RTEMS 6.1-rc1
imxrt1166-pinfunc.h File Reference
Pin function definitions for i.MXRT1166. More...
#define IMXRT_PAD_GPIO_LPSR_00_FLEXCAN3_TX   0x000 0x040 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_00_MIC_CLK   0x000 0x040 0 0x1 0
#define IMXRT_PAD_GPIO_LPSR_00_MQS_RIGHT   0x000 0x040 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_00_ARM_CM4_EVENTO   0x000 0x040 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_00_GPIO_MUX6_IO00   0x000 0x040 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_00_LPUART12_TXD   0x000 0x040 0x0B0 0x6 0
#define IMXRT_PAD_GPIO_LPSR_00_SAI4_MCLK   0x000 0x040 0x0C8 0x7 0
#define IMXRT_PAD_GPIO_LPSR_00_GPIO12_IO00   0x000 0x040 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_01_FLEXCAN3_RX   0x004 0x044 0x080 0x0 0
#define IMXRT_PAD_GPIO_LPSR_01_MIC_BITSTREAM0   0x004 0x044 0x0B4 0x1 0
#define IMXRT_PAD_GPIO_LPSR_01_MQS_LEFT   0x004 0x044 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_01_ARM_CM4_EVENTI   0x004 0x044 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_01_GPIO_MUX6_IO01   0x004 0x044 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_01_LPUART12_RXD   0x004 0x044 0x0AC 0x6 0
#define IMXRT_PAD_GPIO_LPSR_01_GPIO12_IO01   0x004 0x044 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_02_GPIO12_IO02   0x008 0x048 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_02_SRC_BOOT_MODE00   0x008 0x048 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_02_LPSPI5_SCK   0x008 0x048 0x098 0x1 0
#define IMXRT_PAD_GPIO_LPSR_02_SAI4_TX_DATA   0x008 0x048 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_02_MQS_RIGHT   0x008 0x048 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_02_GPIO_MUX6_IO02   0x008 0x048 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_03_SRC_BOOT_MODE01   0x00C 0x04C 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_03_LPSPI5_PCS0   0x00C 0x04C 0x094 0x1 0
#define IMXRT_PAD_GPIO_LPSR_03_SAI4_TX_SYNC   0x00C 0x04C 0x0DC 0x2 0
#define IMXRT_PAD_GPIO_LPSR_03_MQS_LEFT   0x00C 0x04C 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_03_GPIO_MUX6_IO03   0x00C 0x04C 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_03_GPIO12_IO03   0x00C 0x04C 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_04_LPI2C5_SDA   0x010 0x050 0x088 0x0 0
#define IMXRT_PAD_GPIO_LPSR_04_LPSPI5_SOUT   0x010 0x050 0x0A0 0x1 0
#define IMXRT_PAD_GPIO_LPSR_04_SAI4_TX_BCLK   0x010 0x050 0x0D8 0x2 0
#define IMXRT_PAD_GPIO_LPSR_04_LPUART12_RTS_B   0x010 0x050 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_04_GPIO_MUX6_IO04   0x010 0x050 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_04_LPUART11_TXD   0x010 0x050 0x0A8 0x6 0
#define IMXRT_PAD_GPIO_LPSR_04_GPIO12_IO04   0x010 0x050 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_05_GPIO12_IO05   0x014 0x054 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_05_LPI2C5_SCL   0x014 0x054 0x084 0x0 0
#define IMXRT_PAD_GPIO_LPSR_05_LPSPI5_SIN   0x014 0x054 0x09C 0x1 0
#define IMXRT_PAD_GPIO_LPSR_05_SAI4_MCLK   0x014 0x054 0x0C8 0x2 1
#define IMXRT_PAD_GPIO_LPSR_05_LPUART12_CTS_B   0x014 0x054 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_05_GPIO_MUX6_IO05   0x014 0x054 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_05_LPUART11_RXD   0x014 0x054 0x0A4 0x6 0
#define IMXRT_PAD_GPIO_LPSR_05_NMI_GLUE_NMI   0x014 0x054 0x0C4 0x7 0
#define IMXRT_PAD_GPIO_LPSR_06_LPI2C6_SDA   0x018 0x058 0x090 0x0 0
#define IMXRT_PAD_GPIO_LPSR_06_SAI4_RX_DATA   0x018 0x058 0x0D0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_06_LPUART12_TXD   0x018 0x058 0x0B0 0x3 1
#define IMXRT_PAD_GPIO_LPSR_06_LPSPI6_PCS3   0x018 0x058 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_06_GPIO_MUX6_IO06   0x018 0x058 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_06_FLEXCAN3_TX   0x018 0x058 0 0x6 0
#define IMXRT_PAD_GPIO_LPSR_06_PIT2_TRIGGER3   0x018 0x058 0 0x7 0
#define IMXRT_PAD_GPIO_LPSR_06_LPSPI5_PCS1   0x018 0x058 0 0x8 0
#define IMXRT_PAD_GPIO_LPSR_06_GPIO12_IO06   0x018 0x058 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_07_LPI2C6_SCL   0x01C 0x05C 0x08C 0x0 0
#define IMXRT_PAD_GPIO_LPSR_07_SAI4_RX_BCLK   0x01C 0x05C 0x0CC 0x2 0
#define IMXRT_PAD_GPIO_LPSR_07_LPUART12_RXD   0x01C 0x05C 0x0AC 0x3 1
#define IMXRT_PAD_GPIO_LPSR_07_LPSPI6_PCS2   0x01C 0x05C 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_07_GPIO_MUX6_IO07   0x01C 0x05C 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_07_FLEXCAN3_RX   0x01C 0x05C 0x080 0x6 1
#define IMXRT_PAD_GPIO_LPSR_07_PIT2_TRIGGER2   0x01C 0x05C 0 0x7 0
#define IMXRT_PAD_GPIO_LPSR_07_LPSPI5_PCS2   0x01C 0x05C 0 0x8 0
#define IMXRT_PAD_GPIO_LPSR_07_GPIO12_IO07   0x01C 0x05C 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_08_GPIO12_IO08   0x020 0x060 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_08_LPUART11_TXD   0x020 0x060 0x0A8 0x0 1
#define IMXRT_PAD_GPIO_LPSR_08_FLEXCAN3_TX   0x020 0x060 0 0x1 0
#define IMXRT_PAD_GPIO_LPSR_08_SAI4_RX_SYNC   0x020 0x060 0x0D4 0x2 0
#define IMXRT_PAD_GPIO_LPSR_08_MIC_CLK   0x020 0x060 0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_08_LPSPI6_PCS1   0x020 0x060 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_08_GPIO_MUX6_IO08   0x020 0x060 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_08_LPI2C5_SDA   0x020 0x060 0x088 0x6 1
#define IMXRT_PAD_GPIO_LPSR_08_PIT2_TRIGGER1   0x020 0x060 0 0x7 0
#define IMXRT_PAD_GPIO_LPSR_08_LPSPI5_PCS3   0x020 0x060 0 0x8 0
#define IMXRT_PAD_GPIO_LPSR_09_GPIO12_IO09   0x024 0x064 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_09_LPUART11_RXD   0x024 0x064 0x0A4 0x0 1
#define IMXRT_PAD_GPIO_LPSR_09_FLEXCAN3_RX   0x024 0x064 0x080 0x1 2
#define IMXRT_PAD_GPIO_LPSR_09_PIT2_TRIGGER0   0x024 0x064 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_09_MIC_BITSTREAM0   0x024 0x064 0x0B4 0x3 1
#define IMXRT_PAD_GPIO_LPSR_09_LPSPI6_PCS0   0x024 0x064 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_09_GPIO_MUX6_IO09   0x024 0x064 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_09_LPI2C5_SCL   0x024 0x064 0x084 0x6 1
#define IMXRT_PAD_GPIO_LPSR_09_SAI4_TX_DATA   0x024 0x064 0 0x7 0
#define IMXRT_PAD_GPIO_LPSR_10_GPIO12_IO10   0x028 0x068 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_10_JTAG_MUX_TRSTB   0x028 0x068 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_10_LPUART11_CTS_B   0x028 0x068 0 0x1 0
#define IMXRT_PAD_GPIO_LPSR_10_LPI2C6_SDA   0x028 0x068 0x090 0x2 1
#define IMXRT_PAD_GPIO_LPSR_10_MIC_BITSTREAM1   0x028 0x068 0x0B8 0x3 0
#define IMXRT_PAD_GPIO_LPSR_10_LPSPI6_SCK   0x028 0x068 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_10_GPIO_MUX6_IO10   0x028 0x068 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_10_LPI2C5_SCLS   0x028 0x068 0 0x6 0
#define IMXRT_PAD_GPIO_LPSR_10_SAI4_TX_SYNC   0x028 0x068 0x0DC 0x7 1
#define IMXRT_PAD_GPIO_LPSR_10_LPUART12_TXD   0x028 0x068 0x0B0 0x8 2
#define IMXRT_PAD_GPIO_LPSR_11_JTAG_MUX_TDO   0x02C 0x06C 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_11_LPUART11_RTS_B   0x02C 0x06C 0 0x1 0
#define IMXRT_PAD_GPIO_LPSR_11_LPI2C6_SCL   0x02C 0x06C 0x08C 0x2 1
#define IMXRT_PAD_GPIO_LPSR_11_MIC_BITSTREAM2   0x02C 0x06C 0x0BC 0x3 0
#define IMXRT_PAD_GPIO_LPSR_11_LPSPI6_SOUT   0x02C 0x06C 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_11_GPIO_MUX6_IO11   0x02C 0x06C 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_11_LPI2C5_SDAS   0x02C 0x06C 0 0x6 0
#define IMXRT_PAD_GPIO_LPSR_11_ARM_TRACE_SWO   0x02C 0x06C 0 0x7 0
#define IMXRT_PAD_GPIO_LPSR_11_LPUART12_RXD   0x02C 0x06C 0x0AC 0x8 2
#define IMXRT_PAD_GPIO_LPSR_11_GPIO12_IO11   0x02C 0x06C 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_12_GPIO12_IO12   0x030 0x070 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_12_JTAG_MUX_TDI   0x030 0x070 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_12_PIT2_TRIGGER0   0x030 0x070 0 0x1 0
#define IMXRT_PAD_GPIO_LPSR_12_MIC_BITSTREAM3   0x030 0x070 0x0C0 0x3 0
#define IMXRT_PAD_GPIO_LPSR_12_LPSPI6_SIN   0x030 0x070 0 0x4 0
#define IMXRT_PAD_GPIO_LPSR_12_GPIO_MUX6_IO12   0x030 0x070 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_12_LPI2C5_HREQ   0x030 0x070 0 0x6 0
#define IMXRT_PAD_GPIO_LPSR_12_SAI4_TX_BCLK   0x030 0x070 0x0D8 0x7 1
#define IMXRT_PAD_GPIO_LPSR_12_LPSPI5_SCK   0x030 0x070 0x098 0x8 1
#define IMXRT_PAD_GPIO_LPSR_13_GPIO12_IO13   0x034 0x074 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_13_JTAG_MUX_MOD   0x034 0x074 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_13_MIC_BITSTREAM1   0x034 0x074 0x0B8 0x1 1
#define IMXRT_PAD_GPIO_LPSR_13_PIT2_TRIGGER1   0x034 0x074 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_13_GPIO_MUX6_IO13   0x034 0x074 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_13_SAI4_RX_DATA   0x034 0x074 0x0D0 0x7 1
#define IMXRT_PAD_GPIO_LPSR_13_LPSPI5_PCS0   0x034 0x074 0x094 0x8 1
#define IMXRT_PAD_GPIO_LPSR_14_JTAG_MUX_TCK   0x038 0x078 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_14_MIC_BITSTREAM2   0x038 0x078 0x0BC 0x1 1
#define IMXRT_PAD_GPIO_LPSR_14_PIT2_TRIGGER2   0x038 0x078 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_14_GPIO_MUX6_IO14   0x038 0x078 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_14_SAI4_RX_BCLK   0x038 0x078 0x0CC 0x7 1
#define IMXRT_PAD_GPIO_LPSR_14_LPSPI5_SOUT   0x038 0x078 0x0A0 0x8 1
#define IMXRT_PAD_GPIO_LPSR_14_GPIO12_IO14   0x038 0x078 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_15_GPIO12_IO15   0x03C 0x07C 0 0xA 0
#define IMXRT_PAD_GPIO_LPSR_15_JTAG_MUX_TMS   0x03C 0x07C 0 0x0 0
#define IMXRT_PAD_GPIO_LPSR_15_MIC_BITSTREAM3   0x03C 0x07C 0x0C0 0x1 1
#define IMXRT_PAD_GPIO_LPSR_15_PIT2_TRIGGER3   0x03C 0x07C 0 0x2 0
#define IMXRT_PAD_GPIO_LPSR_15_GPIO_MUX6_IO15   0x03C 0x07C 0 0x5 0
#define IMXRT_PAD_GPIO_LPSR_15_SAI4_RX_SYNC   0x03C 0x07C 0x0D4 0x7 1
#define IMXRT_PAD_GPIO_LPSR_15_LPSPI5_SIN   0x03C 0x07C 0x09C 0x8 1
#define IMXRT_PAD_WAKEUP_DIG_GPIO13_IO00   0x000 0x040 0 0x5 0
#define IMXRT_PAD_PMIC_ON_REQ_DIG_SNVS_LP_PMIC_ON_REQ   0x004 0x044 0 0x0 0
#define IMXRT_PAD_PMIC_ON_REQ_DIG_GPIO13_IO01   0x004 0x044 0 0x5 0
#define IMXRT_PAD_PMIC_STBY_REQ_DIG_CCM_PMIC_VSTBY_REQ   0x008 0x048 0 0x0 0
#define IMXRT_PAD_PMIC_STBY_REQ_DIG_GPIO13_IO02   0x008 0x048 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_00_DIG_SNVS_TAMPER0   0x00C 0x04C 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_00_DIG_GPIO13_IO03   0x00C 0x04C 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_01_DIG_SNVS_TAMPER1   0x010 0x050 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_01_DIG_GPIO13_IO04   0x010 0x050 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_02_DIG_SNVS_TAMPER2   0x014 0x054 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_02_DIG_GPIO13_IO05   0x014 0x054 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_03_DIG_SNVS_TAMPER3   0x018 0x058 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_03_DIG_GPIO13_IO06   0x018 0x058 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_04_DIG_SNVS_TAMPER4   0x01C 0x05C 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_04_DIG_GPIO13_IO07   0x01C 0x05C 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_05_DIG_SNVS_TAMPER5   0x020 0x060 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_05_DIG_GPIO13_IO08   0x020 0x060 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_06_DIG_SNVS_TAMPER6   0x024 0x064 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_06_DIG_GPIO13_IO09   0x024 0x064 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_07_DIG_SNVS_TAMPER7   0x028 0x068 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_07_DIG_GPIO13_IO10   0x028 0x068 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_08_DIG_SNVS_TAMPER8   0x02C 0x06C 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_08_DIG_GPIO13_IO11   0x02C 0x06C 0 0x5 0
#define IMXRT_PAD_GPIO_SNVS_09_DIG_SNVS_TAMPER9   0x030 0x070 0 0x0 0
#define IMXRT_PAD_GPIO_SNVS_09_DIG_GPIO13_IO12   0x030 0x070 0 0x5 0
#define IMXRT_PAD_TEST_MODE_DIG   0 0x034 0 0 0
#define IMXRT_PAD_POR_B_DIG   0 0x038 0 0 0
#define IMXRT_PAD_ONOFF_DIG   0 0x03C 0 0 0
