 0x3CC 0 0x1 0
1106#define IMXRT_PAD_GPIO_AD_31_FLEXCAN2_RX 0x188 0x3CC 0x49C 0x2 1
1107#define IMXRT_PAD_GPIO_AD_31_ENET_TX_DATA01 0x188 0x3CC 0 0x3 0
1108#define IMXRT_PAD_GPIO_AD_31_LPUART3_RXD 0x188 0x3CC 0 0x4 0
1109#define IMXRT_PAD_GPIO_AD_31_GPIO_MUX3_IO30 0x188 0x3CC 0 0x5 0
1110#define IMXRT_PAD_GPIO_AD_31_KPP_COL02 0x188 0x3CC 0 0x6 0
1111#define IMXRT_PAD_GPIO_AD_31_FLEXIO2_D31 0x188 0x3CC 0 0x8 0
1112#define IMXRT_PAD_GPIO_AD_31_WDOG1_RESET_B_DEB 0x188 0x3CC 0 0x9 0
1113#define IMXRT_PAD_GPIO_AD_31_GPIO9_IO30 0x188 0x3CC 0 0xA 0
1114
1115#define IMXRT_PAD_GPIO_AD_32_GPIO9_IO31 0x18C 0x3D0 0 0xA 0
1116#define IMXRT_PAD_GPIO_AD_32_LPI2C1_SCL 0x18C 0x3D0 0x5AC 0x0 1
1117#define IMXRT_PAD_GPIO_AD_32_USBPHY2_OTG_ID 0x18C 0x3D0 0x6C4 0x1 1
1118#define IMXRT_PAD_GPIO_AD_32_PGMC_PMIC_RDY 0x18C 0x3D0 0 0x2 0
1119#define IMXRT_PAD_GPIO_AD_32_ENET_MDC 0x18C 0x3D0 0 0x3 0
1120#define IMXRT_PAD_GPIO_AD_32_USDHC1_CD_B 0x18C 0x3D0 0x6C8 0x4 0
1121#define IMXRT_PAD_GPIO_AD_32_GPIO_MUX3_IO31 0x18C 0x3D0 0 0x5 0
1122#define IMXRT_PAD_GPIO_AD_32_KPP_ROW01 0x18C 0x3D0 0 0x6 0
1123#define IMXRT_PAD_GPIO_AD_32_LPUART10_TXD 0x18C 0x3D0 0x628 0x8 1
1124#define IMXRT_PAD_GPIO_AD_32_ENET_1G_MDC 0x18C 0x3D0 0 0x9 0
1125
1126#define IMXRT_PAD_GPIO_AD_33_LPI2C1_SDA 0x190 0x3D4 0x5B0 0x0 1
1127#define IMXRT_PAD_GPIO_AD_33_USBPHY1_OTG_ID 0x190 0x3D4 0x6C0 0x1 1
1128#define IMXRT_PAD_GPIO_AD_33_XBAR1_INOUT17 0x190 0x3D4 0 0x2 0
1129#define IMXRT_PAD_GPIO_AD_33_ENET_MDIO 0x190 0x3D4 0x4AC 0x3 1
1130#define IMXRT_PAD_GPIO_AD_33_USDHC1_WP 0x190 0x3D4 0x6CC 0x4 0
1131#define IMXRT_PAD_GPIO_AD_33_GPIO_MUX4_IO00 0x190 0x3D4 0 0x5 0
1132#define IMXRT_PAD_GPIO_AD_33_KPP_COL01 0x190 0x3D4 0 0x6 0
1133#define IMXRT_PAD_GPIO_AD_33_LPUART10_RXD 0x190 0x3D4 0x624 0x8 1
1134#define IMXRT_PAD_GPIO_AD_33_ENET_1G_MDIO 0x190 0x3D4 0x4C8 0x9 3
1135#define IMXRT_PAD_GPIO_AD_33_GPIO10_IO00 0x190 0x3D4 0 0xA 0
1136
1137#define IMXRT_PAD_GPIO_AD_34_ENET_1G_1588_EVENT0_IN 0x194 0x3D8 0 0x0 0
1138#define IMXRT_PAD_GPIO_AD_34_USB_OTG1_PWR 0x194 0x3D8 0 0x1 0
1139#define IMXRT_PAD_GPIO_AD_34_XBAR1_INOUT18 0x194 0x3D8 0 0x2 0
1140#define IMXRT_PAD_GPIO_AD_34_ENET_1588_EVENT0_IN 0x194 0x3D8 0 0x3 0
1141#define IMXRT_PAD_GPIO_AD_34_USDHC1_VSELECT 0x194 0x3D8 0 0x4 0
1142#define IMXRT_PAD_GPIO_AD_34_GPIO_MUX4_IO01 0x194 0x3D8 0 0x5 0
1143#define IMXRT_PAD_GPIO_AD_34_KPP_ROW00 0x194 0x3D8 0 0x6 0
1144#define IMXRT_PAD_GPIO_AD_34_LPUART10_CTS_B 0x194 0x3D8 0 0x8 0
1145#define IMXRT_PAD_GPIO_AD_34_WDOG1_ANY 0x194 0x3D8 0 0x9 0
1146#define IMXRT_PAD_GPIO_AD_34_GPIO10_IO01 0x194 0x3D8 0 0xA 0
1147
1148#define IMXRT_PAD_GPIO_AD_35_GPIO10_IO02 0x198 0x3DC 0 0xA 0
1149#define IMXRT_PAD_GPIO_AD_35_ENET_1G_1588_EVENT0_OUT 0x198 0x3DC 0 0x0 0
1150#define IMXRT_PAD_GPIO_AD_35_USB_OTG1_OC 0x198 0x3DC 0x6BC 0x1 1
1151#define IMXRT_PAD_GPIO_AD_35_XBAR1_INOUT19 0x198 0x3DC 0 0x2 0
1152#define IMXRT_PAD_GPIO_AD_35_ENET_1588_EVENT0_OUT 0x198 0x3DC 0 0x3 0
1153#define IMXRT_PAD_GPIO_AD_35_USDHC1_RESET_B 0x198 0x3DC 0 0x4 0
1154#define IMXRT_PAD_GPIO_AD_35_GPIO_MUX4_IO02 0x198 0x3DC 0 0x5 0
1155#define IMXRT_PAD_GPIO_AD_35_KPP_COL00 0x198 0x3DC 0 0x6 0
1156#define IMXRT_PAD_GPIO_AD_35_LPUART10_RTS_B 0x198 0x3DC 0 0x8 0
1157#define IMXRT_PAD_GPIO_AD_35_FLEXSPI1_B_SS1_B 0x198 0x3DC 0 0x9 0
1158
1159#define IMXRT_PAD_GPIO_SD_B1_00_USDHC1_CMD 0x19C 0x3E0 0 0x0 0
1160#define IMXRT_PAD_GPIO_SD_B1_00_XBAR1_INOUT20 0x19C 0x3E0 0x6D8 0x2 1
1161#define IMXRT_PAD_GPIO_SD_B1_00_GPT4_CAPTURE1 0x19C 0x3E0 0 0x3 0
1162#define IMXRT_PAD_GPIO_SD_B1_00_GPIO_MUX4_IO03 0x19C 0x3E0 0 0x5 0
1163#define IMXRT_PAD_GPIO_SD_B1_00_FLEXSPI2_A_SS0_B 0x19C 0x3E0 0 0x6 0
1164#define IMXRT_PAD_GPIO_SD_B1_00_KPP_ROW07 0x19C 0x3E0 0x5A8 0x8 1
1165#define IMXRT_PAD_GPIO_SD_B1_00_GPIO10_IO03 0x19C 0x3E0 0 0xA 0
1166
1167#define IMXRT_PAD_GPIO_SD_B1_01_USDHC1_CLK 0x1A0 0x3E4 0 0x0 0
1168#define IMXRT_PAD_GPIO_SD_B1_01_XBAR1_INOUT21 0x1A0 0x3E4 0x6DC 0x2 1
1169#define IMXRT_PAD_GPIO_SD_B1_01_GPT4_CAPTURE2 0x1A0 0x3E4 0 0x3 0
1170#define IMXRT_PAD_GPIO_SD_B1_01_GPIO_MUX4_IO04 0x1A0 0x3E4 0 0x5 0
1171#define IMXRT_PAD_GPIO_SD_B1_01_FLEXSPI2_A_SCLK 0x1A0 0x3E4 0x58C 0x6 1
