RTEMS 6.1-rc1
Modules | |
DMA Interface | |
General Call | |
Interrupt and Status Conditions | |
RX FIFO Management | |
SDA Hold Time Configuration | |
TX FIFO Management | |
struct | ALT_I2C_DEV_s |
struct | ALT_I2C_MASTER_CONFIG_s |
struct | ALT_I2C_SLAVE_CONFIG_s |
#define | alt_i2c_cfg_to_speed(i2c_dev, speed_in_hz, cfg) alt_i2c_master_config_speed_get((i2c_dev), (cfg), (speed_in_hz)) |
#define | alt_i2c_speed_to_cfg(i2c_dev, speed_in_hz, cfg) alt_i2c_master_config_speed_set((i2c_dev), (cfg), (speed_in_hz)) |
Typedefs | |
typedef enum ALT_I2C_TRANSFER_TYPE_e | ALT_I2C_TRANSFER_TYPE_t |
typedef struct ALT_I2C_DEV_s | ALT_I2C_DEV_t |
typedef enum ALT_I2C_CTLR_e | ALT_I2C_CTLR_t |
typedef enum ALT_I2C_MODE_e | ALT_I2C_MODE_t |
typedef enum ALT_I2C_SPEED_e | ALT_I2C_SPEED_t |
typedef enum ALT_I2C_ADDR_MODE_e | ALT_I2C_ADDR_MODE_t |
typedef enum ALT_I2C_STATUS_e | ALT_I2C_STATUS_t |
typedef enum ALT_I2C_TX_ABORT_CAUSE_e | ALT_I2C_TX_ABORT_CAUSE_t |
typedef struct ALT_I2C_MASTER_CONFIG_s | ALT_I2C_MASTER_CONFIG_t |
typedef struct ALT_I2C_SLAVE_CONFIG_s | ALT_I2C_SLAVE_CONFIG_t |
This module defines an API for configuring and managing the HPS I2C controllers.
The I2C controller provides support for a communication link between integrated circuits on a board. It is a simple two-wire bus which consists of a serial data line (SDA) and a serial clock (SCL) for use in applications such as temperature sensors and voltage level translators to EEPROMs, A/D and D/A converters, CODECs, and many types of microprocessors.
The Hard Processor System (HPS) provides four I2C controllers to enable system software to communicate serially with I2C buses. Each I2C controller can operate in master or slave mode, and support standard mode of up to 100 kilobits per second (Kbps) or fast mode of up to 400 Kbps. These I2C controllers are instances of the Synopsys DesignWare APB I2C (DW_apb_i2c) controller.
NOTE: Each I2C controller must be programmed to operate in either master or slave mode only. Operating as a master and slave simultaneously is not supported.
Features of the I2C Controller:
For a complete details on the configuration and operation of I2C controller, consult the following references:
#define alt_i2c_cfg_to_speed | ( | i2c_dev, | |
speed_in_hz, | |||
cfg | |||
) | alt_i2c_master_config_speed_get((i2c_dev), (cfg), (speed_in_hz)) |
Definition included for backwards compatibility.
#define alt_i2c_speed_to_cfg | ( | i2c_dev, | |
speed_in_hz, | |||
cfg | |||
) | alt_i2c_master_config_speed_set((i2c_dev), (cfg), (speed_in_hz)) |
typedef enum ALT_I2C_ADDR_MODE_e ALT_I2C_ADDR_MODE_t |
This type enumerates the two addressing modes formats supported by the I2C controller.
The I2C controller does not support mixed address format - that is, a 7-bit address transaction followed by a 10-bit address transaction or vice versa - combined format transactions.
typedef enum ALT_I2C_CTLR_e ALT_I2C_CTLR_t |
This type enumerates the HPS I2C controller instances.
typedef struct ALT_I2C_MASTER_CONFIG_s ALT_I2C_MASTER_CONFIG_t |
This type defines a structure for configuration of the SCL high and low counts to ensure proper I/O timing with the device interface.
The SCL count values are only relevant if the I2C controller is enabled to as an I2C master. The SCL count values are ignored when the I2C controller is enabled as an I2C slave.
See: Clock Frequency Configuration section of Chapter 20. I2C Controller in the Cyclone V Device Handbook Volume 3: Hard Processor System Technical Reference Manual for a complete discussion of calculation of the proper SCL clock high and low times.
typedef enum ALT_I2C_MODE_e ALT_I2C_MODE_t |
This type enumerates the modes that the I2C controller may operate in.
typedef struct ALT_I2C_SLAVE_CONFIG_s ALT_I2C_SLAVE_CONFIG_t |
This type defines a structure for configuration of the I2C controller when it is operating in slave mode.
typedef enum ALT_I2C_SPEED_e ALT_I2C_SPEED_t |
This type enumerates the I2C controller operational speed modes.