#define IMXRT_PAD_GPIO_EMC_B1_00_SEMC_DATA00   0x010 0x254 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_00_FLEXPWM4_PWM0_A   0x010 0x254 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_00_GPIO_MUX1_IO00   0x010 0x254 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_00_FLEXIO1_D00   0x010 0x254 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_00_GPIO7_IO00   0x010 0x254 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_01_GPIO7_IO01   0x014 0x258 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_01_SEMC_DATA01   0x014 0x258 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_01_FLEXPWM4_PWM0_B   0x014 0x258 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_01_GPIO_MUX1_IO01   0x014 0x258 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_01_FLEXIO1_D01   0x014 0x258 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_02_SEMC_DATA02   0x018 0x25C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_02_FLEXPWM4_PWM1_A   0x018 0x25C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_02_GPIO_MUX1_IO02   0x018 0x25C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_02_FLEXIO1_D02   0x018 0x25C 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_02_GPIO7_IO02   0x018 0x25C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_03_SEMC_DATA03   0x01C 0x260 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_03_FLEXPWM4_PWM1_B   0x01C 0x260 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_03_GPIO_MUX1_IO03   0x01C 0x260 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_03_FLEXIO1_D03   0x01C 0x260 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_03_GPIO7_IO03   0x01C 0x260 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_04_GPIO7_IO04   0x020 0x264 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_04_SEMC_DATA04   0x020 0x264 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_04_FLEXPWM4_PWM2_A   0x020 0x264 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_04_GPIO_MUX1_IO04   0x020 0x264 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_04_FLEXIO1_D04   0x020 0x264 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_05_SEMC_DATA05   0x024 0x268 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_05_FLEXPWM4_PWM2_B   0x024 0x268 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_05_GPIO_MUX1_IO05   0x024 0x268 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_05_FLEXIO1_D05   0x024 0x268 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_05_GPIO7_IO05   0x024 0x268 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_06_SEMC_DATA06   0x028 0x26C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_06_FLEXPWM2_PWM0_A   0x028 0x26C 0x518 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_06_GPIO_MUX1_IO06   0x028 0x26C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_06_FLEXIO1_D06   0x028 0x26C 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_06_GPIO7_IO06   0x028 0x26C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_07_GPIO7_IO07   0x02C 0x270 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_07_SEMC_DATA07   0x02C 0x270 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_07_FLEXPWM2_PWM0_B   0x02C 0x270 0x524 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_07_GPIO_MUX1_IO07   0x02C 0x270 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_07_FLEXIO1_D07   0x02C 0x270 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_08_SEMC_DM00   0x030 0x274 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_08_FLEXPWM2_PWM1_A   0x030 0x274 0x51C 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_08_GPIO_MUX1_IO08   0x030 0x274 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_08_FLEXIO1_D08   0x030 0x274 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_08_GPIO7_IO08   0x030 0x274 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_09_SEMC_ADDR00   0x034 0x278 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_09_FLEXPWM2_PWM1_B   0x034 0x278 0x528 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_09_GPT5_CAPTURE1   0x034 0x278 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_09_GPIO_MUX1_IO09   0x034 0x278 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_09_FLEXIO1_D09   0x034 0x278 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_09_GPIO7_IO09   0x034 0x278 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_10_SEMC_ADDR01   0x038 0x27C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_10_FLEXPWM2_PWM2_A   0x038 0x27C 0x520 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_10_GPT5_CAPTURE2   0x038 0x27C 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_10_GPIO_MUX1_IO10   0x038 0x27C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_10_FLEXIO1_D10   0x038 0x27C 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_10_GPIO7_IO10   0x038 0x27C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_11_GPIO7_IO11   0x03C 0x280 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_11_SEMC_ADDR02   0x03C 0x280 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_11_FLEXPWM2_PWM2_B   0x03C 0x280 0x52C 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_11_GPT5_COMPARE1   0x03C 0x280 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_11_GPIO_MUX1_IO11   0x03C 0x280 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_11_FLEXIO1_D11   0x03C 0x280 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_12_SEMC_ADDR03   0x040 0x284 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_12_XBAR1_INOUT04   0x040 0x284 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_12_GPT5_COMPARE2   0x040 0x284 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_12_GPIO_MUX1_IO12   0x040 0x284 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_12_FLEXIO1_D12   0x040 0x284 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_12_GPIO7_IO12   0x040 0x284 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_13_SEMC_ADDR04   0x044 0x288 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_13_XBAR1_INOUT05   0x044 0x288 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_13_GPT5_COMPARE3   0x044 0x288 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_13_GPIO_MUX1_IO13   0x044 0x288 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_13_FLEXIO1_D13   0x044 0x288 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_13_GPIO7_IO13   0x044 0x288 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_14_GPIO7_IO14   0x048 0x28C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_14_SEMC_ADDR05   0x048 0x28C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_14_XBAR1_INOUT06   0x048 0x28C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_14_GPT5_CLK   0x048 0x28C 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_14_GPIO_MUX1_IO14   0x048 0x28C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_14_FLEXIO1_D14   0x048 0x28C 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_15_SEMC_ADDR06   0x04C 0x290 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_15_XBAR1_INOUT07   0x04C 0x290 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_15_GPIO_MUX1_IO15   0x04C 0x290 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_15_FLEXIO1_D15   0x04C 0x290 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_15_GPIO7_IO15   0x04C 0x290 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_16_SEMC_ADDR07   0x050 0x294 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_16_XBAR1_INOUT08   0x050 0x294 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_16_GPIO_MUX1_IO16   0x050 0x294 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_16_FLEXIO1_D16   0x050 0x294 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_16_GPIO7_IO16   0x050 0x294 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_17_GPIO7_IO17   0x054 0x298 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_17_SEMC_ADDR08   0x054 0x298 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_17_FLEXPWM4_PWM3_A   0x054 0x298 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_17_TMR1_TIMER0   0x054 0x298 0x63C 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_17_GPIO_MUX1_IO17   0x054 0x298 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_17_FLEXIO1_D17   0x054 0x298 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_18_SEMC_ADDR09   0x058 0x29C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_18_FLEXPWM4_PWM3_B   0x058 0x29C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_18_TMR2_TIMER0   0x058 0x29C 0x648 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_18_GPIO_MUX1_IO18   0x058 0x29C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_18_FLEXIO1_D18   0x058 0x29C 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_18_GPIO7_IO18   0x058 0x29C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_19_SEMC_ADDR11   0x05C 0x2A0 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_19_FLEXPWM2_PWM3_A   0x05C 0x2A0 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_19_TMR3_TIMER0   0x05C 0x2A0 0x654 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_19_GPIO_MUX1_IO19   0x05C 0x2A0 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_19_FLEXIO1_D19   0x05C 0x2A0 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_19_GPIO7_IO19   0x05C 0x2A0 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_20_SEMC_ADDR12   0x060 0x2A4 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_20_FLEXPWM2_PWM3_B   0x060 0x2A4 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_20_TMR4_TIMER0   0x060 0x2A4 0x660 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_20_GPIO_MUX1_IO20   0x060 0x2A4 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_20_FLEXIO1_D20   0x060 0x2A4 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_20_GPIO7_IO20   0x060 0x2A4 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_21_GPIO7_IO21   0x064 0x2A8 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_21_SEMC_BA0   0x064 0x2A8 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_21_FLEXPWM3_PWM3_A   0x064 0x2A8 0x53C 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_21_GPIO_MUX1_IO21   0x064 0x2A8 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_21_FLEXIO1_D21   0x064 0x2A8 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_22_GPIO7_IO22   0x068 0x2AC 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_22_SEMC_BA1   0x068 0x2AC 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_22_FLEXPWM3_PWM3_B   0x068 0x2AC 0x54C 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_22_GPIO_MUX1_IO22   0x068 0x2AC 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_22_FLEXIO1_D22   0x068 0x2AC 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_23_SEMC_ADDR10   0x06C 0x2B0 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_23_FLEXPWM1_PWM0_A   0x06C 0x2B0 0x500 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_23_GPIO_MUX1_IO23   0x06C 0x2B0 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_23_FLEXIO1_D23   0x06C 0x2B0 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_23_GPIO7_IO23   0x06C 0x2B0 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_24_GPIO7_IO24   0x070 0x2B4 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_24_SEMC_CAS   0x070 0x2B4 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_24_FLEXPWM1_PWM0_B   0x070 0x2B4 0x50C 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_24_GPIO_MUX1_IO24   0x070 0x2B4 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_24_FLEXIO1_D24   0x070 0x2B4 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_25_GPIO7_IO25   0x074 0x2B8 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_25_SEMC_RAS   0x074 0x2B8 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_25_FLEXPWM1_PWM1_A   0x074 0x2B8 0x504 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_25_GPIO_MUX1_IO25   0x074 0x2B8 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_25_FLEXIO1_D25   0x074 0x2B8 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_26_SEMC_CLK   0x078 0x2BC 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_26_FLEXPWM1_PWM1_B   0x078 0x2BC 0x510 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_26_GPIO_MUX1_IO26   0x078 0x2BC 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_26_FLEXIO1_D26   0x078 0x2BC 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_26_GPIO7_IO26   0x078 0x2BC 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_27_GPIO7_IO27   0x07C 0x2C0 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_27_SEMC_CKE   0x07C 0x2C0 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_27_FLEXPWM1_PWM2_A   0x07C 0x2C0 0x508 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_27_GPIO_MUX1_IO27   0x07C 0x2C0 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_27_FLEXIO1_D27   0x07C 0x2C0 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_28_GPIO7_IO28   0x080 0x2C4 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_28_SEMC_WE   0x080 0x2C4 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_28_FLEXPWM1_PWM2_B   0x080 0x2C4 0x514 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_28_GPIO_MUX1_IO28   0x080 0x2C4 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_28_FLEXIO1_D28   0x080 0x2C4 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_29_SEMC_CS0   0x084 0x2C8 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_29_FLEXPWM3_PWM0_A   0x084 0x2C8 0x530 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_29_GPIO_MUX1_IO29   0x084 0x2C8 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_29_FLEXIO1_D29   0x084 0x2C8 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_29_GPIO7_IO29   0x084 0x2C8 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_30_SEMC_DATA08   0x088 0x2CC 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_30_FLEXPWM3_PWM0_B   0x088 0x2CC 0x540 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_30_GPIO_MUX1_IO30   0x088 0x2CC 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_30_FLEXIO1_D30   0x088 0x2CC 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_30_GPIO7_IO30   0x088 0x2CC 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_31_GPIO7_IO31   0x08C 0x2D0 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_31_SEMC_DATA09   0x08C 0x2D0 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_31_FLEXPWM3_PWM1_A   0x08C 0x2D0 0x534 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_31_GPIO_MUX1_IO31   0x08C 0x2D0 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_31_FLEXIO1_D31   0x08C 0x2D0 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B1_32_GPIO8_IO00   0x090 0x2D4 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_32_SEMC_DATA10   0x090 0x2D4 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_32_FLEXPWM3_PWM1_B   0x090 0x2D4 0x544 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_32_GPIO_MUX2_IO00   0x090 0x2D4 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_33_SEMC_DATA11   0x094 0x2D8 