RTEMS 6.1-rc1
#define __HAL_SMBUS_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SMBUS_STATE_RESET)
 Reset SMBUS handle state. More...
#define __HAL_SMBUS_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__))
 Enable the specified SMBUS interrupts. More...
#define __HAL_SMBUS_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__)))
 Disable the specified SMBUS interrupts. More...
#define __HAL_SMBUS_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)    ((((__HANDLE__)->Instance->CR1 & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET)
 Check whether the specified SMBUS interrupt source is enabled or not. More...
#define SMBUS_FLAG_MASK   (0x0001FFFFU)
 Check whether the specified SMBUS flag is set or not. More...
#define __HAL_SMBUS_GET_FLAG(__HANDLE__, __FLAG__)
#define __HAL_SMBUS_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the SMBUS pending flags which are cleared by writing 1 in a specific bit. More...
#define __HAL_SMBUS_ENABLE(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
 Enable the specified SMBUS peripheral. More...
#define __HAL_SMBUS_DISABLE(__HANDLE__)   (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
 Disable the specified SMBUS peripheral. More...
#define __HAL_SMBUS_GENERATE_NACK(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK))
 Generate a Non-Acknowledge SMBUS peripheral in Slave mode. More...
◆ __HAL_SMBUS_CLEAR_FLAG
#define __HAL_SMBUS_CLEAR_FLAG (   __HANDLE__,
  __FLAG__
Value:
(((__FLAG__) == SMBUS_FLAG_TXE) ? \
((__HANDLE__)->Instance->ISR |= (__FLAG__)) : \
((__HANDLE__)->Instance->ICR = (__FLAG__)))
Parameters
__HANDLE__specifies the SMBUS Handle.
__FLAG__specifies the flag to clear. This parameter can be any combination of the following values:
  • SMBUS_FLAG_TXE Transmit data register empty
  • SMBUS_FLAG_ADDR Address matched (slave mode)
  • SMBUS_FLAG_AF NACK received flag
  • SMBUS_FLAG_STOPF STOP detection flag
  • SMBUS_FLAG_BERR Bus error
  • SMBUS_FLAG_ARLO Arbitration lost
  • SMBUS_FLAG_OVR Overrun/Underrun
  • SMBUS_FLAG_PECERR PEC error in reception
  • SMBUS_FLAG_TIMEOUT Timeout or Tlow detection flag
  • SMBUS_FLAG_ALERT SMBus alert
Return values
None
◆ __HAL_SMBUS_DISABLE
#define __HAL_SMBUS_DISABLE (   __HANDLE__)    (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
Parameters
Return values
None
◆ __HAL_SMBUS_DISABLE_IT
#define __HAL_SMBUS_DISABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the interrupt source to disable. This parameter can be one of the following values:
  • SMBUS_IT_ERRI Errors interrupt enable
  • SMBUS_IT_TCI Transfer complete interrupt enable
  • SMBUS_IT_STOPI STOP detection interrupt enable
  • SMBUS_IT_NACKI NACK received interrupt enable
  • SMBUS_IT_ADDRI Address match interrupt enable
  • SMBUS_IT_RXI RX interrupt enable
  • SMBUS_IT_TXI TX interrupt enable
Return values
None
◆ __HAL_SMBUS_ENABLE
#define __HAL_SMBUS_ENABLE (   __HANDLE__)    (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
Parameters
Return values
None
◆ __HAL_SMBUS_ENABLE_IT
#define __HAL_SMBUS_ENABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the interrupt source to enable. This parameter can be one of the following values:
Return values
None
◆ __HAL_SMBUS_GENERATE_NACK
#define __HAL_SMBUS_GENERATE_NACK (   __HANDLE__)    (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK))
Parameters
Return values
None
◆ __HAL_SMBUS_GET_FLAG
#define __HAL_SMBUS_GET_FLAG (   __HANDLE__,
  __FLAG__
Value:
(((((__HANDLE__)->Instance->ISR) & ((__FLAG__) & SMBUS_FLAG_MASK)) == \
((__FLAG__) & SMBUS_FLAG_MASK)) ? SET : RESET)
@ RESET
Definition: xnandpsu_onfi.h:172
Definition: stm32h7xx_hal_smbus.h:525
◆ __HAL_SMBUS_GET_IT_SOURCE
#define __HAL_SMBUS_GET_IT_SOURCE (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the SMBUS interrupt source to check. This parameter can be one of the following values:
Return values
Thenew state of IT (SET or RESET).
◆ __HAL_SMBUS_RESET_HANDLE_STATE
#define __HAL_SMBUS_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = HAL_SMBUS_STATE_RESET)
Parameters
Return values
None
◆ SMBUS_FLAG_MASK
Parameters
__FLAG__specifies the flag to check. This parameter can be one of the following values:
  • SMBUS_FLAG_TXIS Transmit interrupt status
  • SMBUS_FLAG_RXNE Receive data register not empty
  • SMBUS_FLAG_TC Transfer complete (master mode)
  • SMBUS_FLAG_TCR Transfer complete reload
  • SMBUS_FLAG_BUSY Bus busy
  • SMBUS_FLAG_DIR Transfer direction (slave mode)
Return values
Thenew state of FLAG (SET or RESET).
