RTEMS 6.1-rc1
struct | XBARAControlConfig |
Defines the configuration structure of the XBARA control register. More... | |
#define | FSL_XBARA_DRIVER_VERSION (MAKE_VERSION(2, 0, 5)) |
#define | XBARA_SELx(base, output) (((volatile uint16_t *)(&((base)->SEL0)))[(uint32_t)(output) / 2UL]) |
#define | XBARA_WR_SELx_SELx(base, input, output) XBARA_SetSignalsConnection((base), (input), (output)) |
#define | kXBARA_RequestInterruptEnalbe kXBARA_RequestInterruptEnable |
Typedefs | |
typedef enum _xbara_active_edge | xbara_active_edge_t |
XBARA active edge for detection. | |
typedef enum _xbar_request | xbara_request_t |
Defines the XBARA DMA and interrupt configurations. | |
typedef enum _xbara_status_flag_t | xbara_status_flag_t |
XBARA status flags. More... | |
typedef struct XBARAControlConfig | xbara_control_config_t |
Enumerations | |
enum | _xbara_active_edge { kXBARA_EdgeNone = 0U , kXBARA_EdgeRising = 1U , kXBARA_EdgeFalling = 2U , kXBARA_EdgeRisingAndFalling = 3U } |
XBARA active edge for detection. More... | |
enum | _xbar_request { kXBARA_RequestDisable = 0U , kXBARA_RequestDMAEnable = 1U , kXBARA_RequestInterruptEnable = 2U } |
Defines the XBARA DMA and interrupt configurations. More... | |
enum | _xbara_status_flag_t { kXBARA_EdgeDetectionOut0 , kXBARA_EdgeDetectionOut1 , kXBARA_EdgeDetectionOut2 , kXBARA_EdgeDetectionOut3 } |
XBARA functional Operation. | |
void | XBARA_Init (XBARA_Type *base) |
Initializes the XBARA module. More... | |
void | XBARA_Deinit (XBARA_Type *base) |
Shuts down the XBARA module. More... | |
void | XBARA_SetSignalsConnection (XBARA_Type *base, xbar_input_signal_t input, xbar_output_signal_t output) |
Sets a connection between the selected XBARA_IN[*] input and the XBARA_OUT[*] output signal. More... | |
uint32_t | XBARA_GetStatusFlags (XBARA_Type *base) |
Gets the active edge detection status. More... | |
void | XBARA_ClearStatusFlags (XBARA_Type *base, uint32_t mask) |
Clears the edge detection status flags of relative mask. More... | |
void | XBARA_SetOutputSignalConfig (XBARA_Type *base, xbar_output_signal_t output, const xbara_control_config_t *controlConfig) |
Configures the XBARA control register. More... | |
typedef struct XBARAControlConfig xbara_control_config_t |
This structure keeps the configuration of XBARA control register for one output. Control registers are available only for a few outputs. Not every XBARA module has control registers.
typedef enum _xbara_status_flag_t xbara_status_flag_t |
XBARA status flags.
This provides constants for the XBARA status flags for use in the XBARA functions.
XBARA status flags.
void XBARA_ClearStatusFlags | ( | XBARA_Type * | base, |
uint32_t | mask | ||
base | XBARA peripheral address. |
mask | the status flags to clear. |
brief Clears the edge detection status flags of relative mask.
param base XBARA peripheral address. param mask the status flags to clear.
void XBARA_Deinit | ( | XBARA_Type * | base | ) |
This function disables XBARA clock.
brief Shuts down the XBARA module.
uint32_t XBARA_GetStatusFlags | ( | XBARA_Type * | base | ) |
This function gets the active edge detect status of all XBARA_OUTs. If the active edge occurs, the return value is asserted. When the interrupt or the DMA functionality is enabled for the XBARA_OUTx, this field is 1 when the interrupt or DMA request is asserted and 0 when the interrupt or DMA request has been cleared.
brief Gets the active edge detection status.
param base XBARA peripheral address. return the mask of these status flag bits.
void XBARA_Init | ( | XBARA_Type * | base | ) |
This function un-gates the XBARA clock.
brief Initializes the XBARA module.
void XBARA_SetOutputSignalConfig | ( | XBARA_Type * | base, |
xbar_output_signal_t | output, | ||
const xbara_control_config_t * | controlConfig | ||
This function configures an XBARA control register. The active edge detection and the DMA/IRQ function on the corresponding XBARA output can be set.
Example:
output | XBARA output number. |
controlConfig | Pointer to structure that keeps configuration of control register. |
brief Configures the XBARA control register.
Example: code xbara_control_config_t userConfig; userConfig.activeEdge = kXBARA_EdgeRising; userConfig.requestType = kXBARA_RequestInterruptEnalbe; XBARA_SetOutputSignalConfig(XBARA, kXBARA_OutputDMAMUX18, &userConfig); endcode
param base XBARA peripheral address. param output XBARA output number. param controlConfig Pointer to structure that keeps configuration of control register.
void XBARA_SetSignalsConnection | ( | XBARA_Type * | base, |
xbar_input_signal_t | input, | ||
xbar_output_signal_t | output | ||
This function connects the XBARA input to the selected XBARA output. If more than one XBARA module is available, only the inputs and outputs from the same module can be connected.
Example:
input | XBARA input signal. |
output | XBARA output signal. |
brief Sets a connection between the selected XBARA_IN[*] input and the XBARA_OUT[*] output signal.
Example: code XBARA_SetSignalsConnection(XBARA, kXBARA_InputPIT_TRG0, kXBARA_OutputDMAMUX18); endcode
param base XBARA peripheral address. param input XBARA input signal. param output XBARA output signal.