1172#define IMXRT_PAD_GPIO_SD_B1_01_KPP_COL07 0x1A0 0x3E4 0x5A0 0x8 1
1173#define IMXRT_PAD_GPIO_SD_B1_01_GPIO10_IO04 0x1A0 0x3E4 0 0xA 0
1174
1175#define IMXRT_PAD_GPIO_SD_B1_02_GPIO10_IO05 0x1A4 0x3E8 0 0xA 0
1176#define IMXRT_PAD_GPIO_SD_B1_02_USDHC1_DATA0 0x1A4 0x3E8 0 0x0 0
1177#define IMXRT_PAD_GPIO_SD_B1_02_XBAR1_INOUT22 0x1A4 0x3E8 0x6E0 0x2 1
1178#define IMXRT_PAD_GPIO_SD_B1_02_GPT4_COMPARE1 0x1A4 0x3E8 0 0x3 0
1179#define IMXRT_PAD_GPIO_SD_B1_02_GPIO_MUX4_IO05 0x1A4 0x3E8 0 0x5 0
1180#define IMXRT_PAD_GPIO_SD_B1_02_FLEXSPI2_A_DATA00 0x1A4 0x3E8 0x57C 0x6 1
1181#define IMXRT_PAD_GPIO_SD_B1_02_KPP_ROW06 0x1A4 0x3E8 0x5A4 0x8 1
1182#define IMXRT_PAD_GPIO_SD_B1_02_FLEXSPI1_A_SS1_B 0x1A4 0x3E8 0 0x9 0
1183
1184#define IMXRT_PAD_GPIO_SD_B1_03_USDHC1_DATA1 0x1A8 0x3EC 0 0x0 0
1185#define IMXRT_PAD_GPIO_SD_B1_03_XBAR1_INOUT23 0x1A8 0x3EC 0x6E4 0x2 1
1186#define IMXRT_PAD_GPIO_SD_B1_03_GPT4_COMPARE2 0x1A8 0x3EC 0 0x3 0
1187#define IMXRT_PAD_GPIO_SD_B1_03_GPIO_MUX4_IO06 0x1A8 0x3EC 0 0x5 0
1188#define IMXRT_PAD_GPIO_SD_B1_03_FLEXSPI2_A_DATA01 0x1A8 0x3EC 0x580 0x6 1
1189#define IMXRT_PAD_GPIO_SD_B1_03_KPP_COL06 0x1A8 0x3EC 0x59C 0x8 1
1190#define IMXRT_PAD_GPIO_SD_B1_03_FLEXSPI1_B_SS1_B 0x1A8 0x3EC 0 0x9 0
1191#define IMXRT_PAD_GPIO_SD_B1_03_GPIO10_IO06 0x1A8 0x3EC 0 0xA 0
1192
1193#define IMXRT_PAD_GPIO_SD_B1_04_USDHC1_DATA2 0x1AC 0x3F0 0 0x0 0
1194#define IMXRT_PAD_GPIO_SD_B1_04_XBAR1_INOUT24 0x1AC 0x3F0 0x6E8 0x2 1
1195#define IMXRT_PAD_GPIO_SD_B1_04_GPT4_COMPARE3 0x1AC 0x3F0 0 0x3 0
1196#define IMXRT_PAD_GPIO_SD_B1_04_GPIO_MUX4_IO07 0x1AC 0x3F0 0 0x5 0
1197#define IMXRT_PAD_GPIO_SD_B1_04_FLEXSPI2_A_DATA02 0x1AC 0x3F0 0x584 0x6 1
1198#define IMXRT_PAD_GPIO_SD_B1_04_FLEXSPI1_B_SS0_B 0x1AC 0x3F0 0 0x8 0
1199#define IMXRT_PAD_GPIO_SD_B1_04_ENET_QOS_1588_EVENT2_AUX_IN 0x1AC 0x3F0 0 0x9 0
1200#define IMXRT_PAD_GPIO_SD_B1_04_GPIO10_IO07 0x1AC 0x3F0 0 0xA 0
1201
1202#define IMXRT_PAD_GPIO_SD_B1_05_GPIO10_IO08 0x1B0 0x3F4 0 0xA 0
1203#define IMXRT_PAD_GPIO_SD_B1_05_USDHC1_DATA3 0x1B0 0x3F4 0 0x0 0
1204#define IMXRT_PAD_GPIO_SD_B1_05_XBAR1_INOUT25 0x1B0 0x3F4 0x6EC 0x2 1
1205#define IMXRT_PAD_GPIO_SD_B1_05_GPT4_CLK 0x1B0 0x3F4 0 0x3 0
1206#define IMXRT_PAD_GPIO_SD_B1_05_GPIO_MUX4_IO08 0x1B0 0x3F4 0 0x5 0
1207#define IMXRT_PAD_GPIO_SD_B1_05_FLEXSPI2_A_DATA03 0x1B0 0x3F4 0x588 0x6 1
1208#define IMXRT_PAD_GPIO_SD_B1_05_FLEXSPI1_B_DQS 0x1B0 0x3F4 0 0x8 0
1209#define IMXRT_PAD_GPIO_SD_B1_05_ENET_QOS_1588_EVENT3_AUX_IN 0x1B0 0x3F4 0 0x9 0
1210
1211#define IMXRT_PAD_GPIO_SD_B2_00_GPIO10_IO09 0x1B4 0x3F8 0 0xA 0
1212#define IMXRT_PAD_GPIO_SD_B2_00_USDHC2_DATA3 0x1B4 0x3F8 0 0x0 0
1213#define IMXRT_PAD_GPIO_SD_B2_00_FLEXSPI1_B_DATA03 0x1B4 0x3F8 0x570 0x1 1
1214#define IMXRT_PAD_GPIO_SD_B2_00_ENET_1G_RX_EN 0x1B4 0x3F8 0x4E0 0x2 1
1215#define IMXRT_PAD_GPIO_SD_B2_00_LPUART9_TXD 0x1B4 0x3F8 0 0x3 0
1216#define IMXRT_PAD_GPIO_SD_B2_00_LPSPI4_SCK 0x1B4 0x3F8 0x610 0x4 0
1217#define IMXRT_PAD_GPIO_SD_B2_00_GPIO_MUX4_IO09 0x1B4 0x3F8 0 0x5 0
1218
1219#define IMXRT_PAD_GPIO_SD_B2_01_USDHC2_DATA2 0x1B8 0x3FC 0 0x0 0
1220#define IMXRT_PAD_GPIO_SD_B2_01_FLEXSPI1_B_DATA02 0x1B8 0x3FC 0x56C 0x1 1
1221#define IMXRT_PAD_GPIO_SD_B2_01_ENET_1G_RX_CLK 0x1B8 0x3FC 0x4CC 0x2 1
1222#define IMXRT_PAD_GPIO_SD_B2_01_LPUART9_RXD 0x1B8 0x3FC 0 0x3 0
1223#define IMXRT_PAD_GPIO_SD_B2_01_LPSPI4_PCS0 0x1B8 0x3FC 0x60C 0x4 0
1224#define IMXRT_PAD_GPIO_SD_B2_01_GPIO_MUX4_IO10 0x1B8 0x3FC 0 0x5 0
1225#define IMXRT_PAD_GPIO_SD_B2_01_GPIO10_IO10 0x1B8 0x3FC 0 0xA 0
1226
1227#define IMXRT_PAD_GPIO_SD_B2_02_GPIO10_IO11 0x1BC 0x400 0 0xA 0
1228#define IMXRT_PAD_GPIO_SD_B2_02_USDHC2_DATA1 0x1BC 0x400 0 0x0 0
1229#define IMXRT_PAD_GPIO_SD_B2_02_FLEXSPI1_B_DATA01 0x1BC 0x400 0x568 0x1 1
1230#define IMXRT_PAD_GPIO_SD_B2_02_ENET_1G_RX_DATA00 0x1BC 0x400 0x4D0 0x2 1
1231#define IMXRT_PAD_GPIO_SD_B2_02_LPUART9_CTS_B 0x1BC 0x400 0 0x3 0
1232#define IMXRT_PAD_GPIO_SD_B2_02_LPSPI4_SOUT 0x1BC 0x400 0x618 0x4 0
1233#define IMXRT_PAD_GPIO_SD_B2_02_GPIO_MUX4_IO11 0x1BC 0x400 0 0x5 0
1234
1235#define IMXRT_PAD_GPIO_SD_B2_03_GPIO10_IO12 0x1C0 0x404 0 0xA 0