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_33_FLEXPWM3_PWM2_A   0x094 0x2D8 0x538 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_33_GPIO_MUX2_IO01   0x094 0x2D8 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_33_GPIO8_IO01   0x094 0x2D8 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_34_GPIO8_IO02   0x098 0x2DC 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_34_SEMC_DATA12   0x098 0x2DC 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_34_FLEXPWM3_PWM2_B   0x098 0x2DC 0x548 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_34_GPIO_MUX2_IO02   0x098 0x2DC 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_35_GPIO8_IO03   0x09C 0x2E0 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_35_SEMC_DATA13   0x09C 0x2E0 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_35_XBAR1_INOUT09   0x09C 0x2E0 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_35_GPIO_MUX2_IO03   0x09C 0x2E0 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_36_SEMC_DATA14   0x0A0 0x2E4 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_36_XBAR1_INOUT10   0x0A0 0x2E4 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_36_GPIO_MUX2_IO04   0x0A0 0x2E4 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_36_GPIO8_IO04   0x0A0 0x2E4 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_37_GPIO8_IO05   0x0A4 0x2E8 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_37_SEMC_DATA15   0x0A4 0x2E8 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_37_XBAR1_INOUT11   0x0A4 0x2E8 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_37_GPIO_MUX2_IO05   0x0A4 0x2E8 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_38_GPIO8_IO06   0x0A8 0x2EC 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_38_SEMC_DM01   0x0A8 0x2EC 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_38_FLEXPWM1_PWM3_A   0x0A8 0x2EC 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_38_TMR1_TIMER1   0x0A8 0x2EC 0x640 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_38_GPIO_MUX2_IO06   0x0A8 0x2EC 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_39_SEMC_DQS   0x0AC 0x2F0 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_39_FLEXPWM1_PWM3_B   0x0AC 0x2F0 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_39_TMR2_TIMER1   0x0AC 0x2F0 0x64C 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_39_GPIO_MUX2_IO07   0x0AC 0x2F0 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_39_GPIO8_IO07   0x0AC 0x2F0 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_40_SEMC_RDY   0x0B0 0x2F4 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_40_XBAR1_INOUT12   0x0B0 0x2F4 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_40_MQS_RIGHT   0x0B0 0x2F4 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_40_LPUART6_TXD   0x0B0 0x2F4 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B1_40_GPIO_MUX2_IO08   0x0B0 0x2F4 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_40_ENET_1G_MDC   0x0B0 0x2F4 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B1_40_CCM_CLKO1   0x0B0 0x2F4 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B1_40_GPIO8_IO08   0x0B0 0x2F4 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_41_GPIO8_IO09   0x0B4 0x2F8 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B1_41_SEMC_CSX00   0x0B4 0x2F8 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B1_41_XBAR1_INOUT13   0x0B4 0x2F8 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B1_41_MQS_LEFT   0x0B4 0x2F8 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B1_41_LPUART6_RXD   0x0B4 0x2F8 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B1_41_FLEXSPI2_B_DATA07   0x0B4 0x2F8 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B1_41_GPIO_MUX2_IO09   0x0B4 0x2F8 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B1_41_ENET_1G_MDIO   0x0B4 0x2F8 0x4C8 0x7 0
#define IMXRT_PAD_GPIO_EMC_B1_41_CCM_CLKO2   0x0B4 0x2F8 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_00_SEMC_DATA16   0x0B8 0x2FC 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_00_CCM_ENET_REF_CLK_25M   0x0B8 0x2FC 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_00_TMR3_TIMER1   0x0B8 0x2FC 0x658 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_00_LPUART6_CTS_B   0x0B8 0x2FC 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_00_FLEXSPI2_B_DATA06   0x0B8 0x2FC 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_00_GPIO_MUX2_IO10   0x0B8 0x2FC 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_00_XBAR1_INOUT20   0x0B8 0x2FC 0x6D8 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_00_ENET_QOS_1588_EVENT1_OUT   0x0B8 0x2FC 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_00_LPSPI1_SCK   0x0B8 0x2FC 0x5D0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_00_LPI2C2_SCL   0x0B8 0x2FC 0x5B4 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_00_GPIO8_IO10   0x0B8 0x2FC 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_00_FLEXPWM3_PWM0_A   0x0B8 0x2FC 0x530 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_01_SEMC_DATA17   0x0BC 0x300 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_01_USDHC2_CD_B   0x0BC 0x300 0x6D0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_01_TMR4_TIMER1   0x0BC 0x300 0x664 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_01_LPUART6_RTS_B   0x0BC 0x300 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_01_FLEXSPI2_B_DATA05   0x0BC 0x300 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_01_GPIO_MUX2_IO11   0x0BC 0x300 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_01_XBAR1_INOUT21   0x0BC 0x300 0x6DC 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_01_ENET_QOS_1588_EVENT1_IN   0x0BC 0x300 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_01_LPSPI1_PCS0   0x0BC 0x300 0x5CC 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_01_LPI2C2_SDA   0x0BC 0x300 0x5B8 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_01_GPIO8_IO11   0x0BC 0x300 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_01_FLEXPWM3_PWM0_B   0x0BC 0x300 0x540 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_02_SEMC_DATA18   0x0C0 0x304 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_02_USDHC2_WP   0x0C0 0x304 0x6D4 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_02_VIDEO_MUX_CSI_DATA23   0x0C0 0x304 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_02_FLEXSPI2_B_DATA04   0x0C0 0x304 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_02_GPIO_MUX2_IO12   0x0C0 0x304 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_02_XBAR1_INOUT22   0x0C0 0x304 0x6E0 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_02_ENET_QOS_1588_EVENT1_AUX_IN   0x0C0 0x304 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_02_LPSPI1_SOUT   0x0C0 0x304 0x5D8 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_02_GPIO8_IO12   0x0C0 0x304 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_02_FLEXPWM3_PWM1_A   0x0C0 0x304 0x534 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_03_SEMC_DATA19   0x0C4 0x308 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_03_USDHC2_VSELECT   0x0C4 0x308 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_03_VIDEO_MUX_CSI_DATA22   0x0C4 0x308 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_03_FLEXSPI2_B_DATA03   0x0C4 0x308 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_03_GPIO_MUX2_IO13   0x0C4 0x308 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_03_XBAR1_INOUT23   0x0C4 0x308 0x6E4 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_03_ENET_1G_TX_DATA03   0x0C4 0x308 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_03_LPSPI1_SIN   0x0C4 0x308 0x5D4 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_03_GPIO8_IO13   0x0C4 0x308 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_03_FLEXPWM3_PWM1_B   0x0C4 0x308 0x544 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_04_SEMC_DATA20   0x0C8 0x30C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_04_USDHC2_RESET_B   0x0C8 0x30C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_04_SAI2_MCLK   0x0C8 0x30C 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_04_VIDEO_MUX_CSI_DATA21   0x0C8 0x30C 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_04_FLEXSPI2_B_DATA02   0x0C8 0x30C 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_04_GPIO_MUX2_IO14   0x0C8 0x30C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_04_XBAR1_INOUT24   0x0C8 0x30C 0x6E8 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_04_ENET_1G_TX_DATA02   0x0C8 0x30C 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_04_LPSPI3_SCK   0x0C8 0x30C 0x600 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_04_GPIO8_IO14   0x0C8 0x30C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_04_FLEXPWM3_PWM2_A   0x0C8 0x30C 0x538 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_05_SEMC_DATA21   0x0CC 0x310 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_05_GPT3_CLK   0x0CC 0x310 0x598 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_05_SAI2_RX_SYNC   0x0CC 0x310 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_05_VIDEO_MUX_CSI_DATA20   0x0CC 0x310 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_05_FLEXSPI2_B_DATA01   0x0CC 0x310 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_05_GPIO_MUX2_IO15   0x0CC 0x310 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_05_XBAR1_INOUT25   0x0CC 0x310 0x6EC 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_05_ENET_1G_RX_CLK   0x0CC 0x310 0x4CC 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_05_LPSPI3_PCS0   0x0CC 0x310 0x5F0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_05_PIT1_TRIGGER0   0x0CC 0x310 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_05_GPIO8_IO15   0x0CC 0x310 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_05_FLEXPWM3_PWM2_B   0x0CC 0x310 0x548 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_06_SEMC_DATA22   0x0D0 0x314 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_06_GPT3_CAPTURE1   0x0D0 0x314 0x590 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_06_GPIO8_IO16   0x0D0 0x314 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_06_SAI2_RX_BCLK   0x0D0 0x314 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_06_FLEXPWM3_PWM3_A   0x0D0 0x314 0x53C 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_06_VIDEO_MUX_CSI_DATA19   0x0D0 0x314 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_06_FLEXSPI2_B_DATA00   0x0D0 0x314 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_06_GPIO_MUX2_IO16   0x0D0 0x314 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_06_XBAR1_INOUT26   0x0D0 0x314 0x6F0 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_06_ENET_1G_TX_ER   0x0D0 0x314 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_06_LPSPI3_SOUT   0x0D0 0x314 0x608 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_06_PIT1_TRIGGER1   0x0D0 0x314 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_07_SEMC_DATA23   0x0D4 0x318 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_07_GPT3_CAPTURE2   0x0D4 0x318 0x594 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_07_SAI2_RX_DATA   0x0D4 0x318 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_07_VIDEO_MUX_CSI_DATA18   0x0D4 0x318 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_07_FLEXSPI2_B_DQS   0x0D4 0x318 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_07_GPIO_MUX2_IO17   0x0D4 0x318 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_07_XBAR1_INOUT27   0x0D4 0x318 0x6F4 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_07_ENET_1G_RX_DATA03   0x0D4 0x318 0x4DC 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_07_LPSPI3_SIN   0x0D4 0x318 0x604 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_07_PIT1_TRIGGER2   0x0D4 0x318 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_07_GPIO8_IO17   0x0D4 0x318 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_07_FLEXPWM3_PWM3_B   0x0D4 0x318 0x54C 0xB 1
#define IMXRT_PAD_GPIO_EMC_B2_08_SEMC_DM02   0x0D8 0x31C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_08_GPT3_COMPARE1   0x0D8 0x31C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_08_SAI2_TX_DATA   0x0D8 0x31C 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_08_VIDEO_MUX_CSI_DATA17   0x0D8 0x31C 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_08_FLEXSPI2_B_SS0_B   0x0D8 0x31C 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_08_GPIO_MUX2_IO18   0x0D8 0x31C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_08_XBAR1_INOUT28   0x0D8 0x31C 0x6F8 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_08_ENET_1G_RX_DATA02   0x0D8 0x31C 0x4D8 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_08_LPSPI3_PCS1   0x0D8 0x31C 0x5F4 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_08_PIT1_TRIGGER3   0x0D8 0x31C 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_08_GPIO8_IO18   0x0D8 0x31C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_09_GPIO8_IO19   0x0DC 0x320 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_09_SEMC_DATA24   0x0DC 0x320 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_09_GPT3_COMPARE2   0x0DC 0x320 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_09_SAI2_TX_BCLK   0x0DC 0x320 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_09_VIDEO_MUX_CSI_DATA16   0x0DC 0x320 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_09_FLEXSPI2_B_SCLK   0x0DC 0x320 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_09_GPIO_MUX2_IO19   0x0DC 0x320 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_09_XBAR1_INOUT29   0x0DC 0x320 0x6FC 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_09_ENET_1G_CRS   0x0DC 0x320 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_09_LPSPI3_PCS2   0x0DC 0x320 0x5F8 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_09_TMR1_TIMER0   0x0DC 0x320 0x63C 0x9 1
