RTEMS 6.1-rc1
Data Structures | Enumerator | Variables
Iee
struct  _iee_config
 IEE configuration structure. More...
iee_aes_bypass_t _iee_config::bypass
iee_aes_mode_t _iee_config::mode
iee_aes_key_size_t _iee_config::keySize
uint32_t _iee_config::pageOffset
Driver version
enum  _iee_region {
  kIEE_Region0 = 0U , kIEE_Region1 = 1U , kIEE_Region2 = 2U , kIEE_Region3 = 3U ,
  kIEE_Region4 = 4U , kIEE_Region5 = 5U , kIEE_Region6 = 6U , kIEE_Region7 = 7U
 IEE region. More...
enum  _iee_aes_bypass { kIEE_AesUseMdField = 0U , kIEE_AesBypass = 1U }
 IEE AES enablement/bypass. More...
enum  _iee_aes_mode {
  kIEE_ModeNone = 0U , kIEE_ModeAesXTS = 1U , kIEE_ModeAesCTRWAddress = 2U , kIEE_ModeAesCTRWOAddress = 3U ,
  kIEE_ModeAesCTRkeystream = 4U
 IEE AES mode. More...
enum  _iee_aes_key_size { kIEE_AesCTR128XTS256 = 0U , kIEE_AesCTR256XTS512 = 1U }
 IEE AES key size. More...
enum  _iee_aes_key_num { kIEE_AesKey1 = 1U , kIEE_AesKey2 = 2U }
 IEE AES ke number. More...
typedef enum _iee_region iee_region_t
 IEE region.
typedef enum _iee_aes_bypass iee_aes_bypass_t
typedef enum _iee_aes_mode iee_aes_mode_t
 IEE AES mode.
typedef enum _iee_aes_key_size iee_aes_key_size_t
 IEE AES key size.
typedef enum _iee_aes_key_num iee_aes_key_num_t
 IEE AES ke number.
typedef struct _iee_config iee_config_t
void IEE_Init (IEE_Type *base)
 Resets IEE module to factory default values. More...
void IEE_GetDefaultConfig (iee_config_t *config)
 Loads default values to the IEE configuration structure. More...
void IEE_SetRegionConfig (IEE_Type *base, iee_region_t region, iee_config_t *config)
 Sets the IEE module according to the configuration structure. More...
status_t IEE_SetRegionKey (IEE_Type *base, iee_region_t region, iee_aes_key_num_t keyNum, const uint8_t *key, size_t keySize)
 Sets the IEE module key. More...
void IEE_LockRegionConfig (IEE_Type *base, iee_region_t region)
 Lock the IEE region configuration. More...
#define FSL_IEE_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 IEE driver version. Version 2.1.1. More...
◆ FSL_IEE_DRIVER_VERSION
Current version: 2.1.1
Change log:
  • Version 2.0.0
    • Initial version
  • Version 2.1.0
  • Version 2.1.1
    • Fixed MISRA issues.
◆ _iee_aes_bypass
kIEE_AesUseMdField
AES encryption/decryption enabled
kIEE_AesBypass
AES encryption/decryption bypass
◆ _iee_aes_key_num
IEE AES ke number.
kIEE_AesKey1
AES Key 1
kIEE_AesKey2
AES Key 2
◆ _iee_aes_key_size
IEE AES key size.
AES 128 bits (CTR), 256 bits (XTS)
AES 256 bits (CTR), 512 bits (XTS)
◆ _iee_aes_mode
IEE AES mode.
kIEE_ModeNone
AES NONE mode
kIEE_ModeAesXTS
AES XTS mode
CTR w address binding mode
AES CTR w/o address binding mode
AES CTR keystream only
◆ _iee_region
IEE region.
kIEE_Region0
IEE region 0
kIEE_Region1
IEE region 1
kIEE_Region2
IEE region 2
kIEE_Region3
IEE region 3
kIEE_Region4
IEE region 4
kIEE_Region5
IEE region 5
kIEE_Region6
IEE region 6
kIEE_Region7
IEE region 7
◆ IEE_GetDefaultConfig()
void IEE_GetDefaultConfig ( iee_config_t config)
Loads default values to the IEE region configuration structure. The default values are as follows.
config->pageOffset = 0U;
@ kIEE_AesCTR128XTS256
Definition: fsl_iee.h:73
@ kIEE_AesUseMdField
Definition: fsl_iee.h:56
@ kIEE_ModeNone
Definition: fsl_iee.h:63
Definition: deflate.c:114
Parameters
configConfiguration for the selected IEE region.
brief Loads default values to the IEE configuration structure.
Loads default values to the IEE region configuration structure. The default values are as follows. code config->bypass = kIEE_AesUseMdField; config->mode = kIEE_ModeNone; config->keySize = kIEE_AesCTR128XTS256; config->pageOffset = 0U; endcode
param config Configuration for the selected IEE region.
◆ IEE_Init()
void IEE_Init ( IEE_Type base)
This function performs hardware reset of IEE module. Attributes and keys of all regions are cleared.
Parameters
baseIEER peripheral address.
brief Resets IEE module to factory default values.
param base IEER peripheral address.
◆ IEE_LockRegionConfig()
void IEE_LockRegionConfig ( IEE_Type base,
iee_region_t  region
This function locks IEE region registers for Key, Offset and Attribute. Only system reset can clear the Lock bit.
Parameters
baseIEE peripheral address.
regionSelection of the IEE region to be locked.
brief Lock the IEE region configuration.
IEE region Key, Offset and Attribute registers are locked. Only system reset can clear the Lock bit.
param base IEE peripheral address. param region Selection of the IEE region to be locked.
◆ IEE_SetRegionConfig()
void IEE_SetRegionConfig ( IEE_Type base,
iee_config_t config
This function configures IEE region according to configuration structure.
Parameters
regionSelection of the IEE region to be configured.
brief Sets the IEE module according to the configuration structure.
param base IEE peripheral address. param region Selection of the IEE region to be configured. param config Configuration for the selected IEE region.
◆ IEE_SetRegionKey()
status_t IEE_SetRegionKey ( IEE_Type base,
const uint8_t *  key,
size_t  keySize
This function sets specified AES key for the given region.
Parameters
keyNumSelection of AES KEY1 or KEY2.
keyAES key.
keySizeSize of AES key.
brief Sets the IEE module key.
param base IEE peripheral address. param region Selection of the IEE region to be configured. param keyNum Selection of AES KEY1 or KEY2. param key AES key. param keySize Size of AES key.
Variable Documentation
◆ bypass
◆ keySize
size of AES key
◆ mode
AES mode
◆ pageOffset
Offset to physical memory location from IEE start address