1236#define IMXRT_PAD_GPIO_SD_B2_03_USDHC2_DATA0 0x1C0 0x404 0 0x0 0
1237#define IMXRT_PAD_GPIO_SD_B2_03_FLEXSPI1_B_DATA00 0x1C0 0x404 0x564 0x1 1
1238#define IMXRT_PAD_GPIO_SD_B2_03_ENET_1G_RX_DATA01 0x1C0 0x404 0x4D4 0x2 1
1239#define IMXRT_PAD_GPIO_SD_B2_03_LPUART9_RTS_B 0x1C0 0x404 0 0x3 0
1240#define IMXRT_PAD_GPIO_SD_B2_03_LPSPI4_SIN 0x1C0 0x404 0x614 0x4 0
1241#define IMXRT_PAD_GPIO_SD_B2_03_GPIO_MUX4_IO12 0x1C0 0x404 0 0x5 0
1242
1243#define IMXRT_PAD_GPIO_SD_B2_04_USDHC2_CLK 0x1C4 0x408 0 0x0 0
1244#define IMXRT_PAD_GPIO_SD_B2_04_FLEXSPI1_B_SCLK 0x1C4 0x408 0x578 0x1 1
1245#define IMXRT_PAD_GPIO_SD_B2_04_ENET_1G_RX_DATA02 0x1C4 0x408 0x4D8 0x2 1
1246#define IMXRT_PAD_GPIO_SD_B2_04_FLEXSPI1_A_SS1_B 0x1C4 0x408 0 0x3 0
1247#define IMXRT_PAD_GPIO_SD_B2_04_LPSPI4_PCS1 0x1C4 0x408 0 0x4 0
1248#define IMXRT_PAD_GPIO_SD_B2_04_GPIO_MUX4_IO13 0x1C4 0x408 0 0x5 0
1249#define IMXRT_PAD_GPIO_SD_B2_04_GPIO10_IO13 0x1C4 0x408 0 0xA 0
1250
1251#define IMXRT_PAD_GPIO_SD_B2_05_GPIO10_IO14 0x1C8 0x40C 0 0xA 0
1252#define IMXRT_PAD_GPIO_SD_B2_05_USDHC2_CMD 0x1C8 0x40C 0 0x0 0
1253#define IMXRT_PAD_GPIO_SD_B2_05_FLEXSPI1_A_DQS 0x1C8 0x40C 0x550 0x1 2
1254#define IMXRT_PAD_GPIO_SD_B2_05_ENET_1G_RX_DATA03 0x1C8 0x40C 0x4DC 0x2 1
1255#define IMXRT_PAD_GPIO_SD_B2_05_FLEXSPI1_B_SS0_B 0x1C8 0x40C 0 0x3 0
1256#define IMXRT_PAD_GPIO_SD_B2_05_LPSPI4_PCS2 0x1C8 0x40C 0 0x4 0
1257#define IMXRT_PAD_GPIO_SD_B2_05_GPIO_MUX4_IO14 0x1C8 0x40C 0 0x5 0
1258
1259#define IMXRT_PAD_GPIO_SD_B2_06_GPIO10_IO15 0x1CC 0x410 0 0xA 0
1260#define IMXRT_PAD_GPIO_SD_B2_06_USDHC2_RESET_B 0x1CC 0x410 0 0x0 0
1261#define IMXRT_PAD_GPIO_SD_B2_06_FLEXSPI1_A_SS0_B 0x1CC 0x410 0 0x1 0
1262#define IMXRT_PAD_GPIO_SD_B2_06_ENET_1G_TX_DATA03 0x1CC 0x410 0 0x2 0
1263#define IMXRT_PAD_GPIO_SD_B2_06_LPSPI4_PCS3 0x1CC 0x410 0 0x3 0
1264#define IMXRT_PAD_GPIO_SD_B2_06_GPT6_CAPTURE1 0x1CC 0x410 0 0x4 0
1265#define IMXRT_PAD_GPIO_SD_B2_06_GPIO_MUX4_IO15 0x1CC 0x410 0 0x5 0
1266
1267#define IMXRT_PAD_GPIO_SD_B2_07_USDHC2_STROBE 0x1D0 0x414 0 0x0 0
1268#define IMXRT_PAD_GPIO_SD_B2_07_FLEXSPI1_A_SCLK 0x1D0 0x414 0x574 0x1 1
1269#define IMXRT_PAD_GPIO_SD_B2_07_ENET_1G_TX_DATA02 0x1D0 0x414 0 0x2 0
1270#define IMXRT_PAD_GPIO_SD_B2_07_LPUART3_CTS_B 0x1D0 0x414 0 0x3 0
1271#define IMXRT_PAD_GPIO_SD_B2_07_GPT6_CAPTURE2 0x1D0 0x414 0 0x4 0
1272#define IMXRT_PAD_GPIO_SD_B2_07_GPIO_MUX4_IO16 0x1D0 0x414 0 0x5 0
1273#define IMXRT_PAD_GPIO_SD_B2_07_LPSPI2_SCK 0x1D0 0x414 0x5E4 0x6 1
1274#define IMXRT_PAD_GPIO_SD_B2_07_ENET_TX_ER 0x1D0 0x414 0 0x8 0
1275#define IMXRT_PAD_GPIO_SD_B2_07_ENET_QOS_REF_CLK 0x1D0 0x414 0x4A0 0x9 1
1276#define IMXRT_PAD_GPIO_SD_B2_07_GPIO10_IO16 0x1D0 0x414 0 0xA 0
1277
1278#define IMXRT_PAD_GPIO_SD_B2_08_GPIO10_IO17 0x1D4 0x418 0 0xA 0
1279#define IMXRT_PAD_GPIO_SD_B2_08_USDHC2_DATA4 0x1D4 0x418 0 0x0 0
1280#define IMXRT_PAD_GPIO_SD_B2_08_FLEXSPI1_A_DATA00 0x1D4 0x418 0x554 0x1 1
1281#define IMXRT_PAD_GPIO_SD_B2_08_ENET_1G_TX_DATA01 0x1D4 0x418 0 0x2 0
1282#define IMXRT_PAD_GPIO_SD_B2_08_LPUART3_RTS_B 0x1D4 0x418 0 0x3 0
1283#define IMXRT_PAD_GPIO_SD_B2_08_GPT6_COMPARE1 0x1D4 0x418 0 0x4 0
1284#define IMXRT_PAD_GPIO_SD_B2_08_GPIO_MUX4_IO17 0x1D4 0x418 0 0x5 0
1285#define IMXRT_PAD_GPIO_SD_B2_08_LPSPI2_PCS0 0x1D4 0x418 0x5DC 0x6 1
1286
1287#define IMXRT_PAD_GPIO_SD_B2_09_GPIO10_IO18 0x1D8 0x41C 0 0xA 0
1288#define IMXRT_PAD_GPIO_SD_B2_09_USDHC2_DATA5 0x1D8 0x41C 0 0x0 0
1289#define IMXRT_PAD_GPIO_SD_B2_09_FLEXSPI1_A_DATA01 0x1D8 0x41C 0x558 0x1 1
1290#define IMXRT_PAD_GPIO_SD_B2_09_ENET_1G_TX_DATA00 0x1D8 0x41C 0 0x2 0
1291#define IMXRT_PAD_GPIO_SD_B2_09_LPUART5_CTS_B 0x1D8 0x41C 0 0x3 0
1292#define IMXRT_PAD_GPIO_SD_B2_09_GPT6_COMPARE2 0x1D8 0x41C 0 0x4 0
1293#define IMXRT_PAD_GPIO_SD_B2_09_GPIO_MUX4_IO18 0x1D8 0x41C 0 0x5 0
1294#define IMXRT_PAD_GPIO_SD_B2_09_LPSPI2_SOUT 0x1D8 0x41C 0x5EC 0x6 1
1295
1296#define IMXRT_PAD_GPIO_SD_B2_10_GPIO10_IO19 0x1DC 0x420 0 0xA 0
1297#define IMXRT_PAD_GPIO_SD_B2_10_USDHC2_DATA6 0x1DC 0x420 0 0x0 0
1298#define IMXRT_PAD_GPIO_SD_B2_10_FLEXSPI1_A_DATA02 0x1DC 0x420 0x55C 0x1 1
1299#define IMXRT_PAD_GPIO_SD_B2_10_ENET_1G_TX_EN 0x1DC 0x420 0 0x2 0
1300#define IMXRT_PAD_GPIO_SD_B2_10_LPUART5_RTS_B 0x1DC 0x420 0 0x3 0