#define IMXRT_PAD_GPIO_EMC_B2_10_GPIO8_IO20   0x0E0 0x324 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_10_SEMC_DATA25   0x0E0 0x324 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_10_GPT3_COMPARE3   0x0E0 0x324 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_10_SAI2_TX_SYNC   0x0E0 0x324 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_10_VIDEO_MUX_CSI_FIELD   0x0E0 0x324 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_10_FLEXSPI2_A_SCLK   0x0E0 0x324 0x58C 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_10_GPIO_MUX2_IO20   0x0E0 0x324 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_10_XBAR1_INOUT30   0x0E0 0x324 0x700 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_10_ENET_1G_COL   0x0E0 0x324 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_10_LPSPI3_PCS3   0x0E0 0x324 0x5FC 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_10_TMR1_TIMER1   0x0E0 0x324 0x640 0x9 1
#define IMXRT_PAD_GPIO_EMC_B2_11_SEMC_DATA26   0x0E4 0x328 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_11_SPDIF_IN   0x0E4 0x328 0x6B4 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_11_ENET_1G_TX_DATA00   0x0E4 0x328 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_11_SAI3_RX_SYNC   0x0E4 0x328 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_11_FLEXSPI2_A_SS0_B   0x0E4 0x328 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_11_GPIO_MUX2_IO21   0x0E4 0x328 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_11_XBAR1_INOUT31   0x0E4 0x328 0x704 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_11_EMVSIM1_IO   0x0E4 0x328 0x69C 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_11_TMR1_TIMER2   0x0E4 0x328 0x644 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_11_GPIO8_IO21   0x0E4 0x328 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_12_SEMC_DATA27   0x0E8 0x32C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_12_SPDIF_OUT   0x0E8 0x32C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_12_ENET_1G_TX_DATA01   0x0E8 0x32C 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_12_SAI3_RX_BCLK   0x0E8 0x32C 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_12_FLEXSPI2_A_DQS   0x0E8 0x32C 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_12_GPIO_MUX2_IO22   0x0E8 0x32C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_12_XBAR1_INOUT32   0x0E8 0x32C 0x708 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_12_EMVSIM1_CLK   0x0E8 0x32C 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_12_TMR1_TIMER3   0x0E8 0x32C 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_12_GPIO8_IO22   0x0E8 0x32C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_13_GPIO8_IO23   0x0EC 0x330 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_13_SEMC_DATA28   0x0EC 0x330 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_13_ENET_1G_TX_EN   0x0EC 0x330 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_13_SAI3_RX_DATA   0x0EC 0x330 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_13_FLEXSPI2_A_DATA00   0x0EC 0x330 0x57C 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_13_GPIO_MUX2_IO23   0x0EC 0x330 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_13_XBAR1_INOUT33   0x0EC 0x330 0x70C 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_13_EMVSIM1_RST   0x0EC 0x330 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_13_TMR2_TIMER0   0x0EC 0x330 0x648 0x9 1
#define IMXRT_PAD_GPIO_EMC_B2_14_SEMC_DATA29   0x0F0 0x334 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_14_ENET_1G_TX_CLK_IO   0x0F0 0x334 0x4E8 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_14_SAI3_TX_DATA   0x0F0 0x334 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_14_FLEXSPI2_A_DATA01   0x0F0 0x334 0x580 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_14_GPIO_MUX2_IO24   0x0F0 0x334 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_14_XBAR1_INOUT34   0x0F0 0x334 0x710 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_14_SFA_ipp_do_atx_clk_under_test   0x0F0 0x334 0 0x7 0
#define IMXRT_PAD_GPIO_EMC_B2_14_EMVSIM1_SVEN   0x0F0 0x334 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_14_TMR2_TIMER1   0x0F0 0x334 0x64C 0x9 1
#define IMXRT_PAD_GPIO_EMC_B2_14_GPIO8_IO24   0x0F0 0x334 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_15_SEMC_DATA30   0x0F4 0x338 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_15_ENET_1G_RX_DATA00   0x0F4 0x338 0x4D0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_15_SAI3_TX_BCLK   0x0F4 0x338 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_15_FLEXSPI2_A_DATA02   0x0F4 0x338 0x584 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_15_GPIO_MUX2_IO25   0x0F4 0x338 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_15_XBAR1_INOUT35   0x0F4 0x338 0x714 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_15_EMVSIM1_PD   0x0F4 0x338 0x6A0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_15_TMR2_TIMER2   0x0F4 0x338 0x650 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_15_GPIO8_IO25   0x0F4 0x338 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_16_GPIO8_IO26   0x0F8 0x33C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_16_SEMC_DATA31   0x0F8 0x33C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_16_XBAR1_INOUT14   0x0F8 0x33C 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_16_ENET_1G_RX_DATA01   0x0F8 0x33C 0x4D4 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_16_SAI3_TX_SYNC   0x0F8 0x33C 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_16_FLEXSPI2_A_DATA03   0x0F8 0x33C 0x588 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_16_GPIO_MUX2_IO26   0x0F8 0x33C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_16_EMVSIM1_POWER_FAIL   0x0F8 0x33C 0x6A4 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_16_TMR2_TIMER3   0x0F8 0x33C 0 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_17_SEMC_DM03   0x0FC 0x340 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_17_XBAR1_INOUT15   0x0FC 0x340 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_17_ENET_1G_RX_EN   0x0FC 0x340 0x4E0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_17_SAI3_MCLK   0x0FC 0x340 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_17_FLEXSPI2_A_DATA04   0x0FC 0x340 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_17_GPIO_MUX2_IO27   0x0FC 0x340 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_17_WDOG1_ANY   0x0FC 0x340 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_17_TMR3_TIMER0   0x0FC 0x340 0x654 0x9 1
#define IMXRT_PAD_GPIO_EMC_B2_17_GPIO8_IO27   0x0FC 0x340 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_18_SEMC_DQS4   0x100 0x344 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_18_XBAR1_INOUT16   0x100 0x344 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_18_ENET_1G_RX_ER   0x100 0x344 0x4E4 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_18_EWM_OUT_B   0x100 0x344 0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_18_FLEXSPI2_A_DATA05   0x100 0x344 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_18_GPIO_MUX2_IO28   0x100 0x344 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_18_FLEXSPI1_A_DQS   0x100 0x344 0x550 0x6 0
#define IMXRT_PAD_GPIO_EMC_B2_18_WDOG1_B   0x100 0x344 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_18_TMR3_TIMER1   0x100 0x344 0x658 0x9 1
#define IMXRT_PAD_GPIO_EMC_B2_18_GPIO8_IO28   0x100 0x344 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_19_GPIO8_IO29   0x104 0x348 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_19_SEMC_CLKX00   0x104 0x348 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_MDC   0x104 0x348 0 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_1G_MDC   0x104 0x348 0 0x2 0
#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_1G_REF_CLK   0x104 0x348 0x4C4 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_19_FLEXSPI2_A_DATA06   0x104 0x348 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_19_GPIO_MUX2_IO29   0x104 0x348 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_19_ENET_QOS_MDC   0x104 0x348 0 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_19_TMR3_TIMER2   0x104 0x348 0x65C 0x9 0
#define IMXRT_PAD_GPIO_EMC_B2_20_GPIO8_IO30   0x108 0x34C 0 0xA 0
#define IMXRT_PAD_GPIO_EMC_B2_20_SEMC_CLKX01   0x108 0x34C 0 0x0 0
#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_MDIO   0x108 0x34C 0x4AC 0x1 0
#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_1G_MDIO   0x108 0x34C 0x4C8 0x2 1
#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_QOS_REF_CLK   0x108 0x34C 0x4A0 0x3 0
#define IMXRT_PAD_GPIO_EMC_B2_20_FLEXSPI2_A_DATA07   0x108 0x34C 0 0x4 0
#define IMXRT_PAD_GPIO_EMC_B2_20_GPIO_MUX2_IO30   0x108 0x34C 0 0x5 0
#define IMXRT_PAD_GPIO_EMC_B2_20_ENET_QOS_MDIO   0x108 0x34C 0x4EC 0x8 0
#define IMXRT_PAD_GPIO_EMC_B2_20_TMR3_TIMER3   0x108 0x34C 0 0x9 0
#define IMXRT_PAD_GPIO_AD_00_GPIO8_IO31   0x10C 0x350 0 0xA 0
#define IMXRT_PAD_GPIO_AD_00_EMVSIM1_IO   0x10C 0x350 0x69C 0x0 1
#define IMXRT_PAD_GPIO_AD_00_FLEXCAN2_TX   0x10C 0x350 0 0x1 0
#define IMXRT_PAD_GPIO_AD_00_ENET_1G_1588_EVENT1_IN   0x10C 0x350 0 0x2 0
#define IMXRT_PAD_GPIO_AD_00_GPT2_CAPTURE1   0x10C 0x350 0 0x3 0
#define IMXRT_PAD_GPIO_AD_00_FLEXPWM1_PWM0_A   0x10C 0x350 0x500 0x4 1
#define IMXRT_PAD_GPIO_AD_00_GPIO_MUX2_IO31   0x10C 0x350 0 0x5 0
#define IMXRT_PAD_GPIO_AD_00_LPUART7_TXD   0x10C 0x350 0x630 0x6 0
#define IMXRT_PAD_GPIO_AD_00_FLEXIO2_D00   0x10C 0x350 0 0x8 0
#define IMXRT_PAD_GPIO_AD_00_FLEXSPI2_B_SS1_B   0x10C 0x350 0 0x9 0
#define IMXRT_PAD_GPIO_AD_01_GPIO9_IO00   0x110 0x354 0 0xA 0
#define IMXRT_PAD_GPIO_AD_01_EMVSIM1_CLK   0x110 0x354 0 0x0 0
#define IMXRT_PAD_GPIO_AD_01_FLEXCAN2_RX   0x110 0x354 0x49C 0x1 0
#define IMXRT_PAD_GPIO_AD_01_ENET_1G_1588_EVENT1_OUT   0x110 0x354 0 0x2 0
#define IMXRT_PAD_GPIO_AD_01_GPT2_CAPTURE2   0x110 0x354 0 0x3 0
#define IMXRT_PAD_GPIO_AD_01_FLEXPWM1_PWM0_B   0x110 0x354 0x50C 0x4 1
#define IMXRT_PAD_GPIO_AD_01_GPIO_MUX3_IO00   0x110 0x354 0 0x5 0
#define IMXRT_PAD_GPIO_AD_01_LPUART7_RXD   0x110 0x354 0x62C 0x6 0
#define IMXRT_PAD_GPIO_AD_01_FLEXIO2_D01   0x110 0x354 0 0x8 0
#define IMXRT_PAD_GPIO_AD_01_FLEXSPI2_A_SS1_B   0x110 0x354 0 0x9 0
#define IMXRT_PAD_GPIO_AD_02_GPIO9_IO01   0x114 0x358 0 0xA 0
#define IMXRT_PAD_GPIO_AD_02_EMVSIM1_RST   0x114 0x358 0 0x0 0
#define IMXRT_PAD_GPIO_AD_02_LPUART7_CTS_B   0x114 0x358 0 0x1 0
#define IMXRT_PAD_GPIO_AD_02_ENET_1G_1588_EVENT2_IN   0x114 0x358 0 0x2 0
#define IMXRT_PAD_GPIO_AD_02_GPT2_COMPARE1   0x114 0x358 0 0x3 0
#define IMXRT_PAD_GPIO_AD_02_FLEXPWM1_PWM1_A   0x114 0x358 0x504 0x4 1
#define IMXRT_PAD_GPIO_AD_02_GPIO_MUX3_IO01   0x114 0x358 0 0x5 0
#define IMXRT_PAD_GPIO_AD_02_LPUART8_TXD   0x114 0x358 0x638 0x6 0
#define IMXRT_PAD_GPIO_AD_02_FLEXIO2_D02   0x114 0x358 0 0x8 0
#define IMXRT_PAD_GPIO_AD_02_VIDEO_MUX_EXT_DCIC1   0x114 0x358 0 0x9 0
#define IMXRT_PAD_GPIO_AD_03_GPIO9_IO02   0x118 0x35C 0 0xA 0
#define IMXRT_PAD_GPIO_AD_03_EMVSIM1_SVEN   0x118 0x35C 0 0x0 0
#define IMXRT_PAD_GPIO_AD_03_LPUART7_RTS_B   0x118 0x35C 0 0x1 0
#define IMXRT_PAD_GPIO_AD_03_ENET_1G_1588_EVENT2_OUT   0x118 0x35C 0 0x2 0
#define IMXRT_PAD_GPIO_AD_03_GPT2_COMPARE2   0x118 0x35C 0 0x3 0
#define IMXRT_PAD_GPIO_AD_03_FLEXPWM1_PWM1_B   0x118 0x35C 0x510 0x4 1
#define IMXRT_PAD_GPIO_AD_03_GPIO_MUX3_IO02   0x118 0x35C 0 0x5 0
#define IMXRT_PAD_GPIO_AD_03_LPUART8_RXD   0x118 0x35C 0x634 0x6 0
#define IMXRT_PAD_GPIO_AD_03_FLEXIO2_D03   0x118 0x35C 0 0x8 0
#define IMXRT_PAD_GPIO_AD_03_VIDEO_MUX_EXT_DCIC2   0x118 0x35C 0 0x9 0
#define IMXRT_PAD_GPIO_AD_04_EMVSIM1_PD   0x11C 0x360 0x6A0 0x0 1
#define IMXRT_PAD_GPIO_AD_04_LPUART8_CTS_B   0x11C 0x360 0 0x1 0
#define IMXRT_PAD_GPIO_AD_04_ENET_1G_1588_EVENT3_IN   0x11C 0x360 0 0x2 0
#define IMXRT_PAD_GPIO_AD_04_GPT2_COMPARE3   0x11C 0x360 0 0x3 0
#define IMXRT_PAD_GPIO_AD_04_FLEXPWM1_PWM2_A   0x11C 0x360 0x508 0x4 1
#define IMXRT_PAD_GPIO_AD_04_GPIO_MUX3_IO03   0x11C 0x360 0 0x5 0
#define IMXRT_PAD_GPIO_AD_04_WDOG1_B   0x11C 0x360 0 0x6 0
#define IMXRT_PAD_GPIO_AD_04_FLEXIO2_D04   0x11C 0x360 0 0x8 0
#define IMXRT_PAD_GPIO_AD_04_TMR4_TIMER0   0x11C 0x360 0x660 0x9 1
#define IMXRT_PAD_GPIO_AD_04_GPIO9_IO03   0x11C 0x360 0 0xA 0
#define IMXRT_PAD_GPIO_AD_05_EMVSIM1_POWER_FAIL   0x120 0x364 0x6A4 0x0 1
#define IMXRT_PAD_GPIO_AD_05_LPUART8_RTS_B   0x120 0x364 0 0x1 0
#define IMXRT_PAD_GPIO_AD_05_ENET_1G_1588_EVENT3_OUT   0x120 0x364 0 0x2 0
#define IMXRT_PAD_GPIO_AD_05_GPT2_CLK   0x120 0x364 0 0x3 0
#define IMXRT_PAD_GPIO_AD_05_FLEXPWM1_PWM2_B   0x120 0x364 0x514 0x4 1
#define IMXRT_PAD_GPIO_AD_05_GPIO_MUX3_IO04   0x120 0x364 0 0x5 0
#define IMXRT_PAD_GPIO_AD_05_WDOG2_B   0x120 0x364 0 0x6 0
#define IMXRT_PAD_GPIO_AD_05_FLEXIO2_D05   0x120 0x364 0 0x8 0
#define IMXRT_PAD_GPIO_AD_05_TMR4_TIMER1   0x120 0x364 0x664 0x9 1
#define IMXRT_PAD_GPIO_AD_05_GPIO9_IO04   0x120 0x364 0 0xA 0
#define IMXRT_PAD_GPIO_AD_06_USB_OTG2_OC   0x124 0x368 0x6B8 0x0 0
#define IMXRT_PAD_GPIO_AD_06_FLEXCAN1_TX   0x124 0x368 0 0x1 0
#define IMXRT_PAD_GPIO_AD_06_EMVSIM2_IO   0x124 0x368 0x6A8 0x2 0
#define IMXRT_PAD_GPIO_AD_06_GPT3_CAPTURE1   0x124 0x368 0x590 0x3 1
