RTEMS 6.1-rc1
#define SMARTCARD_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__)
 Report the SMARTCARD clock source. More...
#define IS_SMARTCARD_BAUDRATE(__BAUDRATE__)   ((__BAUDRATE__) < 6250001U)
 Check the Baud rate range. More...
#define IS_SMARTCARD_BLOCKLENGTH(__LENGTH__)   ((__LENGTH__) <= 0xFFU)
 Check the block length range. More...
#define IS_SMARTCARD_TIMEOUT_VALUE(__TIMEOUTVALUE__)   ((__TIMEOUTVALUE__) <= 0xFFFFFFU)
 Check the receiver timeout value. More...
#define IS_SMARTCARD_AUTORETRY_COUNT(__COUNT__)   ((__COUNT__) <= 0x7U)
 Check the SMARTCARD autoretry counter value. More...
#define IS_SMARTCARD_WORD_LENGTH(__LENGTH__)   ((__LENGTH__) == SMARTCARD_WORDLENGTH_9B)
 Ensure that SMARTCARD frame length is valid. More...
#define IS_SMARTCARD_STOPBITS(__STOPBITS__)
 Ensure that SMARTCARD frame number of stop bits is valid. More...
#define IS_SMARTCARD_PARITY(__PARITY__)
 Ensure that SMARTCARD frame parity is valid. More...
#define IS_SMARTCARD_MODE(__MODE__)   ((((__MODE__) & 0xFFF3U) == 0x00U) && ((__MODE__) != 0x00U))
 Ensure that SMARTCARD communication mode is valid. More...
#define IS_SMARTCARD_POLARITY(__CPOL__)
 Ensure that SMARTCARD frame polarity is valid. More...
#define IS_SMARTCARD_PHASE(__CPHA__)   (((__CPHA__) == SMARTCARD_PHASE_1EDGE) || ((__CPHA__) == SMARTCARD_PHASE_2EDGE))
 Ensure that SMARTCARD frame phase is valid. More...
#define IS_SMARTCARD_LASTBIT(__LASTBIT__)
 Ensure that SMARTCARD frame last bit clock pulse setting is valid. More...
#define IS_SMARTCARD_ONE_BIT_SAMPLE(__ONEBIT__)
 Ensure that SMARTCARD frame sampling is valid. More...
#define IS_SMARTCARD_NACK(__NACK__)
 Ensure that SMARTCARD NACK transmission setting is valid. More...
#define IS_SMARTCARD_TIMEOUT(__TIMEOUT__)
 Ensure that SMARTCARD receiver timeout setting is valid. More...
#define IS_SMARTCARD_CLOCKPRESCALER(__CLOCKPRESCALER__)
 Ensure that SMARTCARD clock Prescaler is valid. More...
#define IS_SMARTCARD_ADVFEATURE_INIT(__INIT__)
 Ensure that SMARTCARD advanced features initialization is valid. More...
#define IS_SMARTCARD_ADVFEATURE_TXINV(__TXINV__)
 Ensure that SMARTCARD frame TX inversion setting is valid. More...
#define IS_SMARTCARD_ADVFEATURE_RXINV(__RXINV__)
 Ensure that SMARTCARD frame RX inversion setting is valid. More...
#define IS_SMARTCARD_ADVFEATURE_DATAINV(__DATAINV__)
 Ensure that SMARTCARD frame data inversion setting is valid. More...
#define IS_SMARTCARD_ADVFEATURE_SWAP(__SWAP__)
 Ensure that SMARTCARD frame RX/TX pins swap setting is valid. More...
#define IS_SMARTCARD_OVERRUN(__OVERRUN__)
 Ensure that SMARTCARD frame overrun setting is valid. More...
#define IS_SMARTCARD_ADVFEATURE_DMAONRXERROR(__DMA__)
 Ensure that SMARTCARD DMA enabling or disabling on error setting is valid. More...
#define IS_SMARTCARD_ADVFEATURE_MSBFIRST(__MSBFIRST__)
 Ensure that SMARTCARD frame MSB first setting is valid. More...