1301#define IMXRT_PAD_GPIO_SD_B2_10_GPT6_COMPARE3 0x1DC 0x420 0 0x4 0
1302#define IMXRT_PAD_GPIO_SD_B2_10_GPIO_MUX4_IO19 0x1DC 0x420 0 0x5 0
1303#define IMXRT_PAD_GPIO_SD_B2_10_LPSPI2_SIN 0x1DC 0x420 0x5E8 0x6 1
1304
1305#define IMXRT_PAD_GPIO_SD_B2_11_USDHC2_DATA7 0x1E0 0x424 0 0x0 0
1306#define IMXRT_PAD_GPIO_SD_B2_11_FLEXSPI1_A_DATA03 0x1E0 0x424 0x560 0x1 1
1307#define IMXRT_PAD_GPIO_SD_B2_11_ENET_1G_TX_CLK_IO 0x1E0 0x424 0x4E8 0x2 1
1308#define IMXRT_PAD_GPIO_SD_B2_11_ENET_1G_REF_CLK 0x1E0 0x424 0x4C4 0x3 1
1309#define IMXRT_PAD_GPIO_SD_B2_11_GPT6_CLK 0x1E0 0x424 0 0x4 0
1310#define IMXRT_PAD_GPIO_SD_B2_11_GPIO_MUX4_IO20 0x1E0 0x424 0 0x5 0
1311#define IMXRT_PAD_GPIO_SD_B2_11_LPSPI2_PCS1 0x1E0 0x424 0x5E0 0x6 1
1312#define IMXRT_PAD_GPIO_SD_B2_11_GPIO10_IO20 0x1E0 0x424 0 0xA 0
1313
1314#define IMXRT_PAD_GPIO_DISP_B1_00_VIDEO_MUX_LCDIF_CLK 0x1E4 0x428 0 0x0 0
1315#define IMXRT_PAD_GPIO_DISP_B1_00_ENET_1G_RX_EN 0x1E4 0x428 0x4E0 0x1 2
1316#define IMXRT_PAD_GPIO_DISP_B1_00_TMR1_TIMER0 0x1E4 0x428 0x63C 0x3 2
1317#define IMXRT_PAD_GPIO_DISP_B1_00_XBAR1_INOUT26 0x1E4 0x428 0x6F0 0x4 1
1318#define IMXRT_PAD_GPIO_DISP_B1_00_GPIO_MUX4_IO21 0x1E4 0x428 0 0x5 0
1319#define IMXRT_PAD_GPIO_DISP_B1_00_ENET_QOS_RX_EN 0x1E4 0x428 0x4F8 0x8 0
1320#define IMXRT_PAD_GPIO_DISP_B1_00_GPIO10_IO21 0x1E4 0x428 0 0xA 0
1321
1322#define IMXRT_PAD_GPIO_DISP_B1_01_VIDEO_MUX_LCDIF_ENABLE 0x1E8 0x42C 0 0x0 0
1323#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_1G_RX_CLK 0x1E8 0x42C 0x4CC 0x1 2
1324#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_1G_RX_ER 0x1E8 0x42C 0x4E4 0x2 1
1325#define IMXRT_PAD_GPIO_DISP_B1_01_TMR1_TIMER1 0x1E8 0x42C 0x640 0x3 2
1326#define IMXRT_PAD_GPIO_DISP_B1_01_XBAR1_INOUT27 0x1E8 0x42C 0x6F4 0x4 1
1327#define IMXRT_PAD_GPIO_DISP_B1_01_GPIO_MUX4_IO22 0x1E8 0x42C 0 0x5 0
1328#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_QOS_RX_CLK 0x1E8 0x42C 0 0x8 0
1329#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_QOS_RX_ER 0x1E8 0x42C 0x4FC 0x9 0
1330#define IMXRT_PAD_GPIO_DISP_B1_01_GPIO10_IO22 0x1E8 0x42C 0 0xA 0
1331
1332#define IMXRT_PAD_GPIO_DISP_B1_02_GPIO10_IO23 0x1EC 0x430 0 0xA 0
1333#define IMXRT_PAD_GPIO_DISP_B1_02_VIDEO_MUX_LCDIF_HSYNC 0x1EC 0x430 0 0x0 0
1334#define IMXRT_PAD_GPIO_DISP_B1_02_ENET_1G_RX_DATA00 0x1EC 0x430 0x4D0 0x1 2
1335#define IMXRT_PAD_GPIO_DISP_B1_02_LPI2C3_SCL 0x1EC 0x430 0x5BC 0x2 0
1336#define IMXRT_PAD_GPIO_DISP_B1_02_TMR1_TIMER2 0x1EC 0x430 0x644 0x3 1
1337#define IMXRT_PAD_GPIO_DISP_B1_02_XBAR1_INOUT28 0x1EC 0x430 0x6F8 0x4 1
1338#define IMXRT_PAD_GPIO_DISP_B1_02_GPIO_MUX4_IO23 0x1EC 0x430 0 0x5 0
1339#define IMXRT_PAD_GPIO_DISP_B1_02_ENET_QOS_RX_DATA00 0x1EC 0x430 0x4F0 0x8 0
1340#define IMXRT_PAD_GPIO_DISP_B1_02_LPUART1_TXD 0x1EC 0x430 0x620 0x9 1
1341
1342#define IMXRT_PAD_GPIO_DISP_B1_03_VIDEO_MUX_LCDIF_VSYNC 0x1F0 0x434 0 0x0 0
1343#define IMXRT_PAD_GPIO_DISP_B1_03_ENET_1G_RX_DATA01 0x1F0 0x434 0x4D4 0x1 2
1344#define IMXRT_PAD_GPIO_DISP_B1_03_LPI2C3_SDA 0x1F0 0x434 0x5C0 0x2 0
1345#define IMXRT_PAD_GPIO_DISP_B1_03_TMR2_TIMER0 0x1F0 0x434 0x648 0x3 2
1346#define IMXRT_PAD_GPIO_DISP_B1_03_XBAR1_INOUT29 0x1F0 0x434 0x6FC 0x4 1
1347#define IMXRT_PAD_GPIO_DISP_B1_03_GPIO_MUX4_IO24 0x1F0 0x434 0 0x5 0
1348#define IMXRT_PAD_GPIO_DISP_B1_03_ENET_QOS_RX_DATA01 0x1F0 0x434 0x4F4 0x8 0
1349#define IMXRT_PAD_GPIO_DISP_B1_03_LPUART1_RXD 0x1F0 0x434 0x61C 0x9 1
1350#define IMXRT_PAD_GPIO_DISP_B1_03_GPIO10_IO24 0x1F0 0x434 0 0xA 0
1351
1352#define IMXRT_PAD_GPIO_DISP_B1_04_VIDEO_MUX_LCDIF_DATA00 0x1F4 0x438 0 0x0 0
1353#define IMXRT_PAD_GPIO_DISP_B1_04_ENET_1G_RX_DATA02 0x1F4 0x438 0x4D8 0x1 2
1354#define IMXRT_PAD_GPIO_DISP_B1_04_LPUART4_RXD 0x1F4 0x438 0 0x2 0
1355#define IMXRT_PAD_GPIO_DISP_B1_04_TMR2_TIMER1 0x1F4 0x438 0x64C 0x3 2
1356#define IMXRT_PAD_GPIO_DISP_B1_04_XBAR1_INOUT30 0x1F4 0x438 0x700 0x4 1
1357#define IMXRT_PAD_GPIO_DISP_B1_04_GPIO_MUX4_IO25 0x1F4 0x438 0 0x5 0
1358#define IMXRT_PAD_GPIO_DISP_B1_04_ENET_QOS_RX_DATA02 0x1F4 0x438 0 0x8 0
1359#define IMXRT_PAD_GPIO_DISP_B1_04_LPSPI3_SCK 0x1F4 0x438 0x600 0x9 1
1360#define IMXRT_PAD_GPIO_DISP_B1_04_GPIO10_IO25 0x1F4 0x438 0 0xA 0
