RTEMS 6.1-rc1
Data Structures | Variables
Flexio_dma_uart
struct  _flexio_uart_dma_handle
 UART DMA handle. More...
flexio_uart_dma_transfer_callback_t _flexio_uart_dma_handle::callback
void * _flexio_uart_dma_handle::userData
size_t _flexio_uart_dma_handle::txDataSizeAll
size_t _flexio_uart_dma_handle::rxDataSizeAll
dma_handle_t * _flexio_uart_dma_handle::txDmaHandle
dma_handle_t * _flexio_uart_dma_handle::rxDmaHandle
volatile uint8_t _flexio_uart_dma_handle::txState
volatile uint8_t _flexio_uart_dma_handle::rxState
Driver version
typedef struct _flexio_uart_dma_handle flexio_uart_dma_handle_t
typedef void(* flexio_uart_dma_transfer_callback_t) (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, status_t status, void *userData)
 UART transfer callback function.
#define FSL_FLEXIO_UART_DMA_DRIVER_VERSION   (MAKE_VERSION(2, 4, 0))
 FlexIO UART DMA driver version.
eDMA transactional
status_t FLEXIO_UART_TransferCreateHandleDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, flexio_uart_dma_transfer_callback_t callback, void *userData, dma_handle_t *txDmaHandle, dma_handle_t *rxDmaHandle)
 Initializes the FLEXIO_UART handle which is used in transactional functions. More...
status_t FLEXIO_UART_TransferSendDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, flexio_uart_transfer_t *xfer)
 Sends data using DMA. More...
status_t FLEXIO_UART_TransferReceiveDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, flexio_uart_transfer_t *xfer)
 Receives data using DMA. More...
void FLEXIO_UART_TransferAbortSendDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle)
 Aborts the sent data which using DMA. More...
void FLEXIO_UART_TransferAbortReceiveDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle)
 Aborts the receive data which using DMA. More...
status_t FLEXIO_UART_TransferGetSendCountDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, size_t *count)
 Gets the number of bytes sent out. More...
status_t FLEXIO_UART_TransferGetReceiveCountDMA (FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, size_t *count)
 Gets the number of bytes received. More...
◆ FLEXIO_UART_TransferAbortReceiveDMA()
void FLEXIO_UART_TransferAbortReceiveDMA ( FLEXIO_UART_Type base,
flexio_uart_dma_handle_t handle
This function aborts the receive data which using DMA.
Parameters
basePointer to FLEXIO_UART_Type structure
handlePointer to flexio_uart_dma_handle_t structure
◆ FLEXIO_UART_TransferAbortSendDMA()
void FLEXIO_UART_TransferAbortSendDMA ( FLEXIO_UART_Type base,
This function aborts the sent data which using DMA.
Parameters
◆ FLEXIO_UART_TransferCreateHandleDMA()
status_t FLEXIO_UART_TransferCreateHandleDMA ( FLEXIO_UART_Type base,
flexio_uart_dma_handle_t handle,
void *  userData,
dma_handle_t *  txDmaHandle,
dma_handle_t *  rxDmaHandle
Parameters
basePointer to FLEXIO_UART_Type structure.
handlePointer to flexio_uart_dma_handle_t structure.
callbackFlexIO UART callback, NULL means no callback.
userDataUser callback function data.
txDmaHandleUser requested DMA handle for TX DMA transfer.
rxDmaHandleUser requested DMA handle for RX DMA transfer.
Return values
kStatus_SuccessSuccessfully create the handle.
kStatus_OutOfRangeThe FlexIO UART DMA type/handle table out of range.
◆ FLEXIO_UART_TransferGetReceiveCountDMA()
status_t FLEXIO_UART_TransferGetReceiveCountDMA ( FLEXIO_UART_Type base,
size_t *  count
This function gets the number of bytes received.
Parameters
countNumber of bytes received so far by the non-blocking transaction.
Return values
kStatus_NoTransferInProgresstransfer has finished or no transfer in progress.
kStatus_SuccessSuccessfully return the count.
◆ FLEXIO_UART_TransferGetSendCountDMA()
status_t FLEXIO_UART_TransferGetSendCountDMA ( FLEXIO_UART_Type base,
size_t *  count
This function gets the number of bytes sent out.
Parameters
countNumber of bytes sent so far by the non-blocking transaction.
Return values
◆ FLEXIO_UART_TransferReceiveDMA()
status_t FLEXIO_UART_TransferReceiveDMA ( FLEXIO_UART_Type base,
flexio_uart_transfer_t xfer
This function receives data using DMA. This is non-blocking function, which returns right away. When all data is received, the receive callback function is called.
Parameters
xferFLEXIO_UART DMA transfer structure, see flexio_uart_transfer_t.
Return values
kStatus_Successif succeed, others failed.
kStatus_FLEXIO_UART_RxBusyPrevious transfer on going.
◆ FLEXIO_UART_TransferSendDMA()
status_t FLEXIO_UART_TransferSendDMA ( FLEXIO_UART_Type base,
This function send data using DMA. This is non-blocking function, which returns right away. When all data is sent out, the send callback function is called.
Parameters
Return values
kStatus_FLEXIO_UART_TxBusyPrevious transfer on going.
Variable Documentation
◆ callback
Callback function.
◆ rxDataSizeAll
Total bytes to be received.
◆ rxDmaHandle
dma_handle_t* _flexio_uart_dma_handle::rxDmaHandle
The DMA RX channel used.
◆ rxState
RX transfer state
◆ txDataSizeAll
Total bytes to be sent.
◆ txDmaHandle
dma_handle_t* _flexio_uart_dma_handle::txDmaHandle
The DMA TX channel used.
◆ txState
TX transfer state.
◆ userData
void* _flexio_uart_dma_handle::userData
UART callback function parameter.