#define IMXRT_PAD_GPIO_AD_06_VIDEO_MUX_CSI_DATA15   0x124 0x368 0 0x4 0
#define IMXRT_PAD_GPIO_AD_06_GPIO_MUX3_IO05   0x124 0x368 0 0x5 0
#define IMXRT_PAD_GPIO_AD_06_ENET_1588_EVENT1_IN   0x124 0x368 0 0x6 0
#define IMXRT_PAD_GPIO_AD_06_FLEXIO2_D06   0x124 0x368 0 0x8 0
#define IMXRT_PAD_GPIO_AD_06_TMR4_TIMER2   0x124 0x368 0x668 0x9 0
#define IMXRT_PAD_GPIO_AD_06_GPIO9_IO05   0x124 0x368 0 0xA 0
#define IMXRT_PAD_GPIO_AD_06_FLEXPWM1_PWM0_X   0x124 0x368 0 0xB 0
#define IMXRT_PAD_GPIO_AD_07_USB_OTG2_PWR   0x128 0x36C 0 0x0 0
#define IMXRT_PAD_GPIO_AD_07_FLEXCAN1_RX   0x128 0x36C 0x498 0x1 0
#define IMXRT_PAD_GPIO_AD_07_EMVSIM2_CLK   0x128 0x36C 0 0x2 0
#define IMXRT_PAD_GPIO_AD_07_GPT3_CAPTURE2   0x128 0x36C 0x594 0x3 1
#define IMXRT_PAD_GPIO_AD_07_VIDEO_MUX_CSI_DATA14   0x128 0x36C 0 0x4 0
#define IMXRT_PAD_GPIO_AD_07_GPIO_MUX3_IO06   0x128 0x36C 0 0x5 0
#define IMXRT_PAD_GPIO_AD_07_ENET_1588_EVENT1_OUT   0x128 0x36C 0 0x6 0
#define IMXRT_PAD_GPIO_AD_07_FLEXIO2_D07   0x128 0x36C 0 0x8 0
#define IMXRT_PAD_GPIO_AD_07_TMR4_TIMER3   0x128 0x36C 0 0x9 0
#define IMXRT_PAD_GPIO_AD_07_GPIO9_IO06   0x128 0x36C 0 0xA 0
#define IMXRT_PAD_GPIO_AD_07_FLEXPWM1_PWM1_X   0x128 0x36C 0 0xB 0
#define IMXRT_PAD_GPIO_AD_08_USBPHY2_OTG_ID   0x12C 0x370 0x6C4 0x0 0
#define IMXRT_PAD_GPIO_AD_08_LPI2C1_SCL   0x12C 0x370 0x5AC 0x1 0
#define IMXRT_PAD_GPIO_AD_08_EMVSIM2_RST   0x12C 0x370 0 0x2 0
#define IMXRT_PAD_GPIO_AD_08_GPT3_COMPARE1   0x12C 0x370 0 0x3 0
#define IMXRT_PAD_GPIO_AD_08_VIDEO_MUX_CSI_DATA13   0x12C 0x370 0 0x4 0
#define IMXRT_PAD_GPIO_AD_08_GPIO_MUX3_IO07   0x12C 0x370 0 0x5 0
#define IMXRT_PAD_GPIO_AD_08_ENET_1588_EVENT2_IN   0x12C 0x370 0 0x6 0
#define IMXRT_PAD_GPIO_AD_08_FLEXIO2_D08   0x12C 0x370 0 0x8 0
#define IMXRT_PAD_GPIO_AD_08_GPIO9_IO07   0x12C 0x370 0 0xA 0
#define IMXRT_PAD_GPIO_AD_08_FLEXPWM1_PWM2_X   0x12C 0x370 0 0xB 0
#define IMXRT_PAD_GPIO_AD_09_USBPHY1_OTG_ID   0x130 0x374 0x6C0 0x0 0
#define IMXRT_PAD_GPIO_AD_09_LPI2C1_SDA   0x130 0x374 0x5B0 0x1 0
#define IMXRT_PAD_GPIO_AD_09_EMVSIM2_SVEN   0x130 0x374 0 0x2 0
#define IMXRT_PAD_GPIO_AD_09_GPT3_COMPARE2   0x130 0x374 0 0x3 0
#define IMXRT_PAD_GPIO_AD_09_VIDEO_MUX_CSI_DATA12   0x130 0x374 0 0x4 0
#define IMXRT_PAD_GPIO_AD_09_GPIO_MUX3_IO08   0x130 0x374 0 0x5 0
#define IMXRT_PAD_GPIO_AD_09_ENET_1588_EVENT2_OUT   0x130 0x374 0 0x6 0
#define IMXRT_PAD_GPIO_AD_09_FLEXIO2_D09   0x130 0x374 0 0x8 0
#define IMXRT_PAD_GPIO_AD_09_GPIO9_IO08   0x130 0x374 0 0xA 0
#define IMXRT_PAD_GPIO_AD_09_FLEXPWM1_PWM3_X   0x130 0x374 0 0xB 0
#define IMXRT_PAD_GPIO_AD_10_USB_OTG1_PWR   0x134 0x378 0 0x0 0
#define IMXRT_PAD_GPIO_AD_10_LPI2C1_SCLS   0x134 0x378 0 0x1 0
#define IMXRT_PAD_GPIO_AD_10_EMVSIM2_PD   0x134 0x378 0x6AC 0x2 0
#define IMXRT_PAD_GPIO_AD_10_GPT3_COMPARE3   0x134 0x378 0 0x3 0
#define IMXRT_PAD_GPIO_AD_10_VIDEO_MUX_CSI_DATA11   0x134 0x378 0 0x4 0
#define IMXRT_PAD_GPIO_AD_10_GPIO_MUX3_IO09   0x134 0x378 0 0x5 0
#define IMXRT_PAD_GPIO_AD_10_ENET_1588_EVENT3_IN   0x134 0x378 0 0x6 0
#define IMXRT_PAD_GPIO_AD_10_FLEXIO2_D10   0x134 0x378 0 0x8 0
#define IMXRT_PAD_GPIO_AD_10_GPIO9_IO09   0x134 0x378 0 0xA 0
#define IMXRT_PAD_GPIO_AD_10_FLEXPWM2_PWM0_X   0x134 0x378 0 0xB 0
#define IMXRT_PAD_GPIO_AD_11_USB_OTG1_OC   0x138 0x37C 0x6BC 0x0 0
#define IMXRT_PAD_GPIO_AD_11_LPI2C1_SDAS   0x138 0x37C 0 0x1 0
#define IMXRT_PAD_GPIO_AD_11_EMVSIM2_POWER_FAIL   0x138 0x37C 0x6B0 0x2 0
#define IMXRT_PAD_GPIO_AD_11_GPT3_CLK   0x138 0x37C 0x598 0x3 1
#define IMXRT_PAD_GPIO_AD_11_VIDEO_MUX_CSI_DATA10   0x138 0x37C 0 0x4 0
#define IMXRT_PAD_GPIO_AD_11_GPIO_MUX3_IO10   0x138 0x37C 0 0x5 0
#define IMXRT_PAD_GPIO_AD_11_ENET_1588_EVENT3_OUT   0x138 0x37C 0 0x6 0
#define IMXRT_PAD_GPIO_AD_11_FLEXIO2_D11   0x138 0x37C 0 0x8 0
#define IMXRT_PAD_GPIO_AD_11_GPIO9_IO10   0x138 0x37C 0 0xA 0
#define IMXRT_PAD_GPIO_AD_11_FLEXPWM2_PWM1_X   0x138 0x37C 0 0xB 0
#define IMXRT_PAD_GPIO_AD_12_SPDIF_LOCK   0x13C 0x380 0 0x0 0
#define IMXRT_PAD_GPIO_AD_12_LPI2C1_HREQ   0x13C 0x380 0 0x1 0
#define IMXRT_PAD_GPIO_AD_12_GPT1_CAPTURE1   0x13C 0x380 0 0x2 0
#define IMXRT_PAD_GPIO_AD_12_FLEXSPI1_B_DATA03   0x13C 0x380 0x570 0x3 0
#define IMXRT_PAD_GPIO_AD_12_VIDEO_MUX_CSI_PIXCLK   0x13C 0x380 0 0x4 0
#define IMXRT_PAD_GPIO_AD_12_GPIO_MUX3_IO11   0x13C 0x380 0 0x5 0
#define IMXRT_PAD_GPIO_AD_12_ENET_TX_DATA03   0x13C 0x380 0 0x6 0
#define IMXRT_PAD_GPIO_AD_12_FLEXIO2_D12   0x13C 0x380 0 0x8 0
#define IMXRT_PAD_GPIO_AD_12_EWM_OUT_B   0x13C 0x380 0 0x9 0
#define IMXRT_PAD_GPIO_AD_12_GPIO9_IO11   0x13C 0x380 0 0xA 0
#define IMXRT_PAD_GPIO_AD_12_FLEXPWM2_PWM2_X   0x13C 0x380 0 0xB 0
#define IMXRT_PAD_GPIO_AD_13_SPDIF_SR_CLK   0x140 0x384 0 0x0 0
#define IMXRT_PAD_GPIO_AD_13_PIT1_TRIGGER0   0x140 0x384 0 0x1 0
#define IMXRT_PAD_GPIO_AD_13_GPT1_CAPTURE2   0x140 0x384 0 0x2 0
#define IMXRT_PAD_GPIO_AD_13_FLEXSPI1_B_DATA02   0x140 0x384 0x56C 0x3 0
#define IMXRT_PAD_GPIO_AD_13_VIDEO_MUX_CSI_MCLK   0x140 0x384 0 0x4 0
#define IMXRT_PAD_GPIO_AD_13_GPIO_MUX3_IO12   0x140 0x384 0 0x5 0
#define IMXRT_PAD_GPIO_AD_13_ENET_TX_DATA02   0x140 0x384 0 0x6 0
#define IMXRT_PAD_GPIO_AD_13_FLEXIO2_D13   0x140 0x384 0 0x8 0
#define IMXRT_PAD_GPIO_AD_13_REF_CLK_32K   0x140 0x384 0 0x9 0
#define IMXRT_PAD_GPIO_AD_13_GPIO9_IO12   0x140 0x384 0 0xA 0
#define IMXRT_PAD_GPIO_AD_13_FLEXPWM2_PWM3_X   0x140 0x384 0 0xB 0
#define IMXRT_PAD_GPIO_AD_14_SPDIF_EXT_CLK   0x144 0x388 0 0x0 0
#define IMXRT_PAD_GPIO_AD_14_REF_CLK_24M   0x144 0x388 0 0x1 0
#define IMXRT_PAD_GPIO_AD_14_GPT1_COMPARE1   0x144 0x388 0 0x2 0
#define IMXRT_PAD_GPIO_AD_14_FLEXSPI1_B_DATA01   0x144 0x388 0x568 0x3 0
#define IMXRT_PAD_GPIO_AD_14_VIDEO_MUX_CSI_VSYNC   0x144 0x388 0 0x4 0
#define IMXRT_PAD_GPIO_AD_14_GPIO_MUX3_IO13   0x144 0x388 0 0x5 0
#define IMXRT_PAD_GPIO_AD_14_ENET_RX_CLK   0x144 0x388 0 0x6 0
#define IMXRT_PAD_GPIO_AD_14_FLEXIO2_D14   0x144 0x388 0 0x8 0
#define IMXRT_PAD_GPIO_AD_14_CCM_ENET_REF_CLK_25M   0x144 0x388 0 0x9 0
#define IMXRT_PAD_GPIO_AD_14_GPIO9_IO13   0x144 0x388 0 0xA 0
#define IMXRT_PAD_GPIO_AD_14_FLEXPWM3_PWM0_X   0x144 0x388 0 0xB 0
#define IMXRT_PAD_GPIO_AD_15_GPIO9_IO14   0x148 0x38C 0 0xA 0
#define IMXRT_PAD_GPIO_AD_15_FLEXPWM3_PWM1_X   0x148 0x38C 0 0xB 0
#define IMXRT_PAD_GPIO_AD_15_SPDIF_IN   0x148 0x38C 0x6B4 0x0 1
#define IMXRT_PAD_GPIO_AD_15_LPUART10_TXD   0x148 0x38C 0x628 0x1 0
#define IMXRT_PAD_GPIO_AD_15_GPT1_COMPARE2   0x148 0x38C 0 0x2 0
#define IMXRT_PAD_GPIO_AD_15_FLEXSPI1_B_DATA00   0x148 0x38C 0x564 0x3 0
#define IMXRT_PAD_GPIO_AD_15_VIDEO_MUX_CSI_HSYNC   0x148 0x38C 0 0x4 0
#define IMXRT_PAD_GPIO_AD_15_GPIO_MUX3_IO14   0x148 0x38C 0 0x5 0
#define IMXRT_PAD_GPIO_AD_15_ENET_TX_ER   0x148 0x38C 0 0x6 0
#define IMXRT_PAD_GPIO_AD_15_FLEXIO2_D15   0x148 0x38C 0 0x8 0
#define IMXRT_PAD_GPIO_AD_16_SPDIF_OUT   0x14C 0x390 0 0x0 0
#define IMXRT_PAD_GPIO_AD_16_LPUART10_RXD   0x14C 0x390 0x624 0x1 0
#define IMXRT_PAD_GPIO_AD_16_GPT1_COMPARE3   0x14C 0x390 0 0x2 0
#define IMXRT_PAD_GPIO_AD_16_FLEXSPI1_B_SCLK   0x14C 0x390 0x578 0x3 0
#define IMXRT_PAD_GPIO_AD_16_VIDEO_MUX_CSI_DATA09   0x14C 0x390 0 0x4 0
#define IMXRT_PAD_GPIO_AD_16_GPIO_MUX3_IO15   0x14C 0x390 0 0x5 0
#define IMXRT_PAD_GPIO_AD_16_ENET_RX_DATA03   0x14C 0x390 0 0x6 0
#define IMXRT_PAD_GPIO_AD_16_FLEXIO2_D16   0x14C 0x390 0 0x8 0
#define IMXRT_PAD_GPIO_AD_16_ENET_1G_MDC   0x14C 0x390 0 0x9 0
#define IMXRT_PAD_GPIO_AD_16_GPIO9_IO15   0x14C 0x390 0 0xA 0
#define IMXRT_PAD_GPIO_AD_16_FLEXPWM3_PWM2_X   0x14C 0x390 0 0xB 0
#define IMXRT_PAD_GPIO_AD_17_SAI1_MCLK   0x150 0x394 0x66C 0x0 0
#define IMXRT_PAD_GPIO_AD_17_ACMP1_OUT   0x150 0x394 0 0x1 0
#define IMXRT_PAD_GPIO_AD_17_GPT1_CLK   0x150 0x394 0 0x2 0
#define IMXRT_PAD_GPIO_AD_17_FLEXSPI1_A_DQS   0x150 0x394 0x550 0x3 1
#define IMXRT_PAD_GPIO_AD_17_VIDEO_MUX_CSI_DATA08   0x150 0x394 0 0x4 0
#define IMXRT_PAD_GPIO_AD_17_GPIO_MUX3_IO16   0x150 0x394 0 0x5 0
#define IMXRT_PAD_GPIO_AD_17_ENET_RX_DATA02   0x150 0x394 0 0x6 0
#define IMXRT_PAD_GPIO_AD_17_FLEXIO2_D17   0x150 0x394 0 0x8 0
#define IMXRT_PAD_GPIO_AD_17_ENET_1G_MDIO   0x150 0x394 0x4C8 0x9 2
#define IMXRT_PAD_GPIO_AD_17_GPIO9_IO16   0x150 0x394 0 0xA 0
#define IMXRT_PAD_GPIO_AD_17_FLEXPWM3_PWM3_X   0x150 0x394 0 0xB 0
#define IMXRT_PAD_GPIO_AD_18_GPIO9_IO17   0x154 0x398 0 0xA 0
#define IMXRT_PAD_GPIO_AD_18_FLEXPWM4_PWM0_X   0x154 0x398 0 0xB 0
#define IMXRT_PAD_GPIO_AD_18_SAI1_RX_SYNC   0x154 0x398 0x678 0x0 0
#define IMXRT_PAD_GPIO_AD_18_ACMP2_OUT   0x154 0x398 0 0x1 0
#define IMXRT_PAD_GPIO_AD_18_LPSPI1_PCS1   0x154 0x398 0 0x2 0
#define IMXRT_PAD_GPIO_AD_18_FLEXSPI1_A_SS0_B   0x154 0x398 0 0x3 0
#define IMXRT_PAD_GPIO_AD_18_VIDEO_MUX_CSI_DATA07   0x154 0x398 0 0x4 0
#define IMXRT_PAD_GPIO_AD_18_GPIO_MUX3_IO17   0x154 0x398 0 0x5 0
#define IMXRT_PAD_GPIO_AD_18_ENET_CRS   0x154 0x398 0 0x6 0
#define IMXRT_PAD_GPIO_AD_18_FLEXIO2_D18   0x154 0x398 0 0x8 0
#define IMXRT_PAD_GPIO_AD_18_LPI2C2_SCL   0x154 0x398 0x5B4 0x9 1
#define IMXRT_PAD_GPIO_AD_19_SAI1_RX_BCLK   0x158 0x39C 0x670 0x0 0
#define IMXRT_PAD_GPIO_AD_19_ACMP3_OUT   0x158 0x39C 0 0x1 0
#define IMXRT_PAD_GPIO_AD_19_LPSPI1_PCS2   0x158 0x39C 0 0x2 0
#define IMXRT_PAD_GPIO_AD_19_FLEXSPI1_A_SCLK   0x158 0x39C 0x574 0x3 0
#define IMXRT_PAD_GPIO_AD_19_VIDEO_MUX_CSI_DATA06   0x158 0x39C 0 0x4 0
#define IMXRT_PAD_GPIO_AD_19_GPIO_MUX3_IO18   0x158 0x39C 0 0x5 0
#define IMXRT_PAD_GPIO_AD_19_ENET_COL   0x158 0x39C 0 0x6 0
#define IMXRT_PAD_GPIO_AD_19_FLEXIO2_D19   0x158 0x39C 0 0x8 0
#define IMXRT_PAD_GPIO_AD_19_LPI2C2_SDA   0x158 0x39C 0x5B8 0x9 1
#define IMXRT_PAD_GPIO_AD_19_GPIO9_IO18   0x158 0x39C 0 0xA 0
#define IMXRT_PAD_GPIO_AD_19_FLEXPWM4_PWM1_X   0x158 0x39C 0 0xB 0
#define IMXRT_PAD_GPIO_AD_20_SAI1_RX_DATA00   0x15C 0x3A0 0x674 0x0 0
#define IMXRT_PAD_GPIO_AD_20_ACMP4_OUT   0x15C 0x3A0 0 0x1 0
#define IMXRT_PAD_GPIO_AD_20_LPSPI1_PCS3   0x15C 0x3A0 0 0x2 0
#define IMXRT_PAD_GPIO_AD_20_FLEXSPI1_A_DATA00   0x15C 0x3A0 0x554 0x3 0
#define IMXRT_PAD_GPIO_AD_20_VIDEO_MUX_CSI_DATA05   0x15C 0x3A0 0 0x4 0
#define IMXRT_PAD_GPIO_AD_20_GPIO_MUX3_IO19   0x15C 0x3A0 0 0x5 0
#define IMXRT_PAD_GPIO_AD_20_KPP_ROW07   0x15C 0x3A0 0x5A8 0x6 0
#define IMXRT_PAD_GPIO_AD_20_FLEXIO2_D20   0x15C 0x3A0 0 0x8 0
#define IMXRT_PAD_GPIO_AD_20_ENET_QOS_1588_EVENT2_OUT   0x15C 0x3A0 0 0x9 0
#define IMXRT_PAD_GPIO_AD_20_GPIO9_IO19   0x15C 0x3A0 0 0xA 0
#define IMXRT_PAD_GPIO_AD_20_FLEXPWM4_PWM2_X   0x15C 0x3A0 0 0xB 0
#define IMXRT_PAD_GPIO_AD_21_SAI1_TX_DATA00   0x160 0x3A4 0 0x0 0
#define IMXRT_PAD_GPIO_AD_21_LPSPI2_PCS1   0x160 0x3A4 0x5E0 0x2 0
#define IMXRT_PAD_GPIO_AD_21_FLEXSPI1_A_DATA01   0x160 0x3A4 0x558 0x3 0
#define IMXRT_PAD_GPIO_AD_21_VIDEO_MUX_CSI_DATA04   0x160 0x3A4 0 0x4 0
#define IMXRT_PAD_GPIO_AD_21_GPIO_MUX3_IO20   0x160 0x3A4 0 0x5 0
#define IMXRT_PAD_GPIO_AD_21_KPP_COL07   0x160 0x3A4 0x5A0 0x6 0
#define IMXRT_PAD_GPIO_AD_21_FLEXIO2_D21   0x160 0x3A4 0 0x8 0
#define IMXRT_PAD_GPIO_AD_21_ENET_QOS_1588_EVENT2_IN   0x160 0x3A4 0 0x9 0
#define IMXRT_PAD_GPIO_AD_21_GPIO9_IO20   0x160 0x3A4 0 0xA 0
#define IMXRT_PAD_GPIO_AD_21_FLEXPWM4_PWM3_X   0x160 0x3A4 0 0xB 0
#define IMXRT_PAD_GPIO_AD_22_GPIO9_IO21   0x164 0x3A8 0 0xA 0
#define IMXRT_PAD_GPIO_AD_22_SAI1_TX_BCLK   0x164 0x3A8 0x67C 0x0 0
#define IMXRT_PAD_GPIO_AD_22_LPSPI2_PCS2   0x164 0x3A8 0 0x2 0
#define IMXRT_PAD_GPIO_AD_22_FLEXSPI1_A_DATA02   0x164 0x3A8 0x55C 0x3 0
#define IMXRT_PAD_GPIO_AD_22_VIDEO_MUX_CSI_DATA03   0x164 0x3A8 0 0x4 0
#define IMXRT_PAD_GPIO_AD_22_GPIO_MUX3_IO21   0x164 0x3A8 0 0x5 0
#define IMXRT_PAD_GPIO_AD_22_KPP_ROW06   0x164 0x3A8 0x5A4 0x6 0
#define IMXRT_PAD_GPIO_AD_22_FLEXIO2_D22   0x164 0x3A8 0 0x8 0
#define IMXRT_PAD_GPIO_AD_22_ENET_QOS_1588_EVENT3_OUT   0x164 0x3A8 0 0x9 0
#define IMXRT_PAD_GPIO_AD_23_SAI1_TX_SYNC   0x168 0x3AC 0x680 0x0 0
#define IMXRT_PAD_GPIO_AD_23_LPSPI2_PCS3   0x168 0x3AC 0 0x2 0
#define IMXRT_PAD_GPIO_AD_23_FLEXSPI1_A_DATA03   0x168 0x3AC 0x560 0x3 0
#define IMXRT_PAD_GPIO_AD_23_VIDEO_MUX_CSI_DATA02   0x168 0x3AC 0 0x4 0
#define IMXRT_PAD_GPIO_AD_23_GPIO_MUX3_IO22   0x168 0x3AC 0 0x5 0
#define IMXRT_PAD_GPIO_AD_23_KPP_COL06   0x168 0x3AC 0x59C 0x6 0
#define IMXRT_PAD_GPIO_AD_23_FLEXIO2_D23   0x168 0x3AC 0 0x8 0
#define IMXRT_PAD_GPIO_AD_23_ENET_QOS_1588_EVENT3_IN   0x168 0x3AC 0 0x9 0
#define IMXRT_PAD_GPIO_AD_23_GPIO9_IO22   0x168 0x3AC 0 0xA 0
#define IMXRT_PAD_GPIO_AD_24_LPUART1_TXD   0x16C 0x3B0 0x620 0x0 0
#define IMXRT_PAD_GPIO_AD_24_LPSPI2_SCK   0x16C 0x3B0 0x5E4 0x1 0
#define IMXRT_PAD_GPIO_AD_24_VIDEO_MUX_CSI_DATA00   0x16C 0x3B0 0 0x2 0
#define IMXRT_PAD_GPIO_AD_24_ENET_RX_EN   0x16C 0x3B0 0x4B8 0x3 0
#define IMXRT_PAD_GPIO_AD_24_FLEXPWM2_PWM0_A   0x16C 0x3B0 0x518 0x4 1
#define IMXRT_PAD_GPIO_AD_24_GPIO_MUX3_IO23   0x16C 0x3B0 0 0x5 0
#define IMXRT_PAD_GPIO_AD_24_KPP_ROW05   0x16C 0x3B0 0 0x6 0
#define IMXRT_PAD_GPIO_AD_24_FLEXIO2_D24   0x16C 0x3B0 0 0x8 0
#define IMXRT_PAD_GPIO_AD_24_LPI2C4_SCL   0x16C 0x3B0 0x5C4 0x9 0
#define IMXRT_PAD_GPIO_AD_24_GPIO9_IO23   0x16C 0x3B0 0 0xA 0
#define IMXRT_PAD_GPIO_AD_25_GPIO9_IO24   0x170 0x3B4 0 0xA 0
#define IMXRT_PAD_GPIO_AD_25_LPUART1_RXD   0x170 0x3B4 0x61C 0x0 0
#define IMXRT_PAD_GPIO_AD_25_LPSPI2_PCS0   0x170 0x3B4 0x5DC 0x1 0
#define IMXRT_PAD_GPIO_AD_25_VIDEO_MUX_CSI_DATA01   0x170 0x3B4 0 0x2 0
#define IMXRT_PAD_GPIO_AD_25_ENET_RX_ER   0x170 0x3B4 0x4BC 0x3 0
#define IMXRT_PAD_GPIO_AD_25_FLEXPWM2_PWM0_B   0x170 0x3B4 0x524 0x4 1
#define IMXRT_PAD_GPIO_AD_25_GPIO_MUX3_IO24   0x170 0x3B4 0 0x5 0
#define IMXRT_PAD_GPIO_AD_25_KPP_COL05   0x170 0x3B4 0 0x6 0