1361
1362#define IMXRT_PAD_GPIO_DISP_B1_05_GPIO10_IO26 0x1F8 0x43C 0 0xA 0
1363#define IMXRT_PAD_GPIO_DISP_B1_05_VIDEO_MUX_LCDIF_DATA01 0x1F8 0x43C 0 0x0 0
1364#define IMXRT_PAD_GPIO_DISP_B1_05_ENET_1G_RX_DATA03 0x1F8 0x43C 0x4DC 0x1 2
1365#define IMXRT_PAD_GPIO_DISP_B1_05_LPUART4_CTS_B 0x1F8 0x43C 0 0x2 0
1366#define IMXRT_PAD_GPIO_DISP_B1_05_TMR2_TIMER2 0x1F8 0x43C 0x650 0x3 1
1367#define IMXRT_PAD_GPIO_DISP_B1_05_XBAR1_INOUT31 0x1F8 0x43C 0x704 0x4 1
1368#define IMXRT_PAD_GPIO_DISP_B1_05_GPIO_MUX4_IO26 0x1F8 0x43C 0 0x5 0
1369#define IMXRT_PAD_GPIO_DISP_B1_05_ENET_QOS_RX_DATA03 0x1F8 0x43C 0 0x8 0
1370#define IMXRT_PAD_GPIO_DISP_B1_05_LPSPI3_SIN 0x1F8 0x43C 0x604 0x9 1
1371
1372#define IMXRT_PAD_GPIO_DISP_B1_06_VIDEO_MUX_LCDIF_DATA02 0x1FC 0x440 0 0x0 0
1373#define IMXRT_PAD_GPIO_DISP_B1_06_ENET_1G_TX_DATA03 0x1FC 0x440 0 0x1 0
1374#define IMXRT_PAD_GPIO_DISP_B1_06_LPUART4_TXD 0x1FC 0x440 0 0x2 0
1375#define IMXRT_PAD_GPIO_DISP_B1_06_TMR3_TIMER0 0x1FC 0x440 0x654 0x3 2
1376#define IMXRT_PAD_GPIO_DISP_B1_06_XBAR1_INOUT32 0x1FC 0x440 0x708 0x4 1
1377#define IMXRT_PAD_GPIO_DISP_B1_06_GPIO_MUX4_IO27 0x1FC 0x440 0 0x5 0
1378#define IMXRT_PAD_GPIO_DISP_B1_06_SRC_BT_CFG00 0x1FC 0x440 0 0x6 0
1379#define IMXRT_PAD_GPIO_DISP_B1_06_ENET_QOS_TX_DATA03 0x1FC 0x440 0 0x8 0
1380#define IMXRT_PAD_GPIO_DISP_B1_06_LPSPI3_SOUT 0x1FC 0x440 0x608 0x9 1
1381#define IMXRT_PAD_GPIO_DISP_B1_06_GPIO10_IO27 0x1FC 0x440 0 0xA 0
1382
1383#define IMXRT_PAD_GPIO_DISP_B1_07_VIDEO_MUX_LCDIF_DATA03 0x200 0x444 0 0x0 0
1384#define IMXRT_PAD_GPIO_DISP_B1_07_ENET_1G_TX_DATA02 0x200 0x444 0 0x1 0
1385#define IMXRT_PAD_GPIO_DISP_B1_07_LPUART4_RTS_B 0x200 0x444 0 0x2 0
1386#define IMXRT_PAD_GPIO_DISP_B1_07_TMR3_TIMER1 0x200 0x444 0x658 0x3 2
1387#define IMXRT_PAD_GPIO_DISP_B1_07_XBAR1_INOUT33 0x200 0x444 0x70C 0x4 1
1388#define IMXRT_PAD_GPIO_DISP_B1_07_GPIO_MUX4_IO28 0x200 0x444 0 0x5 0
1389#define IMXRT_PAD_GPIO_DISP_B1_07_SRC_BT_CFG01 0x200 0x444 0 0x6 0
1390#define IMXRT_PAD_GPIO_DISP_B1_07_ENET_QOS_TX_DATA02 0x200 0x444 0 0x8 0
1391#define IMXRT_PAD_GPIO_DISP_B1_07_LPSPI3_PCS0 0x200 0x444 0x5F0 0x9 1
1392#define IMXRT_PAD_GPIO_DISP_B1_07_GPIO10_IO28 0x200 0x444 0 0xA 0
1393
1394#define IMXRT_PAD_GPIO_DISP_B1_08_GPIO10_IO29 0x204 0x448 0 0xA 0
1395#define IMXRT_PAD_GPIO_DISP_B1_08_VIDEO_MUX_LCDIF_DATA04 0x204 0x448 0 0x0 0
1396#define IMXRT_PAD_GPIO_DISP_B1_08_ENET_1G_TX_DATA01 0x204 0x448 0 0x1 0
1397#define IMXRT_PAD_GPIO_DISP_B1_08_USDHC1_CD_B 0x204 0x448 0x6C8 0x2 1
1398#define IMXRT_PAD_GPIO_DISP_B1_08_TMR3_TIMER2 0x204 0x448 0x65C 0x3 1
1399#define IMXRT_PAD_GPIO_DISP_B1_08_XBAR1_INOUT34 0x204 0x448 0x710 0x4 1
1400#define IMXRT_PAD_GPIO_DISP_B1_08_GPIO_MUX4_IO29 0x204 0x448 0 0x5 0
1401#define IMXRT_PAD_GPIO_DISP_B1_08_SRC_BT_CFG02 0x204 0x448 0 0x6 0
1402#define IMXRT_PAD_GPIO_DISP_B1_08_ENET_QOS_TX_DATA01 0x204 0x448 0 0x8 0
1403#define IMXRT_PAD_GPIO_DISP_B1_08_LPSPI3_PCS1 0x204 0x448 0x5F4 0x9 1
1404
1405#define IMXRT_PAD_GPIO_DISP_B1_09_VIDEO_MUX_LCDIF_DATA05 0x208 0x44C 0 0x0 0
1406#define IMXRT_PAD_GPIO_DISP_B1_09_ENET_1G_TX_DATA00 0x208 0x44C 0 0x1 0
1407#define IMXRT_PAD_GPIO_DISP_B1_09_USDHC1_WP 0x208 0x44C 0x6CC 0x2 1
1408#define IMXRT_PAD_GPIO_DISP_B1_09_TMR4_TIMER0 0x208 0x44C 0x660 0x3 2
1409#define IMXRT_PAD_GPIO_DISP_B1_09_XBAR1_INOUT35 0x208 0x44C 0x714 0x4 1
1410#define IMXRT_PAD_GPIO_DISP_B1_09_GPIO_MUX4_IO30 0x208 0x44C 0 0x5 0
1411#define IMXRT_PAD_GPIO_DISP_B1_09_SRC_BT_CFG03 0x208 0x44C 0 0x6 0
1412#define IMXRT_PAD_GPIO_DISP_B1_09_ENET_QOS_TX_DATA00 0x208 0x44C 0 0x8 0
1413#define IMXRT_PAD_GPIO_DISP_B1_09_LPSPI3_PCS2 0x208 0x44C 0x5F8 0x9 1
1414#define IMXRT_PAD_GPIO_DISP_B1_09_GPIO10_IO30 0x208 0x44C 0 0xA 0
1415
1416#define IMXRT_PAD_GPIO_DISP_B1_10_VIDEO_MUX_LCDIF_DATA06 0x20C 0x450 0 0x0 0
1417#define IMXRT_PAD_GPIO_DISP_B1_10_ENET_1G_TX_EN 0x20C 0x450 0 0x1 0
1418#define IMXRT_PAD_GPIO_DISP_B1_10_USDHC1_RESET_B 0x20C 0x450 0 0x2 0
1419#define IMXRT_PAD_GPIO_DISP_B1_10_TMR4_TIMER1 0x20C 0x450 0x664 0x3 2
1420#define IMXRT_PAD_GPIO_DISP_B1_10_XBAR1_INOUT36 0x20C 0x450 0 0x4 0
