RTEMS 6.1-rc1
Functions | Variables
bool XDMAD_UpdateStatusFromCallback (sXdmad *pXdmad, uint32_t Channel, uint32_t status)
void XDMAD_DoNothingCallback (uint32_t Channel, void *pArg, uint32_t status)
 RTEMS_SYSINIT_ITEM (XDMAD_SysInitialize, RTEMS_SYSINIT_BSP_START, RTEMS_SYSINIT_ORDER_LAST_BUT_5)
uint32_t XDMAD_AllocateChannel (sXdmad *pXdmad, uint8_t bSrcID, uint8_t bDstID)
 Allocate a XDMA channel for upper layer. More...
eXdmadRC XDMAD_FreeChannel (sXdmad *pXdmad, uint32_t dwChannel)
 Free the specified xDMA channel. More...
eXdmadRC XDMAD_SetCallback (sXdmad *pXdmad, uint32_t dwChannel, XdmadTransferCallback fCallback, void *pArg)
 Set the callback function for xDMA channel transfer. More...
eXdmadRC XDMAD_PrepareChannel (sXdmad *pXdmad, uint32_t dwChannel)
 Enable clock of the xDMA peripheral, Enable the dma peripheral, configure configuration register for xDMA transfer. More...
eXdmadRC XDMAD_ConfigureTransfer (sXdmad *pXdmad, uint32_t dwChannel, sXdmadCfg *pXdmaParam, uint32_t dwXdmaDescCfg, uint32_t dwXdmaDescAddr, uint32_t dwXdmaIntEn)
 Configure DMA for a single transfer. More...
eXdmadRC XDMAD_StartTransfer (sXdmad *pXdmad, uint32_t dwChannel)
 Start xDMA transfer. More...
eXdmadRC XDMAD_StopTransfer (sXdmad *pXdmad, uint32_t dwChannel)
 Stop DMA transfer. More...
eXdmadRC XDMAD_IsTransferDone (sXdmad *pXdmad, uint32_t dwChannel)
sXdmad XDMAD_Instance
◆ XDMAD_AllocateChannel()
uint32_t XDMAD_AllocateChannel ( sXdmad pXdmad,
uint8_t  bSrcID,
uint8_t  bDstID
Parameters
pXdmadPointer to xDMA driver instance.
bSrcIDSource peripheral ID, 0xFF for memory.
bDstIDDestination peripheral ID, 0xFF for memory.
Returns
Channel number if allocation successful, return XDMAD_ALLOC_FAILED if allocation failed.
◆ XDMAD_ConfigureTransfer()
eXdmadRC XDMAD_ConfigureTransfer ( sXdmad pXdmad,
uint32_t  dwChannel,
sXdmadCfg pXdmaParam,
Parameters
dwChannelControllerNumber << 8 | ChannelNumber.
◆ XDMAD_FreeChannel()
eXdmadRC XDMAD_FreeChannel ( sXdmad pXdmad,
uint32_t  dwChannel
Parameters
◆ XDMAD_PrepareChannel()
eXdmadRC XDMAD_PrepareChannel ( sXdmad pXdmad,
uint32_t  dwChannel
Parameters
dwCfgConfiguration value.
◆ XDMAD_SetCallback()
eXdmadRC XDMAD_SetCallback ( sXdmad pXdmad,
uint32_t  dwChannel,
void *  pArg
Parameters
fCallbackPointer to callback function.
pArgPointer to optional argument for callback.
◆ XDMAD_StartTransfer()
eXdmadRC XDMAD_StartTransfer ( sXdmad pXdmad,
uint32_t  dwChannel
Parameters
pXdmadPointer to XDMA driver instance.
◆ XDMAD_StopTransfer()
eXdmadRC XDMAD_StopTransfer ( sXdmad pXdmad,
uint32_t  dwChannel
Stop DMA transfer.
Parameters
pDmadPointer to DMA driver instance.