#define IMXRT_PAD_GPIO_AD_25_FLEXIO2_D25   0x170 0x3B4 0 0x8 0
#define IMXRT_PAD_GPIO_AD_25_LPI2C4_SDA   0x170 0x3B4 0x5C8 0x9 0
#define IMXRT_PAD_GPIO_AD_26_LPUART1_CTS_B   0x174 0x3B8 0 0x0 0
#define IMXRT_PAD_GPIO_AD_26_LPSPI2_SOUT   0x174 0x3B8 0x5EC 0x1 0
#define IMXRT_PAD_GPIO_AD_26_SEMC_CSX01   0x174 0x3B8 0 0x2 0
#define IMXRT_PAD_GPIO_AD_26_ENET_RX_DATA00   0x174 0x3B8 0x4B0 0x3 0
#define IMXRT_PAD_GPIO_AD_26_FLEXPWM2_PWM1_A   0x174 0x3B8 0x51C 0x4 1
#define IMXRT_PAD_GPIO_AD_26_GPIO_MUX3_IO25   0x174 0x3B8 0 0x5 0
#define IMXRT_PAD_GPIO_AD_26_KPP_ROW04   0x174 0x3B8 0 0x6 0
#define IMXRT_PAD_GPIO_AD_26_FLEXIO2_D26   0x174 0x3B8 0 0x8 0
#define IMXRT_PAD_GPIO_AD_26_ENET_QOS_MDC   0x174 0x3B8 0 0x9 0
#define IMXRT_PAD_GPIO_AD_26_GPIO9_IO25   0x174 0x3B8 0 0xA 0
#define IMXRT_PAD_GPIO_AD_26_USDHC2_CD_B   0x174 0x3B8 0x6D0 0xB 1
#define IMXRT_PAD_GPIO_AD_27_LPUART1_RTS_B   0x178 0x3BC 0 0x0 0
#define IMXRT_PAD_GPIO_AD_27_LPSPI2_SIN   0x178 0x3BC 0x5E8 0x1 0
#define IMXRT_PAD_GPIO_AD_27_SEMC_CSX02   0x178 0x3BC 0 0x2 0
#define IMXRT_PAD_GPIO_AD_27_ENET_RX_DATA01   0x178 0x3BC 0x4B4 0x3 0
#define IMXRT_PAD_GPIO_AD_27_FLEXPWM2_PWM1_B   0x178 0x3BC 0x528 0x4 1
#define IMXRT_PAD_GPIO_AD_27_GPIO_MUX3_IO26   0x178 0x3BC 0 0x5 0
#define IMXRT_PAD_GPIO_AD_27_KPP_COL04   0x178 0x3BC 0 0x6 0
#define IMXRT_PAD_GPIO_AD_27_FLEXIO2_D27   0x178 0x3BC 0 0x8 0
#define IMXRT_PAD_GPIO_AD_27_ENET_QOS_MDIO   0x178 0x3BC 0x4EC 0x9 1
#define IMXRT_PAD_GPIO_AD_27_GPIO9_IO26   0x178 0x3BC 0 0xA 0
#define IMXRT_PAD_GPIO_AD_27_USDHC2_WP   0x178 0x3BC 0x6D4 0xB 1
#define IMXRT_PAD_GPIO_AD_28_GPIO9_IO27   0x17C 0x3C0 0 0xA 0
#define IMXRT_PAD_GPIO_AD_28_USDHC2_VSELECT   0x17C 0x3C0 0 0xB 0
#define IMXRT_PAD_GPIO_AD_28_LPSPI1_SCK   0x17C 0x3C0 0x5D0 0x0 1
#define IMXRT_PAD_GPIO_AD_28_LPUART5_TXD   0x17C 0x3C0 0 0x1 0
#define IMXRT_PAD_GPIO_AD_28_SEMC_CSX03   0x17C 0x3C0 0 0x2 0
#define IMXRT_PAD_GPIO_AD_28_ENET_TX_EN   0x17C 0x3C0 0 0x3 0
#define IMXRT_PAD_GPIO_AD_28_FLEXPWM2_PWM2_A   0x17C 0x3C0 0x520 0x4 1
#define IMXRT_PAD_GPIO_AD_28_GPIO_MUX3_IO27   0x17C 0x3C0 0 0x5 0
#define IMXRT_PAD_GPIO_AD_28_KPP_ROW03   0x17C 0x3C0 0 0x6 0
#define IMXRT_PAD_GPIO_AD_28_FLEXIO2_D28   0x17C 0x3C0 0 0x8 0
#define IMXRT_PAD_GPIO_AD_28_VIDEO_MUX_EXT_DCIC1   0x17C 0x3C0 0 0x9 0
#define IMXRT_PAD_GPIO_AD_29_LPSPI1_PCS0   0x180 0x3C4 0x5CC 0x0 1
#define IMXRT_PAD_GPIO_AD_29_LPUART5_RXD   0x180 0x3C4 0 0x1 0
#define IMXRT_PAD_GPIO_AD_29_ENET_REF_CLK   0x180 0x3C4 0x4A8 0x2 0
#define IMXRT_PAD_GPIO_AD_29_ENET_TX_CLK   0x180 0x3C4 0x4C0 0x3 0
#define IMXRT_PAD_GPIO_AD_29_FLEXPWM2_PWM2_B   0x180 0x3C4 0x52C 0x4 1
#define IMXRT_PAD_GPIO_AD_29_GPIO_MUX3_IO28   0x180 0x3C4 0 0x5 0
#define IMXRT_PAD_GPIO_AD_29_KPP_COL03   0x180 0x3C4 0 0x6 0
#define IMXRT_PAD_GPIO_AD_29_FLEXIO2_D29   0x180 0x3C4 0 0x8 0
#define IMXRT_PAD_GPIO_AD_29_VIDEO_MUX_EXT_DCIC2   0x180 0x3C4 0 0x9 0
#define IMXRT_PAD_GPIO_AD_29_GPIO9_IO28   0x180 0x3C4 0 0xA 0
#define IMXRT_PAD_GPIO_AD_29_USDHC2_RESET_B   0x180 0x3C4 0 0xB 0
#define IMXRT_PAD_GPIO_AD_30_LPSPI1_SOUT   0x184 0x3C8 0x5D8 0x0 1
#define IMXRT_PAD_GPIO_AD_30_USB_OTG2_OC   0x184 0x3C8 0x6B8 0x1 1
#define IMXRT_PAD_GPIO_AD_30_FLEXCAN2_TX   0x184 0x3C8 0 0x2 0
#define IMXRT_PAD_GPIO_AD_30_ENET_TX_DATA00   0x184 0x3C8 0 0x3 0
#define IMXRT_PAD_GPIO_AD_30_LPUART3_TXD   0x184 0x3C8 0 0x4 0
#define IMXRT_PAD_GPIO_AD_30_GPIO_MUX3_IO29   0x184 0x3C8 0 0x5 0
#define IMXRT_PAD_GPIO_AD_30_KPP_ROW02   0x184 0x3C8 0 0x6 0
#define IMXRT_PAD_GPIO_AD_30_FLEXIO2_D30   0x184 0x3C8 0 0x8 0
#define IMXRT_PAD_GPIO_AD_30_WDOG2_RESET_B_DEB   0x184 0x3C8 0 0x9 0
#define IMXRT_PAD_GPIO_AD_30_GPIO9_IO29   0x184 0x3C8 0 0xA 0
#define IMXRT_PAD_GPIO_AD_31_LPSPI1_SIN   0x188 0x3CC 0x5D4 0x0 1
#define IMXRT_PAD_GPIO_AD_31_USB_OTG2_PWR   0x188 0x3CC 0 0x1 0
#define IMXRT_PAD_GPIO_AD_31_FLEXCAN2_RX   0x188 0x3CC 0x49C 0x2 1
#define IMXRT_PAD_GPIO_AD_31_ENET_TX_DATA01   0x188 0x3CC 0 0x3 0
#define IMXRT_PAD_GPIO_AD_31_LPUART3_RXD   0x188 0x3CC 0 0x4 0
#define IMXRT_PAD_GPIO_AD_31_GPIO_MUX3_IO30   0x188 0x3CC 0 0x5 0
#define IMXRT_PAD_GPIO_AD_31_KPP_COL02   0x188 0x3CC 0 0x6 0
#define IMXRT_PAD_GPIO_AD_31_FLEXIO2_D31   0x188 0x3CC 0 0x8 0
#define IMXRT_PAD_GPIO_AD_31_WDOG1_RESET_B_DEB   0x188 0x3CC 0 0x9 0
#define IMXRT_PAD_GPIO_AD_31_GPIO9_IO30   0x188 0x3CC 0 0xA 0
#define IMXRT_PAD_GPIO_AD_32_GPIO9_IO31   0x18C 0x3D0 0 0xA 0
#define IMXRT_PAD_GPIO_AD_32_LPI2C1_SCL   0x18C 0x3D0 0x5AC 0x0 1
#define IMXRT_PAD_GPIO_AD_32_USBPHY2_OTG_ID   0x18C 0x3D0 0x6C4 0x1 1
#define IMXRT_PAD_GPIO_AD_32_PGMC_PMIC_RDY   0x18C 0x3D0 0 0x2 0
#define IMXRT_PAD_GPIO_AD_32_ENET_MDC   0x18C 0x3D0 0 0x3 0
#define IMXRT_PAD_GPIO_AD_32_USDHC1_CD_B   0x18C 0x3D0 0x6C8 0x4 0
#define IMXRT_PAD_GPIO_AD_32_GPIO_MUX3_IO31   0x18C 0x3D0 0 0x5 0
#define IMXRT_PAD_GPIO_AD_32_KPP_ROW01   0x18C 0x3D0 0 0x6 0
#define IMXRT_PAD_GPIO_AD_32_LPUART10_TXD   0x18C 0x3D0 0x628 0x8 1
#define IMXRT_PAD_GPIO_AD_32_ENET_1G_MDC   0x18C 0x3D0 0 0x9 0
#define IMXRT_PAD_GPIO_AD_33_LPI2C1_SDA   0x190 0x3D4 0x5B0 0x0 1
#define IMXRT_PAD_GPIO_AD_33_USBPHY1_OTG_ID   0x190 0x3D4 0x6C0 0x1 1
#define IMXRT_PAD_GPIO_AD_33_XBAR1_INOUT17   0x190 0x3D4 0 0x2 0
#define IMXRT_PAD_GPIO_AD_33_ENET_MDIO   0x190 0x3D4 0x4AC 0x3 1
#define IMXRT_PAD_GPIO_AD_33_USDHC1_WP   0x190 0x3D4 0x6CC 0x4 0
#define IMXRT_PAD_GPIO_AD_33_GPIO_MUX4_IO00   0x190 0x3D4 0 0x5 0
#define IMXRT_PAD_GPIO_AD_33_KPP_COL01   0x190 0x3D4 0 0x6 0
#define IMXRT_PAD_GPIO_AD_33_LPUART10_RXD   0x190 0x3D4 0x624 0x8 1
#define IMXRT_PAD_GPIO_AD_33_ENET_1G_MDIO   0x190 0x3D4 0x4C8 0x9 3
#define IMXRT_PAD_GPIO_AD_33_GPIO10_IO00   0x190 0x3D4 0 0xA 0
#define IMXRT_PAD_GPIO_AD_34_ENET_1G_1588_EVENT0_IN   0x194 0x3D8 0 0x0 0
#define IMXRT_PAD_GPIO_AD_34_USB_OTG1_PWR   0x194 0x3D8 0 0x1 0
#define IMXRT_PAD_GPIO_AD_34_XBAR1_INOUT18   0x194 0x3D8 0 0x2 0
#define IMXRT_PAD_GPIO_AD_34_ENET_1588_EVENT0_IN   0x194 0x3D8 0 0x3 0
#define IMXRT_PAD_GPIO_AD_34_USDHC1_VSELECT   0x194 0x3D8 0 0x4 0
#define IMXRT_PAD_GPIO_AD_34_GPIO_MUX4_IO01   0x194 0x3D8 0 0x5 0
#define IMXRT_PAD_GPIO_AD_34_KPP_ROW00   0x194 0x3D8 0 0x6 0
#define IMXRT_PAD_GPIO_AD_34_LPUART10_CTS_B   0x194 0x3D8 0 0x8 0
#define IMXRT_PAD_GPIO_AD_34_WDOG1_ANY   0x194 0x3D8 0 0x9 0
#define IMXRT_PAD_GPIO_AD_34_GPIO10_IO01   0x194 0x3D8 0 0xA 0
#define IMXRT_PAD_GPIO_AD_35_GPIO10_IO02   0x198 0x3DC 0 0xA 0
#define IMXRT_PAD_GPIO_AD_35_ENET_1G_1588_EVENT0_OUT   0x198 0x3DC 0 0x0 0
#define IMXRT_PAD_GPIO_AD_35_USB_OTG1_OC   0x198 0x3DC 0x6BC 0x1 1
#define IMXRT_PAD_GPIO_AD_35_XBAR1_INOUT19   0x198 0x3DC 0 0x2 0
#define IMXRT_PAD_GPIO_AD_35_ENET_1588_EVENT0_OUT   0x198 0x3DC 0 0x3 0
#define IMXRT_PAD_GPIO_AD_35_USDHC1_RESET_B   0x198 0x3DC 0 0x4 0
#define IMXRT_PAD_GPIO_AD_35_GPIO_MUX4_IO02   0x198 0x3DC 0 0x5 0
#define IMXRT_PAD_GPIO_AD_35_KPP_COL00   0x198 0x3DC 0 0x6 0
#define IMXRT_PAD_GPIO_AD_35_LPUART10_RTS_B   0x198 0x3DC 0 0x8 0
#define IMXRT_PAD_GPIO_AD_35_FLEXSPI1_B_SS1_B   0x198 0x3DC 0 0x9 0
#define IMXRT_PAD_GPIO_SD_B1_00_USDHC1_CMD   0x19C 0x3E0 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B1_00_XBAR1_INOUT20   0x19C 0x3E0 0x6D8 0x2 1
#define IMXRT_PAD_GPIO_SD_B1_00_GPT4_CAPTURE1   0x19C 0x3E0 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B1_00_GPIO_MUX4_IO03   0x19C 0x3E0 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B1_00_FLEXSPI2_A_SS0_B   0x19C 0x3E0 0 0x6 0
#define IMXRT_PAD_GPIO_SD_B1_00_KPP_ROW07   0x19C 0x3E0 0x5A8 0x8 1
#define IMXRT_PAD_GPIO_SD_B1_00_GPIO10_IO03   0x19C 0x3E0 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B1_01_USDHC1_CLK   0x1A0 0x3E4 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B1_01_XBAR1_INOUT21   0x1A0 0x3E4 0x6DC 0x2 1
#define IMXRT_PAD_GPIO_SD_B1_01_GPT4_CAPTURE2   0x1A0 0x3E4 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B1_01_GPIO_MUX4_IO04   0x1A0 0x3E4 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B1_01_FLEXSPI2_A_SCLK   0x1A0 0x3E4 0x58C 0x6 1
#define IMXRT_PAD_GPIO_SD_B1_01_KPP_COL07   0x1A0 0x3E4 0x5A0 0x8 1
#define IMXRT_PAD_GPIO_SD_B1_01_GPIO10_IO04   0x1A0 0x3E4 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B1_02_GPIO10_IO05   0x1A4 0x3E8 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B1_02_USDHC1_DATA0   0x1A4 0x3E8 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B1_02_XBAR1_INOUT22   0x1A4 0x3E8 0x6E0 0x2 1
#define IMXRT_PAD_GPIO_SD_B1_02_GPT4_COMPARE1   0x1A4 0x3E8 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B1_02_GPIO_MUX4_IO05   0x1A4 0x3E8 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B1_02_FLEXSPI2_A_DATA00   0x1A4 0x3E8 0x57C 0x6 1
#define IMXRT_PAD_GPIO_SD_B1_02_KPP_ROW06   0x1A4 0x3E8 0x5A4 0x8 1
#define IMXRT_PAD_GPIO_SD_B1_02_FLEXSPI1_A_SS1_B   0x1A4 0x3E8 0 0x9 0
#define IMXRT_PAD_GPIO_SD_B1_03_USDHC1_DATA1   0x1A8 0x3EC 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B1_03_XBAR1_INOUT23   0x1A8 0x3EC 0x6E4 0x2 1
#define IMXRT_PAD_GPIO_SD_B1_03_GPT4_COMPARE2   0x1A8 0x3EC 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B1_03_GPIO_MUX4_IO06   0x1A8 0x3EC 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B1_03_FLEXSPI2_A_DATA01   0x1A8 0x3EC 0x580 0x6 1
#define IMXRT_PAD_GPIO_SD_B1_03_KPP_COL06   0x1A8 0x3EC 0x59C 0x8 1
#define IMXRT_PAD_GPIO_SD_B1_03_FLEXSPI1_B_SS1_B   0x1A8 0x3EC 0 0x9 0
#define IMXRT_PAD_GPIO_SD_B1_03_GPIO10_IO06   0x1A8 0x3EC 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B1_04_USDHC1_DATA2   0x1AC 0x3F0 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B1_04_XBAR1_INOUT24   0x1AC 0x3F0 0x6E8 0x2 1
#define IMXRT_PAD_GPIO_SD_B1_04_GPT4_COMPARE3   0x1AC 0x3F0 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B1_04_GPIO_MUX4_IO07   0x1AC 0x3F0 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B1_04_FLEXSPI2_A_DATA02   0x1AC 0x3F0 0x584 0x6 1
#define IMXRT_PAD_GPIO_SD_B1_04_FLEXSPI1_B_SS0_B   0x1AC 0x3F0 0 0x8 0
#define IMXRT_PAD_GPIO_SD_B1_04_ENET_QOS_1588_EVENT2_AUX_IN   0x1AC 0x3F0 0 0x9 0
#define IMXRT_PAD_GPIO_SD_B1_04_GPIO10_IO07   0x1AC 0x3F0 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B1_05_GPIO10_IO08   0x1B0 0x3F4 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B1_05_USDHC1_DATA3   0x1B0 0x3F4 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B1_05_XBAR1_INOUT25   0x1B0 0x3F4 0x6EC 0x2 1
#define IMXRT_PAD_GPIO_SD_B1_05_GPT4_CLK   0x1B0 0x3F4 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B1_05_GPIO_MUX4_IO08   0x1B0 0x3F4 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B1_05_FLEXSPI2_A_DATA03   0x1B0 0x3F4 0x588 0x6 1
#define IMXRT_PAD_GPIO_SD_B1_05_FLEXSPI1_B_DQS   0x1B0 0x3F4 0 0x8 0
#define IMXRT_PAD_GPIO_SD_B1_05_ENET_QOS_1588_EVENT3_AUX_IN   0x1B0 0x3F4 0 0x9 0
#define IMXRT_PAD_GPIO_SD_B2_00_GPIO10_IO09   0x1B4 0x3F8 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_00_USDHC2_DATA3   0x1B4 0x3F8 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_00_FLEXSPI1_B_DATA03   0x1B4 0x3F8 0x570 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_00_ENET_1G_RX_EN   0x1B4 0x3F8 0x4E0 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_00_LPUART9_TXD   0x1B4 0x3F8 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_00_LPSPI4_SCK   0x1B4 0x3F8 0x610 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_00_GPIO_MUX4_IO09   0x1B4 0x3F8 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_01_USDHC2_DATA2   0x1B8 0x3FC 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_01_FLEXSPI1_B_DATA02   0x1B8 0x3FC 0x56C 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_01_ENET_1G_RX_CLK   0x1B8 0x3FC 0x4CC 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_01_LPUART9_RXD   0x1B8 0x3FC 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_01_LPSPI4_PCS0   0x1B8 0x3FC 0x60C 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_01_GPIO_MUX4_IO10   0x1B8 0x3FC 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_01_GPIO10_IO10   0x1B8 0x3FC 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_02_GPIO10_IO11   0x1BC 0x400 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_02_USDHC2_DATA1   0x1BC 0x400 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_02_FLEXSPI1_B_DATA01   0x1BC 0x400 0x568 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_02_ENET_1G_RX_DATA00   0x1BC 0x400 0x4D0 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_02_LPUART9_CTS_B   0x1BC 0x400 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_02_LPSPI4_SOUT   0x1BC 0x400 0x618 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_02_GPIO_MUX4_IO11   0x1BC 0x400 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_03_GPIO10_IO12   0x1C0 0x404 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_03_USDHC2_DATA0   0x1C0 0x404 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_03_FLEXSPI1_B_DATA00   0x1C0 0x404 0x564 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_03_ENET_1G_RX_DATA01   0x1C0 0x404 0x4D4 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_03_LPUART9_RTS_B   0x1C0 0x404 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_03_LPSPI4_SIN   0x1C0 0x404 0x614 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_03_GPIO_MUX4_IO12   0x1C0 0x404 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_04_USDHC2_CLK   0x1C4 0x408 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_04_FLEXSPI1_B_SCLK   0x1C4 0x408 0x578 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_04_ENET_1G_RX_DATA02   0x1C4 0x408 0x4D8 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_04_FLEXSPI1_A_SS1_B   0x1C4 0x408 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_04_LPSPI4_PCS1   0x1C4 0x408 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_04_GPIO_MUX4_IO13   0x1C4 0x408 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_04_GPIO10_IO13   0x1C4 0x408 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_05_GPIO10_IO14   0x1C8 0x40C 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_05_USDHC2_CMD   0x1C8 0x40C 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_05_FLEXSPI1_A_DQS   0x1C8 0x40C 0x550 0x1 2