1421#define IMXRT_PAD_GPIO_DISP_B1_10_GPIO_MUX4_IO31 0x20C 0x450 0 0x5 0
1422#define IMXRT_PAD_GPIO_DISP_B1_10_SRC_BT_CFG04 0x20C 0x450 0 0x6 0
1423#define IMXRT_PAD_GPIO_DISP_B1_10_ENET_QOS_TX_EN 0x20C 0x450 0 0x8 0
1424#define IMXRT_PAD_GPIO_DISP_B1_10_LPSPI3_PCS3 0x20C 0x450 0x5FC 0x9 1
1425#define IMXRT_PAD_GPIO_DISP_B1_10_GPIO10_IO31 0x20C 0x450 0 0xA 0
1426
1427#define IMXRT_PAD_GPIO_DISP_B1_11_VIDEO_MUX_LCDIF_DATA07 0x210 0x454 0 0x0 0
1428#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_1G_TX_CLK_IO 0x210 0x454 0x4E8 0x1 2
1429#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_1G_REF_CLK 0x210 0x454 0x4C4 0x2 2
1430#define IMXRT_PAD_GPIO_DISP_B1_11_TMR4_TIMER2 0x210 0x454 0x668 0x3 1
1431#define IMXRT_PAD_GPIO_DISP_B1_11_XBAR1_INOUT37 0x210 0x454 0 0x4 0
1432#define IMXRT_PAD_GPIO_DISP_B1_11_GPIO_MUX5_IO00 0x210 0x454 0 0x5 0
1433#define IMXRT_PAD_GPIO_DISP_B1_11_SRC_BT_CFG05 0x210 0x454 0 0x6 0
1434#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_QOS_TX_CLK 0x210 0x454 0x4A4 0x8 0
1435#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_QOS_REF_CLK 0x210 0x454 0x4A0 0x9 2
1436#define IMXRT_PAD_GPIO_DISP_B1_11_GPIO11_IO00 0x210 0x454 0 0xA 0
1437
1438#define IMXRT_PAD_GPIO_DISP_B2_00_GPIO11_IO01 0x214 0x458 0 0xA 0
1439#define IMXRT_PAD_GPIO_DISP_B2_00_VIDEO_MUX_LCDIF_DATA08 0x214 0x458 0 0x0 0
1440#define IMXRT_PAD_GPIO_DISP_B2_00_WDOG1_B 0x214 0x458 0 0x1 0
1441#define IMXRT_PAD_GPIO_DISP_B2_00_MQS_RIGHT 0x214 0x458 0 0x2 0
1442#define IMXRT_PAD_GPIO_DISP_B2_00_ENET_1G_TX_ER 0x214 0x458 0 0x3 0
1443#define IMXRT_PAD_GPIO_DISP_B2_00_SAI1_TX_DATA03 0x214 0x458 0 0x4 0
1444#define IMXRT_PAD_GPIO_DISP_B2_00_GPIO_MUX5_IO01 0x214 0x458 0 0x5 0
1445#define IMXRT_PAD_GPIO_DISP_B2_00_SRC_BT_CFG06 0x214 0x458 0 0x6 0
1446#define IMXRT_PAD_GPIO_DISP_B2_00_ENET_QOS_TX_ER 0x214 0x458 0 0x8 0
1447
1448#define IMXRT_PAD_GPIO_DISP_B2_01_VIDEO_MUX_LCDIF_DATA09 0x218 0x45C 0 0x0 0
1449#define IMXRT_PAD_GPIO_DISP_B2_01_USDHC1_VSELECT 0x218 0x45C 0 0x1 0
1450#define IMXRT_PAD_GPIO_DISP_B2_01_MQS_LEFT 0x218 0x45C 0 0x2 0
1451#define IMXRT_PAD_GPIO_DISP_B2_01_WDOG2_B 0x218 0x45C 0 0x3 0
1452#define IMXRT_PAD_GPIO_DISP_B2_01_SAI1_TX_DATA02 0x218 0x45C 0 0x4 0
1453#define IMXRT_PAD_GPIO_DISP_B2_01_GPIO_MUX5_IO02 0x218 0x45C 0 0x5 0
1454#define IMXRT_PAD_GPIO_DISP_B2_01_SRC_BT_CFG07 0x218 0x45C 0 0x6 0
1455#define IMXRT_PAD_GPIO_DISP_B2_01_EWM_OUT_B 0x218 0x45C 0 0x8 0
1456#define IMXRT_PAD_GPIO_DISP_B2_01_CCM_ENET_REF_CLK_25M 0x218 0x45C 0 0x9 0
1457#define IMXRT_PAD_GPIO_DISP_B2_01_GPIO11_IO02 0x218 0x45C 0 0xA 0
1458
1459#define IMXRT_PAD_GPIO_DISP_B2_02_GPIO11_IO03 0x21C 0x460 0 0xA 0
1460#define IMXRT_PAD_GPIO_DISP_B2_02_VIDEO_MUX_LCDIF_DATA10 0x21C 0x460 0 0x0 0
1461#define IMXRT_PAD_GPIO_DISP_B2_02_ENET_TX_DATA00 0x21C 0x460 0 0x1 0
1462#define IMXRT_PAD_GPIO_DISP_B2_02_PIT1_TRIGGER3 0x21C 0x460 0 0x2 0
1463#define IMXRT_PAD_GPIO_DISP_B2_02_ARM_TRACE00 0x21C 0x460 0 0x3 0
1464#define IMXRT_PAD_GPIO_DISP_B2_02_SAI1_TX_DATA01 0x21C 0x460 0 0x4 0
1465#define IMXRT_PAD_GPIO_DISP_B2_02_GPIO_MUX5_IO03 0x21C 0x460 0 0x5 0
1466#define IMXRT_PAD_GPIO_DISP_B2_02_SRC_BT_CFG08 0x21C 0x460 0 0x6 0
1467#define IMXRT_PAD_GPIO_DISP_B2_02_ENET_QOS_TX_DATA00 0x21C 0x460 0 0x8 0
1468
1469#define IMXRT_PAD_GPIO_DISP_B2_03_GPIO11_IO04 0x220 0x464 0 0xA 0
1470#define IMXRT_PAD_GPIO_DISP_B2_03_VIDEO_MUX_LCDIF_DATA11 0x220 0x464 0 0x0 0
1471#define IMXRT_PAD_GPIO_DISP_B2_03_ENET_TX_DATA01 0x220 0x464 0 0x1 0
1472#define IMXRT_PAD_GPIO_DISP_B2_03_PIT1_TRIGGER2 0x220 0x464 0 0x2 0
1473#define IMXRT_PAD_GPIO_DISP_B2_03_ARM_TRACE01 0x220 0x464 0 0x3 0
1474#define IMXRT_PAD_GPIO_DISP_B2_03_SAI1_MCLK 0x220 0x464 0x66C 0x4 1
1475#define IMXRT_PAD_GPIO_DISP_B2_03_GPIO_MUX5_IO04 0x220 0x464 0 0x5 0
1476#define IMXRT_PAD_GPIO_DISP_B2_03_SRC_BT_CFG09 0x220 0x464 0 0x6 0
1477#define IMXRT_PAD_GPIO_DISP_B2_03_ENET_QOS_TX_DATA01 0x220 0x464 0 0x8 0
1478
1479#define IMXRT_PAD_GPIO_DISP_B2_04_VIDEO_MUX_LCDIF_DATA12 0x224 0x468 0 0x0 0
1480#define IMXRT_PAD_GPIO_DISP_B2_04_ENET_TX_EN 0x224 0x468 0 0x1 0
1481#define IMXRT_PAD_GPIO_DISP_B2_04_PIT1_TRIGGER1 0x224 0x468 0 0x2 0