#define IS_SMARTCARD_REQUEST_PARAMETER(__PARAM__)
 Ensure that SMARTCARD request parameter is valid. More...
◆ IS_SMARTCARD_ADVFEATURE_DATAINV
#define IS_SMARTCARD_ADVFEATURE_DATAINV (   __DATAINV__)
Value:
(((__DATAINV__) == SMARTCARD_ADVFEATURE_DATAINV_DISABLE) || \
#define SMARTCARD_ADVFEATURE_DATAINV_DISABLE
Definition: stm32h7xx_hal_smartcard.h:512
#define SMARTCARD_ADVFEATURE_DATAINV_ENABLE
Definition: stm32h7xx_hal_smartcard.h:513
Parameters
__DATAINV__SMARTCARD frame data inversion setting.
Return values
SET(DATAINV is valid) or RESET (DATAINV is invalid)
◆ IS_SMARTCARD_ADVFEATURE_DMAONRXERROR
#define IS_SMARTCARD_ADVFEATURE_DMAONRXERROR (   __DMA__)
Value:
#define SMARTCARD_ADVFEATURE_DMA_DISABLEONRXERROR
Definition: stm32h7xx_hal_smartcard.h:543
#define SMARTCARD_ADVFEATURE_DMA_ENABLEONRXERROR
Definition: stm32h7xx_hal_smartcard.h:542
Parameters
__DMA__SMARTCARD DMA enabling or disabling on error setting.
Return values
SET(DMA is valid) or RESET (DMA is invalid)
◆ IS_SMARTCARD_ADVFEATURE_INIT
#define IS_SMARTCARD_ADVFEATURE_INIT (   __INIT__)
Value:
((__INIT__) <= (SMARTCARD_ADVFEATURE_NO_INIT | \
#define SMARTCARD_ADVFEATURE_SWAP_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:63
#define SMARTCARD_ADVFEATURE_NO_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:59
#define SMARTCARD_ADVFEATURE_DMADISABLEONERROR_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:65
#define SMARTCARD_ADVFEATURE_MSBFIRST_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:66
#define SMARTCARD_ADVFEATURE_TXINVERT_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:60
#define SMARTCARD_ADVFEATURE_RXINVERT_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:61
#define SMARTCARD_ADVFEATURE_RXOVERRUNDISABLE_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:64
#define SMARTCARD_ADVFEATURE_DATAINVERT_INIT
Definition: stm32h7xx_hal_smartcard_ex.h:62
Parameters
__INIT__SMARTCARD advanced features initialization.
Return values
SET(INIT is valid) or RESET (INIT is invalid)
◆ IS_SMARTCARD_ADVFEATURE_MSBFIRST
#define IS_SMARTCARD_ADVFEATURE_MSBFIRST (   __MSBFIRST__)
Value:
(((__MSBFIRST__) == SMARTCARD_ADVFEATURE_MSBFIRST_DISABLE) || \
#define SMARTCARD_ADVFEATURE_MSBFIRST_DISABLE
Definition: stm32h7xx_hal_smartcard.h:552
#define SMARTCARD_ADVFEATURE_MSBFIRST_ENABLE
Definition: stm32h7xx_hal_smartcard.h:553
Parameters
__MSBFIRST__SMARTCARD frame MSB first setting.
Return values
SET(MSBFIRST is valid) or RESET (MSBFIRST is invalid)
◆ IS_SMARTCARD_ADVFEATURE_RXINV
#define IS_SMARTCARD_ADVFEATURE_RXINV (   __RXINV__)
Value:
(((__RXINV__) == SMARTCARD_ADVFEATURE_RXINV_DISABLE) || \
#define SMARTCARD_ADVFEATURE_RXINV_DISABLE
Definition: stm32h7xx_hal_smartcard.h:502
#define SMARTCARD_ADVFEATURE_RXINV_ENABLE
Definition: stm32h7xx_hal_smartcard.h:503
Parameters
__RXINV__SMARTCARD frame RX inversion setting.
Return values
SET(RXINV is valid) or RESET (RXINV is invalid)
◆ IS_SMARTCARD_ADVFEATURE_SWAP
#define IS_SMARTCARD_ADVFEATURE_SWAP (   __SWAP__)
Value:
(((__SWAP__) == SMARTCARD_ADVFEATURE_SWAP_DISABLE) || \
#define SMARTCARD_ADVFEATURE_SWAP_ENABLE
Definition: stm32h7xx_hal_smartcard.h:523
#define SMARTCARD_ADVFEATURE_SWAP_DISABLE
Definition: stm32h7xx_hal_smartcard.h:522
Parameters
__SWAP__SMARTCARD frame RX/TX pins swap setting.
Return values
SET(SWAP is valid) or RESET (SWAP is invalid)
◆ IS_SMARTCARD_ADVFEATURE_TXINV
#define IS_SMARTCARD_ADVFEATURE_TXINV (   __TXINV__)
Value:
(((__TXINV__) == SMARTCARD_ADVFEATURE_TXINV_DISABLE) || \
#define SMARTCARD_ADVFEATURE_TXINV_ENABLE
Definition: stm32h7xx_hal_smartcard.h:493
#define SMARTCARD_ADVFEATURE_TXINV_DISABLE
Definition: stm32h7xx_hal_smartcard.h:492
Parameters
__TXINV__SMARTCARD frame TX inversion setting.
Return values
SET(TXINV is valid) or RESET (TXINV is invalid)
◆ IS_SMARTCARD_AUTORETRY_COUNT
#define IS_SMARTCARD_AUTORETRY_COUNT (   __COUNT__)    ((__COUNT__) <= 0x7U)
Note
The maximum number of retransmissions is 0x7.
Parameters
__COUNT__number of retransmissions.
Return values
Testresult (TRUE or FALSE)
◆ IS_SMARTCARD_BAUDRATE
#define IS_SMARTCARD_BAUDRATE (   __BAUDRATE__)    ((__BAUDRATE__) < 6250001U)
Note
The maximum Baud Rate is derived from the maximum clock on H7 (100 MHz) divided by the oversampling used on the SMARTCARD (i.e. 16).
Parameters
__BAUDRATE__Baud rate set by the configuration function.
Return values
◆ IS_SMARTCARD_BLOCKLENGTH
#define IS_SMARTCARD_BLOCKLENGTH (   __LENGTH__)    ((__LENGTH__) <= 0xFFU)
Note
The maximum SMARTCARD block length is 0xFF.
Parameters
__LENGTH__block length.
Return values
◆ IS_SMARTCARD_CLOCKPRESCALER
#define IS_SMARTCARD_CLOCKPRESCALER (   __CLOCKPRESCALER__)
Value:
(((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV1) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV2) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV4) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV6) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV8) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV10) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV12) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV16) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV32) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV64) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV128) || \
((__CLOCKPRESCALER__) == SMARTCARD_PRESCALER_DIV256))
