RTEMS 6.1-rc1
Driver version | |
enum | _src_reset_status_flags { kSRC_WarmBootIndicationFlag = SRC_SRSR_WBI_MASK , kSRC_TemperatureSensorResetFlag = SRC_SRSR_TSR_MASK , kSRC_JTAGSoftwareResetFlag = SRC_SRSR_SJC_MASK , kSRC_JTAGGeneratedResetFlag = SRC_SRSR_JTAG_MASK , kSRC_WatchdogResetFlag = SRC_SRSR_WDOG_MASK } |
SRC reset status flags. More... | |
enum | _src_warm_reset_bypass_count { kSRC_WarmResetWaitAlways = 0U , kSRC_WarmResetWaitClk16 = 1U , kSRC_WarmResetWaitClk32 = 2U , kSRC_WarmResetWaitClk64 = 3U } |
Selection of WARM reset bypass count. More... | |
typedef enum _src_warm_reset_bypass_count | src_warm_reset_bypass_count_t |
void | SRC_ClearResetStatusFlags (SRC_Type *base, uint32_t flags) |
Clear the status flags of SRC. More... | |
#define | FSL_SRC_DRIVER_VERSION (MAKE_VERSION(2, 0, 1)) |
SRC driver version 2.0.1. | |
This type defines the 32KHz clock cycles to count before bypassing the MMDC acknowledge for WARM reset. If the MMDC acknowledge is not asserted before this counter is elapsed, a COLD reset will be initiated.
void SRC_ClearResetStatusFlags | ( | SRC_Type * | base, |
uint32_t | flags | ||
base | SRC peripheral base address. |
flags | value of status flags to be cleared, see to _src_reset_status_flags. |
brief Clear the status flags of SRC.
param base SRC peripheral base address. param Mask value of status flags to be cleared, see to _src_reset_status_flags.