1482#define IMXRT_PAD_GPIO_DISP_B2_04_ARM_TRACE02 0x224 0x468 0 0x3 0
1483#define IMXRT_PAD_GPIO_DISP_B2_04_SAI1_RX_SYNC 0x224 0x468 0x678 0x4 1
1484#define IMXRT_PAD_GPIO_DISP_B2_04_GPIO_MUX5_IO05 0x224 0x468 0 0x5 0
1485#define IMXRT_PAD_GPIO_DISP_B2_04_SRC_BT_CFG10 0x224 0x468 0 0x6 0
1486#define IMXRT_PAD_GPIO_DISP_B2_04_ENET_QOS_TX_EN 0x224 0x468 0 0x8 0
1487#define IMXRT_PAD_GPIO_DISP_B2_04_GPIO11_IO05 0x224 0x468 0 0xA 0
1488
1489#define IMXRT_PAD_GPIO_DISP_B2_05_GPIO11_IO06 0x228 0x46C 0 0xA 0
1490#define IMXRT_PAD_GPIO_DISP_B2_05_VIDEO_MUX_LCDIF_DATA13 0x228 0x46C 0 0x0 0
1491#define IMXRT_PAD_GPIO_DISP_B2_05_ENET_TX_CLK 0x228 0x46C 0x4C0 0x1 1
1492#define IMXRT_PAD_GPIO_DISP_B2_05_ENET_REF_CLK 0x228 0x46C 0x4A8 0x2 1
1493#define IMXRT_PAD_GPIO_DISP_B2_05_ARM_TRACE03 0x228 0x46C 0 0x3 0
1494#define IMXRT_PAD_GPIO_DISP_B2_05_SAI1_RX_BCLK 0x228 0x46C 0x670 0x4 1
1495#define IMXRT_PAD_GPIO_DISP_B2_05_GPIO_MUX5_IO06 0x228 0x46C 0 0x5 0
1496#define IMXRT_PAD_GPIO_DISP_B2_05_SRC_BT_CFG11 0x228 0x46C 0 0x6 0
1497#define IMXRT_PAD_GPIO_DISP_B2_05_ENET_QOS_TX_CLK 0x228 0x46C 0x4A4 0x8 1
1498
1499#define IMXRT_PAD_GPIO_DISP_B2_06_GPIO11_IO07 0x22C 0x470 0 0xA 0
1500#define IMXRT_PAD_GPIO_DISP_B2_06_VIDEO_MUX_LCDIF_DATA14 0x22C 0x470 0 0x0 0
1501#define IMXRT_PAD_GPIO_DISP_B2_06_ENET_RX_DATA00 0x22C 0x470 0x4B0 0x1 1
1502#define IMXRT_PAD_GPIO_DISP_B2_06_LPUART7_TXD 0x22C 0x470 0x630 0x2 1
1503#define IMXRT_PAD_GPIO_DISP_B2_06_ARM_TRACE_CLK 0x22C 0x470 0 0x3 0
1504#define IMXRT_PAD_GPIO_DISP_B2_06_SAI1_RX_DATA00 0x22C 0x470 0x674 0x4 1
1505#define IMXRT_PAD_GPIO_DISP_B2_06_GPIO_MUX5_IO07 0x22C 0x470 0 0x5 0
1506#define IMXRT_PAD_GPIO_DISP_B2_06_ENET_QOS_RX_DATA00 0x22C 0x470 0x4F0 0x8 1
1507
1508#define IMXRT_PAD_GPIO_DISP_B2_07_VIDEO_MUX_LCDIF_DATA15 0x230 0x474 0 0x0 0
1509#define IMXRT_PAD_GPIO_DISP_B2_07_ENET_RX_DATA01 0x230 0x474 0x4B4 0x1 1
1510#define IMXRT_PAD_GPIO_DISP_B2_07_LPUART7_RXD 0x230 0x474 0x62C 0x2 1
1511#define IMXRT_PAD_GPIO_DISP_B2_07_ARM_TRACE_SWO 0x230 0x474 0 0x3 0
1512#define IMXRT_PAD_GPIO_DISP_B2_07_SAI1_TX_DATA00 0x230 0x474 0 0x4 0
1513#define IMXRT_PAD_GPIO_DISP_B2_07_GPIO_MUX5_IO08 0x230 0x474 0 0x5 0
1514#define IMXRT_PAD_GPIO_DISP_B2_07_ENET_QOS_RX_DATA01 0x230 0x474 0x4F4 0x8 1
1515#define IMXRT_PAD_GPIO_DISP_B2_07_GPIO11_IO08 0x230 0x474 0 0xA 0
1516
1517#define IMXRT_PAD_GPIO_DISP_B2_08_GPIO11_IO09 0x234 0x478 0 0xA 0
1518#define IMXRT_PAD_GPIO_DISP_B2_08_VIDEO_MUX_LCDIF_DATA16 0x234 0x478 0 0x0 0
1519#define IMXRT_PAD_GPIO_DISP_B2_08_ENET_RX_EN 0x234 0x478 0x4B8 0x1 1
1520#define IMXRT_PAD_GPIO_DISP_B2_08_LPUART8_TXD 0x234 0x478 0x638 0x2 1
1521#define IMXRT_PAD_GPIO_DISP_B2_08_ARM_CM7_EVENTO 0x234 0x478 0 0x3 0
1522#define IMXRT_PAD_GPIO_DISP_B2_08_SAI1_TX_BCLK 0x234 0x478 0x67C 0x4 1
1523#define IMXRT_PAD_GPIO_DISP_B2_08_GPIO_MUX5_IO09 0x234 0x478 0 0x5 0
1524#define IMXRT_PAD_GPIO_DISP_B2_08_ENET_QOS_RX_EN 0x234 0x478 0x4F8 0x8 1
1525#define IMXRT_PAD_GPIO_DISP_B2_08_LPUART1_TXD 0x234 0x478 0x620 0x9 2
1526
1527#define IMXRT_PAD_GPIO_DISP_B2_09_GPIO11_IO10 0x238 0x47C 0 0xA 0
1528#define IMXRT_PAD_GPIO_DISP_B2_09_VIDEO_MUX_LCDIF_DATA17 0x238 0x47C 0 0x0 0
1529#define IMXRT_PAD_GPIO_DISP_B2_09_ENET_RX_ER 0x238 0x47C 0x4BC 0x1 1
1530#define IMXRT_PAD_GPIO_DISP_B2_09_LPUART8_RXD 0x238 0x47C 0x634 0x2 1
1531#define IMXRT_PAD_GPIO_DISP_B2_09_ARM_CM7_EVENTI 0x238 0x47C 0 0x3 0
1532#define IMXRT_PAD_GPIO_DISP_B2_09_SAI1_TX_SYNC 0x238 0x47C 0x680 0x4 1
1533#define IMXRT_PAD_GPIO_DISP_B2_09_GPIO_MUX5_IO10 0x238 0x47C 0 0x5 0
1534#define IMXRT_PAD_GPIO_DISP_B2_09_ENET_QOS_RX_ER 0x238 0x47C 0x4FC 0x8 1
1535#define IMXRT_PAD_GPIO_DISP_B2_09_LPUART1_RXD 0x238 0x47C 0x61C 0x9 2
1536
1537#define IMXRT_PAD_GPIO_DISP_B2_10_GPIO11_IO11 0x23C 0x480 0 0xA 0
1538#define IMXRT_PAD_GPIO_DISP_B2_10_VIDEO_MUX_LCDIF_DATA18 0x23C 0x480 0 0x0 0
1539#define IMXRT_PAD_GPIO_DISP_B2_10_EMVSIM2_IO 0x23C 0x480 0x6A8 0x1 1
1540#define IMXRT_PAD_GPIO_DISP_B2_10_LPUART2_TXD 0x23C 0x480 0 0x2 0
1541#define IMXRT_PAD_GPIO_DISP_B2_10_WDOG2_RESET_B_DEB 0x23C 0x480 0 0x3 0
1542#define IMXRT_PAD_GPIO_DISP_B2_10_XBAR1_INOUT38 0x23C 0x480 0 0x4 0
