RTEMS 6.1-rc1
Asrc_driver
struct  _asrc_channel_pair_config
 asrc channel pair configuation More...
struct  _asrc_transfer
 SAI transfer structure. More...
struct  _asrc_in_handle
 asrc in handler More...
struct  _asrc_out_handle
 output handler More...
struct  _asrc_handle
 ASRC handle structure. More...
Driver version
enum  {
  kStatus_ASRCIdle = MAKE_STATUS(kStatusGroup_ASRC, 0) , kStatus_ASRCInIdle = MAKE_STATUS(kStatusGroup_ASRC, 1) , kStatus_ASRCOutIdle = MAKE_STATUS(kStatusGroup_ASRC, 2) , kStatus_ASRCBusy = MAKE_STATUS(kStatusGroup_ASRC, 3) ,
  kStatus_ASRCInvalidArgument = MAKE_STATUS(kStatusGroup_ASRC, 4) , kStatus_ASRCClockConfigureFailed = MAKE_STATUS(kStatusGroup_ASRC, 5) , kStatus_ASRCChannelPairConfigureFailed = MAKE_STATUS(kStatusGroup_ASRC, 6) , kStatus_ASRCConvertError = MAKE_STATUS(kStatusGroup_ASRC, 7) ,
  kStatus_ASRCNotSupport = MAKE_STATUS(kStatusGroup_ASRC, 8) , kStatus_ASRCQueueFull = MAKE_STATUS(kStatusGroup_ASRC, 9) , kStatus_ASRCOutQueueIdle = MAKE_STATUS(kStatusGroup_ASRC, 10) , kStatus_ASRCInQueueIdle = MAKE_STATUS(kStatusGroup_ASRC, 11)
 ASRC return status . More...
enum  _asrc_channel_pair { kASRC_ChannelPairA = 0 , kASRC_ChannelPairB = 1 , kASRC_ChannelPairC = 2 }
 ASRC channel pair mask. More...
enum  {
  kASRC_SampleRate_8000HZ = 8000U , kASRC_SampleRate_11025HZ = 11025U , kASRC_SampleRate_12000HZ = 12000U , kASRC_SampleRate_16000HZ = 16000U ,
  kASRC_SampleRate_22050HZ = 22050U , kASRC_SampleRate_24000HZ = 24000U , kASRC_SampleRate_30000HZ = 30000U , kASRC_SampleRate_32000HZ = 32000U ,
  kASRC_SampleRate_44100HZ = 44100U , kASRC_SampleRate_48000HZ = 48000U , kASRC_SampleRate_64000HZ = 64000U , kASRC_SampleRate_88200HZ = 88200U ,
  kASRC_SampleRate_96000HZ = 96000U , kASRC_SampleRate_128000HZ = 128000U , kASRC_SampleRate_176400HZ = 176400U , kASRC_SampleRate_192000HZ = 192000U
 ASRC support sample rate . More...
enum  {
  kASRC_FPInWaitStateInterruptEnable = ASRC_ASRIER_AFPWE_MASK , kASRC_OverLoadInterruptMask = ASRC_ASRIER_AOLIE_MASK , kASRC_DataOutputCInterruptMask = ASRC_ASRIER_ADOEC_MASK , kASRC_DataOutputBInterruptMask = ASRC_ASRIER_ADOEB_MASK ,
  kASRC_DataOutputAInterruptMask = ASRC_ASRIER_ADOEA_MASK , kASRC_DataInputCInterruptMask = ASRC_ASRIER_ADIEC_MASK , kASRC_DataInputBInterruptMask = ASRC_ASRIER_ADIEB_MASK , kASRC_DataInputAInterruptMask = ASRC_ASRIER_ADIEA_MASK
 The ASRC interrupt enable flag . More...