#define IMXRT_PAD_GPIO_SD_B2_05_ENET_1G_RX_DATA03   0x1C8 0x40C 0x4DC 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_05_FLEXSPI1_B_SS0_B   0x1C8 0x40C 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_05_LPSPI4_PCS2   0x1C8 0x40C 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_05_GPIO_MUX4_IO14   0x1C8 0x40C 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_06_GPIO10_IO15   0x1CC 0x410 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_06_USDHC2_RESET_B   0x1CC 0x410 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_06_FLEXSPI1_A_SS0_B   0x1CC 0x410 0 0x1 0
#define IMXRT_PAD_GPIO_SD_B2_06_ENET_1G_TX_DATA03   0x1CC 0x410 0 0x2 0
#define IMXRT_PAD_GPIO_SD_B2_06_LPSPI4_PCS3   0x1CC 0x410 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_06_GPT6_CAPTURE1   0x1CC 0x410 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_06_GPIO_MUX4_IO15   0x1CC 0x410 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_07_USDHC2_STROBE   0x1D0 0x414 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_07_FLEXSPI1_A_SCLK   0x1D0 0x414 0x574 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_07_ENET_1G_TX_DATA02   0x1D0 0x414 0 0x2 0
#define IMXRT_PAD_GPIO_SD_B2_07_LPUART3_CTS_B   0x1D0 0x414 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_07_GPT6_CAPTURE2   0x1D0 0x414 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_07_GPIO_MUX4_IO16   0x1D0 0x414 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_07_LPSPI2_SCK   0x1D0 0x414 0x5E4 0x6 1
#define IMXRT_PAD_GPIO_SD_B2_07_ENET_TX_ER   0x1D0 0x414 0 0x8 0
#define IMXRT_PAD_GPIO_SD_B2_07_ENET_QOS_REF_CLK   0x1D0 0x414 0x4A0 0x9 1
#define IMXRT_PAD_GPIO_SD_B2_07_GPIO10_IO16   0x1D0 0x414 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_08_GPIO10_IO17   0x1D4 0x418 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_08_USDHC2_DATA4   0x1D4 0x418 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_08_FLEXSPI1_A_DATA00   0x1D4 0x418 0x554 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_08_ENET_1G_TX_DATA01   0x1D4 0x418 0 0x2 0
#define IMXRT_PAD_GPIO_SD_B2_08_LPUART3_RTS_B   0x1D4 0x418 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_08_GPT6_COMPARE1   0x1D4 0x418 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_08_GPIO_MUX4_IO17   0x1D4 0x418 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_08_LPSPI2_PCS0   0x1D4 0x418 0x5DC 0x6 1
#define IMXRT_PAD_GPIO_SD_B2_09_GPIO10_IO18   0x1D8 0x41C 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_09_USDHC2_DATA5   0x1D8 0x41C 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_09_FLEXSPI1_A_DATA01   0x1D8 0x41C 0x558 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_09_ENET_1G_TX_DATA00   0x1D8 0x41C 0 0x2 0
#define IMXRT_PAD_GPIO_SD_B2_09_LPUART5_CTS_B   0x1D8 0x41C 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_09_GPT6_COMPARE2   0x1D8 0x41C 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_09_GPIO_MUX4_IO18   0x1D8 0x41C 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_09_LPSPI2_SOUT   0x1D8 0x41C 0x5EC 0x6 1
#define IMXRT_PAD_GPIO_SD_B2_10_GPIO10_IO19   0x1DC 0x420 0 0xA 0
#define IMXRT_PAD_GPIO_SD_B2_10_USDHC2_DATA6   0x1DC 0x420 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_10_FLEXSPI1_A_DATA02   0x1DC 0x420 0x55C 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_10_ENET_1G_TX_EN   0x1DC 0x420 0 0x2 0
#define IMXRT_PAD_GPIO_SD_B2_10_LPUART5_RTS_B   0x1DC 0x420 0 0x3 0
#define IMXRT_PAD_GPIO_SD_B2_10_GPT6_COMPARE3   0x1DC 0x420 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_10_GPIO_MUX4_IO19   0x1DC 0x420 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_10_LPSPI2_SIN   0x1DC 0x420 0x5E8 0x6 1
#define IMXRT_PAD_GPIO_SD_B2_11_USDHC2_DATA7   0x1E0 0x424 0 0x0 0
#define IMXRT_PAD_GPIO_SD_B2_11_FLEXSPI1_A_DATA03   0x1E0 0x424 0x560 0x1 1
#define IMXRT_PAD_GPIO_SD_B2_11_ENET_1G_TX_CLK_IO   0x1E0 0x424 0x4E8 0x2 1
#define IMXRT_PAD_GPIO_SD_B2_11_ENET_1G_REF_CLK   0x1E0 0x424 0x4C4 0x3 1
#define IMXRT_PAD_GPIO_SD_B2_11_GPT6_CLK   0x1E0 0x424 0 0x4 0
#define IMXRT_PAD_GPIO_SD_B2_11_GPIO_MUX4_IO20   0x1E0 0x424 0 0x5 0
#define IMXRT_PAD_GPIO_SD_B2_11_LPSPI2_PCS1   0x1E0 0x424 0x5E0 0x6 1
#define IMXRT_PAD_GPIO_SD_B2_11_GPIO10_IO20   0x1E0 0x424 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_00_VIDEO_MUX_LCDIF_CLK   0x1E4 0x428 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_00_ENET_1G_RX_EN   0x1E4 0x428 0x4E0 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_00_TMR1_TIMER0   0x1E4 0x428 0x63C 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_00_XBAR1_INOUT26   0x1E4 0x428 0x6F0 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_00_GPIO_MUX4_IO21   0x1E4 0x428 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_00_ENET_QOS_RX_EN   0x1E4 0x428 0x4F8 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_00_GPIO10_IO21   0x1E4 0x428 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_01_VIDEO_MUX_LCDIF_ENABLE   0x1E8 0x42C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_1G_RX_CLK   0x1E8 0x42C 0x4CC 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_1G_RX_ER   0x1E8 0x42C 0x4E4 0x2 1
#define IMXRT_PAD_GPIO_DISP_B1_01_TMR1_TIMER1   0x1E8 0x42C 0x640 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_01_XBAR1_INOUT27   0x1E8 0x42C 0x6F4 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_01_GPIO_MUX4_IO22   0x1E8 0x42C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_QOS_RX_CLK   0x1E8 0x42C 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_01_ENET_QOS_RX_ER   0x1E8 0x42C 0x4FC 0x9 0
#define IMXRT_PAD_GPIO_DISP_B1_01_GPIO10_IO22   0x1E8 0x42C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_02_GPIO10_IO23   0x1EC 0x430 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_02_VIDEO_MUX_LCDIF_HSYNC   0x1EC 0x430 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_02_ENET_1G_RX_DATA00   0x1EC 0x430 0x4D0 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_02_LPI2C3_SCL   0x1EC 0x430 0x5BC 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_02_TMR1_TIMER2   0x1EC 0x430 0x644 0x3 1
#define IMXRT_PAD_GPIO_DISP_B1_02_XBAR1_INOUT28   0x1EC 0x430 0x6F8 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_02_GPIO_MUX4_IO23   0x1EC 0x430 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_02_ENET_QOS_RX_DATA00   0x1EC 0x430 0x4F0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_02_LPUART1_TXD   0x1EC 0x430 0x620 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_03_VIDEO_MUX_LCDIF_VSYNC   0x1F0 0x434 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_03_ENET_1G_RX_DATA01   0x1F0 0x434 0x4D4 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_03_LPI2C3_SDA   0x1F0 0x434 0x5C0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_03_TMR2_TIMER0   0x1F0 0x434 0x648 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_03_XBAR1_INOUT29   0x1F0 0x434 0x6FC 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_03_GPIO_MUX4_IO24   0x1F0 0x434 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_03_ENET_QOS_RX_DATA01   0x1F0 0x434 0x4F4 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_03_LPUART1_RXD   0x1F0 0x434 0x61C 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_03_GPIO10_IO24   0x1F0 0x434 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_04_VIDEO_MUX_LCDIF_DATA00   0x1F4 0x438 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_04_ENET_1G_RX_DATA02   0x1F4 0x438 0x4D8 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_04_LPUART4_RXD   0x1F4 0x438 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_04_TMR2_TIMER1   0x1F4 0x438 0x64C 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_04_XBAR1_INOUT30   0x1F4 0x438 0x700 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_04_GPIO_MUX4_IO25   0x1F4 0x438 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_04_ENET_QOS_RX_DATA02   0x1F4 0x438 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_04_LPSPI3_SCK   0x1F4 0x438 0x600 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_04_GPIO10_IO25   0x1F4 0x438 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_05_GPIO10_IO26   0x1F8 0x43C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_05_VIDEO_MUX_LCDIF_DATA01   0x1F8 0x43C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_05_ENET_1G_RX_DATA03   0x1F8 0x43C 0x4DC 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_05_LPUART4_CTS_B   0x1F8 0x43C 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_05_TMR2_TIMER2   0x1F8 0x43C 0x650 0x3 1
#define IMXRT_PAD_GPIO_DISP_B1_05_XBAR1_INOUT31   0x1F8 0x43C 0x704 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_05_GPIO_MUX4_IO26   0x1F8 0x43C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_05_ENET_QOS_RX_DATA03   0x1F8 0x43C 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_05_LPSPI3_SIN   0x1F8 0x43C 0x604 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_06_VIDEO_MUX_LCDIF_DATA02   0x1FC 0x440 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_06_ENET_1G_TX_DATA03   0x1FC 0x440 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B1_06_LPUART4_TXD   0x1FC 0x440 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_06_TMR3_TIMER0   0x1FC 0x440 0x654 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_06_XBAR1_INOUT32   0x1FC 0x440 0x708 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_06_GPIO_MUX4_IO27   0x1FC 0x440 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_06_SRC_BT_CFG00   0x1FC 0x440 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B1_06_ENET_QOS_TX_DATA03   0x1FC 0x440 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_06_LPSPI3_SOUT   0x1FC 0x440 0x608 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_06_GPIO10_IO27   0x1FC 0x440 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_07_VIDEO_MUX_LCDIF_DATA03   0x200 0x444 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_07_ENET_1G_TX_DATA02   0x200 0x444 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B1_07_LPUART4_RTS_B   0x200 0x444 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_07_TMR3_TIMER1   0x200 0x444 0x658 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_07_XBAR1_INOUT33   0x200 0x444 0x70C 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_07_GPIO_MUX4_IO28   0x200 0x444 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_07_SRC_BT_CFG01   0x200 0x444 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B1_07_ENET_QOS_TX_DATA02   0x200 0x444 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_07_LPSPI3_PCS0   0x200 0x444 0x5F0 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_07_GPIO10_IO28   0x200 0x444 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_08_GPIO10_IO29   0x204 0x448 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_08_VIDEO_MUX_LCDIF_DATA04   0x204 0x448 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_08_ENET_1G_TX_DATA01   0x204 0x448 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B1_08_USDHC1_CD_B   0x204 0x448 0x6C8 0x2 1
#define IMXRT_PAD_GPIO_DISP_B1_08_TMR3_TIMER2   0x204 0x448 0x65C 0x3 1
#define IMXRT_PAD_GPIO_DISP_B1_08_XBAR1_INOUT34   0x204 0x448 0x710 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_08_GPIO_MUX4_IO29   0x204 0x448 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_08_SRC_BT_CFG02   0x204 0x448 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B1_08_ENET_QOS_TX_DATA01   0x204 0x448 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_08_LPSPI3_PCS1   0x204 0x448 0x5F4 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_09_VIDEO_MUX_LCDIF_DATA05   0x208 0x44C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_09_ENET_1G_TX_DATA00   0x208 0x44C 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B1_09_USDHC1_WP   0x208 0x44C 0x6CC 0x2 1
#define IMXRT_PAD_GPIO_DISP_B1_09_TMR4_TIMER0   0x208 0x44C 0x660 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_09_XBAR1_INOUT35   0x208 0x44C 0x714 0x4 1
#define IMXRT_PAD_GPIO_DISP_B1_09_GPIO_MUX4_IO30   0x208 0x44C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_09_SRC_BT_CFG03   0x208 0x44C 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B1_09_ENET_QOS_TX_DATA00   0x208 0x44C 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_09_LPSPI3_PCS2   0x208 0x44C 0x5F8 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_09_GPIO10_IO30   0x208 0x44C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_10_VIDEO_MUX_LCDIF_DATA06   0x20C 0x450 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_10_ENET_1G_TX_EN   0x20C 0x450 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B1_10_USDHC1_RESET_B   0x20C 0x450 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B1_10_TMR4_TIMER1   0x20C 0x450 0x664 0x3 2
#define IMXRT_PAD_GPIO_DISP_B1_10_XBAR1_INOUT36   0x20C 0x450 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B1_10_GPIO_MUX4_IO31   0x20C 0x450 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_10_SRC_BT_CFG04   0x20C 0x450 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B1_10_ENET_QOS_TX_EN   0x20C 0x450 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_10_LPSPI3_PCS3   0x20C 0x450 0x5FC 0x9 1