1543#define IMXRT_PAD_GPIO_DISP_B2_10_GPIO_MUX5_IO11 0x23C 0x480 0 0x5 0
1544#define IMXRT_PAD_GPIO_DISP_B2_10_LPI2C3_SCL 0x23C 0x480 0x5BC 0x6 1
1545#define IMXRT_PAD_GPIO_DISP_B2_10_ENET_QOS_RX_ER 0x23C 0x480 0x4FC 0x8 2
1546#define IMXRT_PAD_GPIO_DISP_B2_10_SPDIF_IN 0x23C 0x480 0x6B4 0x9 2
1547
1548#define IMXRT_PAD_GPIO_DISP_B2_11_VIDEO_MUX_LCDIF_DATA19 0x240 0x484 0 0x0 0
1549#define IMXRT_PAD_GPIO_DISP_B2_11_EMVSIM2_CLK 0x240 0x484 0 0x1 0
1550#define IMXRT_PAD_GPIO_DISP_B2_11_LPUART2_RXD 0x240 0x484 0 0x2 0
1551#define IMXRT_PAD_GPIO_DISP_B2_11_WDOG1_RESET_B_DEB 0x240 0x484 0 0x3 0
1552#define IMXRT_PAD_GPIO_DISP_B2_11_XBAR1_INOUT39 0x240 0x484 0 0x4 0
1553#define IMXRT_PAD_GPIO_DISP_B2_11_GPIO_MUX5_IO12 0x240 0x484 0 0x5 0
1554#define IMXRT_PAD_GPIO_DISP_B2_11_LPI2C3_SDA 0x240 0x484 0x5C0 0x6 1
1555#define IMXRT_PAD_GPIO_DISP_B2_11_ENET_QOS_CRS 0x240 0x484 0 0x8 0
1556#define IMXRT_PAD_GPIO_DISP_B2_11_SPDIF_OUT 0x240 0x484 0 0x9 0
1557#define IMXRT_PAD_GPIO_DISP_B2_11_GPIO11_IO12 0x240 0x484 0 0xA 0
1558
1559#define IMXRT_PAD_GPIO_DISP_B2_12_GPIO11_IO13 0x244 0x488 0 0xA 0
1560#define IMXRT_PAD_GPIO_DISP_B2_12_VIDEO_MUX_LCDIF_DATA20 0x244 0x488 0 0x0 0
1561#define IMXRT_PAD_GPIO_DISP_B2_12_EMVSIM2_RST 0x244 0x488 0 0x1 0
1562#define IMXRT_PAD_GPIO_DISP_B2_12_FLEXCAN1_TX 0x244 0x488 0 0x2 0
1563#define IMXRT_PAD_GPIO_DISP_B2_12_LPUART2_CTS_B 0x244 0x488 0 0x3 0
1564#define IMXRT_PAD_GPIO_DISP_B2_12_XBAR1_INOUT40 0x244 0x488 0 0x4 0
1565#define IMXRT_PAD_GPIO_DISP_B2_12_GPIO_MUX5_IO13 0x244 0x488 0 0x5 0
1566#define IMXRT_PAD_GPIO_DISP_B2_12_LPI2C4_SCL 0x244 0x488 0x5C4 0x6 1
1567#define IMXRT_PAD_GPIO_DISP_B2_12_ENET_QOS_COL 0x244 0x488 0 0x8 0
1568#define IMXRT_PAD_GPIO_DISP_B2_12_LPSPI4_SCK 0x244 0x488 0x610 0x9 1
1569
1570#define IMXRT_PAD_GPIO_DISP_B2_13_GPIO11_IO14 0x248 0x48C 0 0xA 0
1571#define IMXRT_PAD_GPIO_DISP_B2_13_VIDEO_MUX_LCDIF_DATA21 0x248 0x48C 0 0x0 0
1572#define IMXRT_PAD_GPIO_DISP_B2_13_EMVSIM2_SVEN 0x248 0x48C 0 0x1 0
1573#define IMXRT_PAD_GPIO_DISP_B2_13_FLEXCAN1_RX 0x248 0x48C 0x498 0x2 1
1574#define IMXRT_PAD_GPIO_DISP_B2_13_LPUART2_RTS_B 0x248 0x48C 0 0x3 0
1575#define IMXRT_PAD_GPIO_DISP_B2_13_ENET_REF_CLK 0x248 0x48C 0x4A8 0x4 2
1576#define IMXRT_PAD_GPIO_DISP_B2_13_GPIO_MUX5_IO14 0x248 0x48C 0 0x5 0
1577#define IMXRT_PAD_GPIO_DISP_B2_13_LPI2C4_SDA 0x248 0x48C 0x5C8 0x6 1
1578#define IMXRT_PAD_GPIO_DISP_B2_13_ENET_QOS_1588_EVENT0_OUT 0x248 0x48C 0 0x8 0
1579#define IMXRT_PAD_GPIO_DISP_B2_13_LPSPI4_SIN 0x248 0x48C 0x614 0x9 1
1580
1581#define IMXRT_PAD_GPIO_DISP_B2_14_GPIO_MUX5_IO15 0x24C 0x490 0 0x5 0
1582#define IMXRT_PAD_GPIO_DISP_B2_14_FLEXCAN1_TX 0x24C 0x490 0 0x6 0
1583#define IMXRT_PAD_GPIO_DISP_B2_14_ENET_QOS_1588_EVENT0_IN 0x24C 0x490 0 0x8 0
1584#define IMXRT_PAD_GPIO_DISP_B2_14_LPSPI4_SOUT 0x24C 0x490 0x618 0x9 1
1585#define IMXRT_PAD_GPIO_DISP_B2_14_GPIO11_IO15 0x24C 0x490 0 0xA 0
1586#define IMXRT_PAD_GPIO_DISP_B2_14_VIDEO_MUX_LCDIF_DATA22 0x24C 0x490 0 0x0 0
1587#define IMXRT_PAD_GPIO_DISP_B2_14_EMVSIM2_PD 0x24C 0x490 0x6AC 0x1 1
1588#define IMXRT_PAD_GPIO_DISP_B2_14_WDOG2_B 0x24C 0x490 0 0x2 0
1589#define IMXRT_PAD_GPIO_DISP_B2_14_VIDEO_MUX_EXT_DCIC1 0x24C 0x490 0 0x3 0
1590#define IMXRT_PAD_GPIO_DISP_B2_14_ENET_1G_REF_CLK 0x24C 0x490 0x4C4 0x4 3
1591
1592#define IMXRT_PAD_GPIO_DISP_B2_15_VIDEO_MUX_LCDIF_DATA23 0x250 0x494 0 0x0 0
1593#define IMXRT_PAD_GPIO_DISP_B2_15_EMVSIM2_POWER_FAIL 0x250 0x494 0x6B0 0x1 1
1594#define IMXRT_PAD_GPIO_DISP_B2_15_WDOG1_B 0x250 0x494 0 0x2 0
1595#define IMXRT_PAD_GPIO_DISP_B2_15_VIDEO_MUX_EXT_DCIC2 0x250 0x494 0 0x3 0
1596#define IMXRT_PAD_GPIO_DISP_B2_15_PIT1_TRIGGER0 0x250 0x494 0 0x4 0
1597#define IMXRT_PAD_GPIO_DISP_B2_15_GPIO_MUX5_IO16 0x250 0x494 0 0x5 0
1598#define IMXRT_PAD_GPIO_DISP_B2_15_FLEXCAN1_RX 0x250 0x494 0x498 0x6 2
1599#define IMXRT_PAD_GPIO_DISP_B2_15_ENET_QOS_1588_EVENT0_AUX_IN 0x250 0x494 0 0x8 0
1600#define IMXRT_PAD_GPIO_DISP_B2_15_LPSPI4_PCS0 0x250 0x494 0x60C 0x9 1
1601#define IMXRT_PAD_GPIO_DISP_B2_15_GPIO11_IO16 0x250 0x494 0 0xA 0
1602
1603#ifdef __cplusplus
1604}
1605#endif /* __cplusplus */
1606
1607#endif /* LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H */
