RTEMS 6.1-rc1
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Modules | |
spec:/score/smp/val/fatal-start-on-not-online-processor | |
Tests a fatal error. | |
Files | |
file | ts-fatal-start-on-not-online-processor.c |
#define | FATAL_SYSINIT_RUN ScoreSmpValFatalStartOnNotOnlineProcessor_Run |
#define | CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body |
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
#define | CONFIGURE_MAXIMUM_PROCESSORS 2 |
const char | rtems_test_name [] = "TestsuitesFatalStartOnNotOnlineProcessor" |
Each test must define a test name string. | |
