RTEMS 6.1-rc1
Macros | Functions
Microblaze Cache APIs
#define Xil_L1DCacheInvalidate()   microblaze_invalidate_dcache()
 Invalidate the entire L1 data cache. If the cacheline is modified (dirty), the modified contents are lost. More...
#define Xil_L2CacheInvalidate()   microblaze_invalidate_cache_ext()
 Invalidate the entire L2 data cache. If the cacheline is modified (dirty),the modified contents are lost. More...
#define Xil_L1DCacheInvalidateRange(Addr, Len)    microblaze_invalidate_dcache_range((Addr), (Len))
 Invalidate the L1 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the L1 data cache, the cacheline containing that byte is invalidated.If the cacheline is modified (dirty), the modified contents are lost. More...
#define Xil_L2CacheInvalidateRange(Addr, Len)    microblaze_invalidate_cache_ext_range((Addr), (Len))
 Invalidate the L1 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the L1 data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost. More...
#define Xil_L1DCacheFlushRange(Addr, Len)    microblaze_invalidate_dcache_range((Addr), (Len))
 Flush the L1 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the data cache, and is modified (dirty), the cacheline will be written to system memory.The cacheline will also be invalidated. More...
#define Xil_L2CacheFlushRange(Addr, Len)    microblaze_flush_cache_ext_range((Addr), (Len))
 Flush the L2 data cache for the given address range. If the bytes specified by the address (Addr) are cached by the data cache, and is modified (dirty), the cacheline will be written to system memory. The cacheline will also be invalidated. More...
#define Xil_L1DCacheFlush()   microblaze_invalidate_dcache()
 Flush the entire L1 data cache. If any cacheline is dirty, the cacheline will be written to system memory. The entire data cache will be invalidated. More...
#define Xil_L2CacheFlush()   microblaze_flush_cache_ext()
 Flush the entire L2 data cache. If any cacheline is dirty, the cacheline will be written to system memory. The entire data cache will be invalidated. More...
#define Xil_L1ICacheInvalidateRange(Addr, Len)    microblaze_invalidate_icache_range((Addr), (Len))
 Invalidate the instruction cache for the given address range. More...
#define Xil_L1ICacheInvalidate()    microblaze_invalidate_icache()
 Invalidate the entire instruction cache. More...
#define Xil_L1DCacheEnable()    microblaze_enable_dcache()
 Enable the L1 data cache. More...
#define Xil_L1DCacheDisable()    microblaze_disable_dcache()
 Disable the L1 data cache. More...
#define Xil_L1ICacheEnable()    microblaze_enable_icache()
 Enable the instruction cache. More...
#define Xil_L1ICacheDisable()    microblaze_disable_icache()
 Disable the L1 Instruction cache. More...
#define Xil_DCacheEnable()   Xil_L1DCacheEnable()
 Enable the data cache. More...
#define Xil_ICacheEnable()   Xil_L1ICacheEnable()
#define Xil_DCacheInvalidate()
 Invalidate the entire Data cache. More...
#define Xil_DCacheInvalidateRange(Addr, Len)
 Invalidate the Data cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost and are NOT written to system memory before the line is invalidated. More...
#define Xil_DCacheFlush()
 Flush the entire Data cache. More...
#define Xil_DCacheFlushRange(Addr, Len)
 Flush the Data cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the written to system memory first before the before the line is invalidated. More...
#define Xil_ICacheInvalidate()
#define Xil_ICacheInvalidateRange(Addr, Len)
 Invalidate the instruction cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost and are NOT written to system memory before the line is invalidated. More...
void Xil_DCacheDisable (void)
 Disable the Data cache. More...
void Xil_ICacheDisable (void)
 Disable the instruction cache. More...
The xil_cache.h file contains cache related driver functions (or macros) that can be used to access the device. The user should refer to the hardware device specification for more details of the device operation. The functions in this header file can be used across all Xilinx supported processors.
MODIFICATION HISTORY:
Ver   Who  Date     Changes
1.00  hbm  07/28/09 Initial release
3.02a sdm  10/24/11 Updated the file to include xparameters.h so that
                    the correct cache flush routines are used based on
                    whether the write-back or write-through caches are
                    used (cr #630532).
3.10a asa  05/04/13 This version of MicroBlaze BSP adds support for system
                  cache/L2 cache. The existing/old APIs/macros in this
                  file are renamed to imply that they deal with L1 cache.
                  New macros/APIs are added to address similar features for
                  L2 cache. Users can include this file in their application
                  to use the various cache related APIs. These changes are
                  done for implementing PR #697214.
◆ Xil_DCacheEnable
void Xil_DCacheEnable ( )    Xil_L1DCacheEnable()
Returns
None.
