RTEMS
6.1-rc1
bsps
arm
altera-cyclone-v
i2c
i2cdrv-config.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
9
10
* Copyright (c) 2014 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef XXX_H
35
#define XXX_H
36
37
rtems.h
38
bsp/alt_i2c.h
39
40
#ifdef __cplusplus
41
extern
"C"
42
#endif
/* __cplusplus */
43
44
typedef
struct
45
ALT_I2C_CTLR_t
controller;
46
char
*device_name;
47
uint32_t speed;
48
i2cdrv_configuration
49
50
extern
const
i2cdrv_config[];
51
52
#ifdef __cplusplus
53
54
#endif
/* __cplusplus */
55
56
#endif
/* XXX_H */
alt_i2c.h
ALT_I2C_CTLR_t
enum ALT_I2C_CTLR_e ALT_I2C_CTLR_t
rtems.h
Definition:
i2cdrv-config.h:44