#define SMARTCARD_PRESCALER_DIV64
Definition: stm32h7xx_hal_smartcard.h:481
#define SMARTCARD_PRESCALER_DIV4
Definition: stm32h7xx_hal_smartcard.h:474
#define SMARTCARD_PRESCALER_DIV2
Definition: stm32h7xx_hal_smartcard.h:473
#define SMARTCARD_PRESCALER_DIV10
Definition: stm32h7xx_hal_smartcard.h:477
Definition: stm32h7xx_hal_smartcard.h:472
#define SMARTCARD_PRESCALER_DIV256
Definition: stm32h7xx_hal_smartcard.h:483
Definition: stm32h7xx_hal_smartcard.h:475
#define SMARTCARD_PRESCALER_DIV128
Definition: stm32h7xx_hal_smartcard.h:482
#define SMARTCARD_PRESCALER_DIV16
Definition: stm32h7xx_hal_smartcard.h:479
#define SMARTCARD_PRESCALER_DIV32
Definition: stm32h7xx_hal_smartcard.h:480
#define SMARTCARD_PRESCALER_DIV8
Definition: stm32h7xx_hal_smartcard.h:476
Definition: stm32h7xx_hal_smartcard.h:478
Parameters
__CLOCKPRESCALER__SMARTCARD clock Prescaler value.
Return values
SET(CLOCKPRESCALER is valid) or RESET (CLOCKPRESCALER is invalid)
◆ IS_SMARTCARD_LASTBIT
#define IS_SMARTCARD_LASTBIT (   __LASTBIT__)
Value:
(((__LASTBIT__) == SMARTCARD_LASTBIT_DISABLE) || \
((__LASTBIT__) == SMARTCARD_LASTBIT_ENABLE))
#define SMARTCARD_LASTBIT_ENABLE
Definition: stm32h7xx_hal_smartcard.h:433
#define SMARTCARD_LASTBIT_DISABLE
Definition: stm32h7xx_hal_smartcard.h:432
Parameters
__LASTBIT__SMARTCARD frame last bit clock pulse setting.
Return values
SET(LASTBIT is valid) or RESET (LASTBIT is invalid)
◆ IS_SMARTCARD_MODE
#define IS_SMARTCARD_MODE (   __MODE__)    ((((__MODE__) & 0xFFF3U) == 0x00U) && ((__MODE__) != 0x00U))
Parameters
__MODE__SMARTCARD communication mode.
Return values
SET(MODE is valid) or RESET (MODE is invalid)
◆ IS_SMARTCARD_NACK
#define IS_SMARTCARD_NACK (   __NACK__)
Value:
(((__NACK__) == SMARTCARD_NACK_ENABLE) || \
((__NACK__) == SMARTCARD_NACK_DISABLE))
#define SMARTCARD_NACK_DISABLE
Definition: stm32h7xx_hal_smartcard.h:452
#define SMARTCARD_NACK_ENABLE
Definition: stm32h7xx_hal_smartcard.h:453
Parameters
__NACK__SMARTCARD NACK transmission setting.
Return values
SET(NACK is valid) or RESET (NACK is invalid)
◆ IS_SMARTCARD_ONE_BIT_SAMPLE
#define IS_SMARTCARD_ONE_BIT_SAMPLE (   __ONEBIT__)
Value:
(((__ONEBIT__) == SMARTCARD_ONE_BIT_SAMPLE_DISABLE) || \
#define SMARTCARD_ONE_BIT_SAMPLE_ENABLE
Definition: stm32h7xx_hal_smartcard.h:443
#define SMARTCARD_ONE_BIT_SAMPLE_DISABLE
Definition: stm32h7xx_hal_smartcard.h:442
Parameters
__ONEBIT__SMARTCARD frame sampling.
Return values
SET(ONEBIT is valid) or RESET (ONEBIT is invalid)
◆ IS_SMARTCARD_OVERRUN
#define IS_SMARTCARD_OVERRUN (   __OVERRUN__)
Value:
(((__OVERRUN__) == SMARTCARD_ADVFEATURE_OVERRUN_ENABLE) || \
#define SMARTCARD_ADVFEATURE_OVERRUN_ENABLE
Definition: stm32h7xx_hal_smartcard.h:532
#define SMARTCARD_ADVFEATURE_OVERRUN_DISABLE
Definition: stm32h7xx_hal_smartcard.h:533
Parameters
__OVERRUN__SMARTCARD frame overrun setting.
Return values
SET(OVERRUN is valid) or RESET (OVERRUN is invalid)
◆ IS_SMARTCARD_PARITY
#define IS_SMARTCARD_PARITY (   __PARITY__)
Value:
(((__PARITY__) == SMARTCARD_PARITY_EVEN) || \
((__PARITY__) == SMARTCARD_PARITY_ODD))
#define SMARTCARD_PARITY_EVEN
Definition: stm32h7xx_hal_smartcard.h:391
#define SMARTCARD_PARITY_ODD
Definition: stm32h7xx_hal_smartcard.h:392
Parameters
__PARITY__SMARTCARD frame parity.
Return values
SET(PARITY is valid) or RESET (PARITY is invalid)
◆ IS_SMARTCARD_PHASE
#define IS_SMARTCARD_PHASE (   __CPHA__)    (((__CPHA__) == SMARTCARD_PHASE_1EDGE) || ((__CPHA__) == SMARTCARD_PHASE_2EDGE))
