RTEMS 6.1-rc1
Files | Data Structures | Functions | Variables
Tests four fatal errors. More...
file  tr-fatal-smp.c
file  tr-fatal-smp.h
struct  ScoreSmpValFatal_Context
 Test context for spec:/score/smp/val/fatal test case. More...
 RTEMS_SYSINIT_ITEM (TriggerTestCase, RTEMS_SYSINIT_DEVICE_DRIVERS, RTEMS_SYSINIT_ORDER_MIDDLE)
void ScoreSmpValFatal_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case. More...
Per_CPU_Job job
This test case performs the following actions:
◆ ScoreSmpValFatal_Run()
void ScoreSmpValFatal_Run ( rtems_fatal_source  source,
Parameters
sourceis fatal source.
codeis fatal code.
Variable Documentation
◆ job
Per_CPU_Job job
Initial value:
.context = &job_context
