RTEMS 6.1-rc1
STM32H7xx_System_Private_Defines
#define VECT_TAB_OFFSET   0x00000000UL
#define DATA_IN_ExtSRAM
#define DATA_IN_ExtSDRAM
◆ DATA_IN_ExtSDRAM
Uncomment the following line if you need to relocate your vector Table in Internal SRAM.
◆ DATA_IN_ExtSRAM
< Uncomment the following line if you need to use external SRAM or SDRAM mounted on EVAL board as data memory
◆ VECT_TAB_OFFSET [1/6]
< Uncomment the following line if you need to use initialized data in D2 domain SRAM (AHB SRAM)
< Uncomment the following line if you need to relocate your vector Table in Internal SRAM. Vector Table base offset field. This value must be a multiple of 0x200.
◆ VECT_TAB_OFFSET [2/6]
◆ VECT_TAB_OFFSET [3/6]
< Uncomment the following line if you need to use external SDRAM mounted on DISCO board as data memory
◆ VECT_TAB_OFFSET [4/6]
◆ VECT_TAB_OFFSET [5/6]
◆ VECT_TAB_OFFSET [6/6]
< Uncomment the following line if you need to use initialized data in CD domain AHB SRAM