The I2C controller can operate in standard mode (with data rates 0 to 100 Kbps) or fast mode (with data rates less than or equal to 400 Kbps). Additionally, fast mode devices are downward compatible. For instance, fast mode devices can communicate with standard mode devices in 0 to 100 Kbps I2C bus system. However, standard mode devices are not upward compatible and should not be incorporated in a fast-mode I2C bus system as they cannot follow the higher transfer rate and therefore unpredictable states would occur.
This setting is relevant only if one is operating the I2C in master mode.
typedef enum ALT_I2C_STATUS_e ALT_I2C_STATUS_t |
This type enumerates interrupt status conditions for the I2C controller.
typedef enum ALT_I2C_TRANSFER_TYPE_e ALT_I2C_TRANSFER_TYPE_t |
This type definition enumerates the operational state of I2C by transfer operation.
typedef enum ALT_I2C_TX_ABORT_CAUSE_e ALT_I2C_TX_ABORT_CAUSE_t |
This type enumerates the source causes of a ALT_I2C_STATUS_TX_ABORT condition.
The active ALT_I2C_TX_ABORT_CAUSE_t source conditions are cleared when alt_i2c_int_clear() with is called ALT_I2C_STATUS_TX_ABORT in the mask or alt_i2c_int_clear() is called with ALT_I2C_STATUS_ALL in the mask.
Enumerator | |
ALT_I2C_ADDR_MODE_7_BIT | 7-Bit Address Format |
ALT_I2C_ADDR_MODE_10_BIT | 10-Bit Address Format |
Enumerator | |
ALT_I2C_MODE_SLAVE | Slave Mode |
ALT_I2C_MODE_MASTER | Master Mode |
Enumerator | |
ALT_I2C_SPEED_STANDARD | Standard mode (0 to 100 Kbps) |
ALT_I2C_SPEED_FAST | Fast mode (<= 400 Kbps) |
Enumerator | |
ALT_I2C_STATUS_RX_UNDER | Set if the processor attempts to read the receive buffer when it is empty. If the I2C controller is disabled, this status keeps maintains its state until the master or slave state machines go into idle, then this interrupt is cleared. |
ALT_I2C_STATUS_RX_OVER | Set if the receive buffer is completely filled to capacity and an additional byte is received from an external I2C device. The I2C controller acknowledges this, but any data bytes received after the FIFO is full are discarded. If the I2C controller is disabled, this status maintains its statue until the master or slave state machines go into idle, then this interrupt is cleared. |
ALT_I2C_STATUS_RX_FULL | Set when the receive buffer reaches or goes above the RX_TL threshold. It is automatically cleared by hardware when buffer level goes below the threshold. If the I2C controller is disabled, the RX FIFO is flushed and held in reset; therefore the RX FIFO is not full. So this bit is cleared once the I2C controller is disabled, regardless of the activity that continues. |
ALT_I2C_STATUS_TX_OVER | Set during transmit if the transmit buffer is filled to capacity and the processor attempts to issue another I2C command. When the I2C controller is disabled, this bit maintains its state until the master or slave state machines go into idle, then this interrupt is cleared. |
ALT_I2C_STATUS_TX_EMPTY | This bit is set to 1 when the transmit buffer is at or below the configured threshold value. It is automatically cleared by hardware when the buffer level goes above the threshold. When the I2C controller is disabled, the TX FIFO is flushed and held in reset. The TX FIFO appears as if it has no data in it, so this bit is set to 1, provided there is activity in the master or slave state machines. When there is no longer activity, then this bit is set to 0. |
ALT_I2C_STATUS_RD_REQ | This bit is set to 1 when I2C is acting as a slave and another I2C master is attempting to read data from the I2C. The I2C holds the bus in a wait state until this interrupt is serviced, which means that the slave has been addressed by a remote master that is asking for data to be transferred. The processor must respond to this interrupt and then write the requested data. This bit is set to 0 just after the processor by calling alt_i2c_int_clear() with ALT_I2C_STATUS_RD_REQ in the mask.. |
ALT_I2C_STATUS_TX_ABORT | This bit indicates if I2C, as an I2C transmitter, is unable to complete the intended actions on the contents of the transmit FIFO. This situation can occur both as an I2C master or an I2C slave, and is referred to as a 'transmit abort'. When this bit is set to 1, the IC_TX_ABRT_SOURCE register indicates the reason why the transmit abort takes places. NOTE: The I2C flushes/resets/empties the TX FIFO whenever this bit is set. The TX FIFO remains in this flushed state until the register alt_i2c_int_clear() with ALT_I2C_STATUS_TX_ABORT in the mask is called. Once this happens, the TX FIFO is then ready to accept more data bytes from the APB interface. |
