RTEMS 6.1-rc1
Files | Data Structures | Functions
spec:/score/thread/val/fatal-idle-thread-stack-too-small
Tests a fatal error caused by a too small idle thread stack size. More...
file  tr-fatal-idle-thread-stack-too-small.c
file  tr-fatal-idle-thread-stack-too-small.h
struct  ScoreThreadValFatalIdleThreadStackTooSmall_Context
 Test context for spec:/score/thread/val/fatal-idle-thread-stack-too-small test case. More...
void ScoreThreadValFatalIdleThreadStackTooSmall_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case. More...
This test case performs the following actions:
◆ ScoreThreadValFatalIdleThreadStackTooSmall_Run()
void ScoreThreadValFatalIdleThreadStackTooSmall_Run ( rtems_fatal_source  source,
Parameters
sourceis the fatal source.
codeis the fatal code.
