RTEMS 6.1-rc1
System clocks. More...
void lpc176x_timer_initialize (void)
 Initializes the standard timer. More...
void lpc176x_micro_seconds_delay (unsigned us)
 Delay for us micro seconds. More...
unsigned lpc176x_pllclk (void)
 Returns the PLL output clock frequency in [Hz]. More...
unsigned lpc176x_cclk (void)
 Returns the CPU clock frequency in [Hz]. More...
System clocks.
◆ lpc176x_cclk()
unsigned lpc176x_cclk ( void  )
Returns
Returns zero in case of an unexpected PLL input frequency.
◆ lpc176x_micro_seconds_delay()
void lpc176x_micro_seconds_delay ( unsigned  us)
This function uses the standard timer and assumes that the CPU frequency is in whole MHz numbers. The delay value us will be converted to CPU ticks and there is no protection against integer overflows.
This function uses Timer 1.
◆ lpc176x_pllclk()
unsigned lpc176x_pllclk ( void  )
Returns
◆ lpc176x_timer_initialize()
void lpc176x_timer_initialize ( void  )