ALT_I2C_STATUS_RX_DONE | When the I2C is acting as a slave-transmitter, this bit is set to 1 if the master does not acknowledge a transmitted byte. This occurs on the last byte of the transmission, indicating that the transmission is done. |
ALT_I2C_STATUS_ACTIVITY | This bit captures I2C activity and stays set until it is cleared. There are four ways to clear it:
Once this bit is set, it stays set unless one of the four methods is used to clear it. Even if the I2C module is idle, this bit remains set until cleared, indicating that there was activity on the bus. |
ALT_I2C_STATUS_STOP_DET | Indicates whether a STOP condition has occurred on the I2C interface regardless of whether I2C is operating in slave or master mode. |
ALT_I2C_STATUS_START_DET | Indicates whether a START or RESTART condition has occurred on the I2C interface regardless of whether I2C is operating in slave or master mode. |
ALT_I2C_STATUS_INT_CALL | Set only when a General Call address is received and it is acknowledged. It stays set until it is cleared either by disabling I2C or when alt_i2c_int_clear() with ALT_I2C_STATUS_CALL in the mask is called. I2C stores the received data in the Rx buffer. |
ALT_I2C_STATUS_INT_ALL | All Combined and Individual Interrupts. This enumeration value can be used to clear, disable, and enable the combined interrupt and all individual interrupt status conditions. As a side effect, when passed to alt_i2c_int_clear(), clears the source causes (ALT_I2C_TX_ABORT_CAUSE_t) of the ALT_I2C_STATUS_TX_ABORT condition. |
ALT_STATUS_CODE alt_i2c_disable | ( | ALT_I2C_DEV_t * | i2c_dev | ) |
Disables the I2C controller.
When the I2C controller is disabled, the following occurs:
If the controller is transmitting, it stops as well as deletes the contents of the transmit buffer after the current transfer is complete. If the module is receiving, the controller stops the current transfer at the end of the current byte and does not acknowledge the transfer.
i2c_dev | A pointer to the I2C controller device block instance. |
ALT_E_SUCCESS | Successful status. |
ALT_E_ERROR | Details about error status code |
ALT_STATUS_CODE alt_i2c_enable | ( | ALT_I2C_DEV_t * | i2c_dev | ) |
Enables the I2C controller.
ALT_STATUS_CODE alt_i2c_init | ( | const ALT_I2C_CTLR_t | i2c, |
ALT_I2C_DEV_t * | i2c_dev | ||
Initialize the specified I2C controller instance for use and return a device handle referencing it.
i2c | The HPS I2C controller instance to initialize. |
ALT_STATUS_CODE alt_i2c_is_busy | ( | ALT_I2C_DEV_t * | i2c_dev | ) |
Returns ALT_E_TRUE if the I2C controller is busy. The I2C controller is busy if either the Slave Finite State Machine (FSM) is not in the IDLE state or the Master Finite State Machine (FSM) is not in the IDLE state.
ALT_STATUS_CODE alt_i2c_is_enabled | ( | ALT_I2C_DEV_t * | i2c_dev | ) |
Returns ALT_E_TRUE if the I2C controller is enabled.
ALT_STATUS_CODE alt_i2c_issue_read | ( | ALT_I2C_DEV_t * | i2c_dev, |
const bool | issue_restart, | ||
const bool | issue_stop | ||
This function causes the I2C controller master to issue a READ request on the bus. This function is typically used during master-receiver transfers.
The I2C controller must be in master mode before calling this function.
issue_restart | This parameter controls whether a RESTART is issued before the byte is sent or received. If:
issue_stop | This parameter controls whether a STOP is issued after the byte is sent or received. If:
ALT_STATUS_CODE alt_i2c_issue_write | ( | ALT_I2C_DEV_t * | i2c_dev, |
const uint8_t | value, | ||
This function causes the I2C controller master to issue a send byte on the bus. This function is typically used during master-transmitter/slave-transmitter transfers.
value | The data item to be transmitted. |
ALT_STATUS_CODE alt_i2c_master_config_get | ( | ALT_I2C_DEV_t * | i2c_dev, |
ALT_I2C_MASTER_CONFIG_t * | cfg | ||
Gets the current configuration of the I2C controller when operating in master mode.