enum  {
  kASRC_StatusDSLCounterReady = ASRC_ASRSTR_DSLCNT_MASK , kASRC_StatusTaskQueueOverLoad = ASRC_ASRSTR_ATQOL_MASK , kASRC_StatusPairCOutputOverLoad = ASRC_ASRSTR_AOOLC_MASK , kASRC_StatusPairBOutputOverLoad = ASRC_ASRSTR_AOOLB_MASK ,
  kASRC_StatusPairAOutputOverLoad = ASRC_ASRSTR_AOOLA_MASK , kASRC_StatusPairCInputOverLoad = ASRC_ASRSTR_AIOLC_MASK , kASRC_StatusPairBInputOverLoad = ASRC_ASRSTR_AIOLB_MASK , kASRC_StatusPairAInputOverLoad = ASRC_ASRSTR_AIOLA_MASK ,
  kASRC_StatusPairCOutputOverflow = ASRC_ASRSTR_AODOC_MASK , kASRC_StatusPairBOutputOverflow = ASRC_ASRSTR_AODOB_MASK , kASRC_StatusPairAOutputOverflow = ASRC_ASRSTR_AODOA_MASK , kASRC_StatusPairCInputUnderflow = ASRC_ASRSTR_AIDUC_MASK ,
  kASRC_StatusPairBInputUnderflow = ASRC_ASRSTR_AIDUB_MASK , kASRC_StatusPairAInputUnderflow = ASRC_ASRSTR_AIDUA_MASK , kASRC_StatusFPInWaitState = ASRC_ASRSTR_FPWT_MASK , kASRC_StatusOverloadError = ASRC_ASRSTR_AOLE_MASK ,
  kASRC_StatusInputError , kASRC_StatusOutputError , kASRC_StatusPairCOutputReady = ASRC_ASRSTR_AODFC_MASK , kASRC_StatusPairBOutputReady = ASRC_ASRSTR_AODFB_MASK ,
  kASRC_StatusPairAOutputReady = ASRC_ASRSTR_AODFA_MASK , kASRC_StatusPairCInputReady = ASRC_ASRSTR_AIDEC_MASK , kASRC_StatusPairBInputReady = ASRC_ASRSTR_AIDEB_MASK , kASRC_StatusPairAInputReady = ASRC_ASRSTR_AIDEA_MASK ,
  kASRC_StatusPairAInterrupt = kASRC_StatusPairAInputReady | kASRC_StatusPairAOutputReady , kASRC_StatusPairBInterrupt = kASRC_StatusPairBInputReady | kASRC_StatusPairBOutputReady , kASRC_StatusPairCInterrupt = kASRC_StatusPairCInputReady | kASRC_StatusPairCOutputReady
 The ASRC interrupt status . More...
enum  { kASRC_OutputFifoNearFull = ASRC_ASRFSTA_OAFA_MASK , kASRC_InputFifoNearEmpty = ASRC_ASRFSTA_IAEA_MASK }
 ASRC channel pair status . More...
enum  _asrc_ratio { kASRC_RatioNotUsed = 0U , kASRC_RatioUseInternalMeasured , kASRC_RatioUseIdealRatio }
 ASRC ideal ratio. More...
enum  _asrc_audio_channel {
  kASRC_ChannelsNumber1 = 1U , kASRC_ChannelsNumber2 = 2U , kASRC_ChannelsNumber3 = 3U , kASRC_ChannelsNumber4 = 4U ,
  kASRC_ChannelsNumber5 = 5U , kASRC_ChannelsNumber6 = 6U , kASRC_ChannelsNumber7 = 7U , kASRC_ChannelsNumber8 = 8U ,
  kASRC_ChannelsNumber9 = 9U , kASRC_ChannelsNumber10 = 10U
 Number of channels in audio data. More...
enum  _asrc_data_width { kASRC_DataWidth24Bit = 0U , kASRC_DataWidth16Bit = 1U , kASRC_DataWidth8Bit = 2U }
 data width More...
enum  _asrc_data_align { kASRC_DataAlignMSB = 1U , kASRC_DataAlignLSB = 0U }
 data alignment More...
enum  _asrc_sign_extension { kASRC_NoSignExtension = 0U , kASRC_SignExtension = 1U }
 sign extension More...
typedef enum _asrc_channel_pair asrc_channel_pair_t
typedef enum _asrc_ratio asrc_ratio_t
 ASRC ideal ratio.
typedef enum _asrc_audio_channel asrc_audio_channel_t
typedef enum _asrc_data_width asrc_data_width_t
 data width
typedef enum _asrc_data_align asrc_data_align_t
 data alignment
typedef enum _asrc_sign_extension asrc_sign_extension_t
 sign extension
typedef struct _asrc_channel_pair_config asrc_channel_pair_config_t
typedef struct _asrc_transfer asrc_transfer_t
typedef struct _asrc_handle asrc_handle_t
 asrc handler
typedef void(* asrc_transfer_callback_t) (ASRC_Type *base, asrc_handle_t *handle, status_t status, void *userData)
 ASRC transfer callback prototype.
typedef struct _asrc_in_handle asrc_in_handle_t
 asrc in handler
typedef struct _asrc_out_handle asrc_out_handle_t
 output handler
#define FSL_ASRC_DRIVER_VERSION   (MAKE_VERSION(2, 1, 2))
#define ASRC_XFER_QUEUE_SIZE   (4U)
 ASRC transfer queue size, user can refine it according to use case.
