RTEMS 6.1-rc1
 Interrupt_deprecated_group
Interrupt Service Routine definition
typedef uint32_t irqflags_t
volatile bool g_interrupt_enabled
#define irq_initialize_vectors()
 Initialize interrupt vectors. More...
#define irq_register_handler(int_num, int_prio)
 Register handler for interrupt. More...
#define cpu_irq_enable()
#define cpu_irq_disable()
#define cpu_irq_is_enabled()   (__get_PRIMASK() == 0)
#define Enable_global_interrupt()   cpu_irq_enable()
#define Disable_global_interrupt()   cpu_irq_disable()
#define Is_global_interrupt_enabled()   cpu_irq_is_enabled()
◆ cpu_irq_disable
#define cpu_irq_disable ( )
Value:
do { \
__disable_irq(); \
__DMB(); \
/*g_interrupt_enabled = false; */ \
} while (0)
◆ cpu_irq_enable
#define cpu_irq_enable ( )
Value:
do { \
/*g_interrupt_enabled = true; */ \
__DMB(); \
__enable_irq(); \
} while (0)
◆ irq_initialize_vectors
#define irq_initialize_vectors ( )
Value:
do { \
} while (0)
For NVIC the interrupt vectors are put in vector table. So nothing to do to initialize them, except defined the vector function with right name.
This must be called prior to irq_register_handler.
◆ irq_register_handler
#define irq_register_handler (   int_num,
  int_prio
Value:
NVIC_ClearPendingIRQ((IRQn_Type)int_num); \
NVIC_SetPriority((IRQn_Type)int_num, int_prio); \
NVIC_EnableIRQ((IRQn_Type)int_num); \
IRQn_Type
STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_sect...
Definition: stm32h723xx.h:49
For NVIC the interrupt vectors are put in vector table. So nothing to do to register them, except defined the vector function with right name.
Usage:
irq_register_handler(foo_irq_handler);
Definition: compiler.h:321
Definition: compiler.h:342
Note
The function func must be defined with the ISR macro.
The functions prototypes can be found in the device exception header files (exceptions.h).