cfg | [out] Pointer to a ALT_I2C_MASTER_CONFIG_t structure for holding the returned I2C master mode configuration parameters. |
ALT_STATUS_CODE alt_i2c_master_config_set | ( | ALT_I2C_DEV_t * | i2c_dev, |
const ALT_I2C_MASTER_CONFIG_t * | cfg | ||
Sets the configuration of the I2C controller with operational parameters for operating in master mode.
cfg | Pointer to a ALT_I2C_MASTER_CONFIG_t structure holding the desired I2C master mode operational parameters. |
ALT_STATUS_CODE alt_i2c_master_config_speed_get | ( | ALT_I2C_DEV_t * | i2c_dev, |
const ALT_I2C_MASTER_CONFIG_t * | cfg, | ||
uint32_t * | speed_in_hz | ||
This is a utility function that returns the speed based on parameters of the I2C master configuration.
cfg | A pointer to the master confugurations. |
speed_in_hz | [out] Speed (Hz) of the I2C bus currently configured at. |
ALT_STATUS_CODE alt_i2c_master_config_speed_set | ( | ALT_I2C_DEV_t * | i2c_dev, |
uint32_t | speed_in_hz | ||
This is a utility function that computes parameters for the I2C master configuration that best matches the speed requested.
speed_in_hz | Speed (Hz) of the I2C bus to configure. |
ALT_STATUS_CODE alt_i2c_master_receive | ( | ALT_I2C_DEV_t * | i2c_dev, |
void * | data, | ||
const size_t | size, | ||
This function acts in the role of a master-receiver by receiving one or more data bytes transmitted from a slave in response to read requests issued from this master.
This function causes the master to issue the required number of read requests to the slave and read the received data bytes from the Rx FIFO.
The issue_restart and issue_stop parameters apply to the final read request transaction in the num_data_entries sequence required to fulfill the aggregate receive request.
This API is not suitable for being called in an interrupt context as it may wait for certain controller states before completing.
data | [out] The data buffer to receive the requested size bytes. |
size | The size of the data buffer to read from the RX FIFO. |
ALT_STATUS_CODE alt_i2c_master_target_get | ( | ALT_I2C_DEV_t * | i2c_dev, |
uint32_t * | target_addr | ||
This function returns the current target address.
target_addr | [out] The 7 or 10 bit slave target address. |
ALT_E_ERROR | Details about error status code. |
ALT_STATUS_CODE alt_i2c_master_target_set | ( | ALT_I2C_DEV_t * | i2c_dev, |
uint32_t | target_addr | ||
This function updates the target slave address for any upcoming I2C bus IO.
This API is not suitlabe for being called in an interrupt context as it will wait for the TX FIFO to flush before applying the changes. If the TX FIFO is known to be empty and the controller idle, then it can be safely called.
target_addr | The 7 or 10 bit slave target address. |
ALT_STATUS_CODE alt_i2c_master_transmit | ( | ALT_I2C_DEV_t * | i2c_dev, |
const void * | data, | ||
This function acts in the role of a master-transmitter by issuing a write command and transmitting data to the I2C bus.
data | A pointer to a data buffer to transmit |
size | The size of the data buffer in bytes to place in the TX FIFO. |
ALT_STATUS_CODE alt_i2c_op_mode_get | ( | ALT_I2C_DEV_t * | i2c_dev, |
ALT_I2C_MODE_t * | mode | ||
Gets the current operational mode of the I2C controller.
mode | [out] The current operational mode enabled for the I2C controller. |
ALT_STATUS_CODE alt_i2c_op_mode_set | ( | ALT_I2C_DEV_t * | i2c_dev, |
const ALT_I2C_MODE_t | mode | ||
Sets the operational mode of the I2C controller.
mode | The operational mode to enable for the I2C controller. |
ALT_STATUS_CODE alt_i2c_read | ( | ALT_I2C_DEV_t * | i2c_dev, |
uint8_t * | val | ||
This function reads a single data byte from the receive FIFO.
This function is used to perform low level access to the data bytes received by the I2C controller and buffered in the receive FIFO. It may be used by master-receivers or slave receivers.
This function does not check for valid data in the receive FIFO beforehand and may cause an underflow if improperly used. It is meant to be called from a context where preconditions have been previously asserted such as in the implementation of the alt_i2c_slave_receive() or alt_i2c_master_receive() function.
val | [out] The single data byte read from the receive FIFO. |
ALT_STATUS_CODE alt_i2c_reset | ( | ALT_I2C_DEV_t * | i2c_dev | ) |
Reset the specified I2C controller instance for use.