#define FSL_ASRC_CHANNEL_PAIR_COUNT   (4U)
 ASRC channel pair count.
#define FSL_ASRC_CHANNEL_PAIR_FIFO_DEPTH   (64U)
 ASRC FIFO depth.
#define ASRC_ASRCTR_AT_MASK(index)   ((uint32_t)1U << (ASRC_ASRCTR_ATSA_SHIFT + (uint32_t)(index)))
 ASRC register access macro.
#define ASRC_ASRCTR_RATIO_MASK(index)   ((uint32_t)3U << (ASRC_ASRCTR_IDRA_SHIFT + (uint32_t)(index)*2U))
#define ASRC_ASRCTR_RATIO(ratio, index)    (((uint32_t)((uint32_t)(ratio) << (ASRC_ASRCTR_IDRA_SHIFT + (uint32_t)(index)*2U))) & ASRC_ASRCTR_RATIO_MASK(index))
#define ASRC_ASRIER_INPUT_INTERRUPT_MASK(index)   ((uint32_t)1U << (ASRC_ASRIER_ADIEA_SHIFT + (uint32_t)(index)))
#define ASRC_ASRIER_OUTPUTPUT_INTERRUPT_MASK(index)   ((uint32_t)1U << (ASRC_ASRIER_ADOEA_SHIFT + (uint32_t)(index)))
#define ASRC_ASRCNCR_CHANNEL_COUNTER_MASK(index)   ((uint32_t)0xFU << (ASRC_ASRCNCR_ANCA_SHIFT + (uint32_t)(index)*4U))
#define ASRC_ASRCNCR_CHANNEL_COUNTER(counter, index)
#define ASRC_ASRCFG_PRE_MODE_MASK(index)   ((uint32_t)3U << (ASRC_ASRCFG_PREMODA_SHIFT + (uint32_t)(index)*4U))
#define ASRC_ASRCFG_PRE_MODE(mode, index)
#define ASRC_ASRCFG_POST_MODE_MASK(index)   ((uint32_t)3U << (ASRC_ASRCFG_POSTMODA_SHIFT + (uint32_t)(index)*4U))
#define ASRC_ASRCFG_POST_MODE(mode, index)
#define ASRC_ASRCFG_INIT_DONE_MASK(index)   ((uint32_t)1U << (ASRC_ASRCFG_INIRQA_SHIFT + (uint32_t)(index)))
#define ASRC_ASRCSR_INPUT_CLOCK_SOURCE_MASK(index)   ((uint32_t)0xFU << (ASRC_ASRCSR_AICSA_SHIFT + (uint32_t)(index)*4U))
#define ASRC_ASRCSR_INPUT_CLOCK_SOURCE(source, index)
#define ASRC_ASRCSR_OUTPUT_CLOCK_SOURCE_MASK(index)   ((uint32_t)0xFU << (ASRC_ASRCSR_AOCSA_SHIFT + (uint32_t)(index)*4U))
#define ASRC_ASRCSR_OUTPUT_CLOCK_SOURCE(source, index)
#define ASRC_ASRCDR_INPUT_PRESCALER_MASK(index)    ((uint32_t)(index) < 2U ? ((uint32_t)7U << (ASRC_ASRCDR1_AICPA_SHIFT + (uint32_t)(index)*6U)) : 7U)
#define ASRC_ASRCDR_INPUT_PRESCALER(prescaler, index)
#define ASRC_ASRCDR_INPUT_DIVIDER_MASK(index)
#define ASRC_ASRCDR_INPUT_DIVIDER(divider, index)
#define ASRC_ASRCDR_OUTPUT_PRESCALER_MASK(index)    ((uint32_t)(index) < 2U ? ((uint32_t)7U << (ASRC_ASRCDR1_AOCPA_SHIFT + (uint32_t)(index)*6U)) : (7U << 6U))
#define ASRC_ASRCDR_OUTPUT_PRESCALER(prescaler, index)
#define ASRC_ASRCDR_OUTPUT_DIVIDER_MASK(index)    ((uint32_t)(index) < 2U ? ((uint32_t)7U << (ASRC_ASRCDR1_AOCDA_SHIFT + (uint32_t)(index)*6U)) : (7UL << 9U))
#define ASRC_ASRCDR_OUTPUT_DIVIDER(divider, index)
#define ASCR_ASRCDR_OUTPUT_CLOCK_DIVIDER_PRESCALER(value, index)