Parameters
__CPHA__SMARTCARD frame phase.
Return values
SET(CPHA is valid) or RESET (CPHA is invalid)
◆ IS_SMARTCARD_POLARITY
#define IS_SMARTCARD_POLARITY (   __CPOL__)
Value:
(((__CPOL__) == SMARTCARD_POLARITY_LOW)\
|| ((__CPOL__) == SMARTCARD_POLARITY_HIGH))
#define SMARTCARD_POLARITY_LOW
Definition: stm32h7xx_hal_smartcard.h:412
#define SMARTCARD_POLARITY_HIGH
Definition: stm32h7xx_hal_smartcard.h:413
Parameters
__CPOL__SMARTCARD frame polarity.
Return values
SET(CPOL is valid) or RESET (CPOL is invalid)
◆ IS_SMARTCARD_REQUEST_PARAMETER
#define IS_SMARTCARD_REQUEST_PARAMETER (   __PARAM__)
Value:
(((__PARAM__) == SMARTCARD_RXDATA_FLUSH_REQUEST) || \
#define SMARTCARD_RXDATA_FLUSH_REQUEST
Definition: stm32h7xx_hal_smartcard.h:562
#define SMARTCARD_TXDATA_FLUSH_REQUEST
Definition: stm32h7xx_hal_smartcard.h:563
Parameters
__PARAM__SMARTCARD request parameter.
Return values
SET(PARAM is valid) or RESET (PARAM is invalid)
◆ IS_SMARTCARD_STOPBITS
#define IS_SMARTCARD_STOPBITS (   __STOPBITS__)
Value:
(((__STOPBITS__) == SMARTCARD_STOPBITS_0_5) ||\
((__STOPBITS__) == SMARTCARD_STOPBITS_1_5))
#define SMARTCARD_STOPBITS_1_5
Definition: stm32h7xx_hal_smartcard.h:382
#define SMARTCARD_STOPBITS_0_5
Definition: stm32h7xx_hal_smartcard.h:381
Parameters
__STOPBITS__SMARTCARD frame number of stop bits.
Return values
SET(STOPBITS is valid) or RESET (STOPBITS is invalid)
◆ IS_SMARTCARD_TIMEOUT
#define IS_SMARTCARD_TIMEOUT (   __TIMEOUT__)
Value:
(((__TIMEOUT__) == SMARTCARD_TIMEOUT_DISABLE) || \
((__TIMEOUT__) == SMARTCARD_TIMEOUT_ENABLE))
#define SMARTCARD_TIMEOUT_DISABLE
Definition: stm32h7xx_hal_smartcard.h:462
#define SMARTCARD_TIMEOUT_ENABLE
Definition: stm32h7xx_hal_smartcard.h:463
Parameters
__TIMEOUT__SMARTCARD receiver timeout setting.
Return values
SET(TIMEOUT is valid) or RESET (TIMEOUT is invalid)
◆ IS_SMARTCARD_TIMEOUT_VALUE
#define IS_SMARTCARD_TIMEOUT_VALUE (   __TIMEOUTVALUE__)    ((__TIMEOUTVALUE__) <= 0xFFFFFFU)
Note
The maximum SMARTCARD receiver timeout value is 0xFFFFFF.
Parameters
__TIMEOUTVALUE__receiver timeout value.
Return values
◆ IS_SMARTCARD_WORD_LENGTH
#define IS_SMARTCARD_WORD_LENGTH (   __LENGTH__)    ((__LENGTH__) == SMARTCARD_WORDLENGTH_9B)
Parameters
__LENGTH__SMARTCARD frame length.
Return values
SET(LENGTH is valid) or RESET (LENGTH is invalid)
◆ SMARTCARD_GETCLOCKSOURCE
#define SMARTCARD_GETCLOCKSOURCE (   __HANDLE__,
  __CLOCKSOURCE__
Parameters
__HANDLE__specifies the SMARTCARD Handle.
__CLOCKSOURCE__output variable.
Return values
theSMARTCARD clocking source, written in CLOCKSOURCE.