◆ Xil_DCacheFlush
void Xil_DCacheFlush ( )
Value:
Xil_L1DCacheFlush();
Flush the entire L2 data cache. If any cacheline is dirty, the cacheline will be written to system me...
Definition: xil_cache.h:183
Returns
None.
◆ Xil_DCacheFlushRange
#define Xil_DCacheFlushRange (   Addr,
  Len
Value:
Xil_L2CacheFlushRange((Addr), (Len)); \
Xil_L1DCacheFlushRange((Addr), (Len));
Flush the L2 data cache for the given address range. If the bytes specified by the address (Addr) are...
Definition: xil_cache.h:156
Parameters
AddrStart address of range to be flushed.
LenLength of range to be flushed in bytes.
Returns
None.
◆ Xil_DCacheInvalidate
void Xil_DCacheInvalidate ( )
Value:
Xil_L1DCacheInvalidate();
Invalidate the entire L2 data cache. If the cacheline is modified (dirty),the modified contents are l...
Definition: xil_cache.h:84
Returns
None.
◆ Xil_DCacheInvalidateRange
#define Xil_DCacheInvalidateRange (   Addr,
  Len
Value:
Xil_L2CacheInvalidateRange((Addr), (Len)); \
Xil_L1DCacheInvalidateRange((Addr), (Len));
Invalidate the L1 data cache for the given address range. If the bytes specified by the address (Addr...
Definition: xil_cache.h:119
Parameters
AddrStart address of range to be invalidated.
LenLength of range to be invalidated in bytes.
Returns
None.
◆ Xil_ICacheEnable
void Xil_ICacheEnable ( )    Xil_L1ICacheEnable()
Returns
None.
◆ Xil_ICacheInvalidate
void Xil_ICacheInvalidate ( )
Value:
Xil_L1ICacheInvalidate();
Returns
None.
◆ Xil_ICacheInvalidateRange
#define Xil_ICacheInvalidateRange (   Addr,
  Len
Value:
Xil_L1ICacheInvalidateRange((Addr), (Len));
Parameters
AddrStart address of ragne to be invalidated.
Returns
None.
◆ Xil_L1DCacheDisable
#define Xil_L1DCacheDisable ( )     microblaze_disable_dcache()
Returns
None.
Note
This is processor specific.
◆ Xil_L1DCacheEnable
#define Xil_L1DCacheEnable ( )     microblaze_enable_dcache()
Returns
None.
Note
◆ Xil_L1DCacheFlush
#define Xil_L1DCacheFlush ( )    microblaze_invalidate_dcache()
Returns
None.
◆ Xil_L1DCacheFlushRange
#define Xil_L1DCacheFlushRange (   Addr,
  Len
Parameters
Addrthe starting address of the range to be flushed.
Lenlength in byte to be flushed.
Returns
None.
◆ Xil_L1DCacheInvalidate
#define Xil_L1DCacheInvalidate ( )    microblaze_invalidate_dcache()
Returns
None.
Note
Processor must be in real mode.
◆ Xil_L1DCacheInvalidateRange
#define Xil_L1DCacheInvalidateRange (   Addr,
  Len
Parameters
Addris address of range to be invalidated.
Lenis the length in bytes to be invalidated.
Returns
None.
Note
◆ Xil_L1ICacheDisable
#define Xil_L1ICacheDisable ( )     microblaze_disable_icache()
Returns
None.
Note
◆ Xil_L1ICacheEnable
#define Xil_L1ICacheEnable ( )     microblaze_enable_icache()
Returns
None.
Note
◆ Xil_L1ICacheInvalidate
#define Xil_L1ICacheInvalidate ( )     microblaze_invalidate_icache()
Returns
None.
◆ Xil_L1ICacheInvalidateRange
#define Xil_L1ICacheInvalidateRange (   Addr,
  Len
Parameters
Addris address of ragne to be invalidated.
Returns
None.
◆ Xil_L2CacheFlush
#define Xil_L2CacheFlush ( )    microblaze_flush_cache_ext()
Returns
None.
◆ Xil_L2CacheFlushRange
#define Xil_L2CacheFlushRange (   Addr,
  Len
Parameters
Returns
None.
◆ Xil_L2CacheInvalidate
#define Xil_L2CacheInvalidate ( )    microblaze_invalidate_cache_ext()
Returns
None.
Note
◆ Xil_L2CacheInvalidateRange
#define Xil_L2CacheInvalidateRange (   Addr,
  Len
Parameters
Addraddress of range to be invalidated.
Lenlength in bytes to be invalidated.
Returns
None.
Note
◆ Xil_DCacheDisable()
void Xil_DCacheDisable ( void  )
Returns
None.
◆ Xil_ICacheDisable()
void Xil_ICacheDisable ( void  )
Returns
None.