#define ASCR_ASRCDR_INPUT_CLOCK_DIVIDER_PRESCALER(value, index)    (((uint32_t)(index) < 2U ? ((uint32_t)(value) << ((uint32_t)(index)*6U)) : ((uint32_t)(value))))
#define ASRC_IDEAL_RATIO_HIGH(base, index)   *(volatile uint32_t *)((uint32_t)(&(base)->ASRIDRHA) + (uint32_t)(index)*8U)
#define ASRC_IDEAL_RATIO_LOW(base, index)   *(volatile uint32_t *)((uint32_t)(&(base)->ASRIDRLA) + (uint32_t)(index)*8U)
#define ASRC_ASRMCR(base, index)   *(volatile uint32_t *)((uint32_t)(&(base)->ASRMCRA) + (uint32_t)(index)*8U)
#define ASRC_ASRMCR1(base, index)   *(volatile uint32_t *)((uint32_t)(&((base)->ASRMCR1[(index)])))
#define ASRC_ASRDI(base, index)   *(volatile uint32_t *)((uint32_t)(&(base)->ASRDIA) + (uint32_t)(index)*8U)
#define ASRC_ASRDO(base, index)   *(volatile uint32_t *)((uint32_t)(&(base)->ASRDOA) + (uint32_t)(index)*8U)
#define ASRC_ASRDI_ADDR(base, index)   (volatile uint32_t *)((uint32_t)(&(base)->ASRDIA) + (uint32_t)(index)*8U)
#define ASRC_ASRDO_ADDR(base, index)   (volatile uint32_t *)((uint32_t)(&(base)->ASRDOA) + (uint32_t)(index)*8U)
#define ASRC_ASRFST_ADDR(base, index)   (*(volatile uint32_t *)((uint32_t)(&(base)->ASRFSTA) + (uint32_t)(index)*8U))
#define ASRC_GET_CHANNEL_COUNTER(base, index)   (((base)->ASRCNCR >> ((uint32_t)(index)*4U)) & 0xFU)
Initialization and deinitialization
uint32_t ASRC_GetInstance (ASRC_Type *base)
 Get instance number of the ASRC peripheral. More...
void ASRC_Init (ASRC_Type *base, uint32_t asrcPeripheralClock_Hz)
void ASRC_Deinit (ASRC_Type *base)
 De-initializes the ASRC peripheral. More...
void ASRC_SoftwareReset (ASRC_Type *base)
 Do software reset . More...
status_t ASRC_SetChannelPairConfig (ASRC_Type *base, asrc_channel_pair_t channelPair, asrc_channel_pair_config_t *config, uint32_t inputSampleRate, uint32_t outputSampleRate)
 ASRC configure channel pair. More...
uint32_t ASRC_GetOutSamplesSize (ASRC_Type *base, asrc_channel_pair_t channelPair, uint32_t inSampleRate, uint32_t outSampleRate, uint32_t inSamplesize)
 Get output sample buffer size. More...
uint32_t ASRC_MapSamplesWidth (ASRC_Type *base, asrc_channel_pair_t channelPair, uint32_t *inWidth, uint32_t *outWidth)
 Map register sample width to real sample width. More...
uint32_t ASRC_GetRemainFifoSamples (ASRC_Type *base, asrc_channel_pair_t channelPair, uint32_t *buffer, uint32_t outSampleWidth, uint32_t remainSamples)
 Get left samples in fifo. More...
Bus Operations
status_t ASRC_SetIdealRatioConfig (ASRC_Type *base, asrc_channel_pair_t channelPair, uint32_t inputSampleRate, uint32_t outputSampleRate)
 ASRC configure ideal ratio. The ideal ratio should be used when input clock source is not avalible. More...