#define IMXRT_PAD_GPIO_DISP_B1_10_GPIO10_IO31   0x20C 0x450 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B1_11_VIDEO_MUX_LCDIF_DATA07   0x210 0x454 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_1G_TX_CLK_IO   0x210 0x454 0x4E8 0x1 2
#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_1G_REF_CLK   0x210 0x454 0x4C4 0x2 2
#define IMXRT_PAD_GPIO_DISP_B1_11_TMR4_TIMER2   0x210 0x454 0x668 0x3 1
#define IMXRT_PAD_GPIO_DISP_B1_11_XBAR1_INOUT37   0x210 0x454 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B1_11_GPIO_MUX5_IO00   0x210 0x454 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B1_11_SRC_BT_CFG05   0x210 0x454 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_QOS_TX_CLK   0x210 0x454 0x4A4 0x8 0
#define IMXRT_PAD_GPIO_DISP_B1_11_ENET_QOS_REF_CLK   0x210 0x454 0x4A0 0x9 2
#define IMXRT_PAD_GPIO_DISP_B1_11_GPIO11_IO00   0x210 0x454 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_00_GPIO11_IO01   0x214 0x458 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_00_VIDEO_MUX_LCDIF_DATA08   0x214 0x458 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_00_WDOG1_B   0x214 0x458 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_00_MQS_RIGHT   0x214 0x458 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_00_ENET_1G_TX_ER   0x214 0x458 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_00_SAI1_TX_DATA03   0x214 0x458 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_00_GPIO_MUX5_IO01   0x214 0x458 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_00_SRC_BT_CFG06   0x214 0x458 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_00_ENET_QOS_TX_ER   0x214 0x458 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_01_VIDEO_MUX_LCDIF_DATA09   0x218 0x45C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_01_USDHC1_VSELECT   0x218 0x45C 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_01_MQS_LEFT   0x218 0x45C 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_01_WDOG2_B   0x218 0x45C 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_01_SAI1_TX_DATA02   0x218 0x45C 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_01_GPIO_MUX5_IO02   0x218 0x45C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_01_SRC_BT_CFG07   0x218 0x45C 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_01_EWM_OUT_B   0x218 0x45C 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_01_CCM_ENET_REF_CLK_25M   0x218 0x45C 0 0x9 0
#define IMXRT_PAD_GPIO_DISP_B2_01_GPIO11_IO02   0x218 0x45C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_02_GPIO11_IO03   0x21C 0x460 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_02_VIDEO_MUX_LCDIF_DATA10   0x21C 0x460 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_02_ENET_TX_DATA00   0x21C 0x460 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_02_PIT1_TRIGGER3   0x21C 0x460 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_02_ARM_TRACE00   0x21C 0x460 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_02_SAI1_TX_DATA01   0x21C 0x460 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_02_GPIO_MUX5_IO03   0x21C 0x460 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_02_SRC_BT_CFG08   0x21C 0x460 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_02_ENET_QOS_TX_DATA00   0x21C 0x460 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_03_GPIO11_IO04   0x220 0x464 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_03_VIDEO_MUX_LCDIF_DATA11   0x220 0x464 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_03_ENET_TX_DATA01   0x220 0x464 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_03_PIT1_TRIGGER2   0x220 0x464 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_03_ARM_TRACE01   0x220 0x464 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_03_SAI1_MCLK   0x220 0x464 0x66C 0x4 1
#define IMXRT_PAD_GPIO_DISP_B2_03_GPIO_MUX5_IO04   0x220 0x464 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_03_SRC_BT_CFG09   0x220 0x464 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_03_ENET_QOS_TX_DATA01   0x220 0x464 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_04_VIDEO_MUX_LCDIF_DATA12   0x224 0x468 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_04_ENET_TX_EN   0x224 0x468 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_04_PIT1_TRIGGER1   0x224 0x468 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_04_ARM_TRACE02   0x224 0x468 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_04_SAI1_RX_SYNC   0x224 0x468 0x678 0x4 1
#define IMXRT_PAD_GPIO_DISP_B2_04_GPIO_MUX5_IO05   0x224 0x468 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_04_SRC_BT_CFG10   0x224 0x468 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_04_ENET_QOS_TX_EN   0x224 0x468 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_04_GPIO11_IO05   0x224 0x468 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_05_GPIO11_IO06   0x228 0x46C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_05_VIDEO_MUX_LCDIF_DATA13   0x228 0x46C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_05_ENET_TX_CLK   0x228 0x46C 0x4C0 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_05_ENET_REF_CLK   0x228 0x46C 0x4A8 0x2 1
#define IMXRT_PAD_GPIO_DISP_B2_05_ARM_TRACE03   0x228 0x46C 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_05_SAI1_RX_BCLK   0x228 0x46C 0x670 0x4 1
#define IMXRT_PAD_GPIO_DISP_B2_05_GPIO_MUX5_IO06   0x228 0x46C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_05_SRC_BT_CFG11   0x228 0x46C 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_05_ENET_QOS_TX_CLK   0x228 0x46C 0x4A4 0x8 1
#define IMXRT_PAD_GPIO_DISP_B2_06_GPIO11_IO07   0x22C 0x470 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_06_VIDEO_MUX_LCDIF_DATA14   0x22C 0x470 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_06_ENET_RX_DATA00   0x22C 0x470 0x4B0 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_06_LPUART7_TXD   0x22C 0x470 0x630 0x2 1
#define IMXRT_PAD_GPIO_DISP_B2_06_ARM_TRACE_CLK   0x22C 0x470 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_06_SAI1_RX_DATA00   0x22C 0x470 0x674 0x4 1
#define IMXRT_PAD_GPIO_DISP_B2_06_GPIO_MUX5_IO07   0x22C 0x470 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_06_ENET_QOS_RX_DATA00   0x22C 0x470 0x4F0 0x8 1
#define IMXRT_PAD_GPIO_DISP_B2_07_VIDEO_MUX_LCDIF_DATA15   0x230 0x474 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_07_ENET_RX_DATA01   0x230 0x474 0x4B4 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_07_LPUART7_RXD   0x230 0x474 0x62C 0x2 1
#define IMXRT_PAD_GPIO_DISP_B2_07_ARM_TRACE_SWO   0x230 0x474 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_07_SAI1_TX_DATA00   0x230 0x474 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_07_GPIO_MUX5_IO08   0x230 0x474 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_07_ENET_QOS_RX_DATA01   0x230 0x474 0x4F4 0x8 1
#define IMXRT_PAD_GPIO_DISP_B2_07_GPIO11_IO08   0x230 0x474 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_08_GPIO11_IO09   0x234 0x478 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_08_VIDEO_MUX_LCDIF_DATA16   0x234 0x478 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_08_ENET_RX_EN   0x234 0x478 0x4B8 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_08_LPUART8_TXD   0x234 0x478 0x638 0x2 1
#define IMXRT_PAD_GPIO_DISP_B2_08_ARM_CM7_EVENTO   0x234 0x478 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_08_SAI1_TX_BCLK   0x234 0x478 0x67C 0x4 1
#define IMXRT_PAD_GPIO_DISP_B2_08_GPIO_MUX5_IO09   0x234 0x478 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_08_ENET_QOS_RX_EN   0x234 0x478 0x4F8 0x8 1
#define IMXRT_PAD_GPIO_DISP_B2_08_LPUART1_TXD   0x234 0x478 0x620 0x9 2
#define IMXRT_PAD_GPIO_DISP_B2_09_GPIO11_IO10   0x238 0x47C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_09_VIDEO_MUX_LCDIF_DATA17   0x238 0x47C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_09_ENET_RX_ER   0x238 0x47C 0x4BC 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_09_LPUART8_RXD   0x238 0x47C 0x634 0x2 1
#define IMXRT_PAD_GPIO_DISP_B2_09_ARM_CM7_EVENTI   0x238 0x47C 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_09_SAI1_TX_SYNC   0x238 0x47C 0x680 0x4 1
#define IMXRT_PAD_GPIO_DISP_B2_09_GPIO_MUX5_IO10   0x238 0x47C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_09_ENET_QOS_RX_ER   0x238 0x47C 0x4FC 0x8 1
#define IMXRT_PAD_GPIO_DISP_B2_09_LPUART1_RXD   0x238 0x47C 0x61C 0x9 2
#define IMXRT_PAD_GPIO_DISP_B2_10_GPIO11_IO11   0x23C 0x480 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_10_VIDEO_MUX_LCDIF_DATA18   0x23C 0x480 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_10_EMVSIM2_IO   0x23C 0x480 0x6A8 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_10_LPUART2_TXD   0x23C 0x480 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_10_WDOG2_RESET_B_DEB   0x23C 0x480 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_10_XBAR1_INOUT38   0x23C 0x480 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_10_GPIO_MUX5_IO11   0x23C 0x480 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_10_LPI2C3_SCL   0x23C 0x480 0x5BC 0x6 1
#define IMXRT_PAD_GPIO_DISP_B2_10_ENET_QOS_RX_ER   0x23C 0x480 0x4FC 0x8 2
#define IMXRT_PAD_GPIO_DISP_B2_10_SPDIF_IN   0x23C 0x480 0x6B4 0x9 2
#define IMXRT_PAD_GPIO_DISP_B2_11_VIDEO_MUX_LCDIF_DATA19   0x240 0x484 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_11_EMVSIM2_CLK   0x240 0x484 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_11_LPUART2_RXD   0x240 0x484 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_11_WDOG1_RESET_B_DEB   0x240 0x484 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_11_XBAR1_INOUT39   0x240 0x484 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_11_GPIO_MUX5_IO12   0x240 0x484 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_11_LPI2C3_SDA   0x240 0x484 0x5C0 0x6 1
#define IMXRT_PAD_GPIO_DISP_B2_11_ENET_QOS_CRS   0x240 0x484 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_11_SPDIF_OUT   0x240 0x484 0 0x9 0
#define IMXRT_PAD_GPIO_DISP_B2_11_GPIO11_IO12   0x240 0x484 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_12_GPIO11_IO13   0x244 0x488 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_12_VIDEO_MUX_LCDIF_DATA20   0x244 0x488 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_12_EMVSIM2_RST   0x244 0x488 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_12_FLEXCAN1_TX   0x244 0x488 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_12_LPUART2_CTS_B   0x244 0x488 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_12_XBAR1_INOUT40   0x244 0x488 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_12_GPIO_MUX5_IO13   0x244 0x488 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_12_LPI2C4_SCL   0x244 0x488 0x5C4 0x6 1
#define IMXRT_PAD_GPIO_DISP_B2_12_ENET_QOS_COL   0x244 0x488 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_12_LPSPI4_SCK   0x244 0x488 0x610 0x9 1
#define IMXRT_PAD_GPIO_DISP_B2_13_GPIO11_IO14   0x248 0x48C 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_13_VIDEO_MUX_LCDIF_DATA21   0x248 0x48C 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_13_EMVSIM2_SVEN   0x248 0x48C 0 0x1 0
#define IMXRT_PAD_GPIO_DISP_B2_13_FLEXCAN1_RX   0x248 0x48C 0x498 0x2 1
#define IMXRT_PAD_GPIO_DISP_B2_13_LPUART2_RTS_B   0x248 0x48C 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_13_ENET_REF_CLK   0x248 0x48C 0x4A8 0x4 2
#define IMXRT_PAD_GPIO_DISP_B2_13_GPIO_MUX5_IO14   0x248 0x48C 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_13_LPI2C4_SDA   0x248 0x48C 0x5C8 0x6 1
#define IMXRT_PAD_GPIO_DISP_B2_13_ENET_QOS_1588_EVENT0_OUT   0x248 0x48C 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_13_LPSPI4_SIN   0x248 0x48C 0x614 0x9 1
#define IMXRT_PAD_GPIO_DISP_B2_14_GPIO_MUX5_IO15   0x24C 0x490 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_14_FLEXCAN1_TX   0x24C 0x490 0 0x6 0
#define IMXRT_PAD_GPIO_DISP_B2_14_ENET_QOS_1588_EVENT0_IN   0x24C 0x490 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_14_LPSPI4_SOUT   0x24C 0x490 0x618 0x9 1
#define IMXRT_PAD_GPIO_DISP_B2_14_GPIO11_IO15   0x24C 0x490 0 0xA 0
#define IMXRT_PAD_GPIO_DISP_B2_14_VIDEO_MUX_LCDIF_DATA22   0x24C 0x490 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_14_EMVSIM2_PD   0x24C 0x490 0x6AC 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_14_WDOG2_B   0x24C 0x490 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_14_VIDEO_MUX_EXT_DCIC1   0x24C 0x490 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_14_ENET_1G_REF_CLK   0x24C 0x490 0x4C4 0x4 3
#define IMXRT_PAD_GPIO_DISP_B2_15_VIDEO_MUX_LCDIF_DATA23   0x250 0x494 0 0x0 0
#define IMXRT_PAD_GPIO_DISP_B2_15_EMVSIM2_POWER_FAIL   0x250 0x494 0x6B0 0x1 1
#define IMXRT_PAD_GPIO_DISP_B2_15_WDOG1_B   0x250 0x494 0 0x2 0
#define IMXRT_PAD_GPIO_DISP_B2_15_VIDEO_MUX_EXT_DCIC2   0x250 0x494 0 0x3 0
#define IMXRT_PAD_GPIO_DISP_B2_15_PIT1_TRIGGER0   0x250 0x494 0 0x4 0
#define IMXRT_PAD_GPIO_DISP_B2_15_GPIO_MUX5_IO16   0x250 0x494 0 0x5 0
#define IMXRT_PAD_GPIO_DISP_B2_15_FLEXCAN1_RX   0x250 0x494 0x498 0x6 2
#define IMXRT_PAD_GPIO_DISP_B2_15_ENET_QOS_1588_EVENT0_AUX_IN   0x250 0x494 0 0x8 0
#define IMXRT_PAD_GPIO_DISP_B2_15_LPSPI4_PCS0   0x250 0x494 0x60C 0x9 1
#define IMXRT_PAD_GPIO_DISP_B2_15_GPIO11_IO16   0x250 0x494 0 0xA 0
Pin function definitions for i.MXRT1166.
Note: This file is basically a reformatted version of the fsl_iomuxc.h. RTEMS uses a driver based on the FreeBSD iomux driver for the i.mx6. That driver expects a different order of the values.