ALT_STATUS_CODE alt_i2c_slave_bulk_transmit | ( | ALT_I2C_DEV_t * | i2c_dev, |
const size_t | size | ||
This function acts in the role of a slave-transmitter by transmitting data in bulk to the I2C bus in response to a series of read requests from a master.
In the standard I2C protocol, all transactions are single byte transactions and the slave responds to a remote master read request by writing one byte into the slave's TX FIFO. When a slave (slave-transmitter) is issued with a read request from the remote master (master-receiver), at a minimum there should be at least one entry placed into the slave-transmitter's TX FIFO. The I2C controller is capable of handling more data in the TX FIFO so that subsequent read requests can receive that data without raising an interrupt or software having to poll to request more data. This eliminates overhead latencies from being incurred by servicing the interrupt or polling for data requests each time had there been a restriction of having only one entry placed in the TX FIFO.
If the remote master acknowledges the data sent by the slave-transmitter and there is no data in the slave's TX FIFO, the I2C controller raises the read request interrupt and waits for data to be written into the TX FIFO before it can be sent to the remote master.
If the programmer knows in advance that the master is requesting a packet of n bytes, then when another master request for data is received, the TX FIFO could be written with n number bytes and the master receives it as a continuous stream of data. For example, the slave continues to send data to the master as long as the master is acknowledging the data sent and there is data available in the TX FIFO. There is no need to hold the SCL line low or to issue READ request again.
If the remote master is to receive n bytes from the slave but the programmer wrote a number of bytes larger than n to the TX FIFO, then when the slave finishes sending the requested n bytes, it clears the TX FIFO and ignores any excess bytes.
This API is suitable for being called during an interrupt context. It is the programmer's responsibility to ensure that there is enough space in the TX FIFO to accomodate the request made.
The I2C controller must be in slave mode before calling this function.
data | A pointer to the data buffer to transmit. |
ALT_STATUS_CODE alt_i2c_slave_config_get | ( | ALT_I2C_DEV_t * | i2c_dev, |
ALT_I2C_SLAVE_CONFIG_t * | cfg | ||
Gets the current configuration of the I2C controller when operating in slave mode.
cfg | [out] Pointer to a ALT_I2C_SLAVE_CONFIG_t structure for holding the returned I2C slave mode configuration parameters. |
ALT_STATUS_CODE alt_i2c_slave_config_set | ( | ALT_I2C_DEV_t * | i2c_dev, |
const ALT_I2C_SLAVE_CONFIG_t * | cfg | ||
Sets the configuration of the I2C controller with operational parameters for operating in slave mode.
cfg | Pointer to a ALT_I2C_SLAVE_CONFIG_t structure holding the desired I2C slave mode operational parameters. |
ALT_STATUS_CODE alt_i2c_slave_receive | ( | ALT_I2C_DEV_t * | i2c_dev, |
uint8_t * | data | ||
This function acts in the role of a slave-receiver by receiving a single data byte from the I2C bus in response to a write command from the master.
This API is suitable for being called during an interrupt context. It is the programmer's responsibility to ensure that there is data in the RX FIFO to accomodate the request made.
data | [out] A pointer to a buffer to contain the received data byte. |
ALT_STATUS_CODE alt_i2c_slave_transmit | ( | ALT_I2C_DEV_t * | i2c_dev, |
const uint8_t | data | ||
This function acts in the role of a slave-transmitter by transmitting a single data byte to the I2C bus in response to a read request from the master.
data | The data byte to transmit. |
ALT_STATUS_CODE alt_i2c_uninit | ( | ALT_I2C_DEV_t * | i2c_dev | ) |
Uninitialize the I2C controller referenced by the i2c_dev handle.
This function attempts to gracefully shutdown the I2C controller by waiting for any inpcomplete transactions to finish and then putting the I2C controller into reset.
ALT_STATUS_CODE alt_i2c_write | ( | ALT_I2C_DEV_t * | i2c_dev, |
const uint8_t | val | ||
This function writes a single data byte to the transmit FIFO.
This function is used to perform low level writes of data to the transmit FIFO for transmission by the I2C controller. It may be used by slave receivers.
This function does not check whether the transmit FIFO is full or not beforehand and may cause an overflow if improperly used. It is meant to be called from a context where preconditions have been previously asserted such as in the implementation of the alt_i2c_slave_transmit() function.
val | The data byte to write to the transmission FIFO. |