Transactional
status_t ASRC_TransferSetChannelPairConfig (ASRC_Type *base, asrc_handle_t *handle, asrc_channel_pair_config_t *config, uint32_t inputSampleRate, uint32_t outputSampleRate)
void ASRC_TransferCreateHandle (ASRC_Type *base, asrc_handle_t *handle, asrc_channel_pair_t channelPair, asrc_transfer_callback_t inCallback, asrc_transfer_callback_t outCallback, void *userData)
 Initializes the ASRC handle. More...
status_t ASRC_TransferNonBlocking (ASRC_Type *base, asrc_handle_t *handle, asrc_transfer_t *xfer)
 Performs an interrupt non-blocking convert on asrc. More...
status_t ASRC_TransferBlocking (ASRC_Type *base, asrc_channel_pair_t channelPair, asrc_transfer_t *xfer)
 Performs an blocking convert on asrc. More...
status_t ASRC_TransferGetConvertedCount (ASRC_Type *base, asrc_handle_t *handle, size_t *count)
 Get converted byte count. More...
void ASRC_TransferAbortConvert (ASRC_Type *base, asrc_handle_t *handle)
 Aborts the current convert. More...
void ASRC_TransferTerminateConvert (ASRC_Type *base, asrc_handle_t *handle)
 Terminate all ASRC convert. More...
void ASRC_TransferHandleIRQ (ASRC_Type *base, asrc_handle_t *handle)
 ASRC convert interrupt handler. More...
◆ ASCR_ASRCDR_OUTPUT_CLOCK_DIVIDER_PRESCALER
#define ASCR_ASRCDR_OUTPUT_CLOCK_DIVIDER_PRESCALER (   value,
  index
Value:
(((uint32_t)(index) < 2U ? ((uint32_t)(value) << (ASRC_ASRCDR1_AOCPA_SHIFT + (uint32_t)(index)*6U)) : \
((uint32_t)(value) << 6U)))
◆ ASRC_ASRCDR_INPUT_DIVIDER
#define ASRC_ASRCDR_INPUT_DIVIDER (   divider,
  index
Value:
(((uint32_t)(index) < 2U ? ((uint32_t)(divider) << (ASRC_ASRCDR1_AICDA_SHIFT + (uint32_t)(index)*6U)) : \
((uint32_t)(divider) << ASRC_ASRCDR1_AICDA_SHIFT)) & \
ASRC_ASRCDR_INPUT_DIVIDER_MASK(index))
◆ ASRC_ASRCDR_INPUT_DIVIDER_MASK
#define ASRC_ASRCDR_INPUT_DIVIDER_MASK (   index)
Value:
((uint32_t)(index) < 2U ? ((uint32_t)7U << (ASRC_ASRCDR1_AICDA_SHIFT + (uint32_t)(index)*6U)) : \
(7U << ASRC_ASRCDR1_AICDA_SHIFT))
◆ ASRC_ASRCDR_INPUT_PRESCALER
#define ASRC_ASRCDR_INPUT_PRESCALER (   prescaler,
  index
Value:
(((index) < 2U ? ((uint32_t)(prescaler) << (ASRC_ASRCDR1_AICPA_SHIFT + (uint32_t)(index)*6U)) : (prescaler)) & \
ASRC_ASRCDR1_INPUT_PRESCALER_MASK(index))
◆ ASRC_ASRCDR_OUTPUT_DIVIDER
#define ASRC_ASRCDR_OUTPUT_DIVIDER (   divider,
  index
Value:
(((uint32_t)(index) < 2U ? ((uint32_t)(divider) << (ASRC_ASRCDR1_AOCDA_SHIFT + (uint32_t)(index)*6U)) : \
((uint32_t)(divider) << 9U)) & \
ASRC_ASRCDR_OUTPUT_DIVIDER_MASK(index))
◆ ASRC_ASRCDR_OUTPUT_PRESCALER
#define ASRC_ASRCDR_OUTPUT_PRESCALER (   prescaler,
  index
Value:
(((uint32_t)(index) < 2U ? ((uint32_t)(prescaler) << (ASRC_ASRCDR1_AOCPA_SHIFT + (uint32_t)(index)*6U)) : \
((uint32_t)(prescaler) << 6U)) & \
ASRC_ASRCDR_OUTPUT_PRESCALER_MASK(index))
◆ ASRC_ASRCFG_POST_MODE
#define ASRC_ASRCFG_POST_MODE (   mode,
  index
Value:
((uint32_t)((uint32_t)(mode) << (ASRC_ASRCFG_POSTMODA_SHIFT + (uint32_t)(index)*4U)) & \
ASRC_ASRCFG_POST_MODE_MASK(index))
◆ ASRC_ASRCFG_PRE_MODE
#define ASRC_ASRCFG_PRE_MODE (   mode,
  index
Value:
