RTEMS 6.1-rc1
Macros | Typedefs | Functions | Variables
Assert APIs and Macros
#define Xil_AssertVoid(Expression)
 This assert macro is to be used for void functions. This in conjunction with the Xil_AssertWait boolean can be used to accommodate tests so that asserts which fail allow execution to continue. More...
#define Xil_AssertNonvoid(Expression)
 This assert macro is to be used for functions that do return a value. This in conjunction with the Xil_AssertWait boolean can be used to accommodate tests so that asserts which fail allow execution to continue. More...
#define Xil_AssertVoidAlways()
 Always assert. This assert macro is to be used for void functions. Use for instances where an assert should always occur. More...
#define Xil_AssertNonvoidAlways()
 Always assert. This assert macro is to be used for functions that do return a value. Use for instances where an assert should always occur. More...
typedef void(* Xil_AssertCallback) (const char8 *File, s32 Line)
void XNullHandler (void *NullParameter)
 Null handler function. This follows the XInterruptHandler signature for interrupt handlers. It can be used to assign a null handler (a stub) to an interrupt controller vector table. More...
void Xil_AssertSetCallback (Xil_AssertCallback Routine)
 Set up a callback function to be invoked when an assert occurs. If a callback is already installed, then it will be replaced. More...
void Xil_Assert (const char8 *File, s32 Line)
 Implement assert. Currently, it calls a user-defined callback function if one has been set. Then, it potentially enters an infinite loop depending on the value of the Xil_AssertWait variable. More...
u32 Xil_AssertStatus
 This variable allows testing to be done easier with asserts. An assert sets this variable such that a driver can evaluate this variable to determine if an assert occurred.
s32 Xil_AssertWait = 1
 This variable allows the assert functionality to be changed for testing such that it does not wait infinitely. Use the debugger to disable the waiting during testing of asserts.
The xil_assert.h file contains assert related functions and macros. Assert APIs/Macros specifies that a application program satisfies certain conditions at particular points in its execution. These function can be used by application programs to ensure that, application code is satisfying certain conditions.
MODIFICATION HISTORY:
Ver   Who    Date   Changes
1.00a hbm  07/14/09 First release
6.0   kvn  05/31/16 Make Xil_AsserWait a global variable
This file contains basic assert related functions for Xilinx software IP.
1.00a hbm  07/14/09 Initial release
◆ Xil_AssertNonvoid
#define Xil_AssertNonvoid (   Expression)
Value:
if (Expression) { \
Xil_AssertStatus = XIL_ASSERT_NONE; \
} else { \
Xil_Assert(__FILE__, __LINE__); \
Xil_AssertStatus = XIL_ASSERT_OCCURRED; \
return 0; \
Parameters
Expressionexpression to be evaluated. If it evaluates to false, the assert occurs.
Returns
Returns 0 unless the Xil_AssertWait variable is true, in which case no return is made and an infinite loop is entered.
◆ Xil_AssertNonvoidAlways
#define Xil_AssertNonvoidAlways ( )
Value:
return 0; \
Returns
Returns void unless the Xil_AssertWait variable is true, in which case no return is made and an infinite loop is entered.
◆ Xil_AssertVoid
#define Xil_AssertVoid (   Expression)
Value:
if (Expression) { \
} else { \
return; \
Parameters
Returns
◆ Xil_AssertVoidAlways
#define Xil_AssertVoidAlways ( )
Value:
return; \
Returns
Typedef Documentation
◆ Xil_AssertCallback
This data type defines a callback to be invoked when an assert occurs. The callback is invoked only when asserts are enabled
◆ Xil_Assert()
void Xil_Assert ( const char8 *  File,
s32  Line
Parameters
Filefilename of the source
Linelinenumber within File
Returns
None.
Note
None.
◆ Xil_AssertSetCallback()
void Xil_AssertSetCallback ( Xil_AssertCallback  Routine)
Parameters
Routinecallback to be invoked when an assert is taken
Returns
None.
Note
This function has no effect if NDEBUG is set
◆ XNullHandler()
void XNullHandler ( void *  NullParameter)
Parameters
NullParameterarbitrary void pointer and not used.
Returns
None.
Note
None.
