RTEMS 6.1-rc1
Ttcps_v3_15
#define XTTCPS_HW_H   /* by using protection macros */
#define ARMA9
Register Map
Register offsets from the base address of the device.
#define XTTCPS_CLK_CNTRL_OFFSET   0x00000000U
#define XTTCPS_CNT_CNTRL_OFFSET   0x0000000CU
#define XTTCPS_COUNT_VALUE_OFFSET   0x00000018U
#define XTTCPS_INTERVAL_VAL_OFFSET   0x00000024U
#define XTTCPS_MATCH_0_OFFSET   0x00000030U
#define XTTCPS_MATCH_1_OFFSET   0x0000003CU
#define XTTCPS_MATCH_2_OFFSET   0x00000048U
#define XTTCPS_ISR_OFFSET   0x00000054U
#define XTTCPS_IER_OFFSET   0x00000060U
Clock Control Register
Clock Control Register definitions
#define XTTCPS_CLK_CNTRL_PS_EN_MASK   0x00000001U
#define XTTCPS_CLK_CNTRL_PS_VAL_MASK   0x0000001EU
#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT   1U
#define XTTCPS_CLK_CNTRL_PS_DISABLE   16U
#define XTTCPS_CLK_CNTRL_SRC_MASK   0x00000020U
#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK   0x00000040U
Counter Control Register
Counter Control Register definitions
#define XTTCPS_CNT_CNTRL_DIS_MASK   0x00000001U
#define XTTCPS_CNT_CNTRL_INT_MASK   0x00000002U
#define XTTCPS_CNT_CNTRL_DECR_MASK   0x00000004U
#define XTTCPS_CNT_CNTRL_MATCH_MASK   0x00000008U
#define XTTCPS_CNT_CNTRL_RST_MASK   0x00000010U
#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK   0x00000020U
#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK   0x00000040U
#define XTTCPS_CNT_CNTRL_RESET_VALUE   0x00000021U
Current Counter Value Register
Current Counter Value Register definitions
#define XTTCPS_COUNT_VALUE_MASK   0x0000FFFFU
Interval Value Register
Interval Value Register is the maximum value the counter will count up or down to.
#define XTTCPS_INTERVAL_VAL_MASK   0x0000FFFFU
Match Registers
Definitions for Match registers, each timer counter has three match registers.
#define XTTCPS_MATCH_MASK   0x0000FFFFU
#define XTTCPS_NUM_MATCH_REG   3U
Interrupt Registers
Following register bit mask is for all interrupt registers.
#define XTTCPS_IXR_INTERVAL_MASK   0x00000001U
#define XTTCPS_IXR_MATCH_0_MASK   0x00000002U
#define XTTCPS_IXR_MATCH_1_MASK   0x00000004U
#define XTTCPS_IXR_MATCH_2_MASK   0x00000008U
#define XTTCPS_IXR_CNT_OVR_MASK   0x00000010U
#define XTTCPS_IXR_ALL_MASK   0x0000001FU
#define XTtcPs_ReadReg(BaseAddress, RegOffset)    (Xil_In32((BaseAddress) + (u32)(RegOffset)))
#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data)    (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
#define XTtcPs_Match_N_Offset(MatchIndex)    ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
This file defines the hardware interface to one of the three timer counters in the Ps block.
MODIFICATION HISTORY:
Ver   Who    Date     Changes
1.00a drg/jz 01/21/10 First release 3.00 kvn 02/13/15 Modified code for MISRA-C:2012 compliance. 3.5 srm 10/06/17 Updated XTTCPS_COUNT_VALUE_MASK, XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK macros to mask 16 bit values for zynq and 32 bit values for zynq ultrascale+mpsoc "
◆ XTTCPS_CLK_CNTRL_EXT_EDGE_MASK
External Clock edge
◆ XTTCPS_CLK_CNTRL_OFFSET
◆ XTTCPS_CLK_CNTRL_PS_DISABLE
Prescale disable
◆ XTTCPS_CLK_CNTRL_PS_EN_MASK
Prescale enable
◆ XTTCPS_CLK_CNTRL_PS_VAL_MASK
Prescale value
◆ XTTCPS_CLK_CNTRL_PS_VAL_SHIFT
Prescale shift
◆ XTTCPS_CLK_CNTRL_SRC_MASK
Clock source
◆ XTTCPS_CNT_CNTRL_DECR_MASK
Decrement mode
◆ XTTCPS_CNT_CNTRL_DIS_MASK
Disable the counter
◆ XTTCPS_CNT_CNTRL_EN_WAVE_MASK
Enable waveform
◆ XTTCPS_CNT_CNTRL_INT_MASK
Interval mode
◆ XTTCPS_CNT_CNTRL_MATCH_MASK
Match mode
◆ XTTCPS_CNT_CNTRL_OFFSET
◆ XTTCPS_CNT_CNTRL_POL_WAVE_MASK
Waveform polarity
◆ XTTCPS_CNT_CNTRL_RESET_VALUE
Reset value
◆ XTTCPS_CNT_CNTRL_RST_MASK
Reset counter
◆ XTTCPS_COUNT_VALUE_MASK
16-bit counter value
◆ XTTCPS_COUNT_VALUE_OFFSET
◆ XTTCPS_IER_OFFSET
Interrupt Enable Register
◆ XTTCPS_INTERVAL_VAL_MASK
16-bit Interval value
◆ XTTCPS_INTERVAL_VAL_OFFSET
Interval Count Value
◆ XTTCPS_ISR_OFFSET
Interrupt Status Register
◆ XTTCPS_IXR_ALL_MASK
All valid Interrupts
◆ XTTCPS_IXR_CNT_OVR_MASK
Counter Overflow
◆ XTTCPS_IXR_INTERVAL_MASK
Interval Interrupt
◆ XTTCPS_IXR_MATCH_0_MASK
Match 1 Interrupt
◆ XTTCPS_IXR_MATCH_1_MASK
Match 2 Interrupt
◆ XTTCPS_IXR_MATCH_2_MASK
Match 3 Interrupt
◆ XTTCPS_MATCH_0_OFFSET
Match 1 value
◆ XTTCPS_MATCH_1_OFFSET
Match 2 value
◆ XTTCPS_MATCH_2_OFFSET
Match 3 value
◆ XTTCPS_MATCH_MASK
16-bit Match value
◆ XTtcPs_Match_N_Offset
#define XTtcPs_Match_N_Offset (   MatchIndex)     ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
Calculate a match register offset using the Match Register index.
Parameters
MatchIndexis the 0-2 value of the match register
Returns
MATCH_N_OFFSET.
Note
C-style signature: u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
◆ XTTCPS_NUM_MATCH_REG
Num of Match reg
◆ XTtcPs_ReadReg
#define XTtcPs_ReadReg (   BaseAddress,
  RegOffset
Read the given Timer Counter register.
Parameters
BaseAddressis the base address of the timer counter device.
RegOffsetis the register offset to be read
Returns
The 32-bit value of the register
Note
C-style signature: u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
◆ XTtcPs_WriteReg
#define XTtcPs_WriteReg (   BaseAddress,
  RegOffset,
  Data
Write the given Timer Counter register.
Parameters
RegOffsetis the register offset to be written
Datais the 32-bit value to write to the register
Returns
None.
Note
C-style signature: void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset, u32 Data)