((uint32_t)((uint32_t)(mode) << (ASRC_ASRCFG_PREMODA_SHIFT + (uint32_t)(index)*4U)) & \
ASRC_ASRCFG_PRE_MODE_MASK(index))
◆ ASRC_ASRCNCR_CHANNEL_COUNTER
#define ASRC_ASRCNCR_CHANNEL_COUNTER (   counter,
  index
Value:
((uint32_t)((uint32_t)(counter) << (ASRC_ASRCNCR_ANCA_SHIFT + (uint32_t)(index)*4U)) & \
ASRC_ASRCNCR_CHANNEL_COUNTER_MASK(index))
◆ ASRC_ASRCSR_INPUT_CLOCK_SOURCE
#define ASRC_ASRCSR_INPUT_CLOCK_SOURCE (   source,
  index
Value:
((uint32_t)((uint32_t)(source) << (ASRC_ASRCSR_AICSA_SHIFT + (uint32_t)(index)*4U)) & \
ASRC_ASRCSR_INPUT_CLOCK_SOURCE_MASK(index))
◆ ASRC_ASRCSR_OUTPUT_CLOCK_SOURCE
#define ASRC_ASRCSR_OUTPUT_CLOCK_SOURCE (   source,
  index
Value:
((uint32_t)((uint32_t)(source) << (ASRC_ASRCSR_AOCSA_SHIFT + (uint32_t)(index)*4U)) & \
ASRC_ASRCSR_OUTPUT_CLOCK_SOURCE_MASK(index))
◆ FSL_ASRC_DRIVER_VERSION
Version 2.1.2
◆ anonymous enum
anonymous enum
kStatus_ASRCIdle
ASRC is idle.
kStatus_ASRCInIdle
ASRC in is idle.
kStatus_ASRCOutIdle
ASRC out is idle.
kStatus_ASRCBusy
ASRC is busy.
ASRC invalid argument.
ASRC clock configure failed
ASRC not support
ASRC queue is full
ASRC out queue is idle
ASRC in queue is idle
◆ anonymous enum
anonymous enum
asrc sample rate 8KHZ
asrc sample rate 11.025KHZ
asrc sample rate 12KHZ
asrc sample rate 16KHZ
asrc sample rate 22.05KHZ
asrc sample rate 24KHZ
asrc sample rate 30KHZ
asrc sample rate 32KHZ
asrc sample rate 44.1KHZ
asrc sample rate 48KHZ
asrc sample rate 64KHZ
asrc sample rate 88.2KHZ
asrc sample rate 96KHZ
asrc sample rate 128KHZ
asrc sample rate 176.4KHZ
asrc sample rate 192KHZ
◆ anonymous enum
anonymous enum
FP in wait state mask
overload interrupt mask
data output c interrupt mask
data output b interrupt mask
data output a interrupt mask
data input c interrupt mask
data input b interrupt mask
data input a interrupt mask
◆ anonymous enum
anonymous enum
DSL counter
task queue overload
pair c output overload
pair b output overload
pair a output overload
pair c input overload
pair b input overload
pair a input overload
pair c output overflow
pair b output overflow
pair a output overflow
pair c input underflow
pair b input under flow
pair a input underflow
FP in wait state
overload error
input error status
output error status
pair c output ready
pair b output ready
pair a output ready
pair c input ready
pair b input ready
pair a input ready
pair A interrupt
pair B interrupt
pair C interrupt
◆ anonymous enum
anonymous enum
channel pair output fifo near full
channel pair input fifo near empty
◆ _asrc_audio_channel
channel number is 1
channel number is 2
channel number is 3
channel number is 4
channel number is 5
channel number is 6
channel number is 7
channel number is 8
channel number is 9
channel number is 10
◆ _asrc_channel_pair
kASRC_ChannelPairA
channel pair A value
kASRC_ChannelPairB
channel pair B value
kASRC_ChannelPairC
channel pair C value
◆ _asrc_data_align
data alignment
kASRC_DataAlignMSB
data alignment MSB
kASRC_DataAlignLSB
data alignment LSB
◆ _asrc_data_width
data width
data width 24bit
data width 16bit
kASRC_DataWidth8Bit
data width 8bit
◆ _asrc_ratio
ASRC ideal ratio.
kASRC_RatioNotUsed
ideal ratio not used
ideal ratio use internal measure ratio, can be used for real time streaming audio
ideal ratio use manual configure ratio, can be used for the non-real time streaming audio
◆ _asrc_sign_extension
sign extension
no sign extension
kASRC_SignExtension
sign extension
◆ ASRC_Deinit()
void ASRC_Deinit ( ASRC_Type base)
This API gates the ASRC clock and disable ASRC module. The ASRC module can't operate unless ASRC_Init
Parameters
baseASRC base pointer.
brief De-initializes the ASRC peripheral.
param base ASRC base pointer.
◆ ASRC_GetInstance()
uint32_t ASRC_GetInstance ( ASRC_Type base)
Parameters
◆ ASRC_GetOutSamplesSize()
uint32_t ASRC_GetOutSamplesSize ( ASRC_Type base,
Note
This API is depends on the ASRC output configuration, should be called after the ASRC_SetChannelPairConfig.
Parameters
baseasrc base pointer.
channelPairASRC channel pair number.
inSampleRateinput sample rate.
outSampleRateoutput sample rate.
inSamplesizeinput sampleS size.
Return values
outputbuffer size in byte.
brief Get output sample buffer size.
note This API is depends on the ASRC output configuration, should be called after the ASRC_SetChannelPairConfig.
param base asrc base pointer. param channelPair ASRC channel pair number. param inSampleRate input sample rate. param outSampleRate output sample rate. param inSamples input sampleS size. retval output buffer size in byte.
◆ ASRC_GetRemainFifoSamples()
uint32_t ASRC_GetRemainFifoSamples ( ASRC_Type base,
uint32_t *  buffer,
Parameters
bufferinput sample numbers.
outSampleWidthoutput sample width.
remainSamplesoutput sample rate.
Return values
remainsamples number.
brief Get left samples in fifo.
param base asrc base pointer. param channelPair ASRC channel pair number. param buffer input sample numbers. param outSampleWidth output sample width. param remainSamples output sample rate. retval remain samples number.
◆ ASRC_Init()
void ASRC_Init ( ASRC_Type base,
brief Initializes the asrc peripheral.
This API gates the asrc clock. The asrc module can't operate unless ASRC_Init is called to enable the clock.
param base asrc base pointer. param asrcPeripheralClock_Hz peripheral clock of ASRC.
◆ ASRC_MapSamplesWidth()
uint32_t ASRC_MapSamplesWidth ( ASRC_Type base,
uint32_t *  inWidth,
uint32_t *  outWidth
Note
This API is depends on the ASRC configuration, should be called after the ASRC_SetChannelPairConfig.
Parameters
channelPairasrc channel pair index.
inWidthASRC channel pair number.
outWidthinput sample rate.
Return values
inputsample mask value.
brief Map register sample width to real sample width.
note This API is depends on the ASRC configuration, should be called after the ASRC_SetChannelPairConfig. param base asrc base pointer. param channelPair asrc channel pair index. param inWidth ASRC channel pair number. param outWidth input sample rate. retval input sample mask value.
◆ ASRC_SetChannelPairConfig()
status_t ASRC_SetChannelPairConfig ( ASRC_Type base,
asrc_channel_pair_config_t config,
Parameters
channelPairindex of channel pair, reference _asrc_channel_pair.
configASRC channel pair configuration pointer.
inputSampleRateinput audio data sample rate.
outputSampleRateoutput audio data sample rate.
brief ASRC configure channel pair.
param base ASRC base pointer. param channelPair index of channel pair, reference _asrc_channel_pair. param config ASRC channel pair configuration pointer. param inputSampleRate in audio data sample rate. param outSampleRate out audio data sample rate.
◆ ASRC_SetIdealRatioConfig()
status_t ASRC_SetIdealRatioConfig ( ASRC_Type base,
Parameters
channelPairASRC channel pair.
brief ASRC configure ideal ratio. The ideal ratio should be used when input clock source is not avalible.
param base ASRC base pointer. param channelPair ASRC channel pair. param inputSampleRate input audio data sample rate. param outputSampleRate output audio data sample rate.
◆ ASRC_SoftwareReset()
void ASRC_SoftwareReset ( ASRC_Type base)
Do software reset .
This software reset bit is self-clear bit, it will generate a software reset signal inside ASRC. After 9 cycles of the ASRC processing clock, this reset process will stop and this bit will cleared automatically.
Parameters
brief Do software reset .
◆ ASRC_TransferAbortConvert()
void ASRC_TransferAbortConvert ( ASRC_Type base,
asrc_handle_t handle
Note
This API can be called any time when an interrupt non-blocking transfer initiates to abort the transfer early.
Parameters
handlePointer to the asrc_handle_t structure which stores the transfer state.
brief Aborts the current convert.
note This API can be called any time when an interrupt non-blocking transfer initiates to abort the transfer early.
param base asrc base pointer. param handle Pointer to the ASRC_handle_t structure which stores the transfer state.
◆ ASRC_TransferBlocking()
status_t ASRC_TransferBlocking ( ASRC_Type base,
asrc_transfer_t xfer
Note
This API returns immediately after the convert finished.
Parameters
channelPairchannel pair index.
xferPointer to the ASRC_transfer_t structure.
Return values
kStatus_SuccessSuccessfully started the data receive.
brief Performs an blocking convert on asrc.
note This API returns immediately after the convert finished.
param base asrc base pointer. param channelPair channel pair index. param xfer Pointer to the ASRC_transfer_t structure. retval kStatus_Success Successfully started the data receive.
◆ ASRC_TransferCreateHandle()
void ASRC_TransferCreateHandle ( ASRC_Type base,
asrc_handle_t handle,
void *  userData
This function initializes the handle for the ASRC transactional APIs. Call this function once to get the handle initialized.
Parameters
handleASRC handle pointer.
inCallbackPointer to the user callback function.
outCallbackPointer to the user callback function.
userDataUser parameter passed to the callback function
brief Initializes the ASRC handle.
param base ASRC base pointer param handle ASRC handle pointer. param inCallback Pointer to the user callback function. param outCallback Pointer to the user callback function. param userData User parameter passed to the callback function
◆ ASRC_TransferGetConvertedCount()
status_t ASRC_TransferGetConvertedCount ( ASRC_Type base,
size_t *  count
Parameters
countBytes count sent.
Return values
kStatus_SuccessSucceed get the transfer count.
kStatus_ASRCIdleThere is not a non-blocking transaction currently in progress.
brief Gets a set byte count.
param base asrc base pointer. param handle Pointer to the ASRC_handle_t structure which stores the transfer state. param count Bytes count sent. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
◆ ASRC_TransferHandleIRQ()
void ASRC_TransferHandleIRQ ( ASRC_Type base,
Parameters
handlePointer to the asrc_handle_t structure.
brief ASRC convert interrupt handler.
param base asrc base pointer. param handle Pointer to the asrc_handle_t structure.
◆ ASRC_TransferNonBlocking()
status_t ASRC_TransferNonBlocking ( ASRC_Type base,
Note
This API returns immediately after the transfer initiates, application should check the wait and check the callback status.
Parameters
Return values
kStatus_ASRCBusyPrevious receive still not finished.
brief Performs an interrupt non-blocking convert on asrc.
note This API returns immediately after the transfer initiates, application should check the wait and check the callback status.
param base asrc base pointer. param handle Pointer to the asrc_handle_t structure which stores the transfer state. param xfer Pointer to the ASRC_transfer_t structure. retval kStatus_Success Successfully started the data receive. retval kStatus_ASRCBusy Previous receive still not finished.
◆ ASRC_TransferSetChannelPairConfig()
status_t ASRC_TransferSetChannelPairConfig ( ASRC_Type base,
Parameters
handleASRC transactional handle pointer.
param base ASRC base pointer. param handle ASRC transactional handle pointer. param config ASRC channel pair configuration pointer. param inputSampleRate in audio data sample rate. param outputSampleRate out audio data sample rate.
◆ ASRC_TransferTerminateConvert()
void ASRC_TransferTerminateConvert ( ASRC_Type base,
This function will clear all transfer slots buffered in the asrc queue. If users only want to abort the current transfer slot, please call ASRC_TransferAbortConvert.
Parameters
handleASRC eDMA handle pointer.
brief Terminate all asrc convert.
This function will clear all transfer slots buffered in the asrc queue. If users only want to abort the current transfer slot, please call ASRC_TransferAbortSend.
param base asrc base pointer. param handle asrc eDMA handle pointer.
